View Full Version : Aurora
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13
  1. A/c Compressor
  2. HVAC Fan
  3. 1996 Aurora dash/running lights out
  4. 96 A/C Blower won't shut off
  5. HP rating 95 4.0 aurora
  6. 95 Aurora stalling
  7. Splash guards
  8. new remote help
  9. oxygen sensors
  10. Tune Up
  11. a/c fan noise
  12. Oxygeb Sensor
  13. High speed noise
  14. Brake Booster 96
  15. Anyone have A/C info?
  16. cruise control question ???
  17. need more opinions ????
  18. Fuel Line Leaking
  19. Anyone have the Bose cd/cass plaer for sale
  20. why aren't my remotes working for the keyless entry?
  21. Spark plug location on 01 Aurora 4.0
  22. 97 Aurora---many problems
  23. Sudden loss of engine power when turning.
  24. Climate control
  25. Radiator replacement choices
  26. How long should your service engine light be on?
  27. Balancer Pulley
  28. 96 Aurora overheating &
  29. Traction Control and Anti-Lock lights
  30. lights continue to flicker now what????
  31. Air Bag light
  32. 95 - Engine turns - doesn't Start
  33. Hesitation
  34. 96 AC issue
  35. My Aurora
  36. Metric to English
  37. Oil Level System Fault
  38. I would like one
  39. replace OR clean the egr valve ????
  40. Fog Lamps
  41. Dead Battery
  42. Wheel Hubs
  43. Help!!! Shifts Hard Light Comes On!
  44. Interior questions about 99'
  45. stability service warning message
  46. Smog(air) Pump
  47. IAT Sensor for 2001 - where is it?
  48. 95 Steering Wheel Controls Out....help
  49. Can I replace my Bose Cassette/CD changer with....
  50. Low Tire pressure indicator
  51. Wierd starting problem
  52. Air Bag Light
  53. who needs radio knobs
  54. fuel pressure regulator and new fuel rail
  55. Streering wheel controls 2nd. gen.
  56. Engine Miss
  57. Water Pump Belt
  58. '95 service engine codes
  59. OLDSMOBILE Stereo questiion
  60. Annoying Sqeaking SOUND..OOO PLEASE HELP ME CURE MY HEADACHE
  61. 2002 Aurora, water leak in rear seat area
  62. Help- replaced a/c compressor on '99 aurora & now won't start
  63. Aurora may be dying
  64. Traction lock and anti skid problems
  65. DTC 84 too few 24x reference pulses
  66. Fixed my transmission problem!!
  67. Is there hope for my a/c?
  68. steering column
  69. 2001 3.5 codes
  70. Brake pads clunking/movment. how do I stop it??
  71. Recall????
  72. drivers window won't budge
  73. a car like the aurora
  74. Rear Control Arm - DIY project??
  75. A/C noise
  76. Location of A/C orifice
  77. Engine Cuts Out
  78. clean key wait 3 min
  79. howling noise
  80. howling noice -help.
  81. Parting Out Aurora?
  82. Another oil pressure question
  83. 97 aurora starting problem
  84. Engine light is on, oh no!
  85. Water pump help
  86. parking lights, fog lights stay on flicker
  87. Aurora "sluggish/slugging" problem in overdrive
  88. a/c recharge is it possible???
  89. Chirping noise..kinda annoying!
  90. 96 Aurora Mirrors fold in?
  91. cracked engine block
  92. yet another problem
  93. fuel line leaking
  94. Car Accident Experience
  95. mileage
  96. rear driver door won't open
  97. Vibration when braking
  98. "Service vehicle soon" warning on the dashboard display
  99. engine hesitation
  100. Driver Side Courtesy Lights OUT!!!
  101. 2002 Aurora Airbag trouble code
  102. Rear fog lites 2nd. gen
  103. Thumpin455-You are a lifesaver!
  104. rpm at idle
  105. Replaced plugs, wires and coil packs - 4 plugs still look burnt?
  106. low engine coolant
  107. Headlight assembly removal
  108. coolant temperature sensor 97 aurora
  109. ASC Button
  110. Strange Intermitant Stalling Problem when engine Hot -Not FPR or Crank Sensor related
  111. 96 overheats with a/c on
  112. OEM wheels and possibly painting them
  113. parking lights pissing me off
  114. A/C "recycle On light button"
  115. motor mounts tranny mounts
  116. Spark plug carbon tracking
  117. normal battery volts
  118. My 1995 Aurora won't start
  119. Display thingy dangit
  120. autobahn vs. non autobahn
  121. lights in steering wheel
  122. story: 1st week of ownership, 02 Aurora 3.5
  123. WTB:plastic trim around radio
  124. ebay..parting out 2 auroras..95 and 97!
