View Full Version : Grand Prix
- glove box light
- Knocking when starting the car
- air noise
- Rim cleaner
- NEED HELP!!!! New Plenum
- u-bend delete
- Fan control / running lights.
- Radio problem
- poor fuel economy
- Transmission problem
- Wire..........
- new mods?
- Performance
- Cruising RPM jumps?
- ??performance mods??
- headlights out
- Blower Fan works on setting 3-4-5, but not 1-2
- Another Blower Motor out thread with a twist
- Oil Leak...
- gtp suspension
- Car Stereo Replacement
- instrument cluster lights
- Low Gas Mileage
- need advice
- Heater Stop Working
- Exhaust
- dead car
- Intercooler
- What type of intake for GTP?
- Grand Prix Off-Topic Thread (Closed)
- 2004 GTP Mods?
- Need help quickly - electrical problem?
- keyless remote transmitter and receiver
- Transmission Question
- transmission question
- Keyless remote
- cd changer wiring
- DRL removal
- 2002 Grand Prix SE icm
- spoiler
- No start - 91 GP - please help!
- Getting MAF sensor bad problem...not MAF sensor.
- blower motor out
- Fuel Pressure - 97 GP SE 3.1L
- fuel gauge
- 2001 GA-SE Rotors V6 3.4
- Car Heater Only Work On High
- 2000 gtp missfire, maf sensor?
- leather material around gear shifter
- My heater blower stays on when car is off.
- neutral safety switch
- a "minor" shaking problem
- 94 GTP Running Rich
- 210 too hot???
- gonna shoot my 02 gp gt
- Air Blower /AC/Heater
- 02 GP-GT suspension question
- wipers-1988 grand prix
- Question about Vehicle speed sensor
- Block Heater cord
- 2004 grand prix cd stopped working
- 1994 gp with steering wheel radio controls
- Transmission fluid
- 94 GTP wiper assembly
- Hello All
- Tranny issues (ugh!!!)
- 89 GP idles bad
- making the GTP loud
- 3.4" pulley install
- Upper Plenum Replacement
- u bend delete
- 98 grand prix dies on right hand turns
- Happy New Years!!!!!!!!
- Exhaust systems
- 2001 Grand Prix
- Car dies, then drives rough.
- PCV Valve
- Painting Calipers
- HUB Bearings and Axles Question
- junkyard engine, sluggish
- 2002 Gr. Prix winding noise as I accelerate
- 2001 Grand Prix GT
- 97 Grand Prix Door Chime
- Car misses what might be the problem HELP!
- change hub assembly
- replace or repair supercharger
- Delay shift from park
- Replacement parts, better than OEM
- Spark plugs and wires
- pcv valve ?
- fuel filter
- GP overheats at idle
- adding nitrous oxide to a supercharger
- Adding power to a 3.1 se
- Adding Horsepower!!!
- Rear License Plate BULB Replacement
- Bad Oil Leak 1990
- Air Intake
- Transmission question please help!!!!!!!
- windshield wipers stop in upright postion
- window seals for 84 grand prix
- 95 grand prix gtp 3.4L
- Throttle Position Sensor and Misfire
- Grand Prix crank, but doesn't fire
- 1991 Grand prix 3.1L turbo frying up ECM
- Head Gasket
- turbo too big?
- 92 Grand Prix crank but no start
- Changing SC Pulley on GTP
- GTP or not
- key does not come out
- How do you remove a supercharger on a 98 Pontiac GTP
- 95 GTP Fuses
- DIC on 2000 Grand Prix GTP
- 2001 Grand Prix GT trany Problem
- '91 Overheated and burned coolant
- 03 GTP dies in cold weather
- Is GP GXP friendly for tall drivers??
- my grand prix
- 97 grand prix heater blower troubles
- Headlights
- just was wondering.....
- Coolant
- 98 grand prix se 3.8
- Reverse
- Funny wiper Problems
- supercharger sounds
- 94 Grand Prix overheating
- Gt/se???
