View Full Version : Aurora
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13
  1. Aurora is dead in the water - idler pulley seized up , shattered belt
  2. (k)no(w) when to say when ?
  3. 2001 Aurora Interior Lights
  4. Coolant Temperature sensor
  5. Wanted to buy - set of Aurora wheels
  6. Releasing the fuel pressure
  7. Fuel Injector(s) Replacement
  8. New Aurora, Good idea???
  9. Spark plugs
  10. Changing the 2 Crankcase Sensors easy?
  11. Question regarding Radio and CD Changer (use as aux input)
  12. fuel pump ???
  13. transmission swap
  14. ??? on 95 Rail Recall vs. 96/97 Rail Recall
  15. speakers
  16. Head Gasket
  17. lighting up the rear bar
  18. Brand New Engine
  19. Outside Mirror - Just the glass
  20. 1995 Overheating Issue
  21. burning smell + exaust white/gary smoke
  22. NorthStar?
  23. Button on Shifter
  24. 96 Aurora tranny
  25. Intake noise
  26. service engine light
  27. SS Brake Lines
  28. parking brake... how does it work??
  29. Making Progress
  30. Aurora suddenly lost power
  31. how often should I change my trans fluid?
  32. Whine and seat switch
  33. antenna modification
  34. Where to buy / How to replace drivers power window motor
  35. Front end Moaning sound
  36. '95 Aurora transmission shifting strange
  37. aurora parts
  38. 2001 Fog Light
  39. tranmission fluid change
  40. Front Axle--differential
  41. Hesitation Issues
  42. water pump replacement-won't budge
  43. Misfire in Cyl #3 - solutions?
  44. Accident Pictures
  45. Who has the most miles
  46. Starter and Intake Manifold
  47. water pump belt replacement
  48. Alternator Question
  49. when accelerating, surges??
  50. 96 Shift position indicator light out
  51. replacing control arm? Is it difficult?
  52. Razzi I think I seen your Aurora, or a twin
  53. Water in Trunck and Trunck latch
  54. CODE PO502 & PO503
  55. 95 Aurora - Transmission Mounts Problem
  56. Selling my Aurora $1500
  57. racing parts
  58. want to buy 95 olds aurora service manual, HELP
  59. Recall Question
  60. New Tire Problem
  61. Tire suggestions for 96 in Northeast
  62. Please tell Grandma how to disconnect the torque converter lockup solenoid
  63. seat problems
  64. suspension problems
  65. Grandma needs more help with Grandsons car URGENTLY
  66. Cooling mystery????????
  67. 98 Aurora Buring Oil?
  68. Loud Bang, white smoke from engine: Blown gaskets?
  69. Air/Fuel Performance Chips!?!?!
  70. Passkey Module Help For Oldsmobile Aurora
  71. Steering rack question
  72. Will someone answer my questions......
  73. Ride Control
  74. headlight question
  75. 2001 Aurora Transmission
  76. Master cylinder
  77. garage opener
  78. parting out aurora
  79. Aurora Engine Cover Trap Heat?
  80. Aurora Aftermarket
  81. headlight replacement
  82. Dash Lights Out?-Check rear Park Lmp Fuse
  83. Is it hard to change plugs and wires??
  84. 2002 Aurora V6 Starting Problems...HELP!!!
  85. Aurora Is DEAD!!!
  86. sometimes pulls to the right
  87. exterior lights or park lights wont go off
  88. Need DIS help
  89. Died twice now?
  90. Inheriting Grandpa's Aurora
  91. 1998 Aurora oil pressure problem
  92. Fuel Rail Recall
  93. Dash Lights Wont Work And Headlights
  94. Spark Plugs
  95. no power/rough idle/but new plugs
  96. control arm bushing-- where is it?
  97. Crank shaft positions sensors on 95 Aurora
  98. winter tires
  99. rear soeaker wire +/_ color ??
  100. Can AC Condensors Be repaired
  101. couple of problems
  102. Where Is The Temp. Sensor On A 95 Aurora Engine?
  103. Problems with 98 aurora
  104. what car to buy?
  105. Aftermarket seat heaters
  106. AC control unit not working on my car but will work on my friends car ....Please help
  107. 95 Aurora Trany acting really wierd or is it the ECM?
  108. Grinding Noise on Aurora
  109. Vibration in Steering Wheel ?
  110. aurora troubles
  111. Stalling when cold
  112. Loud pop in bottom left.
  113. Tips on fixing broken wires / harness driver door
  114. 95 aurora trannsmission issue. help!!
  115. Air Pump Noise
  116. Factory Radio
  117. exhaust Mods
  118. wrecked or ruined auroras
  119. how do i take the front door panels off??
  120. O2 Sensor Locations
  121. 1996 aurora 4 SALE
  122. fuel preasure regulator
  123. Wanted to Buy:
  124. Misfire and Hesitation
  125. how do i put up car pics on here?
