View Full Version : Grand Prix
- Brake Lines Rusting Away
- Progaming Keyless Remote 2006 Grand Prix
- Another "looking at a car" thread
- Tire's
- gp wont start "please help"
- A little interior paint
- Quick wire question
- What's involved in replacing a cruise control switch?
- annoying clunk
- 2006 grand pris rotors/calipiers on a 97
- FWI question
- 2000 GT Transmission slipping/grinding
- DIC replacement bulb
- Transmission Fluid change write up
- 97 grand prix gtp DIC-Fan-A/C problem
- need your help
- Intermittent Loss of A/C
- Plugs in a 97 GrandPrix GT
- Cold-Air Intakes? Short-Ram?
- GTP $ price get a good deal or no
- Dumb HUD Question
- Tran fluid leaking
- AC "Secret" Codes
- Exhaust question
- tuning help?
- 2000 GPgt No Brake lights...
- Hood adjustment
- GP in general
- upgrade time need opinions
- Radio and Windows shutoff
- battery dead
- No OBD codes
- 3.4 pulley, installed!
- engine over heating
- Gtp Slipping
- Electrical/ and other
- tire balance
- rear tailight covers
- Question on installing a battery disconnect switch
- Grand Prix help!!
- Weapon-R Short Ram Intake? Good or Bad?
- Grand Prix on the Quarter Mile, hehe
- 3.1 head gasket !!!
- maf question
- Replacing a fender?
- Supercharger belt
- Losing coolant
- 05' GT, W/Series III Smokes
- my scan:
- emergency brake stuck 94 grand prix se
- Code 442
- 2003 Grand Prix Headlights Fogged Over
- bnaylor, i apologize
- AC Not Blowing Cold
- Grand Prix Fuel Gauge Issue(continued)
- Electrical Hell
- 97 Grand Prix GTP, Engine Miss Stupmed?
- AC Compressor question
- Adding a moonroof
- Gas Gauge Braking on a 2001 Grand Prix SE
- Help with Auto Mirror 03 GP GT
- HELP...Floorboard is wet
- Please help me out!!!
- HELP, is 94 Grand Prix transmission dying ?
- A/C question
- Battery Light woes
- Shift Lock Release
- Fuel Level Sensor resistance
- Teen Drivers in Grand Prix's
- pulley puller tool?
- plz help me out here!!!!
- Pontiac Grand Prix
- Teenagers???
- 2001 Pontiac grand Prix
- 96 GP key? not working
- Just did my first brake job
- quick gas question
- Changing Brakes Pads on 2001 Pontiac Grand Prix GT
- clunk....
- 300 Gpx?
- New Waterpump Now Doesn't Cool Well
- 2000 Grabd Prix GTX...some probs any ideas??
- '99 GTP Headlight / Fog light mod - Need Info
- Electric Superchargers
- Set me free! F'ing 100mph gov.
- Service Engine light = Air Pump issues
- Heres My Dyno #s
- Rear suspension/struts going bad?
- Looking for the theft deterrent relay
- Pontiac Grand Prix Keyless Remote Issue
- Finally!!!
- 2000 grand Prix GT Minor upgrades
- Starting to Run Hot
- Where is my low pressure schrader valve?
- Inside dimmer light fuse keeps popping
- Need Help Fast
- Hesitation then a stall
- rear speakers dont always work
- squeeking when i move
- Anybody have a supercharger pulley tool?
- shaking??
- 04 grand prix grille guard
- Transmission shifts roughly
- Needle In A Haystack
- more 99 Grand prix problems
- groaning, oscillating noise, 04 GT
- 1992 Grand prix oil pan removal help!!!!!
- Where can I find mineral base 525 viscosity refrigerant oil?
- Using E3 spark plug in my 2002
- steering column pump replacement
- '02 GP SE Window Problem
- Broken Front Sway bar 2001 Grand Prix
- Need Help! - 00 GP GT Getting Poor MPG
- 94 Grand Prix problems...
- Photo censor
- Major alternator problems on 91 gp se
- 93 Grand Prix cuts off while driving
- pully
- can you buy split axel boots?
- Knocking noise from the back when coming to a stop?
- Cooling fan sequence 1994 GP
- How Do I Know Which Belt To Use
- Ticking Noise from rear of engine
- looking for 20 over pistons for 99 gtp
- Question about digital DIC's
- '95 GP 3100 marbles in jar noise
- Gas gauge issues
- Now what is wrong? Damn 3800's
- A/C Lights--Take Apart
- ball joints: 2000 Grand Prix GTP
- copper coolant elbow
- Front Fascia Replacement
- Humming/grinding while on brake.
