Our Community is 662,000 Strong. Join Us.
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Mazda
> 323/Protegé/Familia/Etude/Allegro
View Full Version :
Pages :
1
2
3
4
Why are my P5 serpentine belts squealing?
02 Protege burning oil, possibly running rich
2001 Mazda Protoge overheating
2002 Protege Overdrive Light
03 mazda protege. battery drains because of possible short .
Protege (2001) will not turnover
exhaust pipe flange broken
Mazda Protege5 Having Trouble Starting - Maybe Alternator?
So my 2003 Mazda Protege went nuclear in the engine today.
premacy clutch problem scraping sound
2002 Mazda Protege5 - OBDII communication failure
Repairiing the accordion pipes
98 protege 1.5l DOHC timing marks
no high beam 90 protege
2000 Protege check engine light + screeching/scratching noise during acceleration
Mazda 323, 94 1.5L into 92???
Protoge keeps dying
Breaks keep getting tight
1998 Mazda Protege Trouble code help?
No lights
Needs fixing quickly
95 protege' lost dash lights and tail lights
P0850 code
02 timing belt 2.0L
Transmission flush on my 2003 Mazda Protege LX?
Whats wrong with my wheel alignment?
2002 protege dx 2.0ltr stalling
1996 Mazda Ac compressor bypass
1995 mazda protege lx engine light is on ?
1999 Mazda Protege NO Power Steering
01 Protoge 1.6 head
1994 Protege engine/RPM guage revs up & down on its on at stop light with brake on.
2001 Protege front end shake and a check engine light
What brand of spark plugs should I buy for my 2003 Mazda Protege?
Check Engine Light; code says "Running Lean"
two problems, stereo/check engine light
Spark plug threads sheared off
2000 Protege ES, 85k miles, Front brakes
1992 323 Electrical/computer problem
Wabbly steering...sometimes? Rust too...
Help!!!
I'm in trouble...
1991 Mazda 323 Crutchfield MasterSheet
Is is safe to drive my 2001 protege (107K) to Florida
2001 protege battery light on.
Rough idle
Gas hard to push when accelerating...why?
Stalling on a right turn?????
93 Mazda Protege shuts off after hot
I need some expertise!!!!!!!
Cam shaft sproket bolt and dowel pin broke
flushing power steering ?
Oil Pressure switch
oil pressure switch
Programing issues
323i where is the dash water temp gauge sender?
Alternator question
Tire Substitution Question 195/50/16 for ?
99 1.8 protege ES (auto)
OEM Seat Covers
2003 protege
2003 protede 2.0
replaced egr and now.....2003 protege
99 Mazda Protege, what color coolant was original?
'03 Protege5 burning through headlights
96 Protege really loud!
I need help with my 95 protege lx.
Installing Viper Alarm with Keyless entry.
1998 Protege won't start
suspension link kit - simpleton or expert?
Transmission level
Hesitation/rough idle on cold start
1988 mazda 323
1989 323/Tracer with blown head gasket
'03 Prot5, ABS and E-Brake dash lights on
96 protege overheating
97 Mazda Protege - repairs/time for new car?
2004 Mazda Protege
2002 Mazda Protege 2.0
97 familia /323 auto transmissions issue
02 protege dx a/c question
Protege oil filter?
01 Protoge sputtering and low power
1994 dohc over heated now wont start
Looking to buy a 2001-2003 Protege
'99 Protege, Battery light comes on, loss of power
Mazda Protege very hard to start after resting
94' Protege DX with SOHC 4cyl "knocking"
Horrible belt noise on 1.6L 2000 LX
The unfindable fuse..
Mazda Astina performance?
1997 Protoge Driveability Issues
2002 Protege Vibration
question
Mazda 323 rims installation question
2002 Protege5
Mazda Protege5 323F Familia Lantis Parts <== Here
mazda 323 imola engine change
02 Protege Dx Timing Belt Question.
1999 Mazda protege Oil Light will not turn off
95 protege left side problem
Update: September: Carfield Enterprise- Mazda Stuff
91 Protege distrubitor pickup coil
1988 323 GTX for sale - NE IL- Parts requests being taken!!
'91 Protege - Mysterious Problem
HELP!! engine noise
Blowing injection fuse
96 Protege' 1.5L 5 speed
2001 Protege 1.6L
ATF type for protégé 2002
93 protege air conditioner chugging
Wheel Bearing 2000 Protege
93 protege. horn going off
97 Mazda Protege - brake bleeding
1992 Protege driven without oil. Won't start!
horn location
Jack rabbit acceleration
clogged injector or something...Help!!
no spark to plugs help plse
93 mazda with drivers side front wheel squeak(??)
