View Full Version : Grand Prix
- Dead car.
- No throttle response 3800
- 06 GT performance mods?
- Wiper Motor Bad?
- Throttle Body Cleaning..
- Radiator Resevoir ?
- Exhaust
- Spark Plugs and wires?
- Can I Disable ABS Brakes?
- 99 GTP pop noise
- about computer ??
- 99 GP console questions
- Overheating GTP
- Swirls in the paint from car wash.....
- Supercharger Oil Change..
- shifting problems problems after shift kit install
- 99 grand prix 3800 stalls wont re start
- Dex-cool causing problems?
- What are the host of other parts
- trans filter and accumulator
- 91 grand prix se replacing front struts
- LIM for 3800 Series II question
- Possible 1990 GP owner
- TCS Off light and Tach Reads 0
- Transmission Questain please help
- 2001 Grand Prix GT ABS and Trac Off light
- Whirring Sound on '99 Grand Prix GT
- trans filter retaining sleeve
- rebuilding supercharger
- Dexcool Question
- Exhaust ???
- loss of horsepower ?
- Perf Shift Light Quit
- Dome Pistons: Pointers and Suggestions
- DRL/dashboard/taillights
- GP power windows
- squeaky aftermarket brakes??
- Tips and Maintenance Subforum (See Above)
- Parking brake catching....
- Scratched Leather.....
- 2006 Grand Prix Auxilary Input?
- 92 GP se cruise control
- removing super glue
- shift kit springs????
- 98 GT Wont Start. NEED HELP!
- fuse box
- keyless entry remote???
- Exhaust on 98 gt
- How do I remove front seat if motor is shorted out?
- Starting problems
- GTP misfires badly
- What manual to get.
- crankshaft positon sensor location?
- Service engine light and sputtering??
- Winodw Situation
- clunk finally gone
- Error code P0507 1999 grand prix se model 3.1
- engine change
- bearing help!!
- have you named your GP?
- 2002 Electrical Problem
- Struts??
- exhaust tips...
- Catalytic Convertor Lifespan
- 93 grand prix 3.1 wont start when below 0 outside
- Trac Light on 1997 GP SE 3800
- Coolant leak 2002 Grand Prix GT W/3800
- 2002 Grand Prix GT Stereo Clock/Station Lights
- bad computer?
- tie rod problem??
- 2000 Grand Prix eats power windows
- black headlights and corners.
- performance on a budget ?? :)
- noise ??
- 93 Grand Prix Left front howling, humming noise???
- Posting Pics.
- gtp, new motor?
- dual climate control
- Code P1404
- Remote program
- misfire code
- replacing coolant sensor
- Windows foggin bad
- 97 grand prix blower motor
- Replacing Thermostat in 99 Grand Prix
- 91 grand prix need help
- back tire angled
- 2000 Grand Prix IGN Key removal
- Aftermarket CD Player
- Another keyless entry issue
- Anyone ever see this happen to their paint before?
- Exhaust.
- 98 Grand Prix GTP Upgrades
- 89 grand prix help
- locked out
- Rear Hub Issues
- Tranny shifting weird....
- OMG my paint go bye bye
- transmission replace
- O2 Sensor?????
- P0141 And P0401
- Help!! Engine Light When On
- BEST GAS FOR GRAND PRIX GT's
- headlights
- water pump
- cat/struts.....
- miles rolled back?
- 2003 pontiac grand prix gt can't shift out of park
- 0-110 ,no launch but i got there
- K&N or Thrasher...or something else?
- keyless entry
- Finding VSS Signal
- 94-96 Grand Prix Common Problems?
- starter help
- answer to gtp stall when slowing down !!!!
- 2000 grand prix gt cuts out
- Help with Digital DIC conversion
- GTP mods...
- A/C Problems
- 98 GTP goofy ignition problem (help?)
- Rebuilding a engine
- Mr. confused
- quik story..kinda race type
- Batteries?
- Door hinges
- 1993: grindin noise from brakes when right turn made
- is it worth it?
