View Full Version : Grand Prix
- Clunk noise, thump under feet front of car
- Blower motor resistor?
- replaced hub - now I have abs and tcs lights on
- grand prix gt upgrade
- Rally style lights?
- DOOR PANEL BOLTS grand prix 2002
- Injector Seats
- Help with Fuel Pump Resister Relay
- no start: starter or battery?
- Blower Motor Resistor Replacement
- Black polish
- 2002 Grand Prix new CV and Hub bearing noise
- 2001 GTP needing some help
- 02 gtp ect location
- 02 GTP Need help!
- 2001 Grand Prix fuel gauge always reads full
- 1990 Grand Prix engine hesitation upon acceleration
- GTP Question Please Help
- Switching to synthetic
- Help with GM Part Number Please
- front sway bar
- 2000 gp 3.1
- 97 GTP looses power going up hill???
- 2003 Grand Prix rear camber adjustment?
- Trouble Codes for 01 Grand Prix GT
- Obdii "live data" ???
- resistor bypass
- Warped Rotors
- 2000 grand prix dic
- Heeeeeeelllllpppp!!!!!!!!!!!!!!!!
- 100k Tune-Up for 98 GT - All Stock
- Glowing Exhaust Manifolds?
- 1997 GTP problem
- Please Help
- Don't Know What To Do Next!!
- P1404 code came back
- Anti-Pogo washers
- 2005 Engine troubles...missing
- 2007 Pontiac Grand Prix Problems
- Cooling fans not working
- HID Harness help!
- Lower Motor / Transmission Mounts
- Whining noise with slight vibration
- Buying a Grand Prix
- Grand Prix stubborn hub/bearings.
- Weird car sound
- 05 GP - airbag light on/off when turning wheel!
- Traction control issue?
- hid upgrade which one?
- NO RPM Gauge and TRAC light on
- Replacing Power Steering Lines.
- Minnesota Winters vs My GTP
- thunderbird vs grand prix
- 97 gtp stalling... supercharger grinding?
- injector cleaner
- 99 GTP starts and then stalls
- passenger side door
- Clunking sound when shifting from R to D
- cant figure it out. Please help!!!! Thank you.
- Loud Thumping on driverside of car.
- 2002 grand prix gt
- 93 grand prix, 3.1 stalls
- Wrong forum I know
- Sometimes it pays to bring it to a tech
- 1000RPm on start up is that normal ?
- Air Not Cutting off, Draining battery
- Chevron Techron
- Help with 1999 Grand Prix GTP
- 1999 Grand Prix tach
- PLastic side skirt coming off
- SII 3800 Engine Polished Aluminum Valve Covers
- advice on plugs/wires
- need help,Ac 1-34 wont work,except 5.
- Piston travel exceeds block?
- Exhaust Question!
- Yet another coolant issue
- gtp fuel pump?
- swap harness question
- Reduced engine power warning & traction control off
- '02 Grand Prix, driving me insane
- Power Steering Noise
- Intermittant stalling on a 2000 Grand Prix with a 3.8 motor
- Lower and upper intake manifold gasket, help!
- Key stuck in ignition
- '05 grand prix wiper blades....
- 2000 Grand Prix backfire. Oops
- Stereo solution
- Alternator + bearing + front bumper replacement help please
- unlock my doors
- 2004 Grand Prix Gt Intermittent Start issues
- 1999 Grand Prix has spark but won't start.
- Battery cut off switch
- 1997 pontiac gp se strut removal help
- headlight replacement
- power window switch center removal 2001 gp
- can someone help me with my right front axle plz?
- 2000 Turn Blower Fan on and Headlights go out
- 91 3.4 Not firing on 2 and 5
- Fuel Pump Not Prime
- 96 GTP Reverse Acting up Need input !
- 2004 gt starts and stalls
- grand prix theft detterent system
- replaced alot, still won't start
- mpg help
- Crazy wipers
- Hydrogen Generators
- Fuel Pump Problem
- L36 to L67 swap
- No power PLEASE HELP
- belt tensioner
- Random Missfire 01gt
- struts
- Transmission?
- 3.8 GM intake manifold replacement/instructions
- RPM Wavering, surging/hesitation
- 2001 Grand Prix catalytic converter
- comp cams gt2
- 04 GT Dyno results :(
- Need more Juice...smaller pulley or new alternator
- 97 gt weird alternator problem
- Transmission Mount Issue? Or something else?
- Sludge problem in oil pan
- My car Broke down last night ...
