View Full Version : Silhouette
- dumb founded
- Power Window Motor Replacement
- Silhoutte Traction Control
- Easy question
- Power Sliders
- Engine Shake
- Reverse Sensor Adjustment
- Intermittent Starting issue
- Roaring road
- 97 Silouette oil pressure light
- 2000 silo radio
- Sputtering & hacking
- Rear Air Shocks stuck fully extended
- Front Passenger Seat Armrest and Headrests
- 98 Olds Silhouette Front Suspension Knock
- Passenger Power Sliding Door Knocking Noise
- Passenger Sliding Door
- ABS.Brake and TCS are on
- Dead Stick
- 2001 slhouette
- Driver Information Center
- Half on temperature gage
- '97 Olds Silhouette Power Door Problems
- 99 Sillhouette Premiere - Hard start and gas smell
- Coolant draining way too quickly on '99 Silhouette!!
- Sounds like a Whirring Sound
- 99 Premier been sitting for 5 months won't start
- Excessivly high idle & loping
- 97 silhouette vibration when stopped.
- when does the cooling fans kick in
- 1998 - Brakes lights came on Brakes softened
- 2000 Silh won't turnover
- 99 silhouette electrical problem
- 1999 Primire electrical issues
- Muffler Heatshield
- Help with Premier turning 100,000
- 97 silhouette
- Rear Window Washer Pours Inside Van
- 99 Silhouette Half shaft, CV joint, Drive axle (same thing pick your term).
- Soft Brakes?
- Timing chain on 3.4 engine
- 2000 Olds Silhouette Fuel Pump Replacement
- DIY to Test Rad Fans?
- wheel bearings (front)???
- 2002 Silhouette Engine rebuild
- 1999 Olds Sil. Thermostat?
- 3.4 origin--Chevy or Buick?
- Airline Tee Part Number??
- 99 Silhouette Overhead Computer
- silhouette air hose
- Can't find this in the 'search'.
- P1404 p0420 p0141
- Rear heat blower motor
- Olds 2000 Silhouette - How to I remove the headrest?
- No power on windows and A/C blower
- 1999 Silhouette radio not working
- 2000 silhouette sputtering,dying,intermittently runs fine
- 2000 Olds MAF Clean/Replace
- Issue with traction control - 2000 Venture
- 2001 Rouch Idle and dies at low RPM.
- HELP!!! 2001 no pwr locks and windows. security sys, interior lights.
- Transmission Cooler Lines Leaking
- 95 van no power and low rough idle
- 2001 silouette gaskets
- How do you set the clock on the radio?
- New water pump and now overheating
- 2001 Silhouette starter always on
- Horn Not Working
- 2002 Silouette Premier AWD
- Rear Park Aid
- Load level suspension
- Rear window replacement
- P0141 Code
- Liftgate Rear Door
- front blinker works but doesnt
- 2001 silhouette transmission lines
- High Temp Light 02' silhouette
- 99 olds silho cranks but no run
- 2000 silhouette alternator regulator screw
- 97 silhouette power seats & door not working
- Radio system question
- Low Coolant Message
- ABS and TCS Light on Silhouette
- 2002 silhouette leaking
- 99 Olds mini van oil mixing with water
- 99 Premier gas smells and driver side window
- 1999 oldsmobile silhouette air bag light illuminating
- Low idle and going dead
- Headlights and Domelights Flicker?
- What is the coolant hose from Water Pump Bleed Connection?
- Overhead computer help
- New rebuilt, used engine, or repair
- modify the van
- Tail light elec. harness
- 97 Olds Silhouette power seats don't work.
- 97 Olds Silhouette power sliding door won't open
- P0141 & P0341
- 98 silhouette won't read the OBD II device
- coolant leak
- Full suspension replacement
- blower prob
- My Silhouette nightmare
- attempting head gasket replacement
- 2000 Premeire with VCP Radio Wiring Harness NEEDED
- 01' Silohouette VCR
- Interior lights always on
- '03 Silhouette accelerates on its own!
- Auto leveling problem, car is jacked up!
- 97 power door locks going crazy....
- 91 Olds Silhouette electrical issues
- 2000 Sillhouette AC Issues
- Transmission
- miss in engine
- Overhead Console computer not working
- 93 electrical gremlins
- Notice
- Shock and strut advise
- 2001 Silhouette Premier engine issues sputtering?
- Dexcool Litigation
- 99 Olds Silhouette 3.4L
- Glove Box Latch
- R134 capacity
- 2000 Olds Silhouette Front AC Warm
- 98 olds silhouette how to check fuel pump ?
- 98 Olds Silhouette Computer Problems ?
- Bad alternator? Autozone messing with my confidence...
