View Full Version : Grand Prix
- 99GTP clunking noise back when hit brakes
- Mall Pgm
- 90 LE 3.1 Oil Pressure/Low Fuel
- Ambient Temperature Sensor
- License plate light, after market that lights up all around plate.
- Angel Eyes and stock switch?!
- vaccum test
- Heads up display?
- Top Tier
- Valve springs?
- after market 1997 grand prix SE
- Motor Mount
- Traction Control Problem
- Service engine/SRS airbag/Low oil level lights on????
- 93 gran prix bucking dying
- new struts
- 97 GT - A/C - Warm Air, Refrigerant Full
- idle at 3000 rmp wont drop
- Standard tranmisions for my GP?
- That Oil Burning Issue ( updates )
- L36 rocker pivot bols
- motor swap/differance question
- ABS Light, Trac Off and stalling vehicle
- Oil burning issues?????
- Transmission Questions
- 1994 grand prix steering hose
- back with another GTP
- intake control motor?
- A few questions about 2003 GT...
- Engine Compartment Light 2002 GP 3.8L
- Grand Prix Classifieds!
- torque specs?
- Advice Needed: 2002 GP 3.1L 104k
- Part nUmbers
- I Need MAJOR Advice.....Please!!
- 1976 Grand Prix
- Leak and Burning Smell
- 98 GTP losing fuel pressure
- Easy Firewall Hole
- 97 GTP stumbling, missing at low acceleration
- Adding a HUD
- Anybody in Blacksburg?
- 94 GP SE Hesitating and Stuttering
- Someone Help
- aluminum block?
- Rough Idle - '97 GP 3.1L
- Yokohama's?
- HVAC Fan blower
- my 1987 grand prix, how can i "pimp" it
- neons
- Cabin Air Filter
- Help! Need a part number!
- 91 GPrix won t stay running
- front strut bearings
- 1995 Pontiac Grand Prix HUD
- blower motor fitment
- 2001 GP Overheating
- 95 Grand Prix GTP 3.4L-Intake Job
- 2004 Grand Prix - RPM Guage
- Gas??
- Just Bought 99 GT
- water filtering inside-passanger side
- Acceleration problems w/ 2001 Grand Prix
- Help please!my car is running bad and i know nothing about cars
- Air Conditioning - air cold on psgr vents, warm on driver vents?
- Radio install/removal
- 1998 Daytona 500 Pace Car
- Substantial oil leak among many problems
- Grand Prix & Performance Chips
- What size pipe....???
- ABS, Trac Off Light Keep Coming On
- Exhaust Question
- little extra HP for a n00b
- cd player/changer
- '87 grand prix value
- Anyone in need of engine parts??
- 98 Grand Prix GT-SES Code and some
- gorilla chipz?
- hood advice needed!!
- 97 GTP No headlights at all??? HELP ????
- please help
- Rear hub removal problem
- 2 random questions
- Service Engine On... Transmission?? MAF??
- Cooling fan troubles, starting to get somwhere I think
- Help: '98 GTP Sunroof Problems
- 2000 Grand Prix GT stalling at stop
- changing interior light colors
- O2 Sensor
- Starting Problems
- passenger door
- fuel pump & starter
- Transmission Problem. Diagnosis please?
- steering
- Shifter will not go into Park
- 2000 Grand Prix fuel pump replacement.
- Oil Pan Gasket Replace
- help please??
- need to replace ignition switch
- my 98 grand prix is stalling when it gets hot
- Misc. Interior Light Problems...
- Front valve cover gasket
- Rear Drive Gp Replacement!?
- How to change headlight
- preformance and style
- how do i take a tire off the rim my self
- Iginition trouble 01 grand prix
- I have a Brain Buster Question (Car Related)
- A/C no longer working
- Parking Brake Parts
- Performance upgrades, without voiding the warranty?
- 05 GTP Oil Filter change..w/o the mess?
- 3.1 turbocharged McLaren SE???
- 99 GP GT timing trouble HELP!
- wanting info on GXP
- Steering Colum is Smoking on GP 92 wont start!
