View Full Version : Aurora
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13
  1. a website that has a used parts index
  2. Problems related?
  3. Aurora Rear Camber Fix
  4. secondary air injection valve!!!!!
  5. Check Engine Light
  6. 95 Aurora help pleeeeeeese!
  7. Multiple Problems Seem related
  8. 95 aurora for sale in So. Ca. 4 parts or fix
  9. Aurora Timing Chain
  10. plugs/wires/fuel filter
  11. clear side markers
  12. another no start problem
  13. Hot '98 Engine Solved
  14. Brake Fluid Light
  15. Torque Converter Clutch Solenoid
  16. It keeps Reving
  17. Where to Mount XM reciever
  18. 96 Brake Booster and Wheel Bearings
  19. dreadful maf sensor!!!!!!!
  20. Replacing Shift Solenoids and have a question
  21. warning low oil pressure 95 aurora
  22. trans expert needed
  23. Rough Idle and Surging
  24. Dead Car
  25. Fuel rail recall
  26. '96 Rt Frt Side Turn Signal Bulb - How to Replace?
  27. oldsmobile aurora abs light and service engine light
  28. Traction Control and ABS light come on when car is started
  29. please help me :(
  30. 96 Aurora AC blows hot and cold
  31. TSB anyone
  32. Gas gauge drops and car stalls at stops
  33. AC/heater Fan relay switch module $550 ???
  34. 1995 Aurora will not start
  35. 97 aurora cooling fans only work with AC on.
  36. can ANY ONE TELL ME THIS
  37. Service-Engine-Soon Light Doesn't Work
  38. Changing CV joints
  39. AC turns off and gauges go crazy
  40. M7 95 Aurora Stalls when idle
  41. 95 Aurora, strange issues, please help!
  42. New Aurora, electrical problem
  43. Oil Cooler Lines
  44. Headlight multifunction sw. - easy fix
  45. 95 Aurora overheating PLEASE HELP!!!
  46. normal compression readings
  47. tranny interchange
  48. '97 Aurora shut down
  49. evap leak
  50. 1995 aurora power windows not working
  51. garage door opener program
  52. At what voltage should an alt. be charging?
  53. Auto headlights go out
  54. EGR Valve?--Repeatable Stalling Problem
  55. EGR Valve
  56. Radiator
  57. check gas cap warning 01 3.5
  58. Gm Service Bulletins
  59. O'Reilly Ultima Alternators
  60. Fuel volume
  61. 95 Aurora - High Mount Brake light Not Working
  62. Odd idle problem, 3.5 V6
  63. high coolant temp.!!!
  64. Oil leak between head and Block????
  65. Magna Steer
  66. Squealing engine noise
  67. removal of side torque (motor)mount
  68. Low Oil Pressure - New Oil Pump?
  69. 01 aurora wet floor
  70. 01 aurora wet floor
  71. Replacing Driver Air Bag & Wheel Controls
  72. 2003 cabin filter
  73. code 94
  74. Illumination on 2001 3.5 Aurora Bose Stereo-OEM
  75. 2001 Crank Sensors 4.0
  76. repair manual
  77. motor mount replacement
  78. Lambo doors
  79. Head Gasket? I Got Oil Under Intake.
  80. Head lights on, interior lights go out! HELP!
  81. hard reverse cold
  82. more active aurora site?
  83. trouble codes P1350 & P1375
  84. 2001 Aurora Water in Trunk
  85. door lock
  86. 2002 hood rust
  87. Engine Swap
  88. lights out
  89. 2001 Aurora Steering Wheel Lock?
  90. Replaced Altenator x3, car overcharging
  91. No Door Key 1997 Aurora
  92. Lights and tires
  93. Coolant Leak
  94. AC air direction dash lights
  95. 1995 aurora for $3000
  96. Air Bag Warning
  97. adding stock cd changer to car w/out one
  98. 95 Aurora Stuck in second gear
  99. Got Extra Cash
  100. replacing the back 4 plugs....
  101. I Need Parts
  102. power windows not working right
  103. dome lights not working, fuse, and where?
  104. Power Windows intermittent
  105. vibration in at all speeds
  106. My Time-sert kit is on Ebay.
  107. Plug Wires?
  108. gas pedal moves after shut off?
