View Full Version : 323/Protegé/Familia/Etude/Allegro
Pages : [1] 2 3 4
  1. 99 1.8 protege ES (auto)
  2. OEM Seat Covers
  3. 2003 protege
  4. 2003 protede 2.0
  5. replaced egr and now.....2003 protege
  6. 99 Mazda Protege, what color coolant was original?
  7. '03 Protege5 burning through headlights
  8. 96 Protege really loud!
  9. I need help with my 95 protege lx.
  10. Installing Viper Alarm with Keyless entry.
  11. 1998 Protege won't start
  12. suspension link kit - simpleton or expert?
  13. Transmission level
  14. Hesitation/rough idle on cold start
  15. 1988 mazda 323
  16. 1989 323/Tracer with blown head gasket
  17. '03 Prot5, ABS and E-Brake dash lights on
  18. 96 protege overheating
  19. 97 Mazda Protege - repairs/time for new car?
  20. 2004 Mazda Protege
  21. 2002 Mazda Protege 2.0
  22. 97 familia /323 auto transmissions issue
  23. 02 protege dx a/c question
  24. Protege oil filter?
  25. 01 Protoge sputtering and low power
  26. 1994 dohc over heated now wont start
  27. Looking to buy a 2001-2003 Protege
  28. '99 Protege, Battery light comes on, loss of power
  29. Mazda Protege very hard to start after resting
  30. 94' Protege DX with SOHC 4cyl "knocking"
  31. Horrible belt noise on 1.6L 2000 LX
  32. The unfindable fuse..
  33. Mazda Astina performance?
  34. 1997 Protoge Driveability Issues
  35. 2002 Protege Vibration
  36. question
  37. Mazda 323 rims installation question
  38. 2002 Protege5
  39. Mazda Protege5 323F Familia Lantis Parts <== Here
  40. mazda 323 imola engine change
  41. 02 Protege Dx Timing Belt Question.
  42. 1999 Mazda protege Oil Light will not turn off
  43. 95 protege left side problem
  44. Update: September: Carfield Enterprise- Mazda Stuff
  45. 91 Protege distrubitor pickup coil
  46. 1988 323 GTX for sale - NE IL- Parts requests being taken!!
  47. '91 Protege - Mysterious Problem
  48. HELP!! engine noise
  49. Blowing injection fuse
  50. 96 Protege' 1.5L 5 speed
  51. 2001 Protege 1.6L
  52. ATF type for protégé 2002
  53. 93 protege air conditioner chugging
  54. Wheel Bearing 2000 Protege
  55. 93 protege. horn going off
  56. 97 Mazda Protege - brake bleeding
  57. 1992 Protege driven without oil. Won't start!
  58. horn location
  59. Jack rabbit acceleration
  60. clogged injector or something...Help!!
  61. no spark to plugs help plse
  62. 93 mazda with drivers side front wheel squeak(??)
  63. 2003 Mazda Protege DX Questions.
  64. Two Part
  65. '98 lx 1.5l with a P0505 code
  66. '98 Protege' dash lights
  67. Wrong rims & tires
  68. sloppy shifter problem
  69. Clicking/Clanking when I turn ('94 323)
  70. 02 protege timing belt
  71. '98 lx 1.5L/5speed with scraping noise
  72. How do you connect O2 wires?
  73. Headlamp
  74. 02 Protege5 A/C problem with vent controls
  75. 02 Protege5 Overdrive not turning on..
  76. Looking for handbrake cable for mazda 323
  77. Weapon R SRI
  78. Help identifying my model of car
  79. Protege 2002 ignition issue?
  80. 98 Protege LX brake drum removal
  81. 1998 Protege
  82. Headlight Bulb Replacement?
  83. P0031 what do I do?
  84. Turn signals on and off (99 Protege)
  85. Help With An '87 323.
  86. need new engine
  87. 1999 Protege Gasoline smell in oil
  88. temp. control sliders
  89. 98 thermostat
  90. Mazda CD Radio
  91. `98 Protege o2 sensor location?
  92. Flashing engine light, no power 2002 protege
  93. 2000 Protege Radio Help
  94. No reverse lights- neutral safety switch?
  95. Site for Protege Help
  96. Compatibility intake manifold
  97. Airbag Passenger side
  98. 93 protege OBD port...
  99. 1998 Protege - Rim Size
  100. 2002 Protege Cruise Control light?
  101. Protege Tire Size Question re substitutions
  102. 2003 323 Sp20 Astina - Rattle Sqeak
  103. 92 protege window motor clicking
  104. who's got the most mileage on a Protege
  105. 1997 Protege LX
  106. 97 Protege LX - check engine light
  107. Clutch Problem?
  108. 1990 Mazda Protege/323
  109. Steering wheel needed
  110. Keyless Remote Entry Instructions For Mazda 323 2003 Astina Sp20
  111. please help!!!!!!mazda 626
  112. 03 protege clock problem
  113. A/C dies, speedometer dies, and CHECK ENGINE light comes on all at once- '02 Protege
  114. '97 Protege will not start
  115. 94 protege sohc. dohc head swap?
  116. High Idle at start?
  117. 1990 mazda 323 , help ....
