View Full Version : Grand Prix
- factory alarm going off randomly
- pulley Upgrade Question!
- Now... I have a 2004 Grand Prix GT2
- 03' Leaking underneath the floor mats when it rains!
- 94 Grand Prix will not start
- the gas cap code
- 94 grand prix GTP runs real hot/overheatin. replaced pump and thermostat,still hot!!?
- GP Bonneville bolt pattern
- ZZP HID Headlight Mod
- Sunroof Slide Grease???
- '97 Grand Prix - Help Removing Compressor Pulley!!
- 2001 Grand Prix GT hard starting when the car is hot
- MP3 Player on 2006 Navigation/audio system
- Big Problem
- Shifter position is P but the car sees neutral???
- Aftermarket cd player dimmer?
- 1994 Grand Prix Transmission Help!
- code 401
- Tranmission swap from a 92 3.1 litre Gran prix to a 95 3.1 grand prix
- power window switch
- What to do?
- shift cable adjustment
- In honor of the 3800...a moment of silence!
- 05 Prand Prix code P0410
- Caliper Slide Pins Sticking
- SES Insanity!
- Map Sensor/Maf Sensor
- Changing fluid in grand prix
- 98 GTP with door buz, and radio cut of issue on start up.
- transmission goes to neutal
- Timing Chain / Oil Pump OPPS!!!
- MAF lb/min
- 99GTP moonroof visor help
- Hot in rear seat
- 97 pontiac gp code 121
- 1989 Pepsi car
- 97 Grand Prix SE surging
- Fuel pump?
- Swapped float on Fuel pump now it says empty
- remote start + alarm
- More Power out of 97 GTP
- Gas In Grand Prix Gtp's
- 2000 Grand Prix Lower Control Arms
- Wheel Bearing or???? Help Please
- Help!! Heading to College and my Grand Prix is giving me nightmares
- No handling at all in rain
- Vacuum leak
- '98 Gtp power rear mirror
- Coolant in my Oil
- 1999 GTP engine swap
- 97 Grand Prix GT RPM/Rev limiter
- 2003 grandprix se temp
- Many Issues and Can't Figure it all out!!!
- Fuel sender/gauge out of calibration?
- Fuel Gauge going from empty to fuel without putting gas in
- front end wobble = bad hub?
- immobilizer issue
- 01 GP GT ... Swapping seats and DIC.. READ PLS
- Blower Motor Issues
- Transmission Oil Cooler Radiator Fitting Leaking
- Catalytic Converter and Wheel Bearing assembly
- 4T60-E interchangability--97 GP GT
- Rear Passenger window
- Expected Life
- P0420 Code Emissions Problems
- code 171
- fuel problem
- 2000 Grand Prix po420 code
- Gas Mileage
- how in the frick
- A/C Refrigerant Leak - Possible Clue?
- Grand Prix Supercharger question, in need of expert opinion
- 06 Grand Prix Question
- Dual Climate Control Question
- 2003 Grand Prix SE: Air Conditioning Problem
- 95 grand prix problems.. help..
- Poly Mounts install
- 02 grand prix rear spring to tire clearance
- What does it mean? Help Plz!
- Just bought 2006 GP se
- Doors making noise over big bumps
- Checked KR on stock engine...
- Runs Very bad Please help..!!!
- Broken Glovebox
- Fuel capacity wrong
- Replacing Drivers Window - 98 Coupe
- outer tie rod torque setting
- 05 Grand Prix
- 99 Pontiac Gtp Fuel Tank Breather?
- drivers side fornt window replacement
- Engine knock on cold startup
- Power steering pump?
- 97 GT engine squeal
- 06 grand prix door lock problem
- UIM gasket
- Front Sway Bar
- Neutral Safety Switch
- Grand Prix Fog Light Switch
- 1990 STE dic module location
- Coolant Overflow cap 98GP
- 2001 grand prix starting problem
- Solve this myriad of problems :)
- Code P0300 - Random misfire
- 1994 Pontiac grandprix transmission problem
- Rear speakers cut in and out
- 96 GTP missing at speed
- 2007 grand prix looking for non oem headalights/tailights
- Strange buzzing in drive
- Aftermarket Cd Player
- Shocks
- car has very little power
- 1997 Grand Prix Speaker Sizes?
- 98 GTP oil pan gasket
- What kind of oil?
- Dual climate control conversion???
- SeaFoam
- Speaker question
- 98 grand prix btsi issues
- OnStar?
- abs light question
- tach drops to zero and traction cntl light comes on
- quad driver 4 fault
- Antifreeze Question
- left rear wheel speed sensor 2000 GTP
- Delay wipers issue
- Fuel pump replacement issues
- Door Won't Close!
