View Full Version : Grand Prix
- traction control?
- Losing boost
- Starter.....
- Temperature sensor
- New Car
- modify the grand prix ??
- New to GP few maintainance question
- Grand Prix - Transformers Video
- DIC flashes 0.0
- 97 grant prix gt Keyless remote reciever Question
- Where is the pcm module on a 2000 gp 3.1l?
- Re-locating 98 Grand Prix PCM?
- air cond. cold passanger side not driver
- gtp s/c bearing
- Stock Engine Limitations, 2001 GTP
- grand prix gt overheating when ac is on
- What causes squeeking for Brakes??
- Control arm/Tie rod
- SES light not functioning.......
- turn signals slow and not working when lights are on
- Howling occurs when I turn the steering wheel
- Cooling System Problems - 01 Grand Prix 3.1
- My new fenderwell intake...
- Engine moves backwards when put in reverse
- Clicking or scratching sound when turning
- No SES light @ key on engine off.
- Best tires for 00 Grand Prix GTP?
- fuel pump resistor #14
- '00 gp 3.1 SFI Plug & wire change question
- Too Good to be true?
- Gear shift light flickering/broke
- Rear brakes question
- Relays???
- No power
- i'm full of questions..haha
- 95 GP died on the freeway!!! HELP!
- 99 gtp SUPERCHARGER HELP
- hello
- 1991 pontiac grand prix fuel pump relay
- headlights wont turn off, why?
- Swapping oil pan gaskets.
- Cooling fan problem
- Brakes engagded while driving!?!?
- Can only drive 30mph - 01 grand prix gt
- 92 Grand Prix
- PDF 2001 GP Full Service Manual
- Replacing MAF in 99 Grand Prix SE
- Ignition switch double check.
- 2000 Grand Prix Cold Air Intake ???
- 93 Grand Prix..not saying anything.. doesnt need a motor.
- Gas mileage for a grand prix gtp
- Tapping from engine when driving
- Brake light issue
- Service engine soon p0171 Help
- 1994 grand prix 3.1 Manifold Gasket Leaking, help!!
- IGN Wiring diagram
- service engine light on
- A/C blowing cold on drivers side but hot on passenger side
- Swoosh noise coming from fuel tank
- Engine hesitates
- 1998 grand prix se loud winding noise comming from tranny
- Stock Navi in 06 GP with Monsoon
- brakes squeeking!!!!!
- 94 Grand Prix power window motor replacement help
- Grand Prix Gt Multi- Sicknesses
- 1990 Power Window Problems
- Speedometer Failure
- Cigarette lighter port not working
- Royal Purple
- Won't start, fuseable link???
- 98 gtp wipers stop in the middle of windshield
- CD player installation
- Oil in Coolant
- No reverse on 2000 grand prix
- v8 engine swap for the 2002 GTP
- 99 GT problems, hesitation and stalling
- dusk sensor
- Motor Oil
- 1998 grand prix se idle rpm problem
- 88 2.8 L GP won't start
- Is flat towing a no no in my situation?
- High Beam Issue...
- engine noise
- headers or catback.
- Figure This One Out...
- Se Vs. Gt
- 98 GP Engine Overhaul
- Spark Plugs
- engine swap
- Input Speed Sensor (please help)
- A/C won't switch from floor to vents
- Radiator Smoking
- O2 sensor
- SHorter dogbones....
- 1996 Grand Prix (Rear Strut Driver Side Making Noise)
- Front suspension DIY?
- Cooling problem
- Is this car worth saving? Please review pictures
- A few 98 GTP engine R&R snags
- 97GTP Stuck in Third Gear
- Need advice for upgrades
- Rear End Suspension
- 2000 pontiac grand prix headlights don't work
- vibration over 60 and turning right
- More HP out of an '04 GT2?
- 97 grand prix passenger floor is wet, why?
- 94 GTP troubles, any input would be appreciated.
- Replacing Cloth Interior ?
- Strut brace
- buying a grand prix
- 2005 Grand Prix Parking Lights Lamps Are Out???
- 1993 Pontaic Grand Prix
- 2001 Grand Prix GT Shifting hard occasionally
- Looking for 40th anniversary hood scoops
- gt60E tranny to 6t65e tranny conversion in 97 GPGT
- Spilt Oil Question
- Supercharger Pulley Removal
- How about this Grand Prix??
- supercharger problems...
