View Full Version : Aurora
Pages :
1 2 3 4 5 6 [ 7]
8 9 10 11 12 13
- Antifreeze
- There's a Set of Service books on eBay only $90.00
- Is there an adjustment for the gear shift cable?
- Turn signals won't work
- anyone need a foglight bulb?
- Cracked bumper
- vent no blow
- gas gage gone wild
- Cracked head
- 4T80E downshifting or will not shift
- Tranny down shifting check engine light
- Recall
- 95 motor into 96 / manual
- no info on waterpump
- New steel fuel rail-vapor lock
- Pcv Valve
- Rear Speakers
- where can I find a listing of Olds or Caddy Dealers near me
- clunking
- Replacing waterpump
- Fuel Injectors
- Tune up
- Idle Surge Problem PCM?
- Safety Switch
- Protect Mode Or Neutral Safety Switch
- 95 Aurora Overheating Problem - HELP
- Buick lucerne= aurora ?
- 1998 Aurora OEM Floor Mats
- Car now starts but having some other issues
- waterpump
- gonna buy new tires help???!!!!
- Changing the radio
- aurora weatherstripping
- Replaced motor & tranny but won't turn over
- hard to start
- Mounts, O2 Sensors, CV Joints
- custom ignition
- Climate Control Possessed!
- Radio prob aft keyless FOB programming
- Changing ignition coil
- 96 aurora, won't shift to OD, seat problems?? Thanks!
- Thermostat replacement
- oil use
- Button on shifter sticking
- Change To Synthetic Oil?
- Voltage
- I want more bass in my bose sound system
- EGR question...
- PASSKEY ll module
- another overheating question
- reverse lamps
- Transmission Problem
- ABS speed sensor harness
- Door chime contact ?
- Which Ac Delco Rear Air Shocks?
- Lights Dim when Brakes applied
- engine light code: crankshaft timing is off
- Repair manuals
- What's the psi that you fill the tires to?
- Hacking the Aurora...
- Heat question
- Fogs up in winter
- Where is the ECM?
- Unknown Powertrain DTC???
- Check Charge System
- Re-doing the cloth upholstery, what are the prices?
- New Stabilizer bar info for the classics.
- New radiator, new warning message...
- Surging, Bucking, Backfire
- wipe key wait 3 minutes
- Wheel bearing problem ???
- removing idle speed motor
- help
- how often do I change Trans. Fluid?
- Oil Level Sensor
- Transmission
- Better gas milage?... ANYONE?
- Reseting The Dic
- cooling question
- Engine swap 95 to 97
- Climate control dead
- How much oil in a 95 Aurora?
- Cruise Control
- custom air filter
- Buying Plug Wires & MAFS
- removed catalyst converter
- Passenger seat problem
- Stalling At Stop
- idle problem while warming up
- 97 wiring diagram HELP!!!!!!
- coolant temp sensor
- turbine shaft speed sensor question
- tach bounces stalls
- problems
- amplifier question
- Air ride compressor for a 95
- 1998 4.0 "Knocks/Tics"
- Miles Annually
- custom air intake
- 95 old aurora noise after shutoff
- Sunroof/Moonroof what do you think???
- Adjusting Voltage?
- Outer door handle replacement?
- engine noise what is it?
- passkey system fault
- what motor oil to use
- Non-Air Shock Rear Replacements...?
- no abs light or trac control
- stalling problem easy to fix....or should I stay away...
- Ignition module may be bad no power
- Twilight Sentinel does not work
- Stalls when warm
- tranny Slip
- 1998 Aurora owners manual pdf?
- Buffed up olds
- Temp at 240
- power window problems
- speed sensor failure
- New Axle Too Long?
- Track1
- Brake Pedal Fades, 95 Aurora
- Gm Th400
- Power-Steering Leaks
- T. control, and abs light
- help please!!!
- powering steering gone (reads CHECK SYSTEM CHARGE)
- Serpitine Belt
- Passenger Door will not open
- Just Bought My First Aurora
- A/c Compressor
- 255/50's
- Sounds Like Lifter Noise( Help )
- Power Steering Issues
- clicking noise in dash???