- Cheap gas
- 98 GTP No headlights , common problems?
- 99 grandprix stumbles under load.. (new issues)
- Where to wire this gauge?
- Plug under hood question
- How to test for faulty MAF
- 97 grand prix blower motor
- 97 grand prix radiator problem...
- Replacement rocker panel moldings
- Introduction
- new brakes but still soft
- 3100 V6 Lower Intake Manifold
- How to get spark plug wires off a 3800
- Brake Failure
- Some problems on a 00 GTP
- 99 grand prix stumbles under load PLEASE HELP!!=)
- L36 3.8 N/A how much extra hp can be made
- 99 Gtp Intermitent Problem
- ZZP Downpipes
- Fuel leak?
- Real Quick Question
- Got an offer for a 2006 Grand Prix GT
- Cooling Fans not coming on A/C??
- Grand Prix Solid 34mm front stabilizer bar
- Power and 1/4 Mile, stock or otherwise
- stereo unlock code???
- 3800 to 3800 supercharged
- dust cap for front bearing nut?
- 2006 After Market Supercharger?
- Grand Prix GT- body painted
- Steering Noise
- GXP Tire Noise/Rotation
- Grand Prix Wheels?
- Turn Key No Start
- 1994 Pontiac grandprix transmission trouble
- Keyless Entry Module
- 3 Quick Questions
- Air Conditioning STINKS!!!!!
- 2006 Grand Prix yellow fog lights
- Plugs and Wires
- 1994 Grand Prix SE Transmission Help
- Tire Wobble Check
- Firewall Holes?
- Time for a new fuel filter
- Headlight Bulb Wattage?
- 1999 Pontiac Grand Prix
- 98 grand prix cruise control not working
- thermostat temp
- Air doesn't work
- 2001 Grand Prix PROBLEMS - hesitation
- Another tranny question.
- Several errors flashing - Help!
- Rhythmic thump in Front end
- Intake & Supercharger Bolt Torgue on '03 GTP?
- ABS light/Trac Off light/Check Tire Press light
- Define hard shifting
- 97 Grand prix transmission fit
- power window problem
- btsi troubles
- 1993 Grand Prix w/ 2002GP 3800 motor swap
- 2000 Grand Prix GTP suspension Clunk (another one)
- Installing a tach on a 02' GP motor
- my wife took my car to California last week
- My experience so far.
- 06 grand prix wont start after front end collision
- will not start
- Used parts for 2000 GP se
- Just bought another 2002 Grand Prix GT Problem
- Something is Missing
- HELP! 2007 Grand Prix GXP
- 3.1L V6 Engine
- Brake Help.
- "normal" values for OBD2 diagnostics tool
- Rhythmic squeak from front driver wheel.
- WIERD ENGINE RATTLE AT IDLE 98 gtp SC
- 2004 GP Spark Plug recomendations
- Radio
- 2002 Pontiac Grand Prix GT
- Speaker question
- annoyed with low electronic cut off speed
- Locked out of glove compartment
- '07 GP Parking lights always stay on.
- I need a new Grand Prix GT or GXP!
- 97 Grand Prix GTP with CJ2 a/c Option
- 1992 grand prix se seats issue
- 02 grand prix code 0440 gas mileage
- Electrical Problem II
- dragstrip times
- 2001 GP GT Blower motor problems... PLS HLP
- Windshield replacement
- 97 gtp front light lens fall off
- Fog Lights
- McLaren 60 Degree Engine Tune Up
- What Coolant To Use?
- glovebox lock in 1992 grand prix
- 1997 GTP electrical problem
- 1995 grand prix se / wondering what to do?
- Bolt Missing, Anyone know the size?
- electrical issues
- One problem down, one to go!
- What's With the #3 Cylinder Misfire?
- dragstrip tips?
- Wiper removal trick?
- Rear View Mirror Fell Off?
- 1990 Grand Prix LE tranny seal problem please help.
- Heater fan won't turn off?
- new struts and still clunking!
- Engine swap grand prix gt 3.8II TO 3.8 III
- 2000 gtp died, wont stay running
- Decent Wreck, Any Estimate of Cost? (Video Link)
- Front strut parts
- Engine Leak
- Misfire Cylinder # 3
- 104 octane stock ok?
- Grand Prix Cigarette lighter
- Smoke from near headers
- 1992 Grand Prix 3.1 Help Please
- CV Joint Inspection, Repair Procedures
- Had Recall 07035 done today et al.
- Multi Function Switch - Steering Wheel Removal
- 04 gtp
- 1.9 Rockers, Install
