View Full Version : Eighty Eight
Pages : 1 2 3 4 [5] 6 7 8
  1. How many miles has anyone ever got out of the 4T60E trans
  2. 1990 Olds 88 shudders at speed
  3. 1991 Olds 88 - Speakers
  4. 1991 Old's 88 - Front Lower Valance
  5. Head lamp Adjustment
  6. Carb And Intake
  7. speedometer
  8. 1995 Olds 88 3.8 with supercharger
  9. car jerks for first 3 minutes of driving
  10. airbag light
  11. exhaust question want to upgrade
  12. 95 LSS Stalling
  13. front brakes
  14. `97 engine squealing issue
  15. Front Brakes 92 oldsmobile delta 88
  16. Anybody Had these codes?
  17. supercharger on 3800 engine 1992
  18. Alternator Light Flickering
  19. 93 olds 88 idle high or just at random
  20. wont start
  21. Predetonation problems on my 88... HELP!!
  22. 92 eighty eight problems
  23. 92 Eighty Eight Olds...Heat!!
  24. delta royal 88
  25. Code 41
  26. chev colbolts
  27. oil leak cant figure it out!
  28. Conversion headlamps ... help!!!???
  29. 1990 olds delta 88 Chargin Issues
  30. Oil Changes
  31. 92 3.8 into 86 88
  32. 1998 3.8 231cid -- replacing oil pan gasket
  33. I was reading in old posts
  34. I want to take a Poll
  35. tranny
  36. 83 Olds
  37. HELP! ('95 code misery)
  38. Blinking Climate Control
  39. 1990 88
  40. AC & Heater Controls Problem
  41. do you think that my voltage regulator is shot?
  42. '90 Olds 88 stalling on deceleration
  43. '90 Olds 88 stalling on deceleration
  44. 96 olds wont start
  45. brakes sticking and slipping when stopping
  46. name that part!
  47. Are there any clues to a bad ECM?
  48. delta 88 question
  49. 1987 Olds Delta 88 bad timing chain on 3.8, did it hurt the valves??
  50. more power from 1992 Olds 88 royale
  51. 1992 olds 88 royale (low coolant sensor)
  52. vacuum advance!
  53. fuel line...
  54. Radio '89 Delta 88
  55. Cruise control/Misc. Engine Control fuse is blowing
  56. Powet Steering Pump Removal Please Help!!!
  57. 1996 0lds 88 Lighting sentinel repair
  58. 1992 88 Stalls after idling for a couple minutes
  59. car stalls!
  60. Delta 88 Royale Wont Start (lost For Ideas)
  61. loose wiring under hood?
  62. power steering? 92 olds eighty eight
  63. 65 Engine swap
  64. 95 88 stalls
  65. seat belt stuck
  66. How do I jump my ECM to give me codes? 1992 Delta 88
  67. Please Help Me Im Desperate.....Car Bogs Out!!(Sorry So Long....Please Read!)
  68. rigging up headlights brights = brights and lows at same time
  69. Radio Replacment
  70. 83 olds 98 OD trans electric short
  71. Cam position sensor code 89 Olds V6 192k
  72. AC air vents problem 89 OLDS Delta 88 Brougham
  73. 1982 delta88 stalls in drive!!!
  74. best plug wires for a 92' ???
  75. 83 Multifunction Lever
  76. 86 delta Power Steering Fluid Leak
  77. delta 88 hard start
  78. thanks!
  79. harmonic balancer removal
  80. Door striping
  81. rough idle and stall
  82. Temperature Display Blinks on Startup
  83. Clicking or tapping noise from engine
  84. knock out of the engine consistently getting worse
  85. the worst thing ever.....code 41
  86. 88 Delta 88 Starting Problem - Injectors Leaking??
  87. Filter for air
  88. Bad Knock sensor cause Backfire?
  89. good project
  90. 1992 delta 88 tranny fluid changing?
  91. Click No Crank
  92. update on my 97 88ls dying on me for no reason....
  93. 1995 A/C problems
  94. 1995 Eighty-eight Blows
  95. value of 45k engine
  96. 1996 oldsmobile 88 LS
  97. 1957 Oldsmobile Super 88 Doors
  98. Throttle Body leak/Sea foam
  99. Motor mounts - How many and part numbers?
  100. Brakes and Strange Symptoms
  101. heating or cooling?
  102. 1988 Olds 88 cutting out
  103. Heat Risers!
  104. 1986 88 -- Underwater in Katrina
  105. Rear disc on a 1986 Delta 88 RB???
  106. im clueless! any olds gurus out there???
  107. Diagnosis help please...
  108. Crankshaft Postion Sensor
  109. 1992 Olds 88 Royale doesn't shift into gears correctly
  110. 1992 Olds 88 Royale won't shift into gears correctly
  111. 1992 Olds 88 Royale Radio says "loc"
  112. Speedometer Needle Jumps
  113. 1990 88 Headlight replacement....part compatability?
  114. wont start when hot
  115. front brakes
  116. 1990 olds delta 88 trouble codes
  117. 91 Olds 98 blower stay on all the time.
