View Full Version : Grand Prix
- Rocker Panels
- 3800 Coil On Plug Design
- Cylinder Head Compatibility ? ?
- TCC Solenoid? please help
- Radio Is Locked...HELP!!!!
- Question about switching DIC( driver center)
- Easy Horsepower/Torque Gains On 97' GTP.
- How do I find TCD on this 3800?
- 2000 Grand Prix Manifold Gasket Replacement Problem
- Issue with drive axle boot?
- car battery?
- Only 45lbs of compression
- Quick question about tires
- '01 Grand Prix Dies
- key FOB Question
- 2005 Grand Prix Trouble codes P0641...
- 2000 GTP Problems
- 1991 Grand Prix neutraling
- AC problem
- Window/Lock Problems and Removal of Door Panels
- Secondary Air pump Code P0410
- GTP Died after a minute or two -- MAF.
- Repair and Maintenance Manuals
- Intermittent stall FIXED!
- 2001 Grand Prix GT question
- 1993 Grand Prix COUPE Has Speakers In The Door?
- 2002 Grand Prix Questions
- blower motor resistor?
- Fuel Additive
- Replace Lower Radiator Hose - Tips?
- 2001 Grand Prix ECU issue Please HELP>?
- 1997 Grand Prix SE Vacuum Lines
- vacuum leak??
- Trasmission Problem?
- Engine Swap?
- 97 Gtp Bad Gas Mpg
- Stock GXP 1/4 mile?
- What temp does your guage normally read?
- Weird Sound when accelerating with heater on?
- Value 2000 Grand Prix GT-issues
- 98 Grand Prix Fuse
- bad smell
- 2004 center console shift lights are out
- Tie Rod
- no start
- big battery drain
- Check Engine light came on
- Relearning a Key
- Fuel gauge
- auto dimming rearview mirror
- Rear Speakers
- Low coolant light blinking (continued)
- new key security
- Cigarette lighter not working.
- Trunk light Bulb?
- 97 Gp Se Help!!!!!
- adding new key
- Loud Clicking Sound When Starting in Cold Weather
- Power to fuel pump?
- Check engine light question?
- Coolant Flush
- Engine Overheating('99 3100)
- Shutters at low RPM
- Changing Coolant, need advice
- fuse question
- 93 grand prix missing and guttless
- A Few Questions About My 97 Gtp
- Front lower control arm part number
- Replacing rack and pinion
- quick headlight question
- new gremlins, easy fix i hope?
- 99 gtp strut mount bearing
- AeroForce Gauge
- 01 GT Drivers window no worky worky
- 04 GTP stability control
- 98 GTP: Few Engine Pics - Pistons/E-Manifold
- 2000 3.8 Litre Vin K
- Error Code: p0420
- Evap System
- Intake gasket leak
- 2000 Grand Prix Periodic Shudder In Idle
- 2002 GT Ignition Switch?
- a quick ?
- any good websites or custom ideas?
- repair manual 04 grand prix
- Updated problems
- Tire Question
- 99 grand prix gt 3.8L
- Rear Struts 93 Grand Prix
- CD changer question
- Fuel Pump Problem?
- Tranny temp gauge
- GTP Fuel Pressure Regulator?
- 2005 Gtp Failure!
- 98 Electrical problem
- Evaporator core replacement
- Fuel Level Sending Unit
- Odd noise while stopping
- Fuel Pump Resistor
- Shifting problems?
- 98 GTP Wipers stuck upright
- Add Ons ?
- 97 Grand prix gt transmission
- UIM Coolant Leak
- GTP '99 Blower issues
- Burnt smell from engine compartment
- Sensor Range Question?
- 94 GP SE - tail lights have gone out
- Horsepower?
- Wing Mirror Replacement
- plug gap specs
- Are AutoCraft Car batteries good?
- 99 GTP tranny issue
- 1999 GTP - Rough idle, stalls, black smoke, rich fuel. HELP!
- Couple of questions 1991 Pontiac Grand Prix LE 3.1
- 2004 Grand Prix can I replace original gas cap for locking gas cap
- Electronic Lock Issue. HELP!!
- 95 Grand Prix Thumping noise from rear
- 02' GTP driving problems
- Factory Radio/CD player 2000 GT
- Upper Intake Manifold
- 98 Grand Prix GT with oil leak.
- 99 Grand Prix - shudders in gear
- transmission slipping in first gear!!!
