Oldsmobile
> Aurora
View Full Version :
Aurora
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
heated seat light
Bleeding my coolant system....to death
pads and rotors
Electronic Level Controler
Sparkplug design - sputtering
no heat
short electric
daytime running light flickering on and off
Trade Boxster S for M5
98 Aurora Recharging Problem
hi beam head lights
are these sensors or what?
Brighter fog lamps
Reverse flow cooling system?
Remote Start...Good Idea or Bad?
new noise
its all bad
How long do these cars last? What is the repair history like?
$1050 Air Compressor repair? Too Much?
1995 engine removal
98 aurora overheating
98 runs lousy when cold. TPS code
Problems with headlights...please advise
Exhaust options
Anybody ever used an HID kit?
Alldatadiy.com for 02 3.5
J_Swigz=FAG
See my stupidity folks
Paint codes
Aurora 2001 v6 Intermittent starting - frustrated!
how to remove an ignition switch
98 Aurora Security Alarm
95 stereo
Aluminum wheels...TSB ?
"Theft Attempted"...bulls***
Service Engine Light
Pack of questions.
STEVE BARNES dont BUY FROM
hard starting when cold outside
gel cell or wet cell
Alternator pulley causes hose woes
95 Aurora falls flat after 4000 RPM
CK ENG, ABS & TRAC CONTROL LIGHTS ARE ON
Non-Specific subforum???
Electricals acting odd
Electical Problem
When do you have to replace the transmission fluid?
Help with transmission fluid leak!
Air filter box re-installation troubles
How Do You Reset "Oil Change" on 95 Aurora control panel?
more strange happenings
It Pop
1996 Aurora radiator flush
1995 aurora
Is this an Aurora???
Remote Starter
Solar powered battery charger
Glazed Serpentine Belt
cracked oil pan
Cruise Control
Electrical Problem
4.6 Aurora ?
follow up question i'm screwed
2001 3.5 or 4.0!???
Anyone have the 95 OEM battery part number?
Tranny overfill
coolant temp sensor / water crossover
how do i change the thermostat in a 95
Slipping drived belt?
PO 410 Secondary Air Injection Sys.Malfunction
catalytic converter
strange happenings with my aurora
Anyone with a soft copy of the Aurora Service manual?
My factory chrome rims and Michelins now on Ebay
oil pan removal
Wiper Fuse
Got a brand-new crate engine installed
1996 door locks!?
New pads rubbing
i sold my Aurora
Tranny at the end?
95 transmission issues
Difference between Bose and non-Bose?
Bad Battery?
Air Check Valve?
fuel rail recall
Evap Solenoid Error
Aurora Club of North America
problem with alarm
"thunking" noise when turning corners!
new wires/plugs result in rough idle?
stalling like symptoms
1995 4.0L block, heads: parting out
Coolant Temp Relays
parting out 1996 black on black
Easy question
Temperature Control Panel Remove & Replace
rear brakes awfull noise
1995 Aurora Shift Solenoid
Yet another heating/cooling issue...
Tranny issues
Charging system code
more
OIl
Onstar (? 3 of 3)
Sun/Moon Roof (? 2 of 3)
High Mount stop light... (? 1 of 3)
Buying an Aurora soon
Need help
Electrical Issues - Headlights insane
Front Right Brake Grinding/Clunking
97 Aurora loss of power
Need GM Part Number for "filter-equipped liquid line" service replacement part for 95
Please read my post
1996 Aurora 100K Parting out..
Shredding Sidewall
2001 leds in dah
problem with front heat defrost with a/c on
I need some help
Steering Rack
got me Aurora
Car won't start
1999 aurora recharging air conditioning and lighting flickker
air condition control
Fuel Pump
Interior Lights
ignition switch
Northstar Water Socket for sale
2001 Aurora 3.5 OBD Reset
2002 3.5 Engine Grinding at 3000 rpm
my aurora stalled
Simple cleaning question...
Just brought it home!
headlights blinking when i hit the brake pedal
Even the best of us...
3.5 Engine Knocking
Questions
1996 Aurora
Fuel Pump Removal
98 Blower Motor
P0140 Secondary Air Injection
Fuel Pump
overheating problem
whats this mean?
starter problems
radiator
locked up transmission??
Loss of Power
98 Aurora Blower Motor
Check Gas Cap 2001 Aurora
Selling My 95
drivers seat moved on its own after hurricane katrina - help!!!
Transmission kicks and AC stops cooling ELECTRICAL PROBLEMS
Zeph's Final Overheat Post
Won't even click!!
does anyones aurora run like a dog in the rain?
96 Aurora Code P0171
Tranny woes
'98 Aurora stalling, check engine light on
Success!!!! Finally, sweet vindication!
can i fit 20" rims on a 96
Do all the Injectors Spray at Once
I changed my water pump...I'm an idiot...
code reader with out check engine light on?
can i reprogram my ecu
Rear door- driverside- speaker grill
Replacement Panel
Replacement Trim Pieces
This car is testing me...
1997 Faulty Fuel Gauge
Driver's Info Questions on a 1996
previous aurora owner (greenmachine 95)....looking to get into trouble again....
Cruise control throttle cable....
4.0 camshaft timing
Low Beams do not Come On
Thermostat break-in period???
powertrain computer module PCM
2001 Olds Auroa Interior Parts
did i do the airbox mod right
interior lights click off at dusk and back on at 8 a.m
Wireing
97 AC Fill Port Location & Wire Connection
Looking to buy 01-03 Aurora
Gas Prices & Additives
rpm problem
In need of Owner/Service manual
95 Aurora just buzzes when turning the key?
fuel volume regulator
95 Aurora is making strange noise when in park.....
Air conditioning compressor does not engage
Stripped spark plug thread
AC problem
? about Mods.
Spark plug recommendation for 95 Aurora?
Diagnosis
Bypassing the AC Compressor/ Serpentine Belt
Aurora Door Handle
Wet interior, SES light w/ Hard shifting, and Traction Ctrl light
Timesert update
CV shafts?
Radiator cap orientation...
Air Filter Box.
Leaks, leaks everywhere
1995 being parted out or sold outright
99 Aurora
Car feels like it's going to stall...
97 aurora
PS Pump failing?
Gurgle
Siphon from the tranny?
Headlight
Cooling System
Oil filter question.
Steering Bumping Noise
My AC is gone!!!
Burl Walnut
1997 trans/timing problem?
Oil level and oil pressure...
Throw me a code you dumb car
My car says it has a fever...
Engine temp..
2002 3.5 water pump location
"GM Certified Used" = "GM certified screwed"
fuel pump question ????
Last Aurora Built
Belt speed vs. Engine RPMs
Wax on the plastic trim!!!
HELP! My car is a Hoover
Haines, Chilton...anything would help
1995 Olds Aurora
Is my 2002 3.5 Aurora turning psychotic?
will this help my car or hurt it
High pitch noise from engine
stock mustang muffs on da Aurora
96 aurora antenna stuck
oldsmobile aurora
Maint. Manual
Wierd Stalling/Surging Problem
The Turbonator
? License Plate Light ?
Cruise Control
Key will not come out of Ignition!!!
towing capabilities
A/C, 95 Aurora
2001 Aurora Gas cap Door
Water in the Trunk---Spare Tire Well
Scan Code Reader for 95 Aurora
Regularly scheduled maint.
Chev Impala vs. Olds Aurora
