View Full Version : Aurora
Pages :
1 2 [ 3]
4 5 6 7 8 9 10 11 12 13
- Aurora Tail lights, Dashboard, Fog lamps, Turn signal, Headlight and Cruise Fixed!
- Battery discharging
- turbine speed sensor
- Sounds in my Aurora
- oil leak
- Fuel Question
- instrument panel and DIC
- 95 power window intermittent
- 95 aurora
- exhaust tips
- 1995 Aurora motor/transmission issue
- 1995 unknown problem
- Dying at Stop Signs
- is it me or there's something wrong with the car
- Plugs & Wires - Aurora
- 97 Aurora, Traction/ABS/ Check Engine Lights On
- Engine service soon
- 95 Aurora-Need Help From Mechanic
- Lighting Very Screwed UP!!
- Solved - Burning smell through vents
- Hard Shifting at startup
- 13 nuts to remove front radiator cover?
- A/C unit stays on.
- Differences in ECM .. PROM only?
- New Trans or New ECU
- low low coolant
- 97 aurora no start
- 99 aurora heated sets
- front seats removal
- no heat on passengers side
- clicking from power window
- 95 Aurora rough idle, surging
- Window Cable??
- Aurora traction control
- tapping noise in engine
- steering position sensor
- 02 has no 4th gear
- Intermediate Steering Shaft
- 95 aurora air pump
- oil cooler lines
- 95 Aurora- Which Fuse?
- jet performance module
- whining moaning sound front left
- gas gauge problem & oil leak
- rear shock
- 1997 Aurora--Running very Hot--tried several things __HELP
- shaking while driving and braking
- Need new radiator...Suggestions?
- Hard Starting, not sure its the FPR
- $28 intake
- seat control problems
- 95 Aurora-Help From Great Auto-Electric Specialist Wanted
- Passenger window switches don't work?
- 95 Aurora idles rough and hard starting.
- Can I Unplug The A/c Compressor
- Grinding noise coming form A/C?
- Many "How To" write-ups
- 97 aurora tune up
- rack
- '99: Some Problems - Radio, and A/C
- Problems Charging the A/C
- Battery Life, Just had to share
- 1996 Aurora Trans Issue
- what is this little box???
- '97 washer fluid tube connector
- AC delay problem
- Coolant Leak Problem
- need headlight parts 95-9
- Just got my baby - couple problems
- 95 Aurora Water pump HELP, PLEASE
- Water Pump Leaking - Need Help?
- Code 119 Injector Open or Shorted
- Bank 2 Sensor 1 Oxygen Sensor location and removal
- Looking to buy 99 Aurora
- Runs Bad when Hot
- New Member 95 Aurora many questions
- 1998 Aurora AC compressor noise.
- Blower Growl
- Transmission
- Preparing to Replace a 98 Aurora Water Pump...
- recent repairs did i get took???
- fuel filter
- P0101 MAF Sensor
- aurora ns v8 supercharger
- Transmission exchange
- where to find used aurora parts??
- drops back to 2nd
- 01 aurora pcv valve
- Sticky Gas Pedal
- Aurora Engine Dies/Sporatic Electrical Issues
- Code P0410?
- Confused
- Headliner rattle
- Camshaft sensor, Need Help
- The Air Conditioning System
- parking lights won't turn off
- PK2 Passlock 2 system failure and bypass proceedure
- whats your oil pressure?
- Might be getting a 99 Aurora today
- front end problem HELP
- Front end noises
- Loud Rubbing Type Noise When Steering
- Crank shaft positiong sensors
- Need Info on 2002 Aurora
- 1999 Aurora hard starting
- 1998 Aurora
- Front Wheel Bearing Assembly - lubricate spline?
- 2001 plug gap Aurora
- A/C Won't Work
- 1997 Aurora Transmission Slipping?
- Oldsmobile Aurora
- 1998 Battery Location
- MAP sensor Specs
- running some wires??
- turn signals
- Water Leak at Firewall
- Where is the ECM/PCM located?
- 1999 aurora needs new air compressor
- radio reinstalled now car wont starting
- Dash lights out
- ac problems in 95 aurora
- certi trans problems in 95 aurora
- Caddy 4t80E swap
- 1997 aurora starts then dies.
- Complete Electrical Failure
- Air Conditioning clutch not engaging?