  118. How to program radio presets?
  119. Oldsmobile Super 88 4 door convertible??
  120. 3.8L Engine, Loss of Coolant,No Visible Leak
  121. coil bolts
  122. Suspension
  123. No codes, just dead Post-Bump
  124. 1988 Delta 88 ECM Code 41
  125. Sorry one more thing.
  126. 1994 88 Royale Help Plz
  127. shop manual
  128. Interior Electrical Issues
  129. Ping/Backfire When Accerlating
  130. stock radio removal
  131. 85 delta Info
  132. Gas was coming out of Exhaust
  133. 81 Delta 88 dogging out
  134. 1993 - 88 LSS Oil Pump
  135. unusual blower fan solution, 1995 Olds 88
  136. Radio trim panel removal in '98 88 LS
  137. Liquid out of the exhast
  138. Metal Brake Lines/Exhaust Question
  139. rear bumper for 65 jetstar88 or delta88
  140. Fried Something?
  141. torque for 3.8 vin 3
  142. Previously Stolen Olds 88
  143. 1986 olds.
  144. plastic in pan knock another ??
  145. 3.8 L Plastic in oil pan & Knock
  146. Driver Window off track
  147. Rke (remote Keyless Entry) Instructions Needed. 1991
  148. dash and tail lights out
  149. Blower Motor HELP!
  150. 1964 Oldsmobile Super 88.....worth getting?
  151. Gas, Air Filters
  152. 1986 3.8 Backfiring/funny fuel smell
  153. 95 Olds 88 Security System
  154. 1991 olds 88 "Did I get whacked"
  155. 92 Eighty Eight little to no brakes
  156. Idle vibration after trans rebuild
  157. 1990 Olds delta 88
  158. need help asap please help
  159. delta 88 royale
  160. air conditioner compressor replace 1991 olds 88
  161. clicking when turning 1986 w/ 120k
  162. Gas Leak
  163. still trying to fix my pos car (maf relay question)
  164. knocking sound toward bottom of my 88
  165. 1991 Olds 88 Loud Noise/Rattle while idleing
  166. ABS Module For 94 Olds 88 Royale
  167. Need location of the DLC
  168. 96 olds 88-how to test ignition module, crank & cam sensors
  169. 95 royale rpm surge
  170. newbie with old(s) problem
  171. i need this answered within the next 8 hours
  172. Restoration
  173. 1994 olds 88 royale 3800 tuned port injection dying and sometimes does not start back
  174. 1989 olds 88 transmission problems
  175. 1996 '88 a/c switch problem?
  176. which will work better and make my beast faster
  177. please help you olds gurus im baffled....
  178. Buick L36 help ( from '97 Olds 88 post )
  179. security lockout
  180. car dies when breaks pressed
  181. 97 eighty eight stalling
  182. 92 olds 88 hesitation
  183. 97 eight eight randomly stalls 3.8
  184. Brother's car's coil packs
  185. Intermittent Code 41
  186. Dirty A/C Evaporator
  187. 4T60E Transmission Shudder?
  188. hesitates
  189. ac and heater dead on 95 olds 88
  190. wierd Coil Pack problem
  191. No spark 92 delta 88
  192. automatic transmission shift points?
  193. is my delta finally dead??
  194. 1989 Old 88-98 "c" idle air control won't stop running
  195. 1992 Olds 88 Royale Stalling
  196. code 42
  197. '94 88 3.8L into '97 Cutlass Supreme?
  198. 1995 Olds Delta 88' 3.8L Stalling
  199. Carb problem on 85 Delta 88 307 5.0
  200. Heater/air conditioner blower not working?
  201. radio install
  202. 97 eighty eight stalling
  203. Aftermarket gauge installation on '88 delta88
  204. Paint on Plenum.
  205. 1996 Cutlass, LSS, Brougham???
  206. 97' EightyEight - Sputter/Hesitant @ 40-45mph - Then Engine Light Solid
  207. how to jump the low pressure switch
  208. a/c all over again please help quick
  209. wont start
  210. location of fuel filter and fuel pump fuse in 1992 olds 88 royal LS
  211. Windshield/rear seat/carpet removal
  212. bogging out
  213. Delta 88 Keyless Entry Programming help please?
  214. 96 eighty eight coolant in oil
  215. Spark problem
  216. 3.8L V6 1993 Olds 88 Royale what engine years will replace
  217. what is the proper temp for 307 engine
  218. Throttle positioning sensor nightmare
  219. 78 olds 88 royale
  220. '92 88 no spark at all
  221. 1994 Car miss spark like anything
  222. 1986 start/run probs
  223. 1990 Olds 88 Stalling at idle/driving
  224. 1988 olds delta 88 cam sensor
  225. evacuating and recharging
  226. stumped
  227. 1986 Delta 88 for parts Cleve Ohio
  228. 1990 Olds 88 Royale Stalling
  229. 1993 Olds 88 LS won't start
  230. CAN't FIND ON THE PLANET? -89 delta 88 armrest
  231. carburator problem
  232. this car is a piece of shit
  233. Rear Left Window
  234. ac clutch
  235. 89 Olds Royal AC by pass?
  236. 89 Olds Royal
  237. Starting Problems ???
  238. 1990 Olds 88 Royale
  239. cat convertor
  240. tranny slips
  241. 1992 88 royale stalls!
  242. 1995 LSS engine code diagnosis problem
  243. power windows wiring
  244. '75 Delta won't start with turn of key
  245. '92 88 royale stalling
  246. Backlights are out
  247. door lock blowing fuses
  248. Olds 88 403ci ok to leave EGR disconnected?
  249. Harmonic Balancer Bolt Removal
  250. really wierd engine start problems
