View Full Version : Eighty Eight
Pages : 1 [2] 3 4 5 6 7 8
  1. 92 olds 3.8 stall intermittant
  2. 95 Olds 88 No power when I accelerate
  3. 1987 olds 88 im lost!
  4. 96 dies
  5. 94 88 knock sensor code
  6. 92 Olds 88 Royale LS Oil Sensor
  7. Summer time REBUILD !! :)
  8. mystery problem
  9. Engine interchange
  10. Noisy in gear
  11. 97 Olds 88 - relay clicking when brake is depressed
  12. Good place for parts?
  13. brake "indicator" light
  14. checking for codes on 94 delta 88
  15. 99 olds lss 105mph is that it?
  16. 99 olds lss
  17. carb identification
  18. 94 olds 88 please help
  19. Turning signals don`t blink.
  20. 1995 4t60e first gear issue
  21. 1999 Delta 88 VATS Bypass Problem
  22. Wobbling feeling on driver`s side wheel while driving
  23. 1995 88 - stalled, wont jump start. New battery, radio works, etc...
  24. Why does my antifreeze in overflow have a pinkish tint
  25. 95 olds 88 Royale - Power problems(car keeps dying)/rough acceleration
  26. 99 Olds 88 will not start.
  27. need help
  28. 96 Olds LSS
  29. 98 Oldsmobile Regency - P0171 code issue
  30. '97 Eighty Eight-Intermittent starting/stalling issues
  31. 1994 olds 88 wont start no fuel mabye
  32. 97 olds lss sc p1811 1645 300 171
  33. Is the alternator the problem/85 Delta 88
  34. 1988 - Poor Heat in Cold Weather - Need Suggestions
  35. Loud (Rough-like) sound when accelerate
  36. Olds to Chevy Swap
  37. Blower Motor Relay Location? '97 Olds 88
  38. OldsmobileDelta 88 1988 3800 V6
  39. Replacing an alternator
  40. NO HEAT IN 1995 Delta 88
  41. 1988 Olds 88 3.8L vibration above 45 mph
  42. da
  43. Itermittent heating issues, 1998 88.......
  44. 95 LSS 88, runs rough when traction control is off
  45. Need info about Eaton M62/M90 snout bearings, Please.
  46. 1995 oldsmobile 88 starts then dies right away
  47. 1992 88 won't start on really cold days.
  48. 1992 Olds Eighty-Eight Royale Leaking Coolant
  49. horn relay location on a 95 Eighty-Eight???
  50. Applying brakes caused car to stall.
  51. Wheel shudder when aplying brakes/growling
  52. fuel filter???
  53. Intermitant Blower on 1999 '88
  54. '95 88 3.8L intermittent stalling/missing -- No codes
  55. 1998 LSS: P0171: System Too Lean (Bank 1)
  56. Timing chain issues
  57. 89 Olds Delta 88 Tranny proglems
  58. Leaky seal - Crankshaft -Harmonic Balancer
  59. 1988 Delta 88 Coolant Leak inside passenger compartment
  60. 1990 Olds Delta88 Cruise Control
  61. 1999 Olds 88
  62. RPM surge when in park & in motion
  63. Climate control whacked after sparks while inspecting CD player. Help!!!
  64. Where is the signal light flasher on 1988 Delta 88?
  65. 95 Olds 88 No overdrive
  66. Code P0305 cylinder 5 misfire on LSS
  67. 1995 eighty-eight
  68. Clunk in front end!! Need advice!!
  69. 3.8L no spark,injector,cranks once a day
  70. How to empty tank on my 89 Olds 88
  71. Delta 88 does not start when hot!
  72. Which engine code engine will work in my 88?
  73. Serpentine Belt
  74. won't start
  75. spongy brakes
  76. Where is the Power Steering Fluid?
  77. Passenger Side Mirror Control
  78. no parking lights and chime will not go off aghhhh
  79. Crankshaft Sensor??? or what
  80. engine stops like you turned of the key
  81. 1998 Oldsmobile Fuel Line
  82. a/c switch went out suddenly?
