View Full Version : Grand Prix
- P1811 code
- oil ???????s and then some
- Wiper Fluid Reservoir
- Anti-lock brake problem
- Drivers side temperature actuator - how to
- No Codes, but Not Ready
- AC Issues - Suggestions needed ASAP
- Noise from front end
- 2002 Grand prix cooling fans
- 2005 Grand Prix, Drivers power seat not working
- Let's talk about hood removal.
- Interior Door Part Help
- Leak in AC Compressor HELP
- need help if possible
- Transmission Problems
- Emblem placement ('01 GP GT 4dr)
- Driver side window won't roll up...
- Problem starting
- Grand Prix Starting Problem
- 99 GTP Won't Start
- mods
- fuel relay problem
- issue with shaking headlights
- 98 GTP aftermarket security wiring
- FYI - C0245 - Wheel Speed Sensor Frequency Error
- Trans issue, any ideas?
- how much is to much?
- Engine support cradle detached from my car !!
- Dome light disconnected in 7th gen grand prix
- 00' GP car charger doesn't work!!
- a/c repair quote..am I being ripped off?
- 300hp????
- How to get half shaft off from engine side?
- safety recall 09047
- Check Engine Light
- Upper/Lower Intake Manifold Gaskets? Help!
- Tried Charging Freon Story HELP
- Car does not always have full power (acceleration)
- parking break turns on while accelerating??
- heated seats on daytona grand prix
- AirBag Sensor? Totaled GTP
- 2003 Grand Prix GT - Electrical Problems
- gas or oil leak
- race time
- stupid steering wheel
- Vacuum Leak
- car wont stay running
- removing front seats
- Brake Pads
- HUD Display
- which way do i go
- Mechanic Chicago Burbs
- 2000 Grand Prix Strut Replacement
- Sunroof issues 97 GT
- Oil Plug
- speedometer suddenly stoped working
- more ???????s
- How to remove head bolt from cylinder head?
- 97 pontiac gp door lock problem
- Strange Vibration
- 2000 Grand Prix GT stalling
- 1.0pcm/ 3.4pulley
- Headlights Dim/DRL Not Working
- Maaco body shops?
- Could it be Caliper time? I think so! 99 GTP, 128kmiles.
- 2002 pontiac grand prix gtp sway bar size
- Special Edition, mod or not?
- Car Waxes
- 02gtp/dic/ac/daylights went out
- need a sway bar. OEM or aftermarket?
- pass side headlight
- P0440
- Vent problems
- more ???????????s
- what should i do first?????
- AC Help Needed
- Aftermarket Radio
- fuel filter?
- Resetting Change Oil indicator on dash
- Procedure for replacing spark plugs
- 2000 GP GTP fuel pump
- Service Engine Soon - P0138
- need ?????s answered quickly
- power window issue
- 97 grand prix dies
- P0449 evap vent code
- headlights?
- New Spark Plugs
- exhaust
- Wheel Hub Question
- gtp wont start fuel pump not turning on
- A/C Help
- 99 grand prix GTP tensioner rattle
- G-Body Grand Prix Parts
- 1994 grand prix cutting out helllp
- Stupid Question no one Can Answer
- led tail lights
- trailing arm question
- throttle body cleaning
- breather cap
- Best Drop in Paper Air Filter
- changing tranny oil/fluid?
- Wipers Stuck Straight Up
- newbie ?????????s
- Intermittant Power Windows Issue
- ceramic resistor
- Frozen wheel hub 2002 Grand Prix
- 1990 SE Broken Inner Door handle
- how dumb can GM be
- Emissions Test Failure
- 2 Quick Questions....
- 2000 Grand Prix GTP LIM Gaskets
- alternator color HELP =)
- Alarm
- 2002 gtp vertical control arm bushing
- Heater Core bad in 8 months? Urgent - Help Please
- Help
- 02 sensor ses light
- 98 GP GT 3800 Auto 123k coupe - TRANNY?
- Aftermarket stereo deck
- Loud Humming Noise
- Sway bar starting to crack
- need help A.S.A.P
- Labor on Fuel Filter
- 2008 GP GXP-Service Stability System?
- So this is how it ends..... {hears taps playing}
- Coolant
- Where to buy????
- How easy is it to replace a/c refrigerant on 2003 grand prix
- Differences between 97-03 GP's and 04-08 GP's?
