View Full Version : Aurora
Pages :
1 2 3 4 [ 5]
6 7 8 9 10 11 12 13
- problem with alarm
- "thunking" noise when turning corners!
- new wires/plugs result in rough idle?
- stalling like symptoms
- 1995 4.0L block, heads: parting out
- Coolant Temp Relays
- parting out 1996 black on black
- Easy question
- Temperature Control Panel Remove & Replace
- rear brakes awfull noise
- 1995 Aurora Shift Solenoid
- Yet another heating/cooling issue...
- Tranny issues
- Charging system code
- more
- OIl
- Onstar (? 3 of 3)
- Sun/Moon Roof (? 2 of 3)
- High Mount stop light... (? 1 of 3)
- Buying an Aurora soon
- Need help
- Electrical Issues - Headlights insane
- Front Right Brake Grinding/Clunking
- 97 Aurora loss of power
- Need GM Part Number for "filter-equipped liquid line" service replacement part for 95
- Please read my post
- 1996 Aurora 100K Parting out..
- Shredding Sidewall
- 2001 leds in dah
- problem with front heat defrost with a/c on
- I need some help
- Steering Rack
- got me Aurora
- Car won't start
- 1999 aurora recharging air conditioning and lighting flickker
- air condition control
- Fuel Pump
- Interior Lights
- ignition switch
- Northstar Water Socket for sale
- 2001 Aurora 3.5 OBD Reset
- 2002 3.5 Engine Grinding at 3000 rpm
- my aurora stalled
- Simple cleaning question...
- Just brought it home!
- headlights blinking when i hit the brake pedal
- Even the best of us...
- 3.5 Engine Knocking
- Questions
- 1996 Aurora
- Fuel Pump Removal
- 98 Blower Motor
- P0140 Secondary Air Injection
- Fuel Pump
- overheating problem
- whats this mean?
- starter problems
- radiator
- locked up transmission??
- Loss of Power
- 98 Aurora Blower Motor
- Check Gas Cap 2001 Aurora
- Selling My 95
- drivers seat moved on its own after hurricane katrina - help!!!
- Transmission kicks and AC stops cooling ELECTRICAL PROBLEMS
- Zeph's Final Overheat Post
- Won't even click!!
- does anyones aurora run like a dog in the rain?
- 96 Aurora Code P0171
- Tranny woes
- '98 Aurora stalling, check engine light on
- Success!!!! Finally, sweet vindication!
- can i fit 20" rims on a 96
- Do all the Injectors Spray at Once
- I changed my water pump...I'm an idiot...
- code reader with out check engine light on?
- can i reprogram my ecu
- Rear door- driverside- speaker grill
- Replacement Panel
- Replacement Trim Pieces
- This car is testing me...
- 1997 Faulty Fuel Gauge
- Driver's Info Questions on a 1996
- previous aurora owner (greenmachine 95)....looking to get into trouble again....
- Cruise control throttle cable....
- 4.0 camshaft timing
- Low Beams do not Come On
- Thermostat break-in period???
- powertrain computer module PCM
- 2001 Olds Auroa Interior Parts
- did i do the airbox mod right
- interior lights click off at dusk and back on at 8 a.m
- Wireing
- 97 AC Fill Port Location & Wire Connection
- Looking to buy 01-03 Aurora
- Gas Prices & Additives
- rpm problem
- In need of Owner/Service manual
- 95 Aurora just buzzes when turning the key?
- fuel volume regulator
- 95 Aurora is making strange noise when in park.....
- Air conditioning compressor does not engage
- Stripped spark plug thread
- AC problem
- ? about Mods.
- Spark plug recommendation for 95 Aurora?
- Diagnosis
- Bypassing the AC Compressor/ Serpentine Belt
- Aurora Door Handle
- Wet interior, SES light w/ Hard shifting, and Traction Ctrl light
- Timesert update
- CV shafts?
- Radiator cap orientation...
- Air Filter Box.
- Leaks, leaks everywhere
- 1995 being parted out or sold outright
- 99 Aurora
- Car feels like it's going to stall...
- 97 aurora
- PS Pump failing?