  83. Transmission type
  84. 1996 olds 88 unusual noise
  85. Climate control blower intermittent when hot
  86. Front wheel bearing/smoke through ac vents
  87. 1998 Oldsmobile 88 Intake Problems
  88. 1998 Olds Eighty-Eight high-speed fan doesn't work
  89. Remove Power Steering from 1997 Olds 88
  90. 96 olds lss fuel pump issues maybe
  91. 88 Coolant Loss
  92. Running Rough/Stalling Out.
  93. Broken Bolt - Intake Manifold
  94. 1996 88 barely runs rough idle
  95. Engine Line On
  96. 97 LSS blower motor quits, overheats, looses power
  97. 1992 Olds 88 Transmission
  98. 1989 Royale Brougham 88 Stalling Out
  99. Any way to disable DRL's on 1999 eighty eight
  100. 94 88 transmission swap OBDII OBDI
  101. Security light
  102. One last check before I sell it.
  103. p171 lean code -My Unusual Problem & Solution
  104. A/C Compressor noise (metallic rattle)?
  105. Mysterious no start 1996 Olds 88
  106. AC died in 93 olds
  107. Blower motor relay keeps burning out
  108. 97 olds 88 blower motor runs with ignition off.
  109. Engine Knocking Sound
  110. HD radio???
  111. 94 LSS sputters out of idle
  112. 98 Olds 88 Ls- Console Shifter
  113. 98 Olds 88 Ls- Climate Control Upgrade
  114. 1991 Olds 98 Regency
  115. fuse 14 keeps blowing
  116. 97 Olds 88 Fuel Gauge
  117. Traction control switch on 95 LSS
  118. 1992 oldmobile delta 88 royale ls
  119. 89 Olds 88 Code 41
  120. Reusable trans pan gasket?
  121. brake question
  122. 94 Sputtering Problems over 50MPH Runs Rough, Hot
  123. Wierd Problems
  124. 93 Olds Blower Motor Will Not Cut Off
  125. Brake problems
  126. 1998 Olds Regency
  127. Harmonic Balancer Bolt
  128. 88 1997 Side Veiw Mirror Replacemen
  129. 1992 Delta 88 - climate control flashes?
  130. Help! 92 Olds 88 terrible gas mileage
  131. 1990 Royale 88 trunover won't start
  132. 1998 Olds 88LS Starting Problem
  133. Emergency Fix on '93 Delta - Releasing Tensioner
  134. Fuel Pump/Filter
  135. GM Intake Gasket - Engine #2 (is 3 coming)
  136. 86 olds 88 no spark
  137. 1997 olds 88 dies/wont start
  138. Best replacement plenum??
  139. good site?
  140. 1992 88 royale ls inside door panels
  141. 3800 "C" into "L" code 92 olds
  142. 1990 Delta 88 Check Engine Code 42 ?
  143. Window motor is broken
  144. 1996 Olds 88 3.8l Pinging
  145. Starting/Acceleration Problem for '96 OLDS 88 Part 2
  146. 1988 Delta 88 Won't Start
  147. Plastic Door Covering Repairs
  148. 1985 delta 88 jerks and sometimes stalls
  149. 1995 olds 88 royale temp sending sensor
  150. 98 Olds 88 LS Blower Motor Replacement
  151. Aftermarket radio install problems
  152. Starting/Acceleration Problem for '96 OLDS 88
  153. 99 olds 88 3800 missfire at idle p0301
  154. 1993 Olds 88 Low coolant light and floorboard rattle
  155. Transmission swap!
  156. what is this
  157. 1995 Olds Eighty Eight Royale
  158. 1990 Royale 88 won't start
  159. what, harmonic balancer
  160. NOISEY 98 olds LS - OIL pressure?
  161. Cam sensor
  162. 1994 Old's Axle Shaft
  163. 1995 olds 88 royale temp sencor
  164. 1994 Olds 88 4T60E Trans Problems
  165. code 171 rough chugging start
  166. 1996 Olds 88 W/ 211,000 miles
  167. Starting issues & other??'s
  168. firewall wiring
  169. inner joint on cv axle, is it in all the way?