- Poor Mpg
- 2004 Reduced power and won't drive
- Torque Converter Clutch- P0741 (stuck off)
- misfiring SES light
- 1999 pontiac grand prix gtp, no start!!!
- Fog Lights????
- Grand Prix Se 2000 Fuel Pump
- 97 GP Steering Major Problem! Help Please
- Shifting Problem
- 2000 GP GT Drivers Side Power Seat Malfunction
- 99 GP Power Window
- 1997 Grand Prix GT - dead :(
- Assistance needed
- Autolite Vs Bosch plugs
- 97 grand prix manual conversion?
- 2002 GP rust problem-advise??
- Loud Clunking Noise Coming From Engine
- misfire upon startup
- 98 Grand Prix GT keyless entry problem???
- bumpy ride
- 98 grand prix gt - p0300 code
- 2000 Grand Prix GT 3.8ltr
- speedometer is off by 10 mph
- Fans always on
- 2006 GXP premature tie rod end wear
- Lug Nut Caps Replacements - '01 Grand Prix
- 04 grand prix questions
- Brake Question
- 2004 GTP Bad Gas Mileage
- New Software, You guys want to try it out?
- Read this to get rid of the security light
- transmission
- Supporting Mods
- Bad heater blower resistor? 98 GT 90,000 miles
- Pulley Problems...
- platinum vs iridium plugs
- P0411 Secondary Air Injection system
- Problem with programming keyfob (97 SE)
- 97 gtp stumbles on startup
- Differences Between S/C and Non?
- Racing Stripes?
- Help needed! 94 grand prix engine lopes and hesitation at idle speed
- Fixing Coolant Temp. Gauge...
- oil pan &/or gasket LEAK (not at sensor)
- How to, Drive Axel replacement
- Totaled my Car
- Similar problems as stated in previous posts! Hesitation and Stalling Problem...
- 1995 Pontiac Grand Prix
- rim offset anyone?
- '04 GP rough start / stalling
- tranny
- Troubleshooting codes P0650, P0449...
- Power Window Problems 06 Grand Prix
- 97 Gtp Starts Without Key
- child seat woes... anyone else?
- Transmission Slipping
- Maf P10201
- 99 Grand Prix Gt, No Overdrive?
- UV Coating on Front Windshield?
- Charging System Check
- '94 Intermittent Start
- Windshield Wiper Fluid Pump
- Buzzing vibration
- Water standing on passenger side
- Tranny Fluid to use??
- how to replace wiper fluid pump
- 01 Grand prix Windshield washer fluid
- 98 GTP: Wanted 4T65E-HD R&R Advice
- 99 grand prix with 3.1
- Trunk Release Problem
- vibration on 2003 pontiac grand prix
- Serpentine Belt
- Random Misfire/Fuel Drop/Bogging down HELP PLZ
- Abs... Again!
- Reset the SES light?
- 97' GTP will not start! No spark. No wrn light
- egr valve
- replacement headlight assemblies
- A Few Questions
- 99gtp - P0171 & P0306
- 2001 Grand Prix SE Thermostat?
- resister problem
- Need a suggestion DTC Codes P0128 & P0453
- lower control arm bushings
- oxygen sensor
- Headlights on 99 GP GT
- Bad smellfrom a/c on 06Grand Prix
- This looks bad, any ideas?
- Loose Upholstery
- Dash Lights off... help
- help......
- 99 Grand Prix GT anti freeze smell in cab?
- Gtp Still Wont Start :( Help!
- 05' factory remote start
- I feel lost !
- Loose Wiper
- 97 grand prix power window problem
- 05 grand prix starting problem
- 89 Turbo
- 99 GTP - Overdrive at 37-38mph
- GTP needs help
- Coolant Leaking Issues
- Running at low temp - 99 Grand Prix GTP
- Low Coolant Issue
- tranny / AC compressor help
- spark plugs
- Best place to buy car battery?
- lower ball joints on 96 Grand Prix
- 99 GTP DIC flashing 0's
- 2002 se keyless entry
- Tranny compatibility question
- 2002 wipers stuck in upright position
- undercoating problem
- PCM Question
- 99 Gran Prix Gt Tranny issues
- heat does not work
- Help!! Replacing Coolant sensor
- Replace timing belt/chain soon?
- Newbie needs help with 97 GTP
- no heater control
- PLZ help need to get my window up w/o switch!
- Cold Start Knocking Noise GTP
- 94 trans not completely engaging
- Water Leak Problem
- Hi
- remote start
