View Full Version : Grand Prix
- MSD Ignition coil
- 99 GTP - Purchased at 101k - Any Immediate Maintenance?
- 99 GTP - BTSI issue and P1887 - possibly related?
- 99 Grand prix Humming noise when turning
- 2002 GP GT passenger door hitting the fender
- 04 Grand Prix GTP Cruise control problem
- 2000 GTP coolant level sensor problem.....
- Getting more of a muscle car sound.
- 2006 GP's
- direction knob selector
- Radio / huming noise question 99 GT
- 2003 gt standard transmission swap
- Power Window Motor
- Pre-cut window tint?
- need help setting wipers
- 2001 GTP_ABS/TCS Sensor
- rear speaker wiring on premium Delco system
- Will this work?
- Radio died
- Noise when braking and coasting.
- A/C trouble
- 1995 Grand prix questions
- 2003 gt tips and performance parts
- Ambient Air Temp Sensor
- 97 Pontiac Grand Prix Gtp Please Help!!!
- 97 Grand Prix Shifting and Other Problems
- 89 Grand Prix Auto Trans adjustment
- 2002 GP Starting Problems
- tail lights
- accel ignition coils
- 97 Grand Prix Thud noise. .
- Pad / Rotor recommendations? 04 gtp
- car stalling
- 1989 Grand Prix Stalls, Bogs Down
- 01 SE Acceleration Problems
- Alternator problem 01 GTP,3.8
- grand prix 99 blower motor works on high only
- Fuel line replacement
- Pulley Help
- 99 GP GT: Axle Shaft Removal Q
- 97 grand prix gtp
- 2002 grand prix electric prob
- 97 GrandPrix fan knob
- I have a Question of a 1997 Grand Prix
- Air filter and hard start...
- cv joint or hub??
- Lower Control Arm Bushings - Need Alignment?
- Brake Issues????
- Downpipe question, please help
- Insturment Cluster/PCM Problem? Please help
- 98 gp se Intermittent AC problem
- no start when hot
- If only I could get it right (suspension)
- Rearview Mirror Replacement
- Hud
- Spark plug gap help
- Somewhat of an overheating problem
- 2002 Grand Prix HUD Install
- F-body brake upgrade question
- 2001 Gp Se Radio / CD install
- Overheating, please help?
- front speakers on 04 grand prix change out
- Humming from the GTP over 35mph
- component speaker questions
- Power Loss When Acceleration
- Expensive keys
- Brand new jasper 3.1 NEED HELP
- 1997 Grand prix abs and such problems. NEED HELP
- 97 gp hub and bearing repair problems
- Need help with brakes - problem
- 99 grand prix GT trans issues please help
- anti theft system/2005 grand prix
- Humming in Front end
- wet carpet
- lug nut covers
- Help!!! Ecm/fuel Fuse Keeps Blowing!
- Removing the cat
- new track times....
- Brake Lights
- Washer fluid is leaking
- Radio Help!!
- 1999 Grand Prix Keyless remote.
- 97 gp wheel bearing hub
- Flowmaster Super 44
- Odd problem?
- HELP FAST!!! 3.8 Supercharged FUEL problem
- stubborn caliper bolts
- 99 Grand Prix: Auto door locks on the fritz
- Past Saga of low voltage to O2 sensor
- Outer Tie Rod Ends
- Problems with Shifter
- Oil Plug
- 2002 GP SE Keyless entry HELP
- Think i finnaly found the coolant leak...
- is it hard to replace a insturment cluster in a 98 grand prix
- 98 Grand prix Transmission Screams
- Fog lights not working!
- Windshield Wiper Problems 2000 Grand Prix SE
- High Mileage Grand Prix Help Please
- Antenna on 98 GTP
- Hi-Performance superchargers!
- 01 grand prix gt cold engine hesitation.
- Need trans help!!
- 04 Prix - New brake pads/rotors car shutters when braking
- 1999 Grand Prix trunk release/reverse lights not working...
- ebtcm module help
- replaced head gasket now no fire to engine please help!!!
- 1998 GP shift problem
- Omg Help Me
- 04 GP GT1 Rear Brakes - Compress Piston Q
- Interior Upgrades
- Possible fraud
- Slight miss maybe...
- DRL removal
- 2004 Gran Prix blower motor wont stop running
- Quick Time Electric Exhaust Cutout
- Grand Prix Start up problems
- Headlight Covers
- 2004 Grand Prix Tranny Question
- 1991 Grand Prix SE - 3.1 questions
- RPM Question
- Few Questions
- Alky problem!
