View Full Version : Grand Prix
- Regular versus premium Fuel
- 1995 Pont Grand AM Pwr DR LK
- 98GT drop in replacement
- 95 GP strut bearing plate replacement
- GTP Fuel Pump Flow/Specs??
- fuel injector cleaner
- heads up race
- How to replace front control arm bushing?
- W/B: lower intake manifold
- MPG's
- Will 245 50's in front work with 225 60's out back?
- shifting problem when stopping
- Headlights and A/C on the SAME circuit??
- Just Bought a 2005 GTP
- Wheels--HELP!
- Strange things happening 97 Grand Prix GT
- Brake Problems
- Just got a 98 GTP, and...
- 97 AC/Heater not working on 1-2
- Fog lights question
- 1999 grand prix
- clutch
- radio lock 1998 grand prix gt
- Any ideas?
- Have of you heard of such?
- Front Rotor
- Speedo and Tach pegged all the way...
- F/S: '99 Grand Prix GT NE Illinois
- Motor Oil----fyi----
- Need help with 2004 Grand Prix stalling
- 94 GTP 3.4L Value?
- 1993 pontaic grand prix
- 2005 Grand Prix Oil Filter Location?
- is a pulley puller really necessary?
- hud wiring
- Smoother Idle Wanted ... and less lights
- 2 nd gear start
- Need help changing rear speakers in a 98 GT
- 4T65E Question
- FS or TRADE: 2000 Grand Prix GTP alabama
- Front End Vibration 1997 Grand Prix
- Shocked Mustang Owner
- Interior Window/upholstery fastener
- Brakes are Spongey With Exccess Travel
- Need fast answer about wheels
- The Rights of Automotive Hobbyists - NO MORE UNLAWFUL VEHICLE INSPECTIONS -petition-
- Fuel filter location 90 Grand Prix
- no a/c in 2000 gt
- 93 Gtp Fuel Pump Problems Plz Help
- Fog lamps
- K&N filter causing SES light?
- Replacement part
- L67 in 89 prix
- abs and track light comes on
- better aftermarket 3.1L intk manif gasket?
- Stock amplifier draining battery
- Flush, Change Fluid & Filter, or both?
- Trans Fluid & Filter
- Need help with thermostat....
- oil pressure specs for a 96 grand prix
- Pontiac or GP Logo Seat Covers
- Headlights on the 2004 GP Please Help!!!!!!!
- Ignition and/or Starter Safety
- spare tire part
- road noise...
- Tune-up
- 99 Grandprix - Car jurks Trac light goes off and tach quits working
- starter probs
- idling problems
- emblem
- possible lifter problem?
- electrical problems
- Oil on the Drive way...remove?
- 1990 Pontiac GP idle problem
- To many miles?
- Oil Leaking
- 95 GP - Dashboard lights - No Start
- 1997 Pontiac Grand Prix Jam Nut
- CAI? Warranty
- Installing a new radio in a 2004??????
- 2000 se No 4th gear or TCC lockup
- what problems with 3.1L cars?
- Keyless entry
- Need new struts. I have questions
- 02 Grand Prix GT Troubles
- rear end sitting low
- supercharger pulley question
- Power Steering pump removal-98 GT
- What should i use to remove the wire plugs?
- relocating pcm
- 2001 GTP mods
- 97 Grand Prix GTP cuts off/shopped 4x
- Grand Prix lambo door kit
- Your second choice?
- turbo charge my Grand Prix?
- renew dexcool or go green @ 48k mi.
- Spoiler question
- Steering hard/Clicking while turning
- Fuel gauge pegged full after fill up
- 1995 Grand Prix throttle cable
- Need Stock Stereo......
- Hub assembly
- fuel pump
- Alternator going bad?
- Shifter stick
- 2004 gt1 AC problems after alarm/stereo install
- Wipers park straight up
- No Start Diagnosis HELP!
- 2001 gtp - is keyless entry standard option?
- Head Gasket
- VSS check and replacement
- manual transmission for a 1996 Grand Prix
- CD Player Fix?
- Radio in 97 SE and A/C problem
- Fans
- Anyone Know About Upgrades For A 2004 Gt????
- Battery
- Battery
- Going to attempt to replace CPS
- Flashing PCM
- supercharger pully?