- Park Aid inop
- O2 sensor
- break problem
- 1998 Olds Silo Gas guage question
- 2001 Silhouette Premiere
- Factory repair manual for 93 Olds Silhouette
- 2000 sihoutte transmission leak
- how to set the clock
- 99 Olds Silouhette Not Starting
- 2000 Olds Silhouette Heated Seats
- EGR Valve Location
- Big Red Battery
- Temp Guage Mistery
- Olds Silhouette BCM (Body Control Module)
- Hard Shifts, Slippage before lockup
- 2000 Sil. horn alarm intermittantly goes off.
- Tranny Problems
- 2003 silhouette PK3 key and keyless remote programming
- center roller on sliding door
- wont start
- Olds silhouette Heater core Replaced
- 1999 Dash Lights
- Electrical problem(s)
- AWD Disabled light
- 2000 Olds Silhouette - wipers
- Fan blower not working on level 3???
- 2002 Silouette Wipers Park Veritcally, Help!
- 98 silhouette rear leveling system not working
- 2000 Silhouette Rear leveling problem.
- 2001 Engine Problems
- 93 sil, no heat
- 97 Olds Silhouette-stuck in 2nd-trans problem?
- Whine/howl from rear end? Versatrak-AWD
- 2000 Silhouette rev limiter
- 2000 Silhouette Power Sliding Door Problem
- Rear fluid reservior
- Coolant Fans / Temp Guage
- need help on 3800
- engein problems
- saving money on heater hose replacement
- 3.4 engine intake gasket repair info.
- 98 Silhouette engine removal/rotation
- 99 silo heater and airshock problems
- 1999 Silhouette head removal ?
- Air bag sing on
- Low Oil Pressure light???
- olds 2000 van codepo171 lean burn bank 1
- Remote start on a 2000 Silhouette...........
- Cruise Control not working 98 Silhouette
- 2000 Silhouette Random start problem
- van problems, HELP!
- Wipers don't park in their place.
- 98 silhouette
- HELP!! Problems with a 2k Olds Silo..............
- 2003 Olds Silhouette AWD noise again
- class II hitch photo
- Broken triangle glass
- ABS/TRAC OFF light...I've tried about everything....
- 2000 Running Hot
- 99 Wiring Concerns
- 95 Oldsmobile
- Using my 1997 Silhouette in the Snow
- 2001 Silhouette sometimes won't start
- 04 Silhouette wipers on high only
- 99 Silhouette 3.4L Premiere edition stalls/wheezes/whistles
- 1999-2000 Code Sticker Location
- ABS & TCS lights on. Brake switch problem !?
- 2004 Oldsmobile Silhouette
- belt tensioner
- 2001 wipers won't park
- Fuel Filter Stud
- Fog Lights
- Crank sensor and Tachometer
- 3.4 l gm serpentine belt
- 3.4 liter engine
- 3.4 liter engine intake manifold
- 3.4 l gm engine
- 2001 Silhoette Coolant Leak
- HELP!! turn signals do not work!
- 3.4 intake leak
- Rear Window Wash Help
- 3.4 engine coolant path
- heating problems
- Foglights?
- 2004 Silhoutte Temp Gauge Problem
- 99 Olds Silhouette Van 3.8L engine
- 2001 breakes
- 99 silhouette Engine code PO101
- Small Coolant Leak
- 2000 Silhouette transmission, all of a sudden NOTHING
- 1999 olds silhouette alternator removal
- Bought a 98 Olds Silhouette
- terminal
- wont start, lights went out, error message on radio,
- Dimming Lights
- 95 Silhouette, Intermittent miss/stall then smooth HELP!!
- 95 Olds Silhouette ABS\Brake Light stuck on
- 98Oldsvan leaky roof
- Buying a used Silhouette...
- 97 Silhouette Driver Door Switch
- Codes for 2000 Silhouette
- Olds-2000-Silhoutte-Various lights come on like ABS, Air Bag
- OBD Connector Doesn't work
- 93 3.8ltr not charging
- Oil Pan Gasket Leak on 2000 Silhouette
- Changing out the radiator on the 2000 model
- Bleeding brakes
- EGR Cleaning
- Silhouette Cooling Fans
- HELP w/ CODE PO 441
- Resetting Oil Change Message
- 03 Silouette - rattle in left power sliding door
- 2003 Silouette - Park Assist not working!
- 2000 silhouette - transmission
- Silhouette Driver Side Window A Repeat Offender
- 93 Silhouette Dies after about 10 miles.
- no spark
- 97 Silhouette possible transmission problem?
- 98 Envoy keyfob work on a 98 Silhouette?
- 97 silhoutte gas gauge problem
- 98 Silhouette A/C not working
- 1998 Alarm goes off and shuts off engine
- 1999 Silhoutte
- 2001 silhouette a/c comp locked up
