View Full Version : Grand Prix
- Tranny issues
- alarm bypass kits and override kits
- GM Dex-Cool Intake Manifold Gasket Lawsuit Tentative Class Settlement.
- 1998 Grand Prix GTP Nada price Supercharged
- Acceleration hesitation...
- Cam's GTP
- 1998 GTP Aftermarket wheel and tire sizes
- Brake changing question
- 01 GT - Wiper fluid pump - Stalk Assembly
- Temp. Gauge doesn't work...need to fix ASAP!
- gas mileage help for 97 gtp
- GT Sound System
- GT, 3.8, odd miss
- 2000 Grand Prix 6cyl heavy stutter on acceleration
- Heavy stutter on acceleration (not tuneup)
- Grand Prix Electrical issues
- Possible to Add Steering Wheel Controls?
- How Do I Know if I Have an Amplified Premium Sound System
- My new project! 97 Grand Prix GT 2dr
- Crippling electrical problems
- DIC/HVAC fuse problem
- Steering Wheel Radio Control Light
- I can't believe this is happening
- Fuel Pump Resistor Bypass
- SES Light - OBD Codes
- Instrument Panel Lights & Heat/AC Control Lights
- New 98 GT - AC whirring?
- Remote Keyless
- Wet floor?
- 99 GTP tranny problems
- 2000 GP GT Creaking sound, right front
- outer tie rod ends
- Grand Prix GT w/multiple probs...
- Stumped...
- Key release soleniod
- Power Steering
- passenger window wont stay up
- GTP Fuel Option
- 2003 GTP won't start, lights dim
- grand prix lights
- Amount of time to install rear struts?
- Headlights dimming/rattling while driving
- Need Help Building A Better Super Charger
- Low Coolant Light still on - after new sensor installed
- 98 Grand Prix - Hard Starting and Higher Than Normal Fuel Consumption
- Heated seats amd remote start
- Where to find strut & spring complete assembly
- Keyless Entry/Remote Start
- Oil Change Question
- SES Light on Most of the Time
- Couple problems with a 02 GP
- 99 GT: Coolant Leaks
- 99 grandprix gtp 3.8l sc gets 9/13 mpg!!!
- 97 gp rear strut
- 2004 Keyless Entry
- Pace car
- After Market Radio Installation 2000 GT
- '98 Grand Prix coolant tank switch
- 99 gtp Annoying problem no heat/hvac!
- '94 GTP Leaking Coolant
- 97 gp trac,abs.air pressure light on
- Automotive Training Center Vs. UTI
- 02' GTP problem
- Water Pump?
- Need some help guys
- Poor acceleration with blinking SES light under load
- turn signals don't work
- Looking for parts, can't ship to Canada... Can a yank help me out?
- overheating problem
- No juice
- Aiming Headlights
- bose stereo question
- keyless entry
- Hesitant Start on 97 GT
- What happened?
- Stabilizer Links
- Loss of power at 100mph
- Harmonic Balancer help needed!!!
- Hi all
- no more gtp
- bleeding air out of the heater system
- MAF issue or not?
- Not a Super Charger Problem!
- heater Core
- Gas Milage Loss With New Pulley
- How much should it cost to change a thermostat On a 98 Pontiac GrandPrix S.E. 3.1?
- Transmission Problem
- Remote Start.... Opinions Please
- 98 GTP: Whistling Noise
- Problems with Driver Side Door Handle
- front rotor wear limit for '01se?
- 2002 Grand Prix Engine Light Problem
- Coolant draining noise when accelerating
- 2000 gt ZZP down pipe install
- Check Engine Light - 2002 3.8
- Son's Grand Prix
- Loud HISS when starting car
- help - broken vacuum line
- 1998 GTP TURBO 105000K Problems???
- Dead Transmission
- Blower Motor Resistor
- Coolant Leak On 98 GTP
- Need a little help
- Turn Signal Help
- 1993 grand Prix door locks
- 2001 GTP EBCTM removal
- '98 Headlights poor!
- grand prix engine swap 3.1 to 3.8
- 97 GP GT Tensioner question
- My GTP won't start please HELP!!!
- Window Stuck Half Open
- 2002 GP GT No Blower or HUD
- Transmission Failing?
- More power
- 99 GTP front suspension
- BLOWER MOTOR- 2000 Grand Prix 3100
- stripped screw on supercharger
- 01 rough idle somtimes stalls
- IAC screw woes
- No Heat
- GTP and GTP Super Charger.. Is there a Difference??
- Winter trouble 1999 Gt
- ABS/Trac Off light - weird!!!
- Speedo and Tach Not working WHY??
