View Full Version : Aurora
Pages :
1 2 3 4 5 6 7 8 [ 9]
10 11 12 13
- bugs stuck on front end
- no power to the radio
- Autobahn
- new air conditioning compressor... now what do i do?
- Got a new tire...Kumho 235-60r 16W
- 95 cd cassett player
- Windows lock wire
- Hesitation again and again...
- Car Amps
- anyone have a repair manual for the 96 aurora they want to sell
- How to change plugs on the back 4 cylinders?
- Low Oil Light W/Very Warm Engine...
- TEMPERATURE 220 TO 230 Driving in town...
- Erg
- performance
- Keeps blowing fuse
- Driver Door Wiring Diagram
- 95 aurora wont start
- 1995 Aurora: Surging/Idle issue
- Serpentine belt tensioner
- Passenger Side Courtesy Lights
- Will the 95-99 Aurora wheel rims fit on mine?
- If you like Silverstars, you'll LOVE this trick
- 4t65 problem - no overdrive
- Air vent in dash....ever pull out?
- cruise control quit working
- Suspension/Ride - what goes bad?
- P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
- P0410 Secondary Air Injection System Malfunction
- diagnostic codes, assessing
- Still slow to start
- Aurora to be Re-Introduce in 2006
- gm performance
- engine cooling fans
- A baffling weird problem need info
- wow......I saw a yellow aurora...
- My Engine is Grinding!!!
- Engine an Tranny mounts
- using 2003 Navigation in a 98 aurora
- recall notice in mail
- Changed struts now bouncey rear end??
- radio problem
- Fuel Rail Tragedy Fire under the hood
- REAR WINDOW weather strip
- Front Splash Guard Removal
- BOTH rear shocks dumped fluid!
- When GM Says: 100,000 Mile Tune-Up
- 95-97 Aurora RECALL-Important
- Head problems?
- air conditioning warm???
- Oil pan gasket
- northstar support bar?
- Fuel Rail 95 Aurora
- Rear shocks bad? - Need replacement suggestions
- A tip for your water pump leak
- Question for a GM mechanic or anyone
- Po758
- ignition
- how big is the gas tank??
- bad news
- Bad Brakes?
- Transmission code P0741
- 1995's added to the Fuel Rail ReCall
- Question to the "wise"
- tranny
- TAKING (Car)TODAY IN FOR THE RECALL! (DEALER)
- Having Hesitation after car has heated up
- What should I do?
- Progressive Tuner
- Sunvisor (narrow strip) around the entire visor
- pass. side blows cold/drivers blows warm
- which year had the least problems
- wtb Black 96-99 in excellent cond low miles
- connecting up the ipod- does my stereo have the connection?
- date problem
- more aurora parts forsale
- When bleeding brakes - engine on?
- Fuel gauge gone buzzerk
- Tranny Fluid Servicing: Information
- lacking luxury!
- '02 Aurora Nav unit FS
- a/c contol module issue
- 1995 Low Serial Number?
- Radiator Cap Pressure
- OLDS Aurora Clubs
- steering wheel radio controls
- Air box mod
- Rear sway bar
- ABS and Traction Control light pops on
- www.oldsmobileforums.com DOA?
- Aurora Parts For Sale
- 95s added to fuel rail recall yet?
- olds wont crank
- 1995 needs New Engine
- fuel gage problem
- Hood Paint blistering
- Custom Indiglo Gauge group buy
- Paint code-'95
- Turn Signal
- Air Conditioning
- Heater Core
- Trick to Thermostat???
- 1995 auroa any good
- low pressure a/c recharge valve?
- Parts interchange for Aurora from other cars?
- gas octane
- Tire Cupping
- Rear Window Weather Strp
- coolent flush
- Horn Won't Work!
- hairline scratches in gauges plastic
- '02 Aurora Amp pinout ...
- replace abs sensor?
- CD Cassett swap....code? dealer AHHHH??????
- Questions about the brakes
- Hard starting and getting worse...
- Engine not turning over
- code p0421 and p0421
- anybody running on blank Brembo rotors?
- spots on my dash gauges
- fog light button (is it supposed to light up all the time?)
- turned the key over, took 9 times to start...