- A/C low pressure valve
- so picked up this old 78 grand prix, hmm
- bad head gasket
- 2004 GP Emissions/Street Legal Air Intake in NY!?
- 1994 grand prix tranny replacement
- 2006 Pontiac Grand Prix GXP?
- 98SE fluctuating rpms
- Alternator...3.4 liter TDC
- Found a GTP...worth it?
- turn signal...
- I will recover ,my 90 GPse won't
- 03 Grand Prix Heat/Air not working
- Synthetic engine oil
- Water Pump
- sunroof sticks
- Tie Rod Lubrication
- Driver Side Window Problem
- fuel/sc oil
- A/C vent controls
- Will SES light stay on when problem is fixed?
- Mufflers
- Tranny Removal 97 gtp
- Might need a new motor..
- 98 gtp will not start sometimes
- Will 2006 Navigation fit in 2004 GTP
- BCM trouble codes
- thinking of getting GTP
- dtc error code po420
- Smaller EGR stovepipe
- 2001 grand prix service engine light
- radiator removal??
- interior lighting program?
- Throttle Issue
- Intermitant passenger side window
- Cylinder 4 missfire
- Front end vibration.....
- proportioner valve
- climate control head unit question
- gunk in oil fill cap
- lack of fuel at WOT
- How to Program your remote lock...FOB
- remote key
- 96 gp se stiff shifter
- Suspension Overhaul
- my 78 GP i picked up
- purge valve
- Intake job pictures
- 97 GTP hp?
- Headlight Troubles!!?!?!?!
- Adding speakers
- Cost of my intake job
- HELP!!! ABS Fuse, Tach and AC Problems
- 40 psi?
- 99 Grand Prix RPO list
- bad strut?
- aftermarket boost gauge
- Steering question
- Keyless entry range too low
- Icm
- 02 GT Trouble Starting
- Check gages light on 1992 SE
- Keyless Entry QUestion
- 1st Posting/engine swap?
- Need help now with O-rings
- need a smaller belt
- 1997 SE Steering Wheel
- need advice on a 2001 GT 2DR
- Replacing Outer Tie Rods....
- loosing coolant fast???
- ->Street racing sentence...
- Coolant elbow
- Power Window not working
- Alarm going off
- 2003 Grand Prix GT-Disable Daytime Running Lights??
- Supercharger
- /00 Grand Prix Weather Stripping
- 2 Questions
- head gasket
- low coolant light on?
- Wheel Problem Question
- someone please help!
- Is their anyway to reseal tail lights?
- need some help
- Vac Line
- Exhaust Question????
- ? Pully Question ?
- Old nasty gaskets
- Northstar Grand Prix
- EGR Valve trouble
- Driver side window...falling inside the door
- New LIM gaskets
- about those lug nut lock things...
- Pontiac 2001 Grand Prix ABS and Trac light on
- cd changer advice (bose)
- PCV valve
- Transmission Problem? 2000GT
- stupid question???
- 2000 Grand Prix hesitation problem
- 2001 GT misfire!
- Replacing stock cd player need new speakers??
- supercharger intake for ss kit
- 3.1 hesitating and stalling when reving.
- 97gt weird starting noise
- Performance Switch Problem
- 97 gtp
- IAC Maintenance, it should be easy!
- 2000 Grand Prix Load sound from front end
- Head gasket or Intake gasket?
- FPR location
- A/c Clutch?
- possible head gasket failure??
- 2001 pontiac grand prix... need help with winshield washer
- 2001 pontiac grand prix... need help with power doors
- Plenum leak
- what is rpm at idle for a gtp
- Connector
- A/c warm air
- '94 GTP Bad Alternator (3.4L DOHC)
- my pontiac grand prix
- Buzzing noise from front end
- Stuff on driver's side window
- 3.1l gen II to gen III conversion possible?
- 10 psi
- Rough Idle
- What happend to the performance shift?
- Uim/lim
- Traction Control doesn't work
- 97 grand prix - problems!!!
- grinding sound - front end!!!
- Power Window Switch Trim Piece
- Which actutator controls left/right vents?
- Loud Clunk when backing out of driveway - 97 GTP
- Lowering GTP with 20s?
- Fan Blower Switch
