View Full Version : Grand Prix
- expansion valve
- diagram on fuse panel cover
- I traded my 01 GT for $3K for new 08 Impala
- Power steering pump install? & diagnostics
- 2001 GTP No O.D., no 3rd and slipping in 2nd
- 1990 3.1, runs fine cold, stalls when warm/going from P to D NOT torque conv solenoid
- vibration at Idling
- rear brakes sounds like there grinding
- 93 Grand Prix Lugnut Key
- 40 anniversary hood air extractor
- MPG Problem?
- 2001 GTP Forgot where wires go on new Ignition Harness
- GT Over 340,000 Miles
- Oil Pump Rebuild Difficulty
- Humming in the back
- Broken Downpipe
- '95 Grand Prix Alternator Problem?
- 2000 GTP Lower Intake Gasket
- '07 HVAC help
- What's the hottest Grand Prix you've ever seen?
- 98 GTP HUD Removal
- Where do you buy your GP accesories?
- Fuel and Mileage
- Ebay Wheel Bearings
- ABS light and Traction Control light on-99GTP
- EGR Valve-99GTP
- Vacuum line replacement
- 97 GTP Climate Control
- Damage to the Auto Repair industry?
- still A/C problem in resistor
- 98 Grand Prix GT 3800 Bad mileage
- engine cuts out at 3800 rpm
- Starting problems.
- Cannot hold an idle - Keeps dying
- Aftermarket Audio installation??
- Dead GTP
- 2000 GTP Key Stuck in Ignition Please Help!
- alarm help
- Rear Emergency Brakes? 2000 GP GT
- Vehicle Maintenance - Tips & Tricks
- In General, How Often Should A Power Steering System Be Flushed?
- In General, How Often Should A Brake System Be Flushed?
- 99 GTP A/C Compressor
- Coolant Leak Advice - 2000 GTP
- Need some help!
- Tire Question Need Advice
- 04 grand prix
- 1999 GT will not idle
- my fix for a PO171
- Exhaust questions?
- Replacement carpet...
- Popping/Cracking Noise..
- Gasoline vs. Alternative Power
- Power window malfunction
- 94 G/P 3100 lifter replacement thru head?
- intake/exhaust question
- 04 GP GT won't start 1st try
- 98 Grand Prix coolant leak
- Part Number: FPMS95536 all that is needed for the UIM & LIM on VIN M 3100?
- Clicking noise coming from engine??
- 3800 SII engine hose
- 94 GP SE -Elect. Window Switch...
- does anyone wanna touch this one?? haha
- 2004+ GPs - Is Premium Fuel Required?
- 2007 GP blower motor control module
- Ignition locked...HELP PLEASE
- A/C + heater doesnt completely turn off
- Wobble/vibrating while accelerating
- Power Window: Works, then doesn't.
- Fan blower knob only works on certain numbers
- remote keyless entry
- torque converter solenoid...
- What do I need to replace struts?
- 99 gp gt Repeated problem
- not shifting????
- HO Alternator
- New Wheels, Vibrations
- cool fan relay
- Problem With My Gtp
- Rear drivers side brake line
- Weird Noise, comming from pulley.
- ABS and Check Tire Pressure Lights on
- Removing Power Mirror Switch From Bezel?
- Why are there so many Grand Prix GXP's for sale
- Testing AC
- wondering what is a safe pulley size on my 98 gtp
- 95 Grand Prix gets hot. Need help!
- Rotors WORN out haha
- 2002 GP Hood
- Throttle body bypass kit
- grinding noise while driving
- Rim Cleaning Question?
- Pop in steering
- Front Mount Intercooler?
- 1997 GTP wont rev past 3500
- cold car starts fine but when hot truns over but wont start
- 04 Grand Prix GT transmission fluid change
- Burned Transmission Fluid?
- cooling fans not coming on
- Strut Bearings Making Noise....
- 97 Grand Prix With Intermittent Miss
- Driver Information Center (DIC) trouble!!
- Loss of Power
- Blower Motor Resistor
- problem with starting the car
- Possibly Electrical?
- Fuel injectors
- Stalling problem(possible crankshaft position sensor)
- car dies and must sit for a while before it starts back up
- Steering rattle
- low trac ???
- Bad front axle 2000 GP GT?
