View Full Version : Grand Prix
- misfire 97 grandprix
- Heating problem in 2002 Grand Prix
- RAM Intake
- 98 PGP blower motor resistor
- Nobs for temp select and level select
- windsheild wipers stop in center of windsheild
- 95 GP SE coupe wont start when hot.
- grand prix wont turn off right away
- ATC Blower Motor Connector?
- 1995 Grand Prix shifting problems
- Traction Control Button
- 94 GP 2 Door
- When to service a supercharger? 2007 GrandPrix GT
- 94 GP Suspension
- Transmission will not shift into OD - Any ideas?
- 2000 grand prix service engine soon light
- 01 SE 3.1L intermt. fast idle & no pickup
- water leaking in the car
- help on changing the air filter
- 04 gtp: 3 issues have me stumped
- Starting Issues...
- 04 grandprix blower will not shut off
- 96 grand prix 3.1 wont turn off right away
- rear defrost problem
- 98 GTP - HVAC Question
- 2000 Grand Prix, What is the normal operating coolant temp?
- Front Suspension Question
- gauge mod idea
- Pontiac Grand Prix GTP 1998 Service Engine Soon Light Help
- Transaxle fluid and filter
- Front End Problems
- General Motors Gasket Tablets
- 93 GP SE running poorly
- 4t65e transaxle replacement
- Where to buy performance parts
- HUD Question
- 97 GTP Problem
- Headlamp lens cover
- Throttle body cleaning
- '00 GP Sputtering while driving, need help
- Torque specs for 2004 & up GP's (lug nuts)
- Donut gasket for downpipe. Needed?
- Could it be a bad neutral switch?
- RPM Surging Between 2000 - 2500 RPM
- Fuel Injection
- Helppppppp!!!!
- Cabin Filter
- ECT sensor
- bleed coolent
- compressor running during heat ????
- Key Fob Distance
- Trac Off light and Slow Speed
- TRAC light
- Hard to start
- Another Lighting Issue
- Bolt on downpipe
- P0480 code
- MAT Sensor?
- 96 grand Prix Brake issues... please help
- Please help!
- 08' Se Or 05' Gt?
- 2002 Grand Prix se
- removed cat and got p0420
- PCV Valve
- Cigarette Lighter problem
- Wiring a HUD in a 98 GTP
- Heater/AC problems
- PCM for an L67 kit on a GT
- 99 Gp Gt: P0404
- Went to the track today
- Buying a 98 GTP
- Using ramps to elevate GPs
- 99 GTP - Loud Fuel Pump?
- Coolant sensor and fan
- Pipe diameter '97 GTP
- 02 Grand Prix Project
- Car won't Start - Electrical? Please Help...
- Fuel Pump Swap?????
- CV axle replacement-2000 Grand prix GT
- automatic headlights
- Removing the Coolant Overflow tank
- Volume control bulb
- newbee here, radio LOC out
- Wheel Bearings/Hub Assembly Help
- 92 GP cruise short
- 1997 pontiac grand prix trans ??
- 96 Grand Prix Fog Lights/HID
- Thermostat
- ABS and TRAC OFF light??
- 1988 pontiac grand prix
- Stock Wheel Size for '04 Grand Prix?
- what size are the stock injectors......
- 98 Grand Prix GT 3.8L stalls and wont start??
- Change Ignition key mechanism
- 91 grand prix trans problem
- Rough Idle
- 2004 Grand Prix GT2 Starting Issues?
- Installing Rear Window
- AC/Heater won't switch vents
- no heat blowing what's the problem
- 99 rear window regulator
- 3 degrees more?
- 98 Grand Prix-3.8L: Coolant level sensor
- Power steering flush
- seized rear brakes (91 GP)
- Spark plug help among others
- Sway Bar Broke?
- Blower/Heat Problem
- Fuel pump fuse problems
- 2004 Grand Prix, Whining Noise
- Pontiac 2006 Grand Prix Seat Change
- Brakes
- Misfire on cyl. #1
- Weird Smell from engine
- New brakes, not much better
- Quick question about coil packs
- Need Used Car Supercharged Advice
- Rear bumper removal, help?
- boost gauge not working
- 2001 GTP A/C electrical problem
- fuel filter replacement nightmares
- XM Radio in 2007 Grand Prix GXP
- How does the tire pressure sensing system work?