- New Car Options
- 2003 Grand Prix-Door locks unlock randomly
- Factory Boost Gauge
- Ac Compressor Question
- New paint, one fog light out?
- quick bulb question
- GTP vs Eclipse
- shocks/springs
- rear speakers
- How to remove driver's kick panel-2003 Grand Prix SE
- cooling problems
- i gave my x a possesed car and its haunting me any ideas please
- newbie ???????s
- sitting low in the back
- Rear Wheel Hub/Bearing Removal
- I think I may have just made one of the studpidest and funniest mistakes ever. help
- alternator rating
- How much oil?
- Oil pan gasket?
- want more pep for cheap?????????
- Grand Prix GTP 2000 HUD replacement
- 94 Grand Prix Door Handle Installation
- 2007 cruise control
- clear corners
- GTP Idles rough for a few minutes, engine vibrates all the time.
- 08 grand prix obd code p0411
- Rear Brakes Stuck?
- L67 to l36 engine swap!!
- 2004 gp gtp
- 1997 GTP A.C. compressor question
- 1991 Grand Prix, Wet Plugs, Running rough
- drl fix update
- Grand Prix supercharger
- LIM gasket
- Plug Wire Problem
- 97 Grand Prix GTP
- wires/plugs/coil packs
- 2002 Grand Prix GT 3.8 V6
- Changing Ball Joints 97 GTP
- Classic Prix's
- 2002 gtp passanger side rack boot leak
- gtp running rough and gutless
- RTV sealant on LIM
- Removing/Installing Rear Bumper Cover
- oil on plugs
- Please help, bad vibration coming from front end
- 1999 G.P.GT Died
- wipers/rust
- part number
- intake manifold on 2000 grand prix 3800 engine exploding
- New Recall
- radio harness for 2002 gtp with bose system.
- '01 GT, ABS light on and Traction control always off
- 5spd on a '98 GTP
- Air in the face
- whining noise
- What are some good reliable cars that are cheap ?
- headers yes or no
- 2002 Grand Prix 3.8 cutting out???
- 2000 Pontiac Grand Prix GT After Market Wheel Hub Centric Ring
- What type of gas mileage do you get?
- '06 3.8 dead cylinder
- lots of rock chips on hood
- What is the best OBD-CAN code reader
- 98 GTP headlight/electrical problem
- Local Mechanic
- 2002 grand prix gtp radio problem?
- Fuel Filter install
- what size are the door clips
- Sunroof Controls Leak during heavy rain
- daytime running lights
- 2000 GTX rust below fuel door
- security torx size?
- problem with keyless and lights
- I'm Stressed Out - Keyless Entry
- 2002 grand prix gtp brake control module?
- the inspection garage broke my headlight adjusters!
- hids on ebay?
- 02 GTP S/C Question
- 99 gtp
- want to upgrade suspension
- shifting problems???
- '99 GP/GT Instrument Cluster Problem
- terrible...!!! AM/FM reception
- simple queston i hope
- 1998 pontiac grand prix gtp 4T65E HD tranny problem and dtc's!!!
- Major Oil Leak Front Side of 3.1L
- 03 Grand Prix GT Odd Noise
- 2001 Grand Prix code
- car won't start
- Intake End Cover Gasket Question
- wiper problems
- noise on 97 grand prix
- running speaker wire to doors
- MIL P0410 - I need to Pass NY Inspection
- Climate Control Backlight Went Out..
- 02GTP BatteryChargingSystem/Engine Oil Pressure Indicator Light
- Torque converter slippage and harsh engagement
- NGK Iridium 7s and 8s ???
- Rough idle 1999 Grand Prix
- Help Help. I screwed something up
- Please help me with my 97 grand prix!!!!
- 1999 Grand Prix GT Brake Problem.
- 95 gtp sunroof problems
- 02 GTP Shifter Assembly
- trans slipping?
- New sound
- 97 GTP Weird Nosie?
- Supercharger Problems ('97 Grand Prix GTP)
- GTP Anti-Freeze Leak
- Stupid DIC question
- 3800 Starts then shuts off
- Outter Tie Rod? Spark Plugs? Outside Door/Lower Trim
- front strut binding when turning
- Wiper Blades Park Position
- 97 GTP supercharger oil contamination
- VIN Engine codes
- Fan Blower resistor problems -replaced 3 in last 3 months
- Fuel issues
- 01 grand prix surging at idle
