View Full Version : Grand Prix
- Oil Change Interval
- 2000 GT RPM surge
- Low oil light question
- Ignition switch replacement and harness?
- lim gasket question
- steering wheel wobbles at slow speeds
- 2001 Pontiac Grand Prix GT w/ factory security system problem
- Windshield Washer Pump
- Lifting the Wiper Arm
- Removing belt tensioner?
- Swaying issue help
- '97 Grand Prix low coolant sensor issue...
- MAF issues
- multiport bolt up to a 3100 tranny?
- P0420 misinformation
- just wanna be sure about dexron vi
- 2000 GTP Lower Intake
- Flooded? What to do?
- Auxiliary Function in GTP stereo
- Transmission Slipping in 1st gear
- Freeze plug problems
- MaxLife DEX/MERC High Mileage... or Dexron VI Straight Up ???
- Dead car/DIC message
- 00 GTP - is the heated seat switch icon backlit?
- Deep Whine or Roaring sound
- 05 GP GT Radio Upgrade
- 96 GTP Power Steering Troubles need help
- 2001 Gtp
- Major problems??? Fuel pump or time for new computer?
- spark plug question?
- First time DIY -- Blower Motor Resistor Issue
- 1997 Possible HG Failure
- ABS and Trac Off
- 98 gtp won't start
- 3800 NA Lower Intake Gasket Pictures
- high pitched sound
- 99 GTP sputters, dies, idles odd. Only when warm.
- Radio is dead
- Help !!!! have moisture issues
- Aux input in factory radio
- Strange Electrical Issue
- Top Post Underhood Fuse Box Cable
- Crank Position Sensor?
- Cruise Control
- Use of Jack Stands?
- Programming Remote ( doing it wrong)
- Need some installation help with a 02 Grand Prix
- need advice on how much to sell car for
- roaring noise in wheel
- 97 Prix Se - Sensor Nightmare!
- Post Your Mileage
- Need help finding the right s/c belt!!!
- Vacuum line routing
- Brake problem
- aftermarket radio using steering wheel controls??????
- Dormann Power Window Regulator
- 95 grand prix no heat need help
- DIC bad? or just bulbs?
- 2006 Grand Prix electrical issue?
- 2001 Gran Prix 3800, CPS
- 1998 grand prix
- Label this 95 Master Cylinder (nonABS) diagram...
- Headlights adjustment
- Many problems on my 99' GTP
- 1997 Gtp Drl
- Daytime running lights not working
- Rear brake replacement 98 GP
- Rear Exhaust Manifold Gasket?
- 97 3.8L N/A Starts and Stalls Clogged Cat? Fuel Issue?
- 2001 Grand Prix-Key stuck in Ignition/Ignition won't turn
- Stray Connector ???
- Misfires, retarded ignition timing...
- ses light caused by?
- 98 grand prix MAJOR PROBLEMS need help asap!!!
- SE 3.1 engine died while driving
- Need help on how to change BACK brake pads on 2004 Grand Prix GT!
- SparkPlugs, Wires and Tuneups
- How to change front brake pads on 2004 Pontiac Grand Prix GT
- Missfire issues
- 2001 Grand Prix GT RPM's at 65 MPH
- 01 GP GT...Shifter sticks in park when cold. READ
- 98 gtp starting problem
- Very wierd feeling in steering wheel and noise.
- 2001 grand prix tire question
- Grand Prix 2002
- Oil Pressure Light Flickers
- Now a new problem
- Supercharged 3800 engine, issues?
- 02 Trans??
- 2001 water leak in roof
- Split/Open ICM Wire
- Popping noise over bumps, cold weather
- rear defrost and speakers on the fritz
- 2000 GP 3800 Coolant Leak
- Shocks and Struts advice please?????
- projector headlights
- rear caliper 97 grand prix
- 02 Grand Prix GT Starts hard smell of gas after starts
- Rpms+vibrating+light
- Fog lights wont work.
- SES light flashing while driving
- Service Engine Light
- 2000 GTP SES Light (P0420)
- Heat not working in all positions, and other problems.
- high amp alternator
- 05 Grand Prix GT - factory remote start blowing cold air!
- Trouble starting and stalling
- 1997 Grand Prix GTP Transmission Shifting Issue
- 2000 GT Heater Core
- speaker impedence
- Grand Prix Blower Vacuum lines
- 03 gp se 3.1ltr prob
- need help quick
- '02 GP Remote
- 94 SE High Idle/Car quits after a while... HELP!!
- 1995-96 Grand Prix GTP Wheels
- 1997 GTP getting poor mpg
- Third Brake Light
- '01 GTP, from a warm start it idles very rough
- 2000 GTP Shook PLEASE HELP. NEED ANSWERS SOON
- 2002 Grand Prix 2 problems
- Brake noise & pads still have meat on'em
- climate zone change
- Lights Out
- Blower resistor info
- Low Coolant Light
- Confusing Idle Problem....to high.