  125. Aurora is back to full duty !!! just wanted to share my joy !!!
  126. My '97 has one foot in the grave
  127. 99 Aurora
  128. Hard starting
  129. Aurora stuck in 3rd gear HELP!
  130. New To The Aurora
  131. Settings for Power Locks
  132. 2001 up parts list
  133. A/C issues still
  134. Looking for parts where to get or who has them
  135. Problems with 96 Aurora
  136. aurora stuff
  137. Time To Replace Headgasket
  138. EGR TPS controls overdrive
  139. gatorback autozone belt (noisy)
  140. Could ThiS Be The Problem or Can iT Be Something Else?
  141. Beachlover333FuelPump?(95)
  142. Issues With 96 Aurora
  143. 2001 Aurora 3.5 replace headlights- very easy!
  144. Need a wire harness
  145. check engine light
  146. why is my car over-heating!
  147. hey everyone!
  148. totally off subject
  149. Torque Converter
  150. Any Ideas ?????
  151. Dex_cool only with green antifreeze!!!!!
  152. sad day
  153. gurgling hot
  154. Body Mods
  155. Alternator (I think)
  156. Water in Trunk
  157. Aurora coolant reservoir!
  158. ECT Sensor
  159. Mirror
  160. 97 Aurora
  161. need help here big time!!!!
  162. electrochromic day/night rearview mirror with compass
  163. electrical...ignition?
  164. where do i buy new battery for Aurora?
  165. replacing fuel pressure regulator
  166. 95 vs 96 performance
  167. Hard Start, Black Smoke
  168. Headlights just shutoff driving at night....
  169. idle motor adjustment screw
  170. what size socket i need for front axle nut?
  171. still have problem with dash please help ?
  172. Bearing vs CVJ noise?? ('96)
  173. My 1999 Riv
  174. check engine light!
  175. problem solved
  176. Air conditioner turns on automatically
  177. Wiring Problems on 1982 Ford Econoline
  178. I need help
  179. electrical?
  180. I need Help
  181. Grandma's back, have fuel pump 95 aurora
  182. Experienced Help Please
  183. car surges
  184. aurora seat wireing
  185. aurora instrument panel problem
  186. Lean Condition
  187. Initial speed up problem
  188. spark plug wires
  189. 2001 Tranny shifts hard any opion helps
  190. 95 Electrical follow-up
  191. A/C issues
  192. Looking for ne bumper
  193. electrical issues???
  194. Check Oil Level and Change Oil Now
  195. FS:97 Aurora 73K blk with $2k of damage asking $2K OBO
  196. New Tires
  197. CD chngr/magazine for a 96 Aurora w/Bose system
  198. Time-sert update
  199. 98 aurora-Slow blinking turn signals
  200. Aurora Club of North America
  201. 95 problems - tranny, voltage & AC
  202. Bye Bye Aurora
  203. Razzi Body Kit
  204. heater/ac blower never stops
  205. jet chip
  206. what does code 1372 mean?
  207. Does Size Really Matter? (about tires)
  208. Cruise control won't work?
  209. Rearview compass wacky?
  210. Aurora Indy Motor
  211. 95auro
  212. 01 3.5l sputters at high rpm cold, po1325
  213. licence plate light
  214. Power Antenna problem
  215. turn signals not working
  216. Fuel Sending Unit ?s
  217. Tire Pressure Sensors
  218. 1999 Aurora running hot
  219. compressor hold relay switch
  220. traction control
  221. reverse bulbs
  222. Brake pedal air noise
  223. Looking for a new exaust?
  224. Quick help needed- (Classic Aurora)- Pressure Relief Valve on the Intake Manifold..
  225. My Aurora won't start
  226. car is looseing power
  227. Restored '95 Aurora for sale
  228. coolant leak
  229. cd player installation question
  230. selling 2001 Aurora
  231. Disk Brakes
  232. 1 brake disc is grooving
  233. DIC code 44
  234. driver 1 driver 2 reversed
  235. Interior Problems
  236. anybody in Chicago/WI/IN/MI parting out black aurora ?
  237. DTC's P0452, P0530, and P1639
  238. 96 Aurora Power Seat
  239. some odd problems with classic
  240. alternator please help
  241. Need Engine Support
  242. I need a timesert kit!
  243. Low Voltage
  244. Temperature Gauge-Overheating?
  245. do i need wheel bearings
  246. 98 aurora running jerky
  247. Starter and/or Electrical issue??...Need your input & help PLEASE!
  248. Clicking sound underneith hood when turning off car!! URGENT!!
  249. TPS Sensor stuck on high idle!! URGENT!!!
  250. 1st post!!