- Traction Cont., Abs Light, Bad Rotor
- AC & Temp display
- Need Info on replacing alternator for 95 Olds Aurora
- how do i find out right transmission
- Service engine light and O2 sensor
- Time to charge A/C??
- Throttle Position Sensor / tranny jolt
- Bearing 'Thump'?
- 95 shifting problems, PCM or Selenoids?
- 1998 aurora riviera service manuals ORIGINAL
- Outside Driver Mirrow
- 1996 Aurora how to program key fob remote
- Removing DIC and Climate Control
- FPR replacement with Steel Rail
- A/C Question... need to replace condenser?
- Stop dinging you stupid car!!!!
- 95'- need code read. Paperclip an option?
- 95 Aurora-Service-Engine-Soon light OFF
- Front End Noise
- 95 aurora poor acceleration / milage
- body parts needed
- windows
- 96Aurora 4t80E trans
- aurora fluctuating gas gauge
- A/C Compressor/Condenser Repair Question
- A/C Recharge/Refill problem
- 95 Aurora- Service Engine Soon Light
- Important: New and Old Members Please Read
- 345 hp aurora
- 1st Aurora, good deal but a problem
- Repeated Stalling at Stops!!!
- '95 Aurora-electrical/starting problem
- Steering wheel locked up, Service Engine Soon light, Flickering head lights
- radiator question
- a website that has a used parts index
- Problems related?
- Aurora Rear Camber Fix
- secondary air injection valve!!!!!
- Check Engine Light
- 95 Aurora help pleeeeeeese!
- Multiple Problems Seem related
- 95 aurora for sale in So. Ca. 4 parts or fix
- Aurora Timing Chain
- plugs/wires/fuel filter
- clear side markers
- another no start problem
- Hot '98 Engine Solved
- Brake Fluid Light
- Torque Converter Clutch Solenoid
- It keeps Reving
- Where to Mount XM reciever
- 96 Brake Booster and Wheel Bearings
- dreadful maf sensor!!!!!!!
- Replacing Shift Solenoids and have a question
- warning low oil pressure 95 aurora
- trans expert needed
- Rough Idle and Surging
- Dead Car
- Fuel rail recall
- '96 Rt Frt Side Turn Signal Bulb - How to Replace?
- oldsmobile aurora abs light and service engine light
- Traction Control and ABS light come on when car is started
- please help me :(
- 96 Aurora AC blows hot and cold
- TSB anyone
- Gas gauge drops and car stalls at stops
- AC/heater Fan relay switch module $550 ???
- 1995 Aurora will not start
- 97 aurora cooling fans only work with AC on.
- can ANY ONE TELL ME THIS
- Service-Engine-Soon Light Doesn't Work
- Changing CV joints
- AC turns off and gauges go crazy
- M7 95 Aurora Stalls when idle
- 95 Aurora, strange issues, please help!
- New Aurora, electrical problem
- Oil Cooler Lines
- Headlight multifunction sw. - easy fix
- 95 Aurora overheating PLEASE HELP!!!
- normal compression readings
- tranny interchange
- '97 Aurora shut down
- evap leak
- 1995 aurora power windows not working
- garage door opener program
- At what voltage should an alt. be charging?
- Auto headlights go out
- EGR Valve?--Repeatable Stalling Problem
- EGR Valve
- Radiator
- check gas cap warning 01 3.5
- Gm Service Bulletins
- O'Reilly Ultima Alternators
- Fuel volume
- 95 Aurora - High Mount Brake light Not Working
- Odd idle problem, 3.5 V6
- high coolant temp.!!!
- Oil leak between head and Block????
- Magna Steer
- Squealing engine noise
- removal of side torque (motor)mount
- Low Oil Pressure - New Oil Pump?
- 01 aurora wet floor
- Replacing Driver Air Bag & Wheel Controls
- 2003 cabin filter
- code 94
- Illumination on 2001 3.5 Aurora Bose Stereo-OEM
- 2001 Crank Sensors 4.0
- repair manual
- motor mount replacement
- Lambo doors
- Head Gasket? I Got Oil Under Intake.
- Head lights on, interior lights go out! HELP!
- hard reverse cold
- more active aurora site?
- trouble codes P1350 & P1375
- 2001 Aurora Water in Trunk
- door lock
- 2002 hood rust
- Engine Swap
- lights out
- 2001 Aurora Steering Wheel Lock?
