Pontiac
> Grand Prix
View Full Version :
Grand Prix
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
98 GTP stalls when hot
K&N Filter
Pcm
Parts for 2003 Limited Edition
01 Grand Prix transmission issue?
Left headlight
Chilton Manual for 02 Grand Prix
Gt power
Aftermarket PCM?
Electric Supercharger
Sounds like a good deal, what do you think?
aftermarket headlights
Lug nuts falling off!
1999 gtp problem with wipers
new PCM
01 gt engine upgrades
2006 GXP rims for -> 97 GTP.
Problems getting key out of ignition
97 gtp starts than dies...
Bent my pulley
keyless entry???
Problem
Pacesetters...?
Oxygen sensor - the ongoing saga
New Steering Rack
1993 3.4l o2 sensor
Rear Spark Plugs
97 gp service engine light on steady
L67 Build
Lower control arm
bad MPG
Gotta Gran Prix
06 Pontiac Grand Prix program for keyless entry
99 GP Headlights
KR woes....help please
93 gp 3.4l fouling plugs
grand prix pcm programmer
What is the average amount of Km's / miles per tank of gas...
89 gp wont start??
replacing wheel hubs/tie rods
Header Installation
question about ABS / TCS OFF light error
Engine swap
slow sunroof
high beam issue 98 GTP
No Converter? 97 GTP
New pulley
What'll it take
fuel injectors
Help coolant leak
2001 Grand Prix Door Mirror~Help needed please!
GTP as new car?
How Many Days until you have to Fill that good old Gas Tank Up?
General AC Question
cant wait for summer
tranny problems
1999 Grand Prix GT front end noise
steering wheel puller
hearing differences in exhaust
04 grand prix starting problem urgent!!
Obd
Transmission
Air comes out of all vents no-matter my selection
2005 grand prix dies sometimes.
electrical going nuts
when combining exhaust and pcm
Need help getting steering wheel off
1995 Grand Prix...transmission issues
automoter gauges
Help W/ Keyless Entry Programming 04' Grand Prix
Nasty Exhaust Leak
HELP!!!! i am looking for an 04 gp gt power chip.
alternator placement. . . why me!
tranny ???
Electric waterpump for '98 GTP?
Just purchased 04 GTP
OBD Plug not working
3 insh vs. 2.5 inch
2000 Grand Prix Jerks When Shifting
Shifter, again...
No power steering??? Help!!!
99 Grand Prix 3.1L water leak - replace gasket and what else?
R.I.P. Grand Prix?
Anyone have a Wiring Diagram??
Finally
tranny whine
do all the 3.4's leak everywhere
Help w/ Programing keyless Entry
Iridium spark plugs - Yay or Nay?
04 gt2 hard on gas
Engine stalling
Lower Ball Joints
Stock Spark Plugs in Grand Prix SE
1998 grand prix won't shift from 3rd to 4th
Oil choice advice
Air conditioning cold on passenger, hot for driver
ABS Light
Autometer Gauge Install Question
Do you guys drive in D,or 3 ?
Jack stands?
1995 Grand Prix bought for 16 year old radiator leaks from underneath
2004 passenger water leak!!!
Intake Manifold Bolt Torgue "00" 3.1L
help quick!!!!!!!
Cruise Control Problem in 98 GTP
A Leak And Dont Know Where
Forced Air Induction!!!????? Is it posssible?
Changing Plugs and Wires
Keyless entry control module
Body Question
2000 GTP Fuel Pump Problem?
a miss while running
Help - Snapped Bolts when Cleaning Throttle Body
electronic problem
Lower Intake Manifold gasket replacement $$$???
99 GT rough lugging at medium acceleration
97 Grand Prix GT replaced ignition switch but now radio & wipers are hot
Dual Vs. Mono Exhaust
How can i get a smoother ride out of my 99 GP GT
Repair Manual for 2000
Headlight
keyless entry programming !HELP!
What cleaner for throttle body?
02 Grand Prix SE 3.1
2004 Grand Prix GTP
GP GTP horsepower
supercharger or turbocharger availability
91 grand prix starting problem
94 Grand Prix...how do you put the power for an amp through the fire wall
Grand Prix brake issues
'02 GP GTP - Transmission Question
Strut replacement
Truth or fiction?