- were is fuse to blower motor
- Seafoam-ing
- 98 GT 3.8 - Terrible MPG
- Flooding symptoms
- PLEASE HELP high rpm power loss
- 2000 GP Blower Motor Resistor how to replace
- 2006 gt suspension noise
- help
- DIC Problem
- blower motor not working
- 2002 GTP EngineThermo/Fuel Filter
- 2000 Grand Prix Se Shock Issue?
- '97 GT Noise at At Start up
- headers
- pcm-bcm software
- Transmission?
- 2002 Grand Prix fuel pump location
- Alignment problems
- 98 GP-GT No heat
- UIM/LIM Replacement Procedure.
- Bad Vibration or Shaking
- 2000 grand prix stalls
- Front Fender Removal
- 94 Grand prix se stalls
- Running a power wire in a 2004 Grand Prix GT
- Air Vents - low air flow
- Followup to 2000 GTP starting issues
- Exhaust Rattle from below?
- GTP Transmission Overheating?
- 1994 Grand Prix se several problems
- Drivers side axle shaft help?
- Spark knock after Installing a K@N Cold Air Intake
- Serious Problems?Serious Problem?
- G6 GTP wheels on a 1997 GTP?
- Low cooling temperature
- 97 GT No juice to Fuel Pump
- LEDs for headlights? possible?
- Fog Light Lense Replacement
- 94 Grand Prix
- Intake manifold
- Stat problem?
- P0171...I hate this code
- How to replace brakes on 2001 GT?
- Fuel Filler Neck Flap Missing?
- Cam Positioning sensor and removal tool for 1992 Grand Prix
- uig & lig ?
- 97 3.8L tiny water leak
- 2000 Grand Prix 3800 Problems
- 2000 grand prix 3100 overheat
- pfyc spoiler
- Axel shaft
- Climate Control / Blower Motor
- Transmission
- ZZP HID Headlights (not very happy)
- Trying to determine if 99 Grand Prix GTP has Magnasteer
- starts then stalls
- 1995 Grand Prix SE-anti theft issues
- TCS light always on????
- supercharger problem...
- cold starts?
- replacing dash lights with led?
- safe pulley size for my mods
- The ranking of Headers?
- Thump Thump Thump from front passenger.
- Hood Release Cable
- No 92 octane in Az, is it safe to run a 3.4 pulley?
- 140k Service
- Radio Stays on After Key is off, Doors won't lock
- Mobile 1 30wt oil and super charger?
- GTP drive train help??
- Part information
- stall problem
- humming noise
- no lights..
- High and Low Beam Problem
- ABS Light + Check Tire Press. Light Problems
- Headlight and control panel light malfunction
- 2nd bank O2 sensor replacement
- Symptoms of A Flaky Speed Sensor?
- Where to lube?
- Fuel Gauge Reading Incorrectly
- jumping idle when releasing gas pedal
- 96 grand prix se poor gas mileage
- bad pcm?
- 2001 grand prix repair manual
- 98 GTP no spark on one coil only
- front end noise, 2001 GP
- exhaust cutout pointless?
- Where to buy/Order Btsi connector 97 GTP
- Economical Brake Upgrade
- 89 GP 3.1 timing mark for replacing timing chain
- Raybestos Wheel Hubs
- heater making noise
- Heads Up Display
- O"reillys auto and blower resistor issue
- white smoke/consuming coolant
- 2002 grand prix p0176 obdII code
- where is the theft deterent relay..
- Need Help with rough idle...this one stumps even me...
- Would It Hurt To Use Rtv On Intake Gasket?
- Cork Intake Gasket?
- Wiper Assembly
- Help with GTP neg Tach reading and then Dying
- blower not working
- Gas Cap Rant
- 2000 GT temp guage
- correct position of head gaskets?
- head bolt thread sealant?
- vacuum modulator location?
- P1404 need a new EGR valve?
- mirror........
- 3.1/3.4 Intake Manifold Gasket R/r
- Vehicle Anti Theft Modules?
- making a set of intake gaskets?
- gasket sealer on head gaskets?
- grand prix which head gaskets?
- loud noise under the hood.
- Ignition switch problem???
- Tension assembly woes
- po301cylinder 3 misfire
- Removing iron torque-strut/coil pack bracket on L67
- EGR Issues
- easy dogbone mount removal?
- Passkey 3 help please
- grand prix overheating
- Sourcing a new OEM-style radiator hose clamp
- Wiper woes...