- Performance parts for a grand prix gt ???
- amp wireing
- Gt Vs Gtp
- Change Oil Soon Light
- Key stuck, gear-shifter squeaks, issues galore
- problems with heater/blower
- can a stock gt run a 15.0 flat ???
- 91 grand prix blowing alternators
- 98 Grand Prix 3800 sfi engine shuts off
- 90 GP Transmission Problem. No 3rd or 4th!
- rear struts
- antilock brakes
- '95 GP struts
- Parts
- oil flow
- center console computer 93 grandprix
- 97 GP SE with 3800?
- TCS off and Driver Info Center blinks zero...
- 95gtp maf sensor on a 93 3.4
- 91 Grand prix starts up idols fine but put it in gear it dies
- slight steering clunk
- HUD problems
- Car dies
- wipers
- aftermarket cd installation
- 2000 GTP Bizarre Shudder?
- Vacuum Diagram
- o2 sensor and catalytic converter where to buy?
- Emissions Code
- Car won't turn over sometimes
- 3.1 Erratic Temp Gage
- Dash dims fans weaken with no gas
- Car just tuned up why is it actin up?
- 94 GTP Driver Side Window Problem
- intercooler
- rear ended!
- 2002 Pontiac Grand Prix Wiper Problem HELP!!
- how does your gp handle
- lower cfm's when heater on?
- Fuel Gauge not working
- Just replaced O2 sensor, car is now stalling out
- Grand Prix dragging running sluggish til warm
- Fast idle during cold start
- Wrecked Grand Prix Pics
- heads up light
- Keyless Programming 98 GP GTP
- cat efficiency failure code please help?????
- carfax
- rear brakes
- 3.4L DOHC Timing
- Possessed car.
- brake light...
- Please help...the alarm is driving me nuts
- seatbelt wont latch
- P0140 does not seem to be O2
- Major Window Problems
- Windshield Washer Pump
- rim chioce
- Best source for leather seat covers?
- 1994 Grand Prix unable to start
- grand prix 4t60-e
- Changing DIC
- GTP 96, 3.4L IDLE Problem, PLEASE HELP!
- 98 GTP dash fire!! Almost?????
- scared to upgrade
- burning up tranny 2nd one
- Factory Stereo Wiring Diagram
- 2000 Grand Prix
- pcv?
- Looking at an '06 GP
- Fuel Pressure Regulator
- rims leaking air
- Hi beams work Low Beams Don't
- how to disable factory alarm
- need some advise here please
- Grinding Noise in '97 GTP
- 2002 GP Auto Trans Slipping/not shifting
- NEWBIE.... GT to GTP
- 99 grand prix thermostat
- fusebox?
- owners manual
- alternator noise
- dual control heat on passenger side/none on drivers
- Speakers
- Foul Odor from vents
- trunk light
- tech 2 error codes
- Satellite Radio
- supercharger
- Burning Smell
- Need some information.....
- Headlights
- Anyone sold a GP, Xmas- Valentines Day?
- 1993 gp 3.4 sudden coolant leak/smoking
- major coolant leak
- Idle problems with a twist...
- Engine temp
- 94 Gran Prix Cooling Issue
- 94 GTP 3.4 DOHC Wont stay running
- cobra rims on a grand prix??
- Drivers side door hinge replacement
- I have no clue what's going on
- humming noise while driving
- Hellllp plz :((
- bad cat symptoms
- Pontiac Grand Prix GT performance.
- Change Oil Soon Question
- supercharger leak
- Just got an 01 GTP...anything I should look for?
- '91 GTP 3.4 Timing
- Homemade Cold Air Induction
- i bought my gtp today!!!
- blower motor
- when should it stop????
- pcm?
- Engine Swap???
- Thermostats/Spark plugs/ Wires
- radio display
- 2002 Grd Prix Coolant loss question
- supercharger
