View Full Version : Aurora
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13
  1. Replaced Altenator x3, car overcharging
  2. No Door Key 1997 Aurora
  3. Lights and tires
  4. Coolant Leak
  5. AC air direction dash lights
  6. 1995 aurora for $3000
  7. Air Bag Warning
  8. adding stock cd changer to car w/out one
  9. 95 Aurora Stuck in second gear
  10. Got Extra Cash
  11. replacing the back 4 plugs....
  12. I Need Parts
  13. power windows not working right
  14. dome lights not working, fuse, and where?
  15. Power Windows intermittent
  16. vibration in at all speeds
  17. My Time-sert kit is on Ebay.
  18. Plug Wires?
  19. gas pedal moves after shut off?
  20. Transmission Jolt / Rebuilt Tranny
  21. Custom gauges!!!!!
  22. This car have Autobahn?
  23. Coolant Level Low?
  24. Steering Position Sensor replacement instructions?
  25. 98 Aurora surgin under acceleration
  26. Turn of SES light
  27. Non-specific subforum???
  28. Rear Camber Kit
  29. Turn signal mirrors???
  30. Auto transmission woes
  31. a little off topic, but hopefully you can help:)
  32. need aurora parts or a parts car
  33. Coolant...I put in the green stuff ??!!.....
  34. Coolant in number 5 cylinder
  35. Looking for seat covers 1996 Aurora
  36. Scanner recommendation
  37. Turn Signal Stutter?
  38. chime stays on and lights wont turn off
  39. I Give Up
  40. how much quicker is the AUTOBAHN PKG
  41. Which one is the 24x Crankshaft Postion Sensor?
  42. Close Call - Plug Backed Out
  43. Coolant Leak
  44. right rear wheel heating up
  45. How fast have you gone?
  46. overdrive issues
  47. Diagnostic Help....CVjoint, wheel hub, or....
  48. Crank Shaft position sensors
  49. Stalling problem
  50. Performance Modifications
  51. Problem Solved(almost)
  52. Tmesis...Anyone...Please Help!
  53. 2001 rear bumper lites
  54. cruise control
  55. dex-cool or traditional antifreeze
  56. Strut Bolts
  57. LED Turn Signal Replacements...
  58. Installing Serpentine Belt
  59. 2 year old steering problem...help!
  60. cuts off while driving!
  61. overcharging
  62. Head gasket diagnosis ???
  63. Stuck shock?
  64. Abs Light On
  65. last post before going to the dealer
  66. coolant sensor
  67. Cold starts
  68. Got A Code 84???
  69. bad pcm
  70. Tranny problems.This might help
  71. IAT sensor
  72. Reading Codes in a 95 Aurora...
  73. fuel injectors
  74. Sweeet_Its Fixed_ No More Tranny Problems
  75. 95 radio won't shut off battery drain?
  76. map sensor
  77. More Tranny Issues after Sol Replacement
  78. Hard Shifting w/ Service Engine Soon Light
  79. 1998 Aurora Lights HELP!!
  80. can anyone help me..
  81. Changing bulb
  82. Think i am ready to give up
  83. not trans Solenoids. Help
  84. Plug Replacement 95 Aurora
  85. locate trans sol kit
  86. still chugging along!!
  87. trans problem Related to Bad Battery?
  88. '97 Aurora - Cylinder 1 misfire (code P0301) - the Saga continues...
  89. power windows on '98 aurora
  90. some questions
  91. finally tested the fuel pressure
  92. 97 Aurora Cooling Problem
  93. need to find parts for 96
  94. Photos & diagrams?
  95. Stalling at Stops
  96. Stalling at Stops
  97. Long cranking when starting after sitting
  98. another fpr question
  99. where is the obd plug 97 aurora ?backfiring
  100. replace steering rack
  101. Aurora stuck in Park
  102. Driving without overdrive will save gas?
  103. Aftermarket Center Caps Anygood ??
  104. headlight
  105. shift solenoid fuse
  106. car wont start after sitting
  107. Heated Seat Problem
  108. Quick Strut/Air Shock Questions
  109. Factory radio again
  110. Error code list
  111. Tranny problems? Stuff a Toyota under the rear
  112. DIC SAYS "CHECK CHARGING SYSTEM"
  113. what's the differance in the ECM and PCM
  114. Car loses power
  115. Thinking of Purchasing an Aurora?
  116. popping noise on front end
  117. popping noise on front end
  118. What Part # (steering Controls)
  119. Steering Column Loose 1995
  120. '95 problems please help
  121. 99 Aurora temp control won't turn off
  122. MAF curcuit resistance?, 1999 Aurora
  123. 2001 trunk & gas door release not working
  124. Bad Shift Solenoids without PCM code possible????
  125. Proper gap settings
  126. fuel pump replacement ?