- very hard steering when turning right
- vibration in steering / lunge forward when starting
- Traction Control
- ran out of gas...and now
- 2001 Crankshaft Position Sensor
- Ignation system
- Lights keeps flashing on and off...
- Runing too lean
- Removing the Left Side Driverr's Insert
- vibration on highways
- headlights won't go off (1995)
- Low Coolant Sensor or switch
- 95-97 vs 98-99 Suspension differences
- Rear shocks 4-5' too high
- Body Control Module
- Outside Temprature
- new a/c comp for $700 now hot air???
- Aurora Chrome Rims
- 97 still for sale
- 1998 Oldsmobile Aurora
- rpo label
- Aurora Vs Potholes!
- SES light on, among other things. '95 Aurora
- Lifter Cladder
- Electrical problem 98 Aurora
- fuel rail
- Water Pump Socket
- Stall and incorrect MPG calculation
- sticking gas pedal on 95 Aurora?
- Wind Deflector things
- Where is the horn located??
- searching gm's techlink website
- Oil Pressure
- 1996 Aurora with NEW GM engine
- Engine Temperature
- FS: 95-99 Aurora 16" factory rims
- Transmission/RPM
- battery change
- Rear Disks
- Wow!! Dex-cool Vs. Green Antifreeze
- Horn Problem, 1995 Aurora
- Does Anyone Know For Sure ??
- Going Crazy
- help?????????
- Going in to A/C shop in the morning.
- speed sensor
- More on starting problems
- CV joint, wheel bearing, & A/C
- over heating, L47 engine
- fuel gage
- very intersting find about Aurora
- 98' door locks won't work (all of them)
- oil weight, why not 20-50
- 1998 Aurora cooling problem
- 1998 alternator question
- wierd!!!
- 1995 Aurora, rod knock (may part out)
- pwr driver seat problems
- '02 Aurora Nav question
- AURORA STOPS AT RED LIGHT, other info...
- recall question
- Yugo here,Yugo there, Yugo Everywhere
- Gurgling sun roof
- Heat Extraction
- AC Troubles 95 Aurora Need HELP!!!!
- 1998 aurora stalling with air on ???
- Recall for 95
- Steering wheel controls
- Automatic door locks won't work
- Tranny Issues
- Headlights flashing....again
- Stuck spark plugs- Help I can't get them out
- Starting Problems 2001 Aurora
- Help, I need to change out a motor
- Removing the Insert
- how remove cover over idiot lights?
- Change transmission fluid and oil NOW!
- should I change the tranny fluid?
- Engine Removal Tips
- billet steering wheel?
- took my Aurora in for the recall
- Blue Headlights
- Gas Mileage??
- Hard Starts
- help electrical problem with flashers
- Service Manuals on CD-on ebay
- Lamp Control Module Information
- Service manuals, What do they cover?
- Temperature blinking?
- Stability System???????
- 2001 Aurora-Check Gas Cap Warning
- Front Driver side Hub (spindle) replacement
- Air conditioning DIY, need advice
- will these wheels fit my 1998 aurora????
- 2001 Rear Seat Bench Removal
- Trooper Pulls Suicidal Woman Off Bridge
- Code 410 Stored Air Pump ?
- Radio Removal
- Wtb: Etcbm
- 1997 Factory Manuals For Sale
- What was that?
- Failed emission test
- Transmission Mystery
- Instrument Panel Not Working
- Diagnostic Codes Po 300 and PO 441
- Air conditioning problem
- 2 questions
- Question About 2001 Trunk Wiring Harness
- What's causing a chirping squeeking sound when I go over bumps and in turn
- disappearing oil
- engine codes?
- $1000.00 --95 Aurora--
- Aurora Collectable ?
- '95 Trunk Lid Disassembly Help, Please
- Any Advice At All PLEASE.....BEGGING
- Oil Opinion
- Security Light always on
- Need pages from 1995 Aurora service manual to replace drivers side mirror
- 01 front foglight problem
- Fuel Pump R&R
- oil pressure relief valve
- head lights flashing on and off
- where to put "hide-a-Key" ?
- damn recall
- Electrical Problems... NEED ADVICE!!!
- New England
- horrible gas mileage
- New dynomax turbo exhaust
