View Full Version : Grand Prix
- put some new wheels and tips on the GTP:
- cat delete?
- Need advice on new rotors for '04 Grand Prix
- Idle Problem Need help!!
- Cannot change air direction 2002 GP SE 3.1
- 98 GTP - Motor "Clangs" R & R tips?
- Wheel hub bearing question
- 2000 gtx ram air...pwr windows... heater fan
- 97 GP se rattling noise
- 02 3.8 nightmare
- No headlights on 2001 Grand Prix
- high pitched whining noise from heater
- How to remove 02 Grand prix door panel?
- Question on replacing oil pan on 98 grand prix
- Cooling System Issues
- Help with a 91 grand prix
- cobalt ss supercharged vs gtp
- 98 performance parts
- strut mount question
- 94 grand prix problems please help me
- what does a gtp run in a 1/4 mile stock???
- Change Oil Light
- Temp Gauge Gone Crazy
- 98 SE 3.1 ABS and TRAC OFF Light is On
- Coolant smell inside car???????
- 02 fuel pump
- Electrical Dies upon Ignition
- Remote Keyless Entry Range Low
- O2 sensor - long standing issue
- performance parts
- Code PO172
- Idle problem!!!
- I Have A Couple Questions About A 2000 Gtp.
- Thermostat location 2000 grand prix 3.1
- Exhaust
- Heating problem
- How to reset a Service Engine Light
- HUD - special windshield or not?
- How to remove fuel rails?
- Heater core
- VES solenoid
- How Much Faster Is A 2000 Gtp Than A 2005 3.4 Grand Am????
- Question about coolant flush
- K&N Air Filter for a 2001 Pontiac grand prix SE
- Gen IV supercharger question.
- car not getting fuel?
- Spoiler Type?
- Fuse Panel Location
- Upper manifold gasket coolant leak, need help, advice
- help windshield wipers going crazy
- 1997 Grand Prix GTP rattling noise
- Problem with Fan Control/Heater
- shift lock release..
- Abs/trac Off
- brand new engine
- fuse question
- Intake
- radio question
- Turbo's
- HUD worth fixing?
- What aftermarket hub assembly should I buy?
- Getting Extra/Spare keys
- 1995 Grand Prix GTP Randomly Dies
- 02 grand prix misfire
- How do you replace the Heater Water Bypass elbow?
- GTP will not start - HELP!
- 2000 grand prix gt mp3 adapter?
- Door Dismount
- Coolant leak, and effect of driving with temp gauge in red zone
- 02 Grand Prix Gas gage
- Intermitent ticking noise
- '97 Grand Prix GT electric window problem
- '97 Grand Prix GT Help Heater problem
- waiting for weight
- K and N Air Filter for 3.1 V6. Grand Prix
- Upgrades for a 2001 Pontiac Grand Prix SE
- 01 GTP not shifting into overdrive
- TCC Solenoid Circuit
- Removing Dash Trim Bezel 2000 GP GT
- Transmission Slipping
- Belt tensioner on super charger
- hi, Got a few questions about 04 GT
- 1995 Pontiac Grand Prix se PLZ HELP
- lights coming on randomly/ bad sensor?
- Whining somewhere in engine !
- 1990 Grand Prix nasty transmission vibe
- '00 Lug Nut Torque
- Bolt pattern
- 01 3.1 underdrive/super
- supercharger question
- tranny fluid change (not flush)
- harmonic balancer ?
- Minor sqeak...
- Chassis Lube job?
- 01 3.8 GTP w/p1404
- Strange: Caliper hitting inside wheel after rotor change
- Key Question
- 2001 grand prix GT keyless entry
- VIN Number Look Up
- Rear Speakers Not Working in 2001 Grand Prix GT
- spark plug broke
- 2000 grand prix keyless entry question
- 02 Grand Prix hood latch and wipers
- Custom exhaust
- crate engines???
- Re: Steel Seal
- hood lock
- Up in smoke...
- power steering problem....i think
- thinking of buying a new gp soon GXP or GTP
- body moulding problem
- blower motor replacement
- Sunroof Installation
- 1997 front bumper cover
- Premium vs Regular
- Transmission Fluid Question
- Spark Plugs
- 02 front end damage question
- Grinding sound - front end
- Gtp Motor In A 2005 Grand Am
- 1986 Gp 2+2
- Water Pump?
