View Full Version : Grand Prix
- Steering Problem 2001 grand prix GT
- No fan..
- SES Code: P0140 Front or Rear O2?
- 1988 Grand Prix Idoling problems
- 94 grand prix se trans problems...
- what symptoms call for trans fluid flush?
- 2000 GP Starts, but stops seconds later?
- nuclear grandprix
- 2004 Grand Prix GTP
- delco remote cd player problem
- Is my Water Pump bad?
- LCD Radio Display Still Not Working
- Heat problems
- aftermarket parts for a 95 gp
- Upgraded PCM question
- Programming 2002 Grand Prix Keyless remotes
- armrest lid
- Turbo 3.1...
- 91 3.4 starting problems
- 3800 S/C Motor and trans--Dream Setup?
- Does anyone have?
- Quarter Mile Time of Stock GP GT
- Whining Sound when turning
- relay?....for heater motor
- Climate control causing windows to fog
- Lifter Replacement
- where to get a rim
- Grand Prix MPG/RPM
- '99 Grand Prix - BIG audio problem
- pulsing/surging problem
- For Sale! 18" mille miglia evo rims/yokohama z rated tires
- Headlights - Replacement Bulb Suggestions
- Rebuild kit?
- low coolant indicator
- '91 Gtp 3.4 Still Won't Start...help!!!!!
- Stereo Problems - '02 GP GT
- Headlights
- heating system malfunctioning
- can anyone help me
- headlamp and fog light reconditioning?
- bleeding brakes
- Audio Help Needed
- found a gtp for sale
- intermitten starting problems gtp
- 04 GTP Temp Gauge
- 99 grand prix
- supercharger help
- New Intercooler
- ABS and traction off lights on together
- heater motor plug
- Overheating Problem
- engine misfire
- Alignment?
- 98 GP wont start
- '96 Grand Prix 3.4 Alternator Replacement
- shocks on 97 grand prix gt hard??
- Tranny pan gasket
- Head gasket fix
- 97 grand prix se- trans problem
- ? about 01 GP GT
- tranny making a ruckus
- defrost foggin up
- 180 Thermostat
- HEATER a/c / LIGHT PROBLEM
- 97 GT 3.8 Engine Locked Up???
- 95 GP 3.1L stumble
- Happy Thanksgiving!
- hud?
- Video System
- 97 3.1 engine clatter on cold mornings start
- passenger seat heater switch
- spindle nut
- suspension or alignment?
- HVAC Control Head
- 2000 GTP dash electrical issue.
- Who woulda thunk?
- Vdeo of ZZP/Stattama Grand Prix Smoking a Viper
- Blazer3200 driving lights for Grand Prix
- Not heat and its 17 degrees outside!
- Grinding Sound from under the hood!!
- Replacing a headlight in a '92 GP SE...?
- Foglight bulbs
- Disabling Supercharger
- 98 GT running cool
- Pour Gas Milage
- Pour Gas Milage
- stuck on defrost
- upper strut bar
- my trip to the pontiac dealership
- 99 Grand Prix GT DIC Problem
- 2000 Grand Prix SE Slow Leak
- Help in Canada
- Locked out of deceased father's glove box
- Back door driver side lock only works manually
- 2001 gt or gtp?
- Help asap
- A1 Cardone Shut down!
- car is surging
- transmission question 91 grand prix se
- 94 grand prix window motor replacement
- New User
- '95 E Brake Cable
- '95 GP Fuel odor
- 1998 Grand Prix SE 3.1L
- setting 5 doesn't work
- 2000 GP making creaking noise
- 1994 grand prix trunk clicking & opening
- 2000 pontiac grand prix door panels
- Onstar Antenna
- 04 GT in snow question
- Supercharger Oil?
- coil pack 1+4 random missfire
- Looking for this place in GA...
- problem removing the rear speakers
- Hello Everyone
- Possible Engine Misfire
- front stabilizer bar
- Climate control becomes unresponsive
- 1990 Grand Prix Problems!!!!
- 2000 GP GTP Electrical problems
- half shaft spline is loose in trans
- Winter Gas
- '04 Child Locks
- removing door panel
- How to get Fog Lights to stay on with High Beams???
