Pontiac
> Grand Prix
View Full Version :
Grand Prix
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
Grand Prix Overheats & Service Engine Light is on
1990 Gran Prix
98 Pontiac Idle Pulley
2000 GP GT audio information required....
99GTP yet antoher prob
1991 pontiac grand prix stalls and dies
Did my 1994 Grand Prix come with keyless entry and other questions.
Have CAI, whats next???
dash removal
Info display dimming
Jerky Acceleration of 98 Grand Prix SE
keyless entry installation
Exhaust Mods...HP Gain?
95 Steering Column Replacement
Replacing stock Driving lights
Supercharger Pulley
GTP Daytonas?
Remote Entry Receiver / Transmitter
Lowering effects???
Misfire
power windows
need repair manual
2001 Grand prix gt coolant fan stays on all the time
Throttle Body Screen
Cold Start Whistle GTP
speaker amp
Performance Shift?
Question about a mod
squealing steering pump
Help which is cylinder 1
Whining noise between motor & firewall
97 GTP electrical and other problems
New GTP. DIES OUT????
02 GP Remote Auto Trunk Opening?
service engine light
Suspension Upgrade
Need Advice on Air temp sensor location on CIA
Sacralige!!!
Governor
Flexpipeleak??$$$$??dealeronly
GaugeCluster
Bonneville faster than a GP GT?
Water leak in trunk door
Radio swap
What Kind Of Modification does it take to swap a L67 into a 95 GTP
02 3.1 se o2 sensor
Small coolant puddles.
lug nut key
scratch engine #2
Radio and climate control lighting issue
94 3.1 GP, Radiator Fans Not Working
spark plugs removal
225/60-16 vs 225/50-16
Shifter problem, water in passenger floor
Cold Problems with My Grand Prix
drive belt routing-99 gtp
Weird jumping when going from a stop!
99GTP another problem
Sway Bar Bracket/Links on a 92 GP LE
2004 cloudy headlights
another wiper problem...
Removing front inside door panel
Low coolant light
Power seat track question
racing
running lights on 1992 grand prix?
headers vs. ported exhaust manifolds
3" exhaust flange
need help with kr issue
What can i upgrade to increase HP on a 95 GTP???
2003 Pontiac GT Questions (Tires and Interior)
steering wheel clicking....99 gp se
Transmission overdrive
97 GTP cutting off
A Misfire maybe?
Drive Train Warranty
SE and GT front end differences
shifting feels wrong
Anyone Know Where To Buy a Supercharger Pulley Kit For 95 GTP???
help...
engine oil advice needed
Crunching noise???
tranny
Fatigued Lateral Arms
aluminum engine parts cleaning?
1991 Grand Prix Speed Sensor Location
91 Grand Prix 3.1 stalled
97 GTP running ruff
Washer under axle nut??
anyone have a OEM rim for sale?
Low coolant light on!
97 GTP problems
100 octane....Whats the big deal?/
Throttle body spacer?
Best Spark Plugs?
Interior mod questions
Host of Questions
cd player aftermarket??bose
Converting headlights
Fuse box layout
turboing a 98 grand prix
Squeaky Doors
Temp Gauge Confusion
ipod/mp3 adapter?
Rear defrost doesn't work
tranny
00 GT Lunging/bogging after shift
98 gtp times??
box size
MAP sensor or PCV valve buzzing whining
One more question on the heater hose
TCC Plug on GTGP2000
New wheel hub, car shakeing
91 GP LE engine swap now it won't start
Morning Starts
Front Hub assembly and CV/Halfshaft
98 gtp
GTP gas door
what is the U-Bend delete i keep seeing?
K&N 63 Series Air Charger High-Flow Intake Kit
rear view mirror
2000 grand prix wiring diagram
1996 Pont Gran Prix
3800 Rip
1999 GP GT coupe dies 2 times in two month after purchase
1988 Grand Prix Alternator
Heat/defrost not working!
Brakes not braking well!!!
Grand Prix Won't Stay Running To Drive
Is the GTP the only GP with a supercharged 3.8?
HELP '91 GTP 3.4L Still won't start
Resetting a Misfire (P0301) code?
94 GP coolant capacity
petrol
Crunching noise???
fan doesn't work
New brake problems - help
'91 GTP 3.4L 187k Won't start
98 gtp exhaust system
What do you think??
3.1 overheating
02 gp gt worth trade
What Mods With $$$
Help99gtp
99GTP1/2 throttleSteeringWheelShake&DoesntGoNewhere
MAF or VAF circuit low input, p0102
How to Reattach Trunk Torsion Bar?
98 Gtp
Wheel bearing/hub.....one question
Oil Pressure Guage Question:
CAI... Which one is best?
Aftermarket guages
Park/Curb Sensor Install? HELP!
92 gp aftermarket tach
3.1 motor surge
tranny code
What`s it worth
Bolts on for Perf and MPG (00 GT)
Noise From Dashboard...Very Puzzled!!!!
Grand Prix GT (2000) loss of engine power
Wheel bearing replacement on 99 gtp...please help
grnd prix Transmssn shifting very hard
problem with 97 gp, mass air flow??
Dummy for install. Remote Starter??
air bag question
I added more info to the 7mpg thread, help appreciated
Outside temperature sensor
Supercharger "whine" question...
water in passenger floorboard
Fast and the Furious
Oxygen sensor removal
2004 Grand Prix getting 7 to 13 mpg in city?? HELP PLEASE
info on 98 99 gtp
Oil Pan Gasket
Speakers
93 Grand Prix SE A/C Compressor
no power after shut off
Engine Frozen or Does not turn
Window
97 grand prix GT vs. 99 jetta 4cyl turbo
Looking for a part number
problem W/recharging the a/c
Power Steering Pulley Issue
Audio Problems on 01'
Signs of wheel brearing going out in a gtp??
250hp Audi TT vs stock 99 GTP
Auto.Sunroof Modification
96 GP SE Trans Problem
Buying advice 97 GTP
How well does the GTP run on 10% ethanol
99 GTP Quits
Fuel Pump Question!
Windshield Wipers Just Stop
grandprix problem
ok, I feel retarded but.....
98 GT What size factory speakers?
remote door lock problem,95 pontiac grand pre se
What head gasket is best for 95 3.1
COMPUTER on DASH
Code P0304
CD Changer 99 GTP
s/c pulley leak
Low Tire Light = Expensive Rims!
Windows wont move
SOS - Need firing order ASAP!!
door switches
Two Things
Fuel Pressure Regulator replacement!
Excessive RPM drop on 3-4 shift.
Pontiac Grand Prix 2003 Purchase
questions about wiring harness
First Stage of Mods
Nitrous with 3800 S/C?
BlazerTech 3200 Driving Lights
tensioner pulley
Who's got the fastest GTP?
changing the SC pulley
Help Installing A Factory Tach In '63 Grand Prix
Throttel Bodies
Is it possible???
strong crankcase vacuum?
Noobie Needs Help on 99 gtp
A/f
Wheel Hub & ABS question???
Air Fuel
92 Grand Prix LE Thermostat Problem
Power Steering pump replacement
Guage Displays
Emergency Brake
2003 wont start
front door panels??????
Low Coolant Sensor Help
'97 Grand Prix GTP for sale
1995 Grand Prix GTP tail light question
Help installing boost Gauge
Coupler from Rollin Performance??
air conditioner smell
engine coolant
Pontiac Grand Prix
fuel tank sensor
heater blower squeak
Reset Oil change light help??
First warranty claim experince
Car Insurance
Grand Prix GT-windshield leak
low fuel light and check guages light
Keyless Entry Remote
Changed Fuel pump relay not working?