Wipers
99 GP GT Headlight Up Grade
2000 GP Mass Flow Code??
pieces came out of my transmission :(
99 GP GT Serpentine Belt Replacement
Something binding on throttle body when pressing gas pedal
steering wheel radio control installation
cross braces
'02 GP shifting takes longer than normal
WaWa Gas, Vs. Other Gas in Grand Prix's
Serpentine Belt Questions 99 GP GT
94 SE Coupe 3.1L Temp Issues vs. Transaxle
Did my UIM gasket tonight. Did I waste my time??
2004 Pontiac Grand Prix Transmission problem
Fuel Sending Unit Question????!?!?
Electrical Stalling Problem HELP!
Exhaust resistor
94 GP high idle and rough shift.
intake gasket
Boost Bypass Valve
rusted rockers
Hit a horse!
Starting problems
PS fluid/ effort
Front End/ ABS Sensor
a 3.4 pontiac motor
05 Grand Prix Nav System
Supercharger Idler Pulley
lowering...
Remote entry 2000 Grand Prix
97 gtp pully change
Worth Repairing?
Do you know if Ford and Pontiac wheels are interchangeable?
01 gt muffler help
91 Grand Prix-fuses????
Questions about pcm and exhaust
Resonator Delete.. Yes/No?
Flickering/pulsating headlights on my 2002 GT
2001 lights dim issues
Concern about my Gas Gauge.......
low coolant
Recommend me some aftermarket lug nuts
91-grand Prix-no Fire
02 Grand Prix Outside Air Temp. Rear View Mirror readings off!!!
Dripping Fluid....on outside of Tranny
Car Is Over Heating
New 94
"Sludge" in oil fill cap
coolant vs. water
04 GP Roof leaking
'07 Grand Prix V8
hood ???
Cigarette Lighter
how to replace dash lights..97 gt
Blower Motor Resistor
HELP, trying to replace ignition switch but key cylinder won't release
What's this shudder about???
153,000 Miles! WOOHOO!!!
My wipers are snobs.
Cheap parts
94 Gran Prix pwr windows/sun roof do not work
Why won't my stereo turn off
Is it the tranny? HELP !!!
common problem or no???
'97 Pontiac Grand Prix SE - OIL PUMP
01 GP won't start
Filling Car up with Fuel
Changing Key Fob Unlock Option on '04 GPGT
Low Fuel Light QUestion..help
$$$$$$$$ Turbo?
97 Grand Prix GT Headlights & Heater shutting off - clicking noise
Windshield Wipers won't turn off.
1997 GP GTP detail component specs required
97' GT shaking at 60 MPH
89 Grand Prix Cooling issues
Daytime Running Lights
96 Grand Prix door help!
99 grand prix stalling at different rpms
supercharger conversion?
97 GP transmission
Body Parts
Tourque Conv.? Throttle Body? Trans.?
adding coolent to a 2000 pontiac grand prix?
no heat
1996 Gtp V6 3.4l... Need Help
96 Grand Prix Problems
Talk to me about head/head gaskets on 97 GP 3800
Grand Prix Stuck Key in on position
GTP Boosting
swapping out pulleys
1997 Pontiac Grand Prix wiper transmission timing?
What do ya think?
Blower Motor Vibrating
What is a Mall PGM fuse???
Front end whining
What tires did you go to?
engine question
Any Recommendation ( GAS Weird problem )
What sealant to use on radiator hose connections?
2006 GP Rear Wheel Well Rattle/Noise
2006 Grand Prix Ipod Integration
Heater/AC Problems
Comp G Calipers
A couple questions
97 Grand Prix help!!!!!!!!(please)
Why wont my lights turn off?
Transmission Fluid Cooler Lines
1998 Grand Prix PCV valve location
Overheating?
Supercharger
A little advice please...
GP GT upgrades
Window Help
Car Dies when Brakes applied
LOUD Squeel/HISS, when starting car in Cold
Clock/ Radio/Cd Display burned out help fixing it