- gas sensor
- supercharger belt installation
- Help! Power steering fluid puddle under car!
- Coolant leak
- 97 gt ABS Question, Help me out
- How can I properly remove Trac Control?
- OBD2 Scan tool question....
- Idler pulley broke off 1997 GP
- Transmission Filter or Flush
- Power Window Motor Replacement
- Wantin One
- might be just another abs trac light thread
- supercharger belt
- Trac Control won't shut off ?
- Oil Pan replacement
- smooth idler pully..
- Another Wiper Problem!!
- 02 Grand Prix wiring for rear speakers
- Miles to the gallon on a Pontiac Grand Prix SE??
- Transmission shifting rough
- Alternate 12V socket
- Gauges stopped working.
- A question about wheel size...
- Grand Prix Display Light
- PassKey III program help
- rebuilt transmission
- 00' GTP Hood tach
- 2000 Grand Prix Radio Removal
- Error codes 0121 and 1404
- New hood
- Is it time to say "goodbye"
- '97 Grand Prix SE 3800 Wiper Problem
- Want to mod!
- Thermostat question
- 97 gt 3800 intake manifold gasket problems
- Simple question.
- Air intake ??
- 2001 Pontiac Grand Prix SE Air Intake
- how many miles to a tank
- sons car, dumps coolant 10 mins after shutdown
- Code 140
- Heater Blower
- 99 Grand Prix thermostat replacement - 3100 engine
- Help me identify/find a part for a 99 Grand Prix
- What kind of mpg's are you getting on your 3.8 non-supercharged?
- lights go out
- 2002 GT ABS and Traction Off Lights
- Help with Grand Prix programming
- ABS/Trac Off
- fuel gauge inaccurate
- my 05 grand prix is haunted....
- Fuel pump location '97GT and Fuel Pressure
- ABS/Trac light on and whining noise under hood while turning.
- 97 GTP DIC problems
- 97 GTP MOD questions
- Possible engine problem.
- seats/headrest
- Lower Intake Manifold Gasked Replacement
- help with pulley removal
- Steel Seal
- Keyless entry
- Couple of PCS solenoid questions
- Starts then dies in 3 sec.
- car won't start
- 91 SE: Power door lock problem
- 02 GP Won't Start When Hot
- 02 GP GT Security ?
- Performance ??
- Car makes whining sound..
- Any fellow GXP owners here?
- 2000 GTP Stalling
- 99 GT, 130,000, tune up/parts to replace
- Randomly Stalling Troubleshooting Help PLEASE!
- 99 SE Replacing Shocks
- Help with info center
- battery/alternator/other?
- mods?
- Ecu ???
- will wheel from T/A fir my G.P.?
- 97 GTP eating accessory belt
- 98 Gt Radio
- Drivers door console
- 2000 Grand Prix Stalls
- drivers door
- p0128
- Flaky Float?
- 2001 gt starting troubles
- starting problems cranks wont start, i spimpithise
- Rear Speaker Replacement - '97 Grand Prix
- Hydro-Locked
- Plugs and wires.
- oil temp sensor
- Low Coolant Light on 01 Grand Prix
- HUD Problems?
- AC compressor clutch making noise
- 97 gt AC/heater/blower whines
- "E20" Error on my CD player- 97 Grand Prix
- Grand Prix 4T60-E Trans
- Windshield washer hose
- water leak ??
- 1992 Grand Prix Idoling problem
- OK, what did I brake?
- Coolant Issue??
- need help please
- Idle/Brake
- Cigarette Lighter
- Transmission Vibrate??
- 99 SE No Blower at all
- Coil Spring Adjuster And Stabilizer
- Heater knob kills headlights and DIC
- Mechanic
- Motor Mounts
- Help with a Tranny solenoid
- Alot of Squeaking, PLEASE help!!!!!!
- wheel bearings
- Blower motor?
- Drop in gas mileage
- 304hp gtp doing 190+mph
- 2000 grand prix torque specs please
- Grand Prix Cabin Air Filter
- steering wheel locked
- Need help 00 grand prix GTX
- Jet Performance Help
- A/C and Computer issues
- Re-programmed PCM
- Stripped wheel bearing bolt - do I have to drill now?
- So what's the difference in GT and GTP besides more HP?
- Coolant Issue