- 2000 Grand Prix GT with key stuck in the ignition
- engine code (emissions)
- 97 SE 3.8 series II stalls randomly
- sunroof woes... this is getting ridiculous
- Air bag light
- Dealer Mischief Reaches New Plateau
- 1995 grand prix. egr soleniod malfunction
- Newbie here,help!!
- 01 Grand Prix SE more HP???
- ABS light
- '96 3.1 "M" question on LIM
- Key Stuck
- 2001 Grand Prix DIC
- Crankshaft Position Sensor
- 1998 Grand Prix Tailight
- 2004 GP Owners, please give me details off your keyless entry =)
- Check Gas Cap?
- No AC only hot air 97 grand prix GT SE 3800
- bad misfire?
- Temp light flashing
- coolant question
- Fan Switch aftermarket mod Q
- Installed 1.9 Roller Rockers today:
- Supercharger belt / ten, idler Pulley questions
- Cruise control not working
- 98 GT overheating?
- '96 3.1, roller or ball & pivot rocker arms?
- need help rebuilding 88 grand prix
- Key will sometimes not release.
- car overheating and leaking.... water pump?
- few questions
- Car Stalls
- odometer
- Wheels and Tires
- Need a door moulding for a 93 Two door..tan
- airbag codes need info
- computer help
- 2000 GT Hesitates Under Acceleration
- Need Help/Advice
- 02 Grand Prix SES light OFF but still getting P0741
- 1995 Grand Prix turning over, taking spark and fuel but not starting
- Weird Problem Starting Car
- Panic alarm
- Is cruise control hard to turn on, or am I doing it all wrong?
- 2000 Pontiac GTP Miss Fires
- dic problem
- AC/Heater Fan & Car Alarm
- When the time comes.......
- srs air bag light on
- Car Starts Then Dies.
- Car Stalls When letting sit for a While.
- Need a mode knob for my 2001 GP GT
- Programming keyless remote for 2002 Grand Prix GTP
- FL Vibration
- Joints and Hubs and Struts 97GTP
- bad gas mileage
- might be fuses
- Slight knock after CAI install...
- 96 with oil in coolant reservoir
- Rim dimensions?
- turn signal issue
- The back three plugs?..argh.
- header installation
- 96-3100 temp gauge or thermostat or ???
- GP GTP 3.8L 3800 Sopercharged Series III ??
- coolant leaking to ??
- 2001 Grand Prix Gt -- Service Engine Light
- Sunroof??
- Cold air intake
- theft deterent service light is on PLEASE HELP!
- What is my car worth?
- 2005 GT problems
- Cooling Fan Issue
- Dashboard information center
- I am about to replace LIM/UIM gaskets. Just few more questions.
- Cold Air intakes on a 2000 Grand Prix GT
- SES light on only at cruising speed, then resets
- p0137
- Fuel Pump Replacement.
- Starting Issues
- Spedometer fluctuating
- I smell coolant
- Check Engine Light
- AC Problems
- another misfire?
- Wheel Bearing replacement
- Hesitation When Cold
- 92 grand prix seat belt locked in place...help...
- '99 GT Cranks but won't start--STILL.
- 97 GT - lots of warning lights staying on
- Front end problem?
- Coolant leaking into oil
- 97 Gtp P0171
- Very bad shaking problem when under power
- Pontiac Grand Prix rear hub will not come out
- Would this be an ignition switch problem?
- Need help shopping
- Finally Started Modding...
- Throttle body?
- 89 GP Tranny issues, need a techie
- '97 front strut noise
- GTP BTSI wiring
- Top Speed?
- Lowering Suspension
- Well, it all worked out
- Old Grand prix
- Does the check engine light bulb have to work in order to pass emissions?
- S/C w/ mods vs. turbo set up....
- Replacement Engine???
- Weird Starting Problem!
- Changing Power Steering Fluid 04 GTP
- 91 grand prix se power window
- Supercharger Or Turbo????????
- 2001 GP or Bonneville
- 98 GTP won't start
- wiring problems maybe?
- P0171 Code Need Some Help Please. I did search first!
- Radiator sealer?
- transmission
- Trunk release and door locks
- 98 GTP trans shutter
- Air Fuel Ratio Gauge Malf????
- '99 GT has spark, but won't turn over!
- '04 GP-GT 3800 Stalls, Always Blows Hot Air
- 93 gp 3.1 with manual trans. Worth buying?
- Stumpt on trany
- 1997 Grand Prix GTP-stumbles on acceleration
- 1998 grand prix transmission problems
- Stumped! '91 starts then dies! Help!
- SUPERCHARGER Rebuild!?!?!
- stumped on my missing oil issue