- Rear End Alignment?
- My old problems
- Interior
- My 97 GP runs for 7 seconds then shuts off.
- Fuse keeps blowing
- First Pontiac
- Help my key doesnt unlock my car!
- 1994 GTP Won't start, help
- passenger air cold, driver is hot, freon is good
- 2004 Compg Pulley Upgrade
- Pioneer Cd Player Fit in 00 GTP
- warning light
- Thinking of buying a GTP, have a few questions...
- I have a DIC Problem
- Exhaust upgrade????
- Change Spoiler
- Brakes HOT?!? CLUNKing noise
- RPM needle doenst work unless hit it
- ? bout headlight bulbs
- Rear Deck Speaker Removal
- 99GTP fixed and all the probs..:-(
- MSD Ignition Coils
- Honest Mechanic recommendations?
- Water leaking in???
- mpg on the DIC
- poor gas mileage 2005 gtp
- 1989 Odometer
- 2001 GP loss of power
- programmer
- 1995 Door Lock Problems...HELP Please
- 95 GP GTP 3.4 how to tell if intake manifold is no good??
- P0742 Torque converter clutch circuit stuck on
- jerky acceleration
- Grand Prix Question Help please
- starter motor screech 3.1L 2001 SE
- Hesitant acceleration
- Bose amplifier specs?
- rear end
- DP question....
- Cowl Removal
- Troubleshooting
- blower problems
- Trunk opening problems solved!
- Brake Lines
- Jonathon Moore?
- 2001 Grand Prix SE starts, then dies in 2-3 seconds
- tune up
- questions...
- Need help restoring interior *Spec. Ed.*
- 2004 Gtp For Sale Cheap Price!!!!!
- top speed
- theft deterrent light
- Different sort of ABS question
- 94 GTP 3.4L rough Idle when cold
- front acceleration vibration
- help replacing rear speakers - 98 GTP
- Gear Selector lights out?
- 97 miss between 45 and 55 mph
- Keyless Entry???
- 89 Grand Prix
- Any tips on replacing broken 1999 cupholder???
- Turbochared done up GP !Sale!
- ABS light in my 95 GTP keeps coming on
- Radio Lights
- vacuum diagram for 1999 gtp?
- 95 Automatic Door Locks
- Cant pump gas?
- **Electrical problem...never seen this before...
- smell when idling
- I smell gasoline
- FoR SaLe: '05 GXP brake set-up
- Lost reverse gear
- Reliability of the GP...
- Pace Car Wheels
- interior lights head lights
- 2600 Rpms to zero!!
- Headlights
- Worthless Question
- Brake pads
- 1997 GT A/C OK but no heat
- gtp engine modifications help
- flickering headlights
- Syphoning Gas
- Cyberwhite driving lights
- Windshield Washer Doesnt work
- help with rim/wheel size, tires, etc.
- 2001 Grand Prix Washer Pump Fuse
- 1997 grand prix..heater motor starts on its own at nite
- Buying a used 2000 GTP...some suggestions please
- Cabin Air Filter
- There is no heat in side my GP
- Fog Lights
- Fuel guage
- metal on metal grinding from belt area
- general question
- U-Bend delete
- painted calipers
- Grand Prix GT Gas Tank / Milage
- Brakes
- Fuel Pump
- digital DIC
- Code questions
- help with my grand prix
- Rear Defroster affects Radio
- Ram air hood
- looking for headers
- 97 Grand Prix - Blower Motor, Temp Gauge, Running Lights, rear defroster Problem
- Car Caught on Fire, any ideas?
- Keeps Stalling 92 Grand Prix
- Left pipe hangs low
- Exhaust Tips on 00 GTP
- Unitized Bearings
- are all intakes created equal?
- spark plug recommendations
- pass side mirror
- 2000 GT Problems
- 92 Le 3.1 127k Please Help!!!!!!!
- change crank pulley
- change crank, pulley
- 90 GP Won't Start. HELP!!!
- intake ?
- dashboards warning sybols
- loud squealing noise w/ climate control
- Interior Lights stay ON!
