Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Mazda
> 323/Protegé/Familia/Etude/Allegro |
View Full Version :
Web
AF
Pages :
1
2
3
4
*wanted* looking 4 a 323 GT-R ECU and a wireharness
Removal of Crankshaft Pulley Bolt
97 Mazda Protege Vibrates on idle
1993 Mazda Protege - Temperature Gauge High
Tune-up intervals
Thinking about buying a '98 Protege
Question regarding a 1998 Mazda Protege LX Touring Edition
am i in the right forum for protege5?
2K Pro 1.8L P0171 DTC
PS Pump -- Help ASAP PLEASE!!
escotGT/323 enigine swap
lookin for 323 3 door
Valve clearance.....
South Florida Mazdaspeed Protege Meet
87-323 Wagon vs HB interchangability
Protege 5 starts to shudder when car is warm
Putting New Wheels On
loss of power at low rpm's
Looking for used 323
92 mazda protege
91 Protege wont start
91 Mazda 323 DOHC Timing belt broke...
where have i been
check engine light
1992 protege hood problems..help needed asap!!
FS Mazdaspeed Protege Grand Am Race Car
Dash lights fail after audio upgrade
1992 protege brakes
Annoying Beeping
Squeeking at startup
Engine Swap 03 Protege' (race project)
long warm up period after t stat change
connectin amp to sotck radio/cd
2001 protege mp3 questions
323 GTX stuttering problem (tried everything)
'89 323 runaway idle on cold mornings
Mazda 323 F GT
JOE P. Fuel Cut Defenser for MSP
1991 Protege 4 cyl SOHC Radiator fan
99 protege doesnt want to start when cold
Headlights
'89 323 hatchback
Modifying Ignition Timing
question about fuel injection
FS: 2003.5 MazdaSpeed Protege
1999 Mazda Protege Transmission O/D problems
323 4WD Rear subframe Q
Center Gauge holder?
Protege horn goes off by itself
Premature power door lock module failure
Recommended Maintenance for Protege 2002
WTB-Mazda MP3
97 madza transmission seal leak
97 Protege Transmission
Popping noise from front suspension area when braking...
Please help me.
car keeps dying, help me please reply
91 Mazda 323 HELLLPPP!
Bodykits for -90 BG sedan?
Changing a/c belt to non a/c belt? 1995 protege
car push (noise)
2001 2.0 mazda protege mp3 engine upgrades
96 protege blowing engine/main fuse
1996 to 2002 Mazda Protoges, Any Chronic problems ?
2000 Protege sometimes won't start
Couple of Q's relating to a 97 Protege DX (1.5L)
Just bought 93 323, couple of questions
1995 mazda protege aftermarket parts???
Need Answer Concerning 98 99 Protege
doorlocks/beep unexplainedly lock/unlock
98 1.5L Protege Fluctuating Idle & ECU Reset
Horn Unexplainedly Going Off!
Friend's 93 Protege
2000 Protege 1.6L
1.6L SOHC Head bolt tap size
Shrieking noise,alternator or water pump?
Headlamp problems
Intake for a '96 Protege
FS: 2003 Protege (M-Speed)
Urine Smell
Another Mazda Forum
1.5L Protege Oil Pump Prime
Protege 1.5L RPM's
no spark in my bp
Replacing Front Sway Bar
87 323 Axle bolt torque - for brake disk replacement
1989 mazda 323 fuel system-no gas
door locks that don't work
Need Advice: Rebuild Rack and Pinion (leaking)
Want to buy a Mazda Protege 5
1998 323 bp engine
Stiffness in Automatic Shift
Bolt pattern
possible wheel bearing gone?
98 LX 1.5L 5sp Pulling The Engine
Redline
2001 protege alternator rmv
93 protege short circuit no tail light or dashboard light
body kit installation price
fitting cd plyer 91 323\familia
front whell bearings
Protege - no spark in #1 and #4
Steering Wheel
WTB: Mazda 1.6 (B6) for BG (90-94 323) chassis
Fluctuating idle
Can someone please help me? on the 323's
head light covers
91 Protege DX overheating...
Mazda 323 Familia AWD Turbo Import Model
car wont move
very low idle?????????????????? please help
'91 323 1.8L DOHC 16V "how to" port grinding and polishing
'91 323 speedometer problem
Spark Plugs and Computer
Frankly, does e68, grounding wires, voltage stabolizer work??