- sticking gas pedal
- I Have Parts
- Which mufflers have the lowest frequency
- Front end
- 97 Aurora - What do you think???
- seatbelt retractor for 96 aurora
- nutral safety switch
- aurora club
- Good price for front end work???
- 2002 Front suspension feels loose
- Car stalls when driving
- Turn Signals are Winding Down
- Crappy Editing Pics
- ding ding ding
- cassette adapter problems
- dipping tachometer
- ipod setup option for aurora
- headlights
- Input/Turbine Speed Sensor...
- Idle Problem Help!
- top of motor
- Check engine light after replacing fuel pump!!!
- Check Engine
- fuel rail not holding pressure
- How do you Change the Alternator in a '97 Aurora?
- abs sensor / computer chip out
- Trunk switch
- Front Urethane Bushings......
- dead as a duck
- Oldsmobile Aurora 2000 mysterious oil leak engine
- Electrical
- 1998 spare tire
- Ravin Mufflers by Midas
- electrical question
- 32 v caddy vs. 4.0 aurora
- Heated seats
- T. control/Cruise
- Terrible Vibrations!!!
- Aiming foglights
- Brakes are thumpy!!! Brand new brake job!!!
- Electrical Problem on 96 Aurora
- 96 Aurora
- '95 4.0 1/4 mile time
- 98 hesitation, miss when warm
- Injector problems-'98 Aurora
- Keeps dying, but only when in gear???
- floor mats and homelink remote
- Turn Lights off
- Why no superchip for 96-99?
- Considering an Aurora, ? is 3.5 or 4.0?!
- Changing radio
- aurora vs. riviera
- Speed sensor question
- 95 subframe???
- 96 aurora hesitation problem
- Breaks and Roters for '98 Aurora
- Voltage
- Installing 12 Disc CD Changer
- Recommened Tires For 1998 Aurora?
- Weird Cooling Issue
- Help! did anyone has a used electronic unit
- extended warranty
- cooling problems
- Turn Signals do not work
- How big of a rim can I go?
- Engine Won't Start...STRANDED...need help
- Power Seat Fuse?
- Serpintine Belt
- Hello All...New To The Board
- tire pressure monitor
- Fuel Pump Fuse
- cam shaft sensor
- Stalling when idling at lights
- Ignition Key Problems
- 1995 Aurora - Time to get rid of it??
- Any Recommendations on Front Brake Pads
- 95 ran good, ran rough, won't start
- changing the right headlamp, lowbeam & fog lamp on 95 Aurora
- A really easy fix!
- heater blower
- A center brake-light...
- RSM Lowering Kit
- fuel gauge after fuel pump replacement
- Turns over but wont start!!!
- Major Aurora problems, need help/advice please with transmission+dash lights/gauges
- Chasing electric drains/shorts
- 2001 Aurora 4.0L OE Spark Plugs
- ipod set up for aurora
- Help Please!!!!!
- 350 HP out of the 3.5L
- Lights around stick shift don't light.
- new member
- Fuel Pump Preasure Regulator
- What Compares to The Aurora??
- 1998 & 1999 Auroras
- Tranny Fluid Change at 153,000 miles?
- Plugged Hole In Firewall on Drivers Side 1998 Aurora
- cd changer won't eject-help!!
- Noobie with Aurora problems
- Northstar in Aurora Engine Swap
- Need HELP ASAP - Fuel Rail Recall '95
- 1996-99 Engine Swap into a 1995 Aurora
- Opportunity to part out 96 Aurora
- Snapping sound from front passenger side!!!
- Olds Dealer Can't Find Problem
- factory head unit problems
- Why Can't I Hate This Car??
- Aurora runs away while idling.
- 1996 Aurora Rear Brakes
- tweeter removal
- what do you think about this?
- fuel tank screen
- Twilight sentinel problems & dashlights out
- Frusterating water leak / Help!?
- starter
- how long to warm up?