- supercharger 1999 gtp
- DIC and Instrument panel problem
- 02 Grand Prix GT (Headlights/Whining Noise)
- Lighter Issue
- pulling tranny
- Gt, Gt1, Gt2, Gxp?
- Thank you everyone
- Transmission Shifting Problems
- 95 Grand Prix GTP cooling issue
- 1998 Grand Prix 3.8 L "Cyl 6 Misfire Detected"
- 1995 GTP Washer Reservoir Location???
- Creaking sound heard from inside when turning at low speeds
- 2007 Radio drifts
- Cost of all 4 strut and shock replacement
- hub adapters
- 2000 Grandprix Supercharger Problems
- Need Help With My Gtp
- Car won't start since security system enabled?
- 1991 grand prix rough idle sputter on interstate
- Belt replacement on a 98 GP GT
- Sea foam
- 2000-2002 transmission problems help
- 98 gtp worth
- Drivers Side Window Motor
- 2000 GT wont stay running-vacuum leak?
- Heater sometimes blows cold hair
- Changing Spark Plugs
- Battery Saver Active Light
- 2000 grand prix gt engine cuts out
- 2002 Grand Prix rocker panels
- Anyone here acess to the GM maintenance documents? (Dealer intranet)
- 130,000 miles, too much?
- Dash Light or Instrument Panel Light
- Length of bolts for ZZP downpipe
- K%N Cold Air Intakes and performance spark plugs
- 97 Grand Prix GT ABS problem...
- AC DELCO STOCK PLUGS from Dealer question
- Does anyone have write up on how to replace lower control arms?
- Rear wheel bearing?
- 2002 GP Heater/AC+Headlights+Windows
- 97 GTP vs. 06 Scion tC
- Super rough Idle, with Bosch Plugs
- 99 GTP cylinder 2 misfire code
- Oil Leak on 98 GP
- 91 grand prix idle/start problems...need ideas
- Squeak coming from the engine
- 2002 GTP OBD code?
- 2002 Grand prix thermostat 3100 - HELP!!
- 93 grand prix 3.1
- iac and maf
- Tensioner pulley 92 GP 3.1
- 2002 grand prix check engine light
- 2000 GTP ABS/TCS lights on solution
- Gas Mileage Question
- 04 GTP Comp G - Borla exhaust anyone?
- 2oo4 gtp will not start
- window motor
- 1997 cracking spark plugs
- 1994 Grand Prix Shifts Early and drops RPM's real low.
- Gripes about the Monsoon 6 CD system
- 97 Grand Prix...HELP!!!
- keyless problem
- Alternator Replacement Guide - '01 GTP
- idle
- Emergency brake cable broke?
- bodywork ideas or feedback please
- Car CODES... HELP!!!!
- Sway Bar
- Tires to buy for '97 Grand Prix GT
- Computer problem?
- Blower motor resistor
- Air Intake Question
- Overheat
- Blower Motor
- 1997 Grand Prix SE 3800 Series Tension Pulley
- Should I put gasket sealant on UIM gasket?
- I need a windshield washer reservoir CAP
- HELP!! frist time Grand Prix GTP buyer with lots of questions
- power locks
- '98 GP GT (VIN K) - UIM or...
- Winterizing Grand Prix
- 1994 grand prix insrument cluster replacemnt
- Temperature Gage does not Register
- Radio Display Bulb
- Looking for part number
- zerex G05 ok w/prestone extnd life?
- Grand Prix 2002 Blower motor
- 93 Pontiac Grand Prix
- Reprogramming auto A/C kick-in temp?
- Question about connectors
- Check Engine Light 2004 GP
- Cold weather oil viscosity
- Drivers door won't unlock
- Some new issues...
- regular heater/ac controls to dual climate controls
- Deleting the resonator
- 2002 Grand Prix Noisy Hub/Wheel Bearing
- Changing the radio
- Anybody know where this goes
- 2000 Gtp Starting Problems
- converting analog dic to digital drivers info center
- Problem with guages
- HVAC question
- bad mileage
- 94 Gp Drivers Window
- 94 GP Passenger Power Window Help
- PEMs question...
- Cooling problems
- need a answer for a code
- o2 simulator question.
- 1997 GTP engine block swap
- Abs Light Come On
- Check this out guys!!!
- Thanks Everyone!!!
- U-bend delete information
- Starter is dying
- Sending unit question
- 97 Grand Prix stalls out
- Wheel Hub Bearing???
- 97 Grand Prix Sputtering
- GTP electrical issues
- Painting Dash Trim
- 94 Grand Prix Overheats. HELP ME!!!!
- Car Starting To Suck~~!!!!
- 2001 grand prix rack and pinion problems
- Coolant Leak on 98 GP
