View Full Version : Silhouette
Pages : 1 [2] 3
  1. 98 Silhouette A/C not working
  2. 1998 Alarm goes off and shuts off engine
  3. 1999 Silhoutte
  4. 2001 silhouette a/c comp locked up
  5. Van Starts and Dies
  6. Finding a Valve spring for a 93 Silhouette 3.8??
  7. front wheel bearing
  8. AWD, changing the "Versatrak" fluid...
  9. 2001 Silhouette how to find and install powerdoor lock module
  10. Question About Aftermarket Stereo Install
  11. Replacement DVD unit
  12. Dexcool - New thread about a recurring problem
  13. 01Silho Suddenly No Function on Door Locks, Power Windows, Interior Lights, Alarm Sys
  14. Front wheel bearing
  15. elc blowing fuse on '99 silhouette
  16. 2000 Premeire with VCP Radio Wiring Harness Problem
  17. dead battery now radio is locked! HELP
  18. P1404, 0131, and 0137 Code Set
  19. Occasional miss, comes and goes 94 3.8
  20. Battery Check Light
  21. Shuddering between 1st and 2nd
  22. Code 420 Converter Efficiency below threshold
  23. rear a/c blows red hot
  24. jay2bears
  25. 2000 olds silhouette wipers
  26. Gas Cap Code
  27. Steering Failure... dire
  28. 99 Olds Silhouette firing order
  29. P0141 Code
  30. 1990 silohette steering popping
  31. 98 Silhouette power loss/rough idle
  32. Mysterious Coolent Drops
  33. 2000 Silhouette abs/traction lights on
  34. When It Rains It Pours
  35. Can't Lock
  36. 96 Silhoette suddenly sputtering, stalling, and surging
  37. 97 Silhouette ..power seats and power sliding door not working
  38. 2 questions on 02 Premiere: a/c Condenser replacement & Differential noise
  39. replacing head gasket in my 99 silhouette
  40. Low Coolant Sensor for 99 Olds Silhouette
  41. 97 Olds 3.4 Head gasket or Intake gasket which?
  42. replacing rear washer pump
  43. Power seat presets in a 2001 Silhouette
  44. 1997 oldsmobile AC/ HEATER problem
  45. 2000 Olds Silhouette POSSESSED!!!!!
  46. 1997 minivan codes P1870 and P0101
  47. Transmission
  48. 2000 Silhouette - A/C blows 15A fuse
  49. Engine Missing and causing hard shifts in Tranny on 2001 Silhouette
  50. 01 silhouette video player??
  51. Van Hubcap
  52. Won't Start 1999 Olds Silhouette
  53. how to check an OMRON 12088567
  54. 2002 Sihouette Foggy Headlamp
  55. motor swap
  56. Please Help!
  57. ABS/TCS light on...
  58. 2001 silhouette ac blows vent air
  59. new engine, no start.
  60. Removing Entertainment/Climate facia?
  61. WANTED: hitch for my 03 Montana
  62. engine removal 93 3.8ltr/auto
  63. 95 silhouette sliding door
  64. Thumping Knocking Sound In Reverse
  65. 95 Keyless Programming HELP!
  66. Flushing radiator
  67. A few questions on the 03/04 Silhouette/Montana....
  68. Switched 12V
  69. ABS/Brakes/TSC Lights on
  70. 2000 silhouette
  71. Tail Light Assembly
  72. 2000 Glove Box Latch
  73. 3.4 L rough idle
  74. strange front end noise with low speed right turns
  75. Electrical Problems 2000 Silhouette
  76. Electrical Problems 2000 Silhouette
  77. Electrical Problems 2000 Silhouette
  78. the radio question help
  79. piston slap
  80. 95 Olds Silohuette EGR Valve
  81. 1996 pont. transsport
  82. Wrong Temprature Readings
  83. Bucking Silhouette
  84. 1999 olds 3.4 Van
  85. no start
  86. Screw Rod in oil filter fell out
  87. emissions codes
  88. 03 Cd jammed in cd player, won't come out.
  89. rear defroster not working
  90. 2002 Climate control problem
  91. Air shock problem...
  92. Mysterious Leak
  93. heated seats/side airbag
  94. Service Manual Suggestions?
  95. I Need Head ... Gasket But Hate Thought Of Doing It Myself
  96. Intake Gasket Repair Cost update
  97. inner tie rod removal
  98. 99 silhouette loose belt broken pulley
  99. interior woes
  100. Power Windows driver
  101. Transmission Maintenance
  102. 98 Silhouette Electrical Problems
  103. Resetting Service Engine Soon light....
  104. Miss
  105. 2000 Premiere Transmission
  106. Traction Control System (TCS) intermittently comes on in my '02 Silhouette
  107. siloetee, engine quits running
  108. cruse control problems
  109. Power side-mirror problem
  110. '98 power sliding door won't unlock
  111. 2001 Silhouette A/C Problem
  112. 2002 Silhouette electrical problems?
  113. 2000 Premiere Driver Side Window
  114. Service Engine Codes??
  115. coolant temp sensor
  116. 2000 silhouette won't start
  117. 98 Silo. with air bag lite on
  118. 98 Silhouette air shocks compressor problem
  119. '94 RPM's up & down
  120. how do you remove VCP from 00 silhouette?