  170. 1988 Olds Delta 88 Royale won't start.
  171. Starter Issues?
  172. Posting in Old Threads
  173. 95 88 royale starting
  174. 86 olds 98 regency popping noise at throttle body
  175. newly acquired 1997 88 need help with a few issues
  176. 92 olds 88 replace/repair speedo head only?
  177. opera lights out
  178. How to tell if keyless entry was an option
  179. 83 delta
  180. 1992 Olds 88 Dead after attempted jump start.
  181. Intermittent elec. problem NO HEAT below zero!!!
  182. 1999 '88 blower fan problem
  183. olds Delta 88 Heater problems
  184. 97 Regency door key alarm disable
  185. 92 royale
  186. how to replace electric side mirrors
  187. 1998 dleta 88 3.8 coolant leak
  188. Blend door problem??
  189. 92 olds 88 fuel consumption - coil pack?
  190. 1998 Olds Eighty-Eight LS
  191. vacume issue??
  192. I got hit today, need help asap!!
  193. 95 88 royale died at 45 mph
  194. 1990 - 88 olds wont start
  195. 1991 eighty-eight keyless entry
  196. 1994 88 Royale, wont start occasionally
  197. 1994 88 royale LS jerking and dying on me
  198. 92 Olds 88 speedo problem,fuel consumption high, and speed sensor
  199. gas gauge messed up
  200. Please help! Passenger front window, both front power seat recliner Problems
  201. Help Please!
  202. fuel pump removal
  203. Blowing Cold Air
  204. 1996 Olds '88 won't start when cold
  205. lose steering and shake at times (1984)
  206. quad driver a and b?
  207. 1994 olds 88,icu ok,now what
  208. 1992 Olds 88 Royale_ STARTING ISSUE
  209. leaking break flude. wheres it comeing from
  210. Blinking climate control temperature
  211. 88000 miles is bad for 88's
  212. 96 88 won't start after repair
  213. charging problem
  214. Engine Modifications
  215. Security light help needed
  216. Suggestions on what might have happened?
  217. 1998 LSS hiss/shriek duing acceleration
  218. no heat
  219. No turn signals or indicator lights/Olds88/HELP
  220. cooling fans are rigged!
  221. No start weird electrical problems
  222. Exhaust smells
  223. 97 olds 88-ls head & dash lights flicker
  224. 93 delta88 fuse panel identification
  225. cooling fans rigged on 92 olds 88
  226. 93 olds SES light comes flashes
  227. Friction plate or something more serious?
  228. 1993 Oldsmobile 88 Royale LS-Sluggish
  229. 93olds88 no dash lights
  230. 1984 oldsmobile delta 88
  231. 96 88ls 3.8 non supercharged stalls out
  232. 1986 Won't Turn Over
  233. No Start
  234. dash lights and tail lights go out keeps blowing fuse
  235. Please Help, Pcm/Ecm?
  236. New stereo problem. (unused wires + constant and switched 12v have to be crossed)
  237. help! now no start!
  238. 97 olds 88 engine dies at steady speed 50-55
  239. 92 olds eighty sometimes starts
  240. 1990 88 speedometer
  241. 1990 6.5 inch door speaker mod.
  242. Beware the Walmart.
  243. security light in 97 olds eighty-eight
  244. Master Cylinders Are Stupid.
  245. 94 chime issues
  246. 93 olds eighty eight won't start
  247. Engine Swap
  248. Title for trouble shooting
  249. Audio system question
  250. 1988 Olds not getting gas