- Problem with 1993 Pontiac Grand Prix
- spark plug replacements on a 3.1
- exhaust kits for a 3.1
- 2005 GrandPrix Gt Stereo Swap
- 98 GP GT tranxaxle fluid questions
- what size downpipe?
- 2001 GTP Sluggish and Bogging Down
- Brake problem
- Wiper Motor Delay At 90 Degrees
- 2006 Grand Prix_Spark Plug Wires
- Car Keeps Shutting Down While Driving
- 2000 GT oil leak/coolant puddling top of engine
- 98 GTP Ticking after changing CPS
- P0401 and P0440
- Another '02 Grand Prix Heat Question
- 2001 GTP Problem PLEASE HELP!!!!!!!!
- 07 Seat Belt problem
- '99 Issue with blower motor?
- 97 gtp Drivers door wont open??
- Brake Problem? 2001 Grand Prix
- 94 grand prix no start
- JMB Performance Fenderwell Intake System
- trans popped?
- Just bought an '04 GTP?????
- K&N air filters ?
- 2000 GTP fogged headlights
- 3.1 Oil filter question
- Scan code for 4th clutch shaft?
- 2002 grand prix doors lock when in drive
- Oil on Lower Intake
- 99 GT won't start
- 2000 GTP Only Starts With MAP Unplugged
- '99 GT 3800 Pan Removal
- Scanner for my grand prix
- 97 Grand Prix turn signal problem
- GMPP Sway Bar Installation?
- Water on passenger floor board???
- lowering grand prix
- ABS/Wheel Hub Wire harness
- Axle shaft
- fuel pump question
- pcv valve location on 1989 grand prix?
- Loose Trans Pan bolts
- GTP 5 star rim or cheap rims
- Fuel Filler Neck
- wipers only work on high
- 2000 GTP bogs under boost
- 2000 Grand Prix GT - no power
- 2003 Grand Prix Vapor Locking?
- Need '95 GP Keyless remote wiring diagram
- towing with a 2002 grand prix 3.1
- REALLY loud fuel pump
- '06 Grand Prix trunk release
- Intrigue '99 3.8L Series II UIM & LIM Prep Questions
- How to Change Power window motor 95SE
- Racing my Grand Prix??? lots of miles??
- Transmissions
- information on replacing rds radio
- Keyless Remote,,, Nothing But Trunk ???
- GP Starting problem
- 2001 Grand Prix warm re-start trouble?
- Transmission question - 4t60e
- troubleshooting code help...
- Cold weather idiling....engine speed.
- key wont pop trunk
- dhp vs zzp pcm?
- best intake gaskets to use 3.1
- Heater blower not working?
- anyone know where the ground on the block is?
- 2006 GP 3.8 Auto Transmission Issue ?
- Headlight brighter then the Other
- Power steering issue. What could this be?
- Service Engine Soon light
- a/c fan and headlights
- enigine missing out
- Cat. converter
- wires under dashboard
- Windshield Washer Antifreeze
- 97 GTP Small ELBOW hose replacement?
- Will installing smaller pulley cause problems?
- custom paint job
- Grand Prix Door Adjuster
- 3.25" pulley
- 2002 Grand Prix GT Coupe getting poor MPGs low 20s in mixed Driving
- 2000 Grand Prix weird problem
- Louder than normal supercharger whine
- Axle Shaft
- 1991 grandprix transmission
- 2002 GP SE Heat Blower issues
- P codes related to the tranny
- 07-can't reset oil guage
- Heater Issue 00" Grand Prix
- 02 Grand Prix Starts then Dies...
- Aftermarket Rocker Arms, Valve Lash?
- shift kit
- 2000 grand prix gt 3800 non s/c pcv location
- Whats is the final call with DEXCOOL?
- Electrical Abnormalities
- Help with an oil leak
- starting/electric problem!!!!
- How many are now using HID kits?
- 2000 Grand Prix Secondary air pump
- How do I aim the headlight on my 02 grand prix?
- 2000 grand prix gt 3800 non s/c stall problem
- Erratic idle
- 2004 gt fuel pump rewire
- 92 GP SE Water Pump
- Outer Tie Rod Ends
- wheel studs
- CV Axle replacement
- transmission problem
- switching from Auto AC controls to Manual
- Larger throttle body, worth it?
- Wipers stop in upright position
- 2003 grand prix gt starts then dies
- Stereo/Speaker problems
- please help, car trouble
- P0128 code
- Huge Problem
- Trans slipping from a stop?
- stocked GTP
- piston slap question