- Gurgle
- Siphon from the tranny?
- Headlight
- Cooling System
- Oil filter question.
- Steering Bumping Noise
- My AC is gone!!!
- Burl Walnut
- 1997 trans/timing problem?
- Oil level and oil pressure...
- Throw me a code you dumb car
- My car says it has a fever...
- Engine temp..
- 2002 3.5 water pump location
- "GM Certified Used" = "GM certified screwed"
- fuel pump question ????
- Last Aurora Built
- Belt speed vs. Engine RPMs
- Wax on the plastic trim!!!
- HELP! My car is a Hoover
- Haines, Chilton...anything would help
- 1995 Olds Aurora
- Is my 2002 3.5 Aurora turning psychotic?
- will this help my car or hurt it
- High pitch noise from engine
- stock mustang muffs on da Aurora
- 96 aurora antenna stuck
- oldsmobile aurora
- Maint. Manual
- Wierd Stalling/Surging Problem
- The Turbonator
- ? License Plate Light ?
- Cruise Control
- Key will not come out of Ignition!!!
- towing capabilities
- A/C, 95 Aurora
- 2001 Aurora Gas cap Door
- Water in the Trunk---Spare Tire Well
- Scan Code Reader for 95 Aurora
- Regularly scheduled maint.
- Chev Impala vs. Olds Aurora
- A/c Compressor
- HVAC Fan
- 1996 Aurora dash/running lights out
- 96 A/C Blower won't shut off
- HP rating 95 4.0 aurora
- 95 Aurora stalling
- Splash guards
- new remote help
- oxygen sensors
- Tune Up
- a/c fan noise
- Oxygeb Sensor
- High speed noise
- Brake Booster 96
- Anyone have A/C info?
- cruise control question ???
- need more opinions ????
- Fuel Line Leaking
- Anyone have the Bose cd/cass plaer for sale
- why aren't my remotes working for the keyless entry?
- Spark plug location on 01 Aurora 4.0
- 97 Aurora---many problems
- Sudden loss of engine power when turning.
- Climate control
- Radiator replacement choices
- How long should your service engine light be on?
- Balancer Pulley
- 96 Aurora overheating &
- Traction Control and Anti-Lock lights
- lights continue to flicker now what????
- Air Bag light
- 95 - Engine turns - doesn't Start
- Hesitation
- 96 AC issue
- My Aurora
- Metric to English
- Oil Level System Fault
- I would like one
- replace OR clean the egr valve ????
- Fog Lamps
- Dead Battery
- Wheel Hubs
- Help!!! Shifts Hard Light Comes On!
- Interior questions about 99'
- stability service warning message
- Smog(air) Pump
- IAT Sensor for 2001 - where is it?
- 95 Steering Wheel Controls Out....help
- Can I replace my Bose Cassette/CD changer with....
- Low Tire pressure indicator
- Wierd starting problem
- Air Bag Light
- who needs radio knobs
- fuel pressure regulator and new fuel rail
- Streering wheel controls 2nd. gen.
- Engine Miss
- Water Pump Belt
- '95 service engine codes
- OLDSMOBILE Stereo questiion
- Annoying Sqeaking SOUND..OOO PLEASE HELP ME CURE MY HEADACHE
- 2002 Aurora, water leak in rear seat area
- Help- replaced a/c compressor on '99 aurora & now won't start
- Aurora may be dying
- Traction lock and anti skid problems
- DTC 84 too few 24x reference pulses
- Fixed my transmission problem!!
- Is there hope for my a/c?
- steering column
- 2001 3.5 codes
- Brake pads clunking/movment. how do I stop it??
- Recall????
- drivers window won't budge
- a car like the aurora
- Rear Control Arm - DIY project??
- A/C noise
- Location of A/C orifice
- Engine Cuts Out
- clean key wait 3 min
- howling noise
- howling noice -help.
- Parting Out Aurora?
- Another oil pressure question
- 97 aurora starting problem
- Engine light is on, oh no!
- Water pump help
- parking lights, fog lights stay on flicker
- Aurora "sluggish/slugging" problem in overdrive
- a/c recharge is it possible???