1989 mazda 323?
Light Bulb Question
91 Protege LX running on 3 cylinders
no spark from coil
'86 323 won't start
Oil Changes? 2002 Protege ES
1.5 valve lash - $$$$$$$$$$$$$$
at what temperature
87 323 1600efi hard start
97 1.5 a/t hard shifting
97 protege dash light bulbs.
97 1.5 rad fan@@
323 No spark and no fuel
1997 protege good car???????
Remote programming on 02 protege 5
2002 ES - Does it have a timing belt
Cylinder 4 misfire
Timing Belt and air filter
Rubbing Sound When Making a Shaper turn
intake temperature mod(IAT)
Help bypassing ignition in my '94 Protege LX
Engine Swap
1991 Mazda 323 Tachomoter help...
Mp3
Starts then Stops
Website For Mazda Parts
1991 323 sputtering help...
Brake bleeding problem (94 Protege)
2000 Protege Brakse
2001 Protege DX (1.6L) - No hp
brake rotor/pad replacement for 91 protege
'89 323 Engine Ticking, Valves?
car wont start
No Gas!
Mp5 Awd...???
Clutch Cable '86 323
help changing belts
engine swap
engine swap
mazda protege seats in a 323?
'92 Mazda Protege parts for sale
mazdaspeed protege mods and turbo swap
horn will not turn off
Mazda 323 system checker substitute
please help Starting pb ignition?
No cabin heat! - HELP!
'96 Protege Engine
Air Intake Question
think you know your Mazda? Come in and find out..
Spark From Coil vs. Spark from Distrubutor Cap
Fuel Pump - 93 Protege
familia gt modz
removing exhaust
1990-94 323 -> Protege parts swap?
1st gen spoiler
Help on testing fuel pump (carb 91 323 1.6l)
Simple Modz?
Protege 5 Need Heat
323 body kit?
88 323 starting problems
92 SOHC Protege no start got spark got fuel
Blown head gasket?
Keyless Entry
94 Protege DX not starting
What mileage are you getting on 2000 Protege SE?
cold air intake for a 1990 protege
91 protege tranny replacement?
Help! Protege Won't Start
New Tires for '01 Protege
recall/service bulletins for '91 323 protege???
CEL P0402 and some sputtering
Question about relay
91 323 Starting problems.. cant find answers..
93 Protege - Fuel Pump
WANTED...blue door panels for a 90-94 BG 323 hatchback only
I have a question about fitting a in-dash reciever.
1993 protege audio wiring
93 protege 1.8l sohc oil consumption
89 323 engine parts
Check Engine Light
how diff is the 2000 and 2001 protege?
323 clear corners
new guy on AF
Cold Start Problem
Brake Light Problem.....
Mazda 323 Protege????
93 Protege - auto transmission
Top-end knocking on 91 Protege - SOHC
1997 Mazda Brakes
Protege'01 gas filter
The Elusive 323
99 mazda protege
will this system suitable to Mazda Protege 1998
Problems when idle and now power at low revs
spark plug wire sequence
How many Mazdaspeed Protege were produced?
1997 Mazda Protge Wheel and Tire Question
coolant temperature sensor question?
Tires for 2000 Protege?
Mazdaspeed Protege?
Engine code!
Strange starting issues with 89 323
Are there any mazda websites?? -Please Read-
Lagging acceleration.
Protege5 under damped?
Parts Fit Questions
Won't Start
Anything for a 02 protege Auto
97 Mazda Protege Fuel Filter
Need Help W/ 91 323
Tire/wheel question...
Timing Belt light on my Mazda 323
2000 Protege exhuast??
turn signal
Protege: Sputtering-like noise upon initial acceleration...
ball joint check
2000 Mazda Protege Coolant leak
97 Protege bottoms out
Protege-5 Snow Tires?
88 323 fuel pump problem ????
323 Chip
Replacing a head gasket - 86 Familia
engine swap...Mazda 323HB 4dr...
'99 Protege Opinions
FS: Mazdaspeed Exhaust - NEW
more problems
2003 MazdaSpeed Protege
Help - haunted 97 Protege LX!!
Help please...sputtering 2000 Protege ES
FS or FT: Eibach Springs (BRAND NEW) / Mazda Speed Exhaust (NEW)
Want to buy 4 GTX compatible 14" aluminum rims
performance parts
Squealing Problem
Transmission
Web
AF