- Spark plugs
- Air flow issue - 99 Pontiac Grand Prix GT
- 94 Grand Prix all of a sudden wont start
- Modifications.....
- Is it Broken???
- 2000 GP Rust Starting Under Gas Filler Door
- supercharger oil plug
- squeaking noise coming from gear shifter?
- How to get a nice quiet ride again..
- ac replacement
- Advance AC help needed
- aftermarket headlight bracket
- control arm bushing
- problem with power after fixed tranny?
- Werid missfire on #3
- 02 fuel gauge and dashlights Help
- 99 gp gt - Before I check SES code
- 97 Gtp Questions
- Air Conditioning
- question about emissions
- hid install 95 grand prix
- "Rhode Island Edition" Grand Prix?
- Identifying Steering Clunk
- speakers
- what looks better?
- Headlights turned off while driving
- *HELP* service engine soon
- Tie rods?????
- egr valve
- bad missfire???
- blower motor resistor failed again
- Dead Washer Fluid Pump
- 99 gp gt
- 98 Grand Prix GT cruise control not working!
- New Struts/Shocks?
- Removing Resonator.
- Humming in my left front wheel area
- 2nd gear start
- outside ambient temp sensor
- Engine Replacement
- Tranny???? I pray its not $$$$
- Ignition Control Module? Help?
- 1999 GTP Service Engine Soon Light
- Weight of Oil
- slight clunk in front
- No Forward Or Reverse gears
- 2000 Grand Prix Stalling
- Need Help with "00 gt front end misalignment
- Headlight Housing.
- Thinkin bout a Grand Prix
- Chiming without key/unable to lock
- 97 gp codes
- TPS Replacement
- How To Roll Engine And Change Back Plugs
- gas line question
- Need some help
- Need some help
- Help with power loss, Overheating cat and vibration.
- Radio Question?
- turn signal/wiper switch replacement
- Oil in Coolant - 99 GTP
- Supercharger Maintenance
- Door random forced locking.
- Upgrades!!!?
- Drivers side window acting up
- '07...where's the paint code?
- Rotors
- Is my ignition coil leaking?
- hud heads up display
- trans problems
- Lifting rear end
- Ahhhh Little help here?
- 2001 GP Brake Caliper Bracket Bolts
- Aftermarket fog light
- CV Joint
- 2001 GTP leaking supercharger oil
- 2000 grand prix 3100 not charging
- Air Conditioner Problem
- ABS light/ turn signals not working
- When it was raining the passenger side will be full of water!
- ambient air sensor
- Towing
- Fuel Issues I Think, HELP!
- '04 Blower Motor Issue
- Help ME with stupid question PLEASE
- 2004 performance/exhaust
- Brakes Dont work, PLZ HELP!!!
- ??? secrurity mode??
- What else could cause low fuel pressure?
- 04 stalls after crank/ performance
- Connector Fuel Pump Grand Prix 2000
- P0128
- 1997 gtp
- 98 GP GT 3800 rack replacement
- grand prix dic
- SE bumper on a GT-ugly?
- 1.0 PCM question
- 93 gp headlights wont come on
- qustions bout my ride
- 1997 gtp
- hot to reset
- Nokian tires?
- 1998 Grand Prix GTP won't shift!
- Help determining part
- p0108
- Fuel Gauge Question
- Easiest & Cheapest Power Boosters
- What is the best spark plug? HELP!
- sc pully
- Right Turn signal light not lit
- SS M90 kit for grand prix ?
- Changing fuel filter
- Engine Service Light
- Scan Tools
- 01 grand prix please help!!!!!!!!!
- Radio Backlight Problem
- 4th clutch shaft?
- Is this safe for the car?
- Paint
- P1585 Cruise Control Inhibit Output Circuit
- 2003 Grand Prix AC/Heat Problem
- 1999 SE brake fluid on the floor
- Plugs and wires
- Mystery Nightmare!!!
- Transmission Drain Plug Kit
- Headlights work but now Interior lights stay on
- 1997 Grand Prix 3.8 Fuel Delivery Issue
- 1999 grand prix se, windshield wiper ?
- HID in GP?
- How to change bushings in lower control arms
- Problem with 12 CD changer
- 2002 GP GT jerks from start
- Front end noise on 2000 GP
- heads are bad
- Replacing Headlamps
- Grand Prix 2000 A/C Condenser
- 92 oil leak