- 2000 grand prix gtp
- Supercharger oil
- Front strut problem, maybe more now??
- 98 GTP Complete loss of electrical power
- leaking oil?
- Brakes!?
- Humming sound
- ISS, Strut, Other Problem?
- 99gtp broken studs new ones wont fit?
- 94 steering column shifter
- 1990 Grand Prix Wont Start!!
- MAF sensor replacement.
- GrandPrix 94 with 3.4 DOHC rough idle...help?
- grand prix performance
- Help Locating vent control actuator
- 3.1 Intake Gasket bad
- How do I remove the Power brake booster?
- A/c Question 2000 Gtp?
- 91 Gp voltage drop when starting
- 2000 Grand Prix - Bad Fuel Injectors
- GTP wont start. Electrical problems...?
- 00 GP GTP dies will driving
- A/C works great at idle and steady speed only
- Pontiac Grand Prix 2002 troubleshooting
- 200 grand prix pop from engine area. Please help.
- Door panels???
- A/C High Side getting cold/sweating
- I'm Confused!!!??!?!?!
- too much boost??
- 04 gt
- rear brakes 2004 Grand Prix
- Electrical problem?
- cd changer/ipod???
- ABS light is on 2001 gtp
- Exhaust is Shot
- 97 GTP Horn honking randomly
- Power Steering Pump Replacement?
- GTP... good deal?
- ABS/Trac lights on - suspect Wheel Bearing
- 2002 GP fuel question
- Looking to buy a 99' GTP, should I?
- sluggish, won't downshift right...related to A/C perhaps
- Power Steering pressure hose
- Fuel gauge Question
- 2002 Grand Prix SE
- 2004 Grand Prix
- Interior lamps won't work
- gt tranny
- Replace springs with struts?
- Why is my car dinging at me??
- 89 Grand Prix Turbo FOR SALE
- bad s/c coupler or pulley??
- what the difference between pk2 and pk3?
- 89 gp tachometer reads too high
- GAS LEAK?PLEASE hELP!!!
- MAF sensor ???
- Has anyone installed the "Tornado" on their engine?
- Over Heating...
- GrandPrix 1994 woudn't start, fuel related problem???
- A/C question and Dual climate controls...
- 99 GT to a 97
- 95 GRAND PRIX Question (Photos included)
- Just a quick simple AC question...
- Oil Presure??? 98 grandprix
- Need help with these codes......
- 91 grand prix se 3.1 motor mounts
- Help choosing a 1998 GTP Mod
- A/c Needs Help On 2000 Gtp!!!!
- Rad Fan Switch question
- Question on in-dash monitor System (Grand Prix GT)
- Car is Dead. No power in the interior of car
- 97 Pontiac Grand Prix mass air flow problem
- Is there something wrong with my tranny??
- ampage
- changing speakers problems
- 1996 Grand Prix SE engine trouble
- Key Fob Programming
- rust by fuel door ?
- Wheel scraping against car?
- Questions Re: PCM and AC
- 1997 grand prix stuttering
- Sound System!!
- Reset Change Oil light......
- not GP realated but don't you love mice!!
- Vibration on the floor while turning
- 97 grand prix A/C compressor oil ?
- What is this? (Engine part on '95 GTP)
- Replace 97 GPGT Crankshaft Position Sensor
- GTP has issues
- window wont roll down
- removing hood scoops?
- GT To GTP
- 95 3.1 Liter fuel rail
- Vacuum Diagram
- GTP sputtering
- Car is dead... Just plain dead
- Fans Questions
- Po441
- stalling
- rear tailights wont come on anymore...need some advice
- Any East Tennessee GP Clubs?!?
- Picking Up My Grand Prix GT Tomorrow
- dead battery locked out
- Problems with 2000 GTP (Questions)
- Good place to buy GM OEM parts on net???
- Help -- Car Overheating At Idle
- Vehicle speed sensor wire
- A/C condenser ?
- struts?
- More horsies please.
- Fuel pump resistor relay missing
- crank pulley/balancer removal
- 1991 3.1 cooling fan inop
- Looking for Trunk Carpet?
- daytime running lamps/ac blower/eng. mngmnt.
- Rear suspension noise
- 1995 Pontiac Grand Prix, 3.4L, DOHC question? female in need of help!