- Clunk!
- 2000 Supercharged Gtp - Factory Alarm And Battery Problems
- parking brake light
- what does GTP stand for?
- GXP DVD NAV Question
- Supercharger oil....
- 1991-1996 GTP question
- leaking hose, simple fix but need ideas!
- Tranny Swap
- CPU Protection problems...
- Should I replace the seat or just the back?
- Anyone know Of?
- t-stat and oil...
- stock radio and ipod
- DTC Code P0401-EGR Flow Insufficient_PLEASE HELP
- 1999 grand prix se transaxle problem Help
- again transmisssion
- coils and ignition
- 78 Parts
- Hessitation really bad!
- Starting Problem
- exhaust question
- 97 grand prix GTP won't stay running
- Car jerks when switching gears
- Valve cover gasket
- Power upgrades, need your thoughts
- 97 Grand Prix GT no horn,please help
- idle problems
- engine change
- P0171 Trouble Code
- engine code/ fuel system evaporation leak
- THM440 slips in 3rd gear
- temp/heat
- Passenger side water leak - extra part
- 5600rpm sputter
- 2002 Grand Prix Cat Convertor?
- One cooling fan not on
- Orifice Tube - 1997 Pontiac Grand Prix
- ses on code p1887
- tires drag racing
- 89 Grand Prix no headlights
- Remote Car Starter.....
- 1860 code...
- Dropped Wiper Arm Nut
- Goodyear tires
- engine wont start without help
- unusual heat problem
- I'm freaking out with my headlights
- 2004 GT Water Leak
- 99 3.1 vin M ?
- pinstriping
- ABS sound on take off
- Heater Fan Problem
- Strange noise from front of 05' GTP
- 99 Grand Prix, Code P0480
- Front Turn Signal Not Working
- Need help getting through firewall please!
- codes returned
- Need help with aftermarket intake
- Gas gage problem & code po420
- Help - 2000 GP Won't Start
- Shift KR and PE/WOT KR
- Passenger side leak
- XM/Sirius Install questions.
- New Wires
- Car wobbles ALOT
- push button ignition
- changing sparkplugs on 3800SC
- 99 Grand Prix GT Front Wheel Hubs
- P0428?
- 97 Grand Prix GT power windows and radio.
- Supercharger Upgrade
- Starting Problem after Fill up
- 89' Grand Prix Problem(Please help.)
- 97 gtp missing under load
- gettin a case learn
- tires
- 94 Grand Prix Stalls Intermittently
- 2000 Grand Prix GTP SES code P0442
- 99 Grand prix Odd elec problem
- Bad coupler????
- short in headlight system?
- Car Still Lacks Power. Need Help!!!
- 99 gtp - car occassionally starts honking
- 2004 Grand Prix GTP
- purchase research
- A/C Problem
- PS fluid low
- start up problem + power steering
- Starting Problem
- Trunk Lid Pops
- Engine swap
- Plastic Glue Rec.
- Problem after fuel tank replaced
- Please help w/ location of solenoids!
- Jacking points
- SES light on WHY
- Tune Up Complete
- Neeed Help Fast Please
- battery dead, couple questions
- Anti freeze question...GTP
- Oil Pan replacment Question 93 3.1L
- 1991 grand prix electric problem with fuel pump
- enhanced DIC
- Airbag light stays on intermittently
- Fuel Filter location and replacement
- Tune Up Tips Needed
- I will replacing stock T-stat with 180, Do I need to drill a hole in it?
- 2002 Grand prix deck
- How do I..... ?
- 02 Grand Prix with extended crank
- very bad rotors
- Were can you buy GXP hood ?
- 2002 GT Vibration, possible diagnosis
- Coolant Pooling on Engine
- Front End Noise
- MSD/BOOST controller...
- 98 Grand Prix rpm gauge stopped
- Were is the Ambient temp. sensor located on Grand Prix?
- gtp handleing
- Supercharger Question..
- where is coolant temp sensor?