2003 Mazda Protege DX Questions.
Two Part
'98 lx 1.5l with a P0505 code
'98 Protege' dash lights
Wrong rims & tires
sloppy shifter problem
Clicking/Clanking when I turn ('94 323)
02 protege timing belt
'98 lx 1.5L/5speed with scraping noise
How do you connect O2 wires?
Headlamp
02 Protege5 A/C problem with vent controls
02 Protege5 Overdrive not turning on..
Looking for handbrake cable for mazda 323
Weapon R SRI
Help identifying my model of car
Protege 2002 ignition issue?
98 Protege LX brake drum removal
1998 Protege
Headlight Bulb Replacement?
P0031 what do I do?
Turn signals on and off (99 Protege)
Help With An '87 323.
need new engine
1999 Protege Gasoline smell in oil
temp. control sliders
98 thermostat
Mazda CD Radio
`98 Protege o2 sensor location?
Flashing engine light, no power 2002 protege
2000 Protege Radio Help
No reverse lights- neutral safety switch?
Site for Protege Help
Compatibility intake manifold
Airbag Passenger side
93 protege OBD port...
1998 Protege - Rim Size
2002 Protege Cruise Control light?
Protege Tire Size Question re substitutions
2003 323 Sp20 Astina - Rattle Sqeak
92 protege window motor clicking
who's got the most mileage on a Protege
1997 Protege LX
97 Protege LX - check engine light
Clutch Problem?
1990 Mazda Protege/323
Steering wheel needed
Keyless Remote Entry Instructions For Mazda 323 2003 Astina Sp20
please help!!!!!!mazda 626
03 protege clock problem
A/C dies, speedometer dies, and CHECK ENGINE light comes on all at once- '02 Protege
'97 Protege will not start
94 protege sohc. dohc head swap?
High Idle at start?
1990 mazda 323 , help ....
2002 Protege5 Auto Tran Chirp
2000 Protege overheating Need advice
STOP the beeping please--seatbelts???
Rough Idling in 1996 Mazda Protege
Cooling fan problem Protege DX 1999
1998 Protege
Update: 30th July 2007 - Carfield Enterprise Mazda Stuff
EGR Problems
You dont see 323
2002 Protege popping noise
2002 Protege Overdrive Problems
93 protege wheel lock...
1994 Mazda 323 Won't Start
Axle Tramp
Prefect Mazda AZ1@HK (Clips)
Looking at buying a 03 protege5
firing problem with my 90 protege DOHC
Looking for a b6t + tranny
question about my 02 protege
1994 Mazda Protege Problems (gas cuts out?, read on)
2003 protege RPM & possible trans problem
323 clacking noise in turns
Mazda National Day – Orlando, Fl – Jul/28/2007
Update: 11st April, 2007- Carfield Enterprise- Maz
Buying 1999 Protege LX
97 protege rpms fluctuating
323 code
1990 mazda protoge starting problems
98 protege
77 323 RWD Hatch
failed emmissions
Waterpump replacement for 88 Mazda 323
performance questions
1991 323 timing pully
96 mazda protege wont start
95 protege muffler
'93 Protege LX pulls to left
bad pulley?
Performance Parts For 93 Mazda Protege
Idle fluctuation problem 92 Protege 1.8 DOHC
2002 Protege 5 Rpms Hunting
Radiator fans cycle when heat turned on
323 engine swap
removing radio from 2000 protege
Installing new gear shift knob
Atf
odd sound from protoge
Protege 5 Blower Motor
Issues with a Protge 96 clutch
2002 Protege misfire
Damn, transmission problem
Replacing a Thermostat?!?!? Help please
Protege5 keyless entry
Thinking about buying a 93 Protege
Key does not turn
I'm a Newbie Who Needs Help
2001 Passenger Mirror
323 body rebuild
1988 Mazda 323 GTX HELP PLEASE!!
F/S: 323/protege bp-t GTX MOTOR + GOODIES
Questions: 2001 Protege/5 Speed Trans Oil Change/Fuel Filter/Wireless Door Locks
P0171 error
1.8 L no spark
First timer! Can anyone help me work out what might be wrong with my 323?
1995 madza protoge distributor
How to change spark plugs
Shop manual - what is available
2001 Protege question
eengine problems on 93 protege
MAZDASPEED MEET @ Tropical Park Miami
my trunk wont open
1995 Mazda Protege Over Heating and shutting off
Please help me identify the origin of a coolant leak
Automotive Network, Inc., Copyright ©2012