- Vibrations while turning
- 2004 Grand Prix Radio
- Good mechs
- car won't start
- the squeaking is driving me crazy
- Engine fans
- Air Conditioner
- 91 grand prix brake repair
- HELP !! HELP !!! AC/ blower control module
- 3.4 not running right
- Right signal not working
- Temperature sensor question
- Muffler Question
- 98 grand prix gt uses excessive fuel
- will a GTP engine work without the supercharger?
- How do you check Injectors?
- DIY Test for Clogged CAT Convertor & Backpressure
- 96 grand prix no a/c
- Changing Supercharger oil, Best Way?
- 91 grand prix problem
- AC Power module
- Loose Tilt and Turn Signals
- HELP needed: 1991 grand prix odometer/fuel light problem
- No A/C in 2000 GT
- 1997 Grand Prix Condenser Replacement
- How well does a 97 Grand Prix GTP hold up?
- Startup Issues
- High performance neon fan filters?
- K & N High Intake Kit
- 5.7L engine in a 1998 grand prix?????
- Fuel Filter nut stuck. replace fuel line?
- engine misfire
- air conditioning questions?
- G8!?
- The 2005 GP GXP????
- Stock S/C pulley 1997 regal GS
- thordall sensor
- 1997 Regal GS S/C belt snapped, ok to drive w/o it?
- 95 keyless remote
- interior lights dont work
- Trouble shifting while on the accelerator
- What do you think of this deal?
- '95 GP electric cooling fan
- Electrical Problem
- Feels like...A Fishtail!?!?
- K&N Breather?
- trouble with shifter
- Radiator
- Fuel Pump resistor
- 2002 GP SE - Won't Start Periodically.
- Blower Fan and Head Lamps
- location of pcv valve on 1988 grand prix
- 60K service check for GP GT 2001
- Idling problem w/ 1988 Grand Prix
- Shifting Problem
- GP gt 2001 transmission?
- WTB: supercharger and underdrive pulley
- WTB: 2004 grand prix OEM bumper
- superchrge lumina?
- new plugs
- k&N filter problems!!!!!!!!!!!!
- Are the Autometer C2 guages considered illegal?
- Online FSM?
- p0102 code
- Indentified Clunking Noise!
- 98 gtp tranny problems???
- running to rich
- 92? engine in 94 GP LE -- running problems
- Whining Noise at Low Speed
- newbie help grand prix gt
- backfire?
- front strut removal...easy?
- 89 Grand Prix Stalling
- PO131 code
- S/C Pully, Smaller is better?http://www.automotiveforums.com/vbulletin/images/icons/i
- fuel system
- Charging the Battery on a 92 GP
- is this normal?
- service engine light comes on and hard jerking shift
- car keeps dying!
- Urgent! Need Help. Pic Provided
- Speakers in 92 GP
- Factory Alarm Will Not Work When Too Hot
- Grand Prix GTP information computer QUIT!!
- whats it do?
- Exhaust.. AGAIN
- How to improve handling?
- case learn
- 92 GP seats in a cutlass?
- 2003 grand prix p0300
- Hud
- whats it do?
- U-Bent Delete, does it actually do anything?
- shift out of park
- 2000 Grand Prix rear speakers
- A Clunking Noise when I hit a bump
- Twilight Sensor
- Dynomax Super Turbo's rotting out?
- 98 Grand Prix GT question
- Exhaust on GTP
- Overheating
- Steering, Left turn hesitation????please help
- Trans Ground
- downpipe
- Ceased caliper?
- My GT lacks power and there is an odd smell...please help!
- Transmission Shutter Starting out
- 91 grand prix cooling fans only work when a/c is on
- who is moderator, enthusiast, regular or newbie
- HVAC Panel Change
- D.i.c.
- Door not latching
- Womp, Womp, Womp sound
- 1992 Grand Prix Ignition Probs
- oil pressure guage
- 1991 grand prix cruise and a/c problem
- more trouble with my 95 gp
- 95 gp window motor
- Aftermarket Wheels
- pre-gen GP's...any of'em? (88-96) long post, lots of pics
- Clunking noise sway bar?
- 98 GTP Dual-Climate A/C Issue
- Overheating
- gtps vs mustang gt's and camaros
- Hesitates to start...
- Tranmission 97 GTP
- Best exhaust
- Egr Valve