  127. Blown Head Gasket repair kit
  128. Change oil
  129. Bouncie ride.
  130. little things
  131. 98 Olds Aurora Parking Brake Solenoid
  132. Hot washer fluid?
  133. brakes...ugghh
  134. electrical trouble
  135. Heated Seats
  136. '97 Aurora - Cylinder 1 misfire (code P0131)
  137. Cold out there !!!
  138. IP on the blink
  139. aurora is dying
  140. '98 - '99 front suspension pieces
  141. Installing onstar?
  142. coolant temperature sensor
  143. 97 Aurora fuel guage
  144. Coolant leak
  145. Starter Problems
  146. p0410
  147. Anyone interested in a 1995 Aurora Service Manual
  148. It Reves
  149. 5 different mounts?!
  150. headlight covers
  151. '97 Need New Struts or What??
  152. 1996 Aurora Oil Pressure/oil pump
  153. Changing Front Strut
  154. Help with steering rack
  155. Eng Tapping Not Valves Or Lifters
  156. rear brake install advice
  157. Bank 1, bank2 ???
  158. Windshield washer not working
  159. How long have your Aurora lasted?
  160. Heat problems...HELP!!!
  161. Broken or loose motor mount
  162. heated seat light
  163. Bleeding my coolant system....to death
  164. pads and rotors
  165. Electronic Level Controler
  166. Sparkplug design - sputtering
  167. no heat
  168. short electric
  169. daytime running light flickering on and off
  170. Trade Boxster S for M5
  171. 98 Aurora Recharging Problem
  172. hi beam head lights
  173. are these sensors or what?
  174. Brighter fog lamps
  175. Reverse flow cooling system?
  176. Remote Start...Good Idea or Bad?
  177. new noise
  178. its all bad
  179. How long do these cars last? What is the repair history like?
  180. $1050 Air Compressor repair? Too Much?
  181. 1995 engine removal
  182. 98 aurora overheating
  183. 98 runs lousy when cold. TPS code
  184. Problems with headlights...please advise
  185. Exhaust options
  186. Anybody ever used an HID kit?
  187. Alldatadiy.com for 02 3.5
  188. J_Swigz=FAG
  189. See my stupidity folks
  190. Paint codes
  191. Aurora 2001 v6 Intermittent starting - frustrated!
  192. how to remove an ignition switch
  193. 98 Aurora Security Alarm
  194. 95 stereo
  195. I'm an idiot
  196. Aluminum wheels...TSB ?
  197. "Theft Attempted"...bulls***
  198. Service Engine Light
  199. Pack of questions.
  200. STEVE BARNES dont BUY FROM
  201. hard starting when cold outside
  202. gel cell or wet cell
  203. Alternator pulley causes hose woes
  204. 95 Aurora falls flat after 4000 RPM
  205. CK ENG, ABS & TRAC CONTROL LIGHTS ARE ON
  206. Non-Specific subforum???
  207. Electricals acting odd
  208. Electical Problem
  209. When do you have to replace the transmission fluid?
  210. Help with transmission fluid leak!
  211. Air filter box re-installation troubles
  212. How Do You Reset "Oil Change" on 95 Aurora control panel?
  213. more strange happenings
  214. It Pop
  215. 1996 Aurora radiator flush
  216. 1995 aurora
  217. Is this an Aurora???
  218. Remote Starter
  219. Solar powered battery charger
  220. Glazed Serpentine Belt
  221. cracked oil pan
  222. Cruise Control
  223. Electrical Problem
  224. 4.6 Aurora ?
  225. follow up question i'm screwed
  226. 2001 3.5 or 4.0!???
  227. Anyone have the 95 OEM battery part number?
  228. Tranny overfill
  229. coolant temp sensor / water crossover
  230. how do i change the thermostat in a 95
  231. Slipping drived belt?
  232. PO 410 Secondary Air Injection Sys.Malfunction
  233. catalytic converter
  234. strange happenings with my aurora
  235. Anyone with a soft copy of the Aurora Service manual?
  236. My factory chrome rims and Michelins now on Ebay
  237. oil pan removal
  238. Wiper Fuse
  239. Got a brand-new crate engine installed
  240. 1996 door locks!?
  241. New pads rubbing
  242. i sold my Aurora
  243. Tranny at the end?
  244. 95 transmission issues
  245. Difference between Bose and non-Bose?
  246. Bad Battery?
  247. Air Check Valve?
  248. fuel rail recall
  249. Evap Solenoid Error
  250. Aurora Club of North America