  121. silhouette ELC
  122. 2002 Premiere - Rear vents?
  123. 95' silo, cost of new engine?
  124. Alternator replacement for 98 Olds Silhouette
  125. Multiplay CD not working
  126. 1998 Olds Silhouette Engines
  127. 1998 Silhouette rear air shocks problem
  128. 2001 radiator cooling fans
  129. Where is the GM trans Pressure Control Solenoid ?
  130. 2001 silhouette coolant disappears
  131. mounting floor console
  132. Wiper motor problem 2001 Sil
  133. How to Replace Alternator Ground Screw
  134. DVD Problems
  135. 98 Silhouette Won't Start
  136. 97 silhouette A/C question????
  137. 1998 Silo life expectancy
  138. Transmission removal
  139. Day time Running Lights
  140. BCM 2000 Olds Silhouette
  141. Terrible AC/Delco sidepost battery
  142. Replaced Rear Wheel Cylinders, now Brake Warning Light On!
  143. Olds Silhouette 1995 3.8 Litre Won't Start
  144. 02 Sillouette random alarm
  145. Help! ac compressor
  146. Alternator and Wiper linkage. 2000
  147. 92 Olds Speedometer pegged/Running ROUGH!
  148. Cold Air Intake?
  149. How to replace rear wiper motor
  150. silhouette value
  151. front wheel bearing
  152. 2001 Silhouette
  153. 2001 Silhouette - trailer hitch wiring
  154. 1994 Olds Silhouette low rpm engine knock ?
  155. Important: New and Old Members Please Read
  156. Oil pressure sensor location
  157. A/C Clutch making noise
  158. Belt Tensioner
  159. What's special about the engine in a 97 Venture?
  160. 2001 Sil - Passenger airbag sign
  161. Brake Lights not working
  162. 97' wiper problem.......?????
  163. Trans rebuild? 2000 Silhouette
  164. no fuel past fuel rail
  165. Air shock problem
  166. Intake manifold gasket...DIY?
  167. 99 Old Siluette Problem
  168. swaping the radiator from a 93 olds Silhouette to a 93 olds 88
  169. NEWB: Water temp gauge doesnt move !!!
  170. adding softened water battery
  171. window
  172. Wiring harness question
  173. '93 Silhouette AC, freon trouble
  174. 1998 Silhouette Check Engine Light
  175. 1999 Silhouette rear deck lid Wiring.
  176. best brand of head gasket kit
  177. Non-shifting Transmission Overdrive Issue
  178. Oil analysis results, not so good.
  179. 2002 Silhouette purchase
  180. Air dryer/ air suspension
  181. oil pressure light
  182. Heater Blows Cold Air
  183. Traction Control System
  184. Almost giving it away but I have had it, so long GM
  185. Breaking for spares (UK)
  186. Intake Manifold "goodwill warranty" Toronto Area
  187. Water pump
  188. Thanks Greg A
  189. BCM Body Control Module location 2001
  190. cooling fan switch
  191. 2003 Olds Silouette won't start
  192. Power Sliding Door Not Working (HELP)
  193. 1999 Olds 3.4 high temp
  194. Power Lock Drivers Side Rear Sliding Door
  195. 1999 Dash Lights
  196. 2000 Silhouette ABS Idiot Light
  197. 1993 sil chugs and dies
  198. 2004 gold pkg-wind noise, seat height, door/radio shut-off
  199. 2002 Steering
  200. Brakes/sudden slip
  201. Windshield Wipers
  202. sporadic grinding noise from front while turning right?
  203. 94 Silhouette 3.1 accelerates
  204. Cylinder Misfire
  205. 92 olds Silhoutte
  206. $4200 brakes! Please advise
  207. 1998 silhouette Heater core?
  208. codes
  209. 91 factory service manual
  210. Rear heating system
  211. 97 side pass. power door froze shut, now not working.
  212. how to program 2001 silhouette remote
  213. jerking when started and on low idle
  214. 99 Silhouette, van starts, runs rough, then dies
  215. 1998 Silouette ABS, TCS, Brake light, and Service Engine Light intermittent
  216. lower intake manifold
  217. Power Sliding door
  218. What years will interchange?
  219. Brake Lights
  220. Passenger side mirror
  221. P0753 1-2 Shift Solenoid
  222. DIY transmission fix
  223. 95 transmission
  224. (parking) BRAKE idiot light
  225. new to forum, quick ?
  226. 2002 Blower Motor
  227. Radio Code
  228. 1975 Omega heater core
  229. windshield wiper motor
  230. tourque converter
  231. Replacing CD Player, Keeping other OEM systems
  232. What is normal coolant loss?
  233. 2001 breaks
  234. surging and dying
  235. starter
  236. starter problem
  237. power door locks
  238. 98 Silhouette new gaskets, now knocking??
  239. Brakes
  240. 1999 Silhouette Drvr window tilts
  241. ashtray power in 2000 Silhouette
  242. Drive Belt Pulley Noise
  243. A/C Questions
  244. 99 Olds Silhouette code P1483
  245. Rear Heater controls
  246. Driver side floor wet
  247. Replacing Key Fobs
  248. high mount brake light
  249. Rear Air Suspension
  250. heated leather seats again