  109. Transmission Jolt / Rebuilt Tranny
  110. Custom gauges!!!!!
  111. This car have Autobahn?
  112. Coolant Level Low?
  113. Steering Position Sensor replacement instructions?
  114. 98 Aurora surgin under acceleration
  115. Turn of SES light
  116. Non-specific subforum???
  117. Rear Camber Kit
  118. Turn signal mirrors???
  119. Auto transmission woes
  120. a little off topic, but hopefully you can help:)
  121. need aurora parts or a parts car
  122. Coolant...I put in the green stuff ??!!.....
  123. Coolant in number 5 cylinder
  124. Looking for seat covers 1996 Aurora
  125. Scanner recommendation
  126. Turn Signal Stutter?
  127. chime stays on and lights wont turn off
  128. I Give Up
  129. how much quicker is the AUTOBAHN PKG
  130. Which one is the 24x Crankshaft Postion Sensor?
  131. Close Call - Plug Backed Out
  132. Coolant Leak
  133. right rear wheel heating up
  134. How fast have you gone?
  135. overdrive issues
  136. Diagnostic Help....CVjoint, wheel hub, or....
  137. Crank Shaft position sensors
  138. Stalling problem
  139. Performance Modifications
  140. Problem Solved(almost)
  141. Tmesis...Anyone...Please Help!
  142. 2001 rear bumper lites
  143. cruise control
  144. dex-cool or traditional antifreeze
  145. Strut Bolts
  146. LED Turn Signal Replacements...
  147. Installing Serpentine Belt
  148. 2 year old steering problem...help!
  149. cuts off while driving!
  150. overcharging
  151. Head gasket diagnosis ???
  152. Stuck shock?
  153. Abs Light On
  154. last post before going to the dealer
  155. coolant sensor
  156. Cold starts
  157. Got A Code 84???
  158. bad pcm
  159. Tranny problems.This might help
  160. IAT sensor
  161. Reading Codes in a 95 Aurora...
  162. fuel injectors
  163. Sweeet_Its Fixed_ No More Tranny Problems
  164. 95 radio won't shut off battery drain?
  165. map sensor
  166. More Tranny Issues after Sol Replacement
  167. Hard Shifting w/ Service Engine Soon Light
  168. 1998 Aurora Lights HELP!!
  169. can anyone help me..
  170. Changing bulb
  171. Think i am ready to give up
  172. not trans Solenoids. Help
  173. Plug Replacement 95 Aurora
  174. locate trans sol kit
  175. still chugging along!!
  176. trans problem Related to Bad Battery?
  177. '97 Aurora - Cylinder 1 misfire (code P0301) - the Saga continues...
  178. power windows on '98 aurora
  179. some questions
  180. finally tested the fuel pressure
  181. 97 Aurora Cooling Problem
  182. need to find parts for 96
  183. Photos & diagrams?
  184. Stalling at Stops
  185. Stalling at Stops
  186. Long cranking when starting after sitting
  187. another fpr question
  188. where is the obd plug 97 aurora ?backfiring
  189. replace steering rack
  190. Aurora stuck in Park
  191. Driving without overdrive will save gas?
  192. Aftermarket Center Caps Anygood ??
  193. headlight
  194. shift solenoid fuse
  195. car wont start after sitting
  196. Heated Seat Problem
  197. Quick Strut/Air Shock Questions
  198. Factory radio again
  199. Error code list
  200. Tranny problems? Stuff a Toyota under the rear
  201. DIC SAYS "CHECK CHARGING SYSTEM"
  202. what's the differance in the ECM and PCM
  203. Car loses power
  204. Thinking of Purchasing an Aurora?
  205. popping noise on front end
  206. popping noise on front end
  207. What Part # (steering Controls)
  208. Steering Column Loose 1995
  209. '95 problems please help
  210. 99 Aurora temp control won't turn off
  211. MAF curcuit resistance?, 1999 Aurora
  212. 2001 trunk & gas door release not working
  213. Bad Shift Solenoids without PCM code possible????
  214. Proper gap settings
  215. fuel pump replacement ?
  216. Blown Head Gasket repair kit
  217. Change oil
  218. Bouncie ride.
  219. little things
  220. 98 Olds Aurora Parking Brake Solenoid
  221. Hot washer fluid?
  222. brakes...ugghh
  223. electrical trouble
  224. Heated Seats
  225. '97 Aurora - Cylinder 1 misfire (code P0131)
  226. Cold out there !!!
  227. IP on the blink
  228. aurora is dying
  229. '98 - '99 front suspension pieces
  230. Installing onstar?
  231. coolant temperature sensor
  232. 97 Aurora fuel guage
  233. Coolant leak
  234. Starter Problems
  235. p0410
  236. Anyone interested in a 1995 Aurora Service Manual
  237. It Reves
  238. 5 different mounts?!
  239. headlight covers
  240. '97 Need New Struts or What??
  241. 1996 Aurora Oil Pressure/oil pump
  242. Changing Front Strut
  243. Help with steering rack
  244. Eng Tapping Not Valves Or Lifters
  245. rear brake install advice
  246. Bank 1, bank2 ???
  247. Windshield washer not working
  248. How long have your Aurora lasted?
  249. Heat problems...HELP!!!
  250. Broken or loose motor mount