  126. new info
  127. Delayed Charging / Alternator
  128. Grandson needs help with Aurora
  129. Chattering Wiper blades
  130. 1998 Aurora Factory Shop Manual
  131. door speakers, what size????
  132. 1995 Aurora-For Sale
  133. Squeak in the right front?
  134. First SPEEDHUT Order
  135. whats tha( EMIISION SYSTEM) MODULE CONTROL is for?
  136. transmission
  137. figured out the problem
  138. How to get rid of this SpeedLimiter
  139. Aftermarket Calipers
  140. Starting Problems
  141. On Star and steering wheel lights
  142. More Horsepower for 2001 4.0L
  143. 98 making noise in turn
  144. Parting out 1995 Auora
  145. Auxiliary power fuse #22 Aurora 2001
  146. Trunk switch/Dead wire
  147. Lights around stick shift don't light.
  148. It Won't Start But I Do Have Power...
  149. It Won't Start?????
  150. 1995 Aurora Part Needed Heater/AC Big Control Know
  151. Bose stereo amplifier.
  152. your opinions ???
  153. Trunk Layout....anyone else try??
  154. 95 Heater Problems
  155. i need the name or the part# of the silver box under the driver seat
  156. 1996 Aurora O2 Sensor Problem
  157. 95 Aurora - Drivers Side Door Electrical Problems
  158. license plate holder (bracket)
  159. Heater problem - where is the "blend box"
  160. recall completed
  161. heated seat not heating
  162. FPRLeak
  163. Monitors for headrest
  164. Why wont my steering wheel controls work...
  165. Wht wont my steering wheel controls work...
  166. engine question
  167. Fuel Injectors
  168. fuel door electronic release problem
  169. awesome LOL
  170. Electrical problem, I think.
  171. '95 Aurora for $350!!!
  172. do brakes on Aurora have to be bleed after pad install?
  173. Overdrive & 4th gear normal highway driving
  174. outside tempeture sensor
  175. Spark Plug or what? Please Help!!!!!!
  176. 2002 Aurora Steering Noise
  177. Steering wheel hard to turn
  178. Bad AC Air Compressor
  179. White out tail light mod
  180. fuel door problem
  181. what there is allready a supercharged 4.0?
  182. 96' Headlights/O2 Sensor/Trunk&Fuel Door Problems
  183. Fuel Filter
  184. anyone have a remote start for their Aurora?
  185. Undercover Racer
  186. Antenna Replacement???
  187. Fog light replacement
  188. Aurora Wallpaper!! Check it out.....
  189. '98 Aurora Nav unit
  190. Knock when turning
  191. Shocks
  192. Classic Aurora 95-99 Indiglo-Gauges (GroupBuy)
  193. Car alarm
  194. Will 96-99 wheel rims fit on a 2001?
  195. ELC 30a fuse blowing
  196. Cadillac Pills?
  197. Little button on steering whell don''t light up!
  198. Arm rest broken!
  199. Fuel Gauge Inaccurate?
  200. Excellent Luck w/ my Aurora Changing coolant questions
  201. thanksgiving
  202. P0101 is MAF Sensor Performance.
  203. Dang My Trac Light
  204. Activating keyless remotes
  205. More about recall on my 95'
  206. Bad Gas Mileage
  207. aurora parts for sale
  208. custom sites?
  209. Aurora acts stupid.. whats your diagnosis?
  210. trans and engine mount Q and prob
  211. Oil leaks......
  212. Did I Blow Something? Lights On Instrument Panel And Ac / Control Lights Went Out
  213. electrical
  214. I Need Parts.....
  215. Blower Motor Control Unit
  216. gas smell inside my car???
  217. Service Engine comes on when it rains, HELP!
  218. Gas tank full of air?
  219. headlights issue
  220. thermostats 180 vrs 195?
  221. heater blower/ac blower
  222. Remote control for 2001
  223. Lighting around the stick shift.
  224. little box in rear dash????
  225. Location of 2001 radiator drain plug?
  226. Another Overheating Problem
  227. turning the Steering wheel
  228. 1995 Aurora...too many headaches...need help
  229. cooling fans only work if a/c on ?????
  230. Direct Fit Catalytic Converter
  231. Tranny slipping
  232. Low Engine Coolent
  233. oldsmobile engine price
  234. white exhaust smoke/misfiring on cool start
  235. 95 Aurora for sale - mint
  236. 2001 Aurora smokes on startup
  237. dead power window front passenger '01
  238. Parting out 1995 Aurora
  239. Rattling in the front end
  240. 97 aurora electrical schematics
  241. Screwed up my front end $$$$$$
  242. DIC--What is the normal charging level
  243. coolant temperature sensor
  244. 95 Aurora: Fuel Filter and FPR location
  245. Radio Lock need ideas
  246. close call with the fuel rail...
  247. air shock compressor
  248. normal temperature
  249. Best Aurora Warranty Coverage???
  250. Transmission problem?
