View Full Version : Silhouette
Pages : 1 2 [3]
  1. replacing head gaskets 3.8 engine
  2. 2000 Silhouette Key Fob Reciever
  3. 1999 Transmission/Traction Control System
  4. Silhouette Transmission Whine
  5. 93 silhouette 3.8
  6. Lower Intake Manifold Leak
  7. 1992 transmission shifting problems
  8. coolant leak
  9. Broken cam. Engine Replacement Procedures?
  10. leather heated seats
  11. Suggestions on an aftermarket entertainment system
  12. smoking heater
  13. Outside Temp Gauge...
  14. Dash lights replacement
  15. coolant fans not turning very fast
  16. 2001 Silhouette VCR Audio
  17. keyless entry programm procedure for 93 cutlass seria
  18. not running
  19. 1994 ignition switch
  20. 2000 Silhouette Driver Window: Up not Down
  21. 94 silhouette
  22. updated head gasket for 3400 V6
  23. AC problem w/ 93 Silo
  24. The elusive J38197-2
  25. chrome peeling off wheels
  26. heater blower
  27. 98 silhouette doesnt run
  28. Coolant change/flush
  29. my 1995 keyless entry
  30. 2000 Olds shilouette trans hard shift
  31. 2001 Silhouette Trans. Problems
  32. 98 Silhouette dash light/running lights intermittent
  33. 98 just replace intake manifold gasket, now rough idle/stalling
  34. Rear wiper arm 2000 Silhouettte
  35. overhead moniters
  36. Rough Idle on 1998 Silhouette 3.4
  37. 1997 Olds Shilouette going crazy! HELP!
  38. ABS, Trac Off and service traction system lights on on 2003 silhouette
  39. Auto Transmission check engine light
  40. Fuse Boxs
  41. 93 Sil oil pressure
  42. 1998 Olds Silhouette 3.4 Bogging out
  43. 93 Sil stalling driving me nuts
  44. ABS Idiot light
  45. Keyless Entry Remote programming - 94-96 Silhouette?
  46. FREE Intake Gasket from dealer, BUT
  47. Silhouette (1999) battery replacement procedure
  48. 99 olds silohette chattering
  49. 93 sil please help no spark
  50. 2002 Slihouette Driver's Power Window
  51. 1999 3.4 V6 Rough Running?
  52. 1998 Olds Silhouette, brakes,TSC, and ABS
  53. How do I know? Intake gasket
  54. Help with my entertianment center
  55. Technical Service Bullitens
  56. replacing VCR with DVD
  57. fuse for dome light
  58. vcr remote
  59. throttle body
  60. Door Ajar Light Stays On
  61. DRIVERS HEATED SEAT IN 2001 Silhouette
  62. Blower motor 94 3.8L
  63. Power Sliding Door and Heated Seat Element
  64. Power window switch
  65. The Case of the disappearing Oil
  66. head gasket
  67. cooling system
  68. 2001 Silhouette heating
  69. changing trans fluid, how much do i use?
  70. Throttle Body Plate Sticking
  71. 2000 Silhouette using oil
  72. Keyless remote programming for 1992
  73. Transmission problem
  74. 1995 3.8L runing rough, stalling, shuttering
  75. tift deterrent relay 2000
  76. Aurora Wheels on a Silhouette ?
  77. 2001 Battery replacement
  78. 01 Silo Rad Cooling Fans
  79. Intake Manifold Replacement Instructions
  80. Silhouette Battery DRAIN
  81. HELP!!! 1995 electrical problems???
  82. air shock replacements
  83. 99 silhouette rear end knocking noise
  84. 3.4L head gasket issue...since 96??
  85. 2001 wiper park position
  86. heater blower 95 silhouette
  87. New Recall
  88. Power Sliding Door
  89. no remote, now no start
  90. Takes forever to warm up
  91. Cruise control
  92. Reprogramming a Ford keyfob for an Olds Silhouette
  93. Cooling problem
  94. Air Comprssor for the Van missing
  95. Transmission Fluid change 2000 Silhouette
  96. 1999 Silhouette Transmission Problems
  97. oldsmobile silhouette bucks.
  98. van won't start after running out of gas.
  99. keyless remote programming?
  100. ign. timing wire
  101. Seafoam
  102. Service Traction System
  103. haunted radio
  104. cold transmission?
  105. 2000 Silhouette fuel guage problem
  106. 98 Silhouette Panic Alarm Sounds when starting van
  107. 1997 Olds Silhouette (Won't Start)
  108. 2000 Silhouette power mods
  109. Missing at idle
  110. Anyone replace air shocks w/ regular shocks?
  111. Audio Steering Wheel Pushbutton Control Lights
  112. Olds/Sil a/c fan and rear blower problems
  113. 98 Silhouette Air Bag Warning Light Stays On
  114. 99 olds silhouette electrical problems
  115. 2000 Silhouette Problems
  116. $400+ to replace burned out radio light?????
  117. need help wiring in 90 silhouette
  118. 90 Silhouette firing Order???
  119. Running Sluggish
  120. Speed Sensor?
  121. False Temperature Reading on Overhead Console
  122. ABS sensor OLDS slow stopping . faulty
  123. '93 Silhouette - Changing lower driving light bulbs
  124. 91 Silhouette door handle night mare
  125. Engine won't crank - occasionally
  126. vibrating
  127. Groaning when braking
  128. Security Message in Message Center
  129. Brake/Traction Control
  130. How many people.....
  131. 97 sliding door quit
  132. 3.8 no fuel problem ???????
  133. '90 Van
  134. TURN OFF "CHANGE OIL" LIGHT
  135. Clicking Around Right Front
  136. 95 olds silhouette getting hot
  137. 2000 Silhouette Trasmission
  138. Unusual AC problem, half hot half cold
  139. Just Programmed a new key and remote on my 2003
  140. 92 Silhouette stalling out
  141. Tranmission Problems??
  142. Cannot open liftgate
  143. 2000 Silouette. Ok Campers, who's changed their spark plugs ?
  144. Olds Silhouette leaking brake cylinder
  145. 2000 Silouette Fuel filter replacement
  146. Add Keyless Entry To 1999 Silhouette
  147. 2 Questions
  148. Coolant Leak?
  149. 2001 keyless programming
  150. 3.8 idles rough, Wheres my EGR ????
  151. torque settings for 1997 olds Silhouette intake manifold?
  152. passenger side electric sliding door
  153. rear window washer dispenser?-
  154. Turn signal on Silhouette
  155. windows dragging
  156. Keyless entry never worked
  157. Wiper speed controls
  158. uh oh, I just bought a 99 Question about intake
  159. transmission fluid
  160. 99 Olds Wipers
  161. Dashboard Idiot Lights
  162. My door wont stay shut on my 2000
  163. Olds 2003 thinking of purchasing
  164. seats
  165. Oldsmobile Silhouette 93 need remote programming
  166. Horn sounds intermittently
  167. Auto lock problems 98 silhouette (random locking)
  168. Remote programming for 93 Silo
  169. AC/HEATER fan stopped
  170. my 97 olds sill
  171. Reprogramming Keyless Entry
  172. heated seats in 2001 silo---problem
  173. 90 silhouette problems with rebuilt alternator not charging.
  174. CD player hot enough to cook an egg!
  175. self inflating rear suspension
  176. self inflating rear suspension
  177. Sputters and dies
  178. Mommy van?