- Leaking water on Passenger's side - HELP
- Front Speakers
- Muffler Problems
- Lights out on cd player 2004
- A/C Vent air direction\Vacuum Problem
- Problems with P1810
- Quick review - 2008 Grand Prix
- Any body familiar with OLD GP's
- Actron CP9185 and CP9190 Scan Tools
- Sunroof issues
- Stall while in reverse...
- brake light on at high RPM's
- Problems......
- 97 Pontiac Grand Prix GT ?'s-suspension and exhaust
- swapping motors
- 02 Grand Prix Head Unit question
- 97 GTP vs. 05 GTP Comp G
- 99 GP SE struts and shocks
- Erratic RPM's
- Bone head jump
- Low fuel and check gauges light stuck on
- 1993 Pontiac Grand Prix Kelyess Entry Receiver Module Location
- Abs/track off light problem - please help
- Low Coolant Light 97 Grand Prix GT
- ABS, Trac off, low tire pressure lights
- Removing & Installing Wheel Stud
- Support Mod Help
- 00 Pontiac Grand Prix GT New Headlights
- Front Valve Cover
- fwd lower control arm bolt stuck inside bushing
- Weird smells
- HELP!!! Car is overheating
- poor milleage, power loss, gas smell, putting muffler
- 04 Grand Prix HUD issue
- Dumb girl has GTP that won't start
- I feel dumb for asking but???
- Help out the new guy....
- Please Help!!! 98 Grand Prix About To Explode!!
- 94 gtp/94 cutlass supreme = Same ecm???
- Very weird stuff happening with 99 Grand Prix
- Oil Pan Gasket Leak
- Fuel Injectors
- 2003 no headlights
- Removing '04 GP GT seats
- ALL lights are flickering
- Intermittent Ignition Problems
- Fuel Vapor Smell After Dealer Fuel Pump/Filter Replacement
- No Place to mount front license plate
- Rear Brake Caliper
- turn signal problem
- Economical way to replace EBCM?
- Air Intake, should I or not?
- sir system
- Transmission advice
- A/C problems. Help!
- No Constant power in new stereo
- Rear Brake Fluid leak???
- Considering Purchase 2000 Grand Prix GTP
- Problems with Daytime Running Lamps
- 94 GTP Timing Belt
- SES light on. (Need to pass emissions)
- adding the tapshift option
- 04 pontiac grand prix GT1
- 1988 pontiac grand prix lock lug
- 92 Pontiac Gran Prix
- Wheel and tire question, yes, im sorry, another.
- This is my 1st time doing this
- Wierd noise
- Blower/fan and power window problem....
- radio in lock mode
- 02 Grand Prix Cigarette Lighter Problems
- Battery Question
- Car Dies When Hvac Control In Off Only
- starter
- New cd player=ughh
- 1991 pontiac grand prix tranny help needed
- Need O2 simulator!!!!
- Difference between GXP and GTP
- Popping sensation when turning the wheel on 04 GT2
- Just a heads up-good vendor-Sticky?
- Autolite 103 race
- superchargers
- "Low Coolant"
- Problem with rear defrost
- HVAC fan
- This is going to sound dumb but...
- Strange problem
- Weird problem
- 94 Pontiac Grand Prix SE 3.1 VSS
- Noisy Lifters????
- cd player???????
- Hud
- 97 GP Coolant Leak
- oil in radiator
- 02 Grand Prix fuel pump ??
- 95 - brake/ABS light??
- 1997 electrical connector in trunk
- 1999 Grand Prix GTP hot center console
- Lifespan on engine??
- Rearview Mirror popped off my '02 GP
- 04 grand prix vss
- Question: How to pull off spark plug covers
- 97 gtp AC problem
- Fan Stays on while car is Off. Help Please.
- HUD Help!!
- Noise at Rear-end of vehicle
- AC compressor
- vibration in 2000 grand prix gt
- 96 Power Steering Actuator
- Digital Horsepower PCM questions
- Change Oil Sensor Reset
- 98 GP GT 3.8l overheating with new parts
- High Idle with 98 GTP
- A lady t-boned me in my 2007 grand prix gt
- Please Help>96>gtp>3.4l
- 94 Pontiac Grand Prix SE 3.1 Thermostat
- Grand Prix tries to start, but doesn't?
- Condensation in Headlights
- Hypertech Tuning
- Larger wheel size question.
- Intercooled Exhaust Tips
- Fuel Gauge Swings
- Steering wheel removal on a 95 GTP
- d/p question...
- Sway Bar
- Bad day for my 98 GTP P0300
- Loss of power