- Another spark plug question
- Rear main warranty
- Opinions please
- Gas Tank Issues
- battery + bolt stripped/stuck
- Broken Supercharger
- 2000 GTP - Tachometer and TCS problem
- '93 grand prix interior door handle
- traction control
- Start up issues
- Help Me Please!!!!!
- Strange electrical / tranny problem today
- 2002 GTP, several small GM issues at a young 60k mileage
- 04 Grand Prix differences
- lower control arm
- Serpentine Belt falling off
- 94 grand prix security light, wont start
- Mileage not good
- Exhaust Questions
- 98 GTP - P0420 PCM Questions
- interior lamps- 97 gt
- MALL PGM Fuse
- 92 GP LE A/C won't switch from floor to vents
- 89 Grand Prix ac/fan problem
- fast idle problem
- 97 GTP air vent question
- Speedometer quit working 98 grand prix
- mall pgm fuse
- Damn P0440 !!!
- A/C problem
- New Here:
- Will 12" brake upgrade kit work with 16" Enkei Torque Star wheels?
- 2002 Grand Prix GTP Supercharger & Serpentine Drive Belts
- re-program remote 2005 GP
- 2001 GP GT AC problems
- What does "polished rims" mean?
- 2000 grand prix transmission/comp probs
- Port Holes
- quick question about boost gauge connect
- 98 GTP Exhaust Leak Story
- Brake Lights
- Blower fan motor in a 2000 se with the 3.8 motor
- AC question..I know its boring but gotta do it
- schematic wiring diagram
- What mod should I go with next?
- 97 grand prix 3800 - Serpentine Belt keeps shredding
- 91 prix still wont start and no one knows
- 98 GTP clock/radio display not working properly
- Daytime Running Lamps
- no power
- 2004 Grand Prix Repair Manual
- Cold Air Intake...slight problem!
- Spark Plug Wires/Igniton Coils
- Overheating and Intake?
- Wet Braking Performance / Slotted Rotors
- PCM Question....
- electrical transmission problem
- ABS low tire TRAC testing
- 1997 Grand Prix SE front end bumper
- 94 Grand Prix SE coup Tranny
- Advice on what to do next
- Cooling System Flush on 1999 GTP
- brand new 2006 as a gift... should i take it?
- clunking and squeeking noises
- 1995 grand prix se doors?
- New owner of a 95 GTP
- upgrade help - 06 GP
- Abs Problems 2001 Gp
- Interior Lights
- 04 a/c whinning problem with acceleration
- Remote Keyless Programming for 2001 Grand Prix
- air bumper guards
- Catalytic Converter
- AC stopped working
- 93 Grand Prix LE headache
- Where to ID options from VIN?
- 94 GP - Tranny - where to start?
- digital dic wiring
- Burnout
- Engine cranks and starts, but dies in minutes...
- Grand Prix GT 3.8 VIN K - Upper intake manifold
- up & down idle problem...
- 6th Cylinder Plug... has won
- Need help car doesnt wanna idle right *with vid*
- Excessive inside tire wear 99GTP
- Motor Mounts
- Installed a K&N Filter on 3.1 v6 Grand Prix
- 99 Grand Prix Remote Power Mirrors
- L67 throttle body modification
- Grand Prix parts available to Canada?
- Spark Plug Covers on '99 3800 SII
- AC/Heat Problems - Blower going, but no air from vents
- Question
- 97 Grand Prix GTP Stock
- enhanced DIC swap
- Several Problems with my 98 GT!!!
- door locked
- gas gauge problem
- Rattle in engine
- heat shield help!!
- Coolant Temp. Sensor..
- AC Problems
- Finally someone to ask
- snapped,,what is this
- 1999 grand prix headlight covers
- how hard is it to drop the engine cradle
- daytime running lights to fog light
- Power Steering Leak
- 00' GP SE loses horsepower...
- 2001 pontiac grand prix se rear speaker removal
- GTP fuel pressure question.Please read!
- 2003 Grand Prix Security Light
- New Pontiac Grand Prix owner.
- need 05/06 transmission and PCM wiring diagrams
- Erratic idle issue - 91 GP GT 3.1L
- Acceleration Problem 2001 GT
- transmission problem
- L67 & L36 throttle body differences.
- 94 Grand Prix SE AC Problems
- Stalls when restarting after short drive
- '07 Grand Prix GXP Radio
- wheel hub replacement question
- 98 GTP starting problems
- "hv3"???
- ’04 Grand Prix ABS and Fuel System
- Dash lights not working.
- rear struts - 98 gtp