  118. 2002 Protege5 Auto Tran Chirp
  119. 2000 Protege overheating Need advice
  120. STOP the beeping please--seatbelts???
  121. Rough Idling in 1996 Mazda Protege
  122. Cooling fan problem Protege DX 1999
  123. 1998 Protege
  124. Update: 30th July 2007 - Carfield Enterprise Mazda Stuff
  125. EGR Problems
  126. You dont see 323
  127. 2002 Protege popping noise
  128. 2002 Protege Overdrive Problems
  129. 93 protege wheel lock...
  130. 1994 Mazda 323 Won't Start
  131. Axle Tramp
  132. Prefect Mazda AZ1@HK (Clips)
  133. Prefect Mazda AZ1@HK (Clips)
  134. Looking at buying a 03 protege5
  135. firing problem with my 90 protege DOHC
  136. Looking for a b6t + tranny
  137. question about my 02 protege
  138. 1994 Mazda Protege Problems (gas cuts out?, read on)
  139. 2003 protege RPM & possible trans problem
  140. 323 clacking noise in turns
  141. 323 clacking noise in turns
  142. Mazda National Day – Orlando, Fl – Jul/28/2007
  143. Update: 11st April, 2007- Carfield Enterprise- Maz
  144. Buying 1999 Protege LX
  145. 97 protege rpms fluctuating
  146. 323 code
  147. 1990 mazda protoge starting problems
  148. 98 protege
  149. 77 323 RWD Hatch
  150. failed emmissions
  151. Waterpump replacement for 88 Mazda 323
  152. performance questions
  153. 1991 323 timing pully
  154. 96 mazda protege wont start
  155. 95 protege muffler
  156. '93 Protege LX pulls to left
  157. bad pulley?
  158. Performance Parts For 93 Mazda Protege
  159. Idle fluctuation problem 92 Protege 1.8 DOHC
  160. 2002 Protege 5 Rpms Hunting
  161. Radiator fans cycle when heat turned on
  162. 323 engine swap
  163. removing radio from 2000 protege
  164. Installing new gear shift knob
  165. Atf
  166. odd sound from protoge
  167. Protege 5 Blower Motor
  168. Issues with a Protge 96 clutch
  169. 2002 Protege misfire
  170. Damn, transmission problem
  171. Replacing a Thermostat?!?!? Help please
  172. Protege5 keyless entry
  173. Thinking about buying a 93 Protege
  174. Key does not turn
  175. I'm a Newbie Who Needs Help
  176. 2001 Passenger Mirror
  177. 323 body rebuild
  178. 1988 Mazda 323 GTX HELP PLEASE!!
  179. F/S: 323/protege bp-t GTX MOTOR + GOODIES
  180. Questions: 2001 Protege/5 Speed Trans Oil Change/Fuel Filter/Wireless Door Locks
  181. P0171 error
  182. 1.8 L no spark
  183. First timer! Can anyone help me work out what might be wrong with my 323?
  184. 1995 madza protoge distributor
  185. How to change spark plugs
  186. Shop manual - what is available
  187. 2001 Protege question
  188. eengine problems on 93 protege
  189. MAZDASPEED MEET @ Tropical Park Miami
  190. my trunk wont open
  191. 1995 Mazda Protege Over Heating and shutting off
  192. Please help me identify the origin of a coolant leak
  193. 2001 Protege 2.0 liter engine - oil change
  194. white smoke from vavle cover
  195. HELP! 97 Protege overheating!!!
  196. blower motor, wiper linkage. tune up questions
  197. 96 protege
  198. Engine Mounts
  199. 2000 Protege
  200. will 14inch rims from 1992 miata fit on 1993 323
  201. code 1195
  202. No Turn Signals or Hazard lights...
  203. blow off valve for intake
  204. Cant find the fuel filter
  205. Protege airbag warning light
  206. anybody changed a waterpump on a 1.5?
  207. 91 Protege noise when AC is on
  208. what other vehicles use the same part
  209. Changing front rotors ?
  210. Changing sway bar bushings on a 1995 Protege
  211. Timing belt change
  212. the 95 mazda symbol...
  213. Is my 323 got fuel problem?
  214. Horn Problems
  215. is a 95 protege obd 1 or obd 2?
  216. 2001 Protege: RPM's High
  217. stabilizer bar in 95 protege
  218. Where is the power steering drain plub?
  219. instrument cluster removal - 93 protege
  220. weird problem in a 323
  221. shifting getting rough
  222. SOHC swap to DOHC
  223. crank shaft seal
  224. re-zero my car comp.
  225. 2002 Protege
  226. 2001 ES squeaks before downshift?
  227. 92 protege
  228. Spastic seatbelt light light - 94 Protege
  229. i need help
  230. replacing timing belt 98 protege 1.8 dohc
  231. bad acceleration!
  232. check engine light 96 protege
  233. Fs: 323 Gtx
  234. 93 protege Just started running like crap!! help?
  235. no power to fuse boxes but headlights work
  236. 91 protege lx DOHC Firing order?
  237. help with turn signal switch
  238. Protege Vavle cover Gasket
  239. bad gas mileage on 2002 protege5
  240. 1999 Mazda 323F LX Suspension
  241. Over Heating 02 protege5
  242. Questions about 323
  243. Need a web site to SOUP UP 94 Protege'
  244. Turbo needed!!!
  245. Locks Don't Work
  246. 1988 Mazda 323 GT problem help...
  247. depresurize fuel system on 02 Protege?
  248. After market options for 01 Protege Mp3?
  249. dash light problems
  250. *wanted* looking 4 a 323 GT-R ECU and a wireharness
