View Full Version : Aurora
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13
  1. '96 Starts cold, but takes several attempts when hot
  2. Fuel Pump Life? ('96)
  3. head gasket
  4. 1997 aurora wiring diagram?!
  5. 2001 Aurora keeps cutting off!
  6. 1996 aurora repair manual needed
  7. Radiator with or with out engine oil cooler
  8. Rail Replacement..What Is It
  9. Low Pressur Light Off and On
  10. Blown Head Gasket, Raditor Leak, Low Oil Pressure HELP PLEASE
  11. Lifters
  12. 95 aurora 4.0 oil and coolant.... hm..
  13. 97 Aurora won't start when its cold outside
  14. 97 aurora key in ignition...wont turn
  15. 96 Aurora
  16. Plastic Radiator Fill on 2001 Aurora 4.0 bursts
  17. 1995 Aurora- PLEASE HELP!! ***UPDATE!!!!
  18. 1995 Aurora- PLEASE HELP!!
  19. Power tuners/reprogramers
  20. will be swaping with 4.6L
  21. radio wont shut off when car shuts off and door opens
  22. Air Bag Problem
  23. wiring
  24. 98 Aurora Heater Blower Dont Work
  25. Fuel Pressure
  26. Front passenger door won't open '99 Aurora
  27. 2002 Aurora 3.5v6
  28. 150k miles - time for a tune up?
  29. 2001 oldsmobile Auaora
  30. Replacing half shaft
  31. Where is my MAF?
  32. Input turbine speed sensor
  33. Aurora sites
  34. Trans 4t80-e Rebuild
  35. 99 aurora hard shifting
  36. intermittent power loss 97 rora
  37. 95 rora wont start
  38. Souping up the old 4.0 few questions..
  39. New twist to old heating problem
  40. 01 aurora theft system fault
  41. Aurora 2001 back doors won't lock!
  42. Air shock manual adjustment?
  43. power steering won't turn left
  44. Fuel gauge malfunction
  45. Cure for Aurora's dying periodically at stop signs, PROBLEM SOLVED!!
  46. Second set of rims - bolt pattern/offset?
  47. 4.0 oil leaks
  48. Shifting Problems
  49. time sert
  50. 97 Aurora will not start..possible fuel problem
  51. low coolant message on
  52. mirror installation issue
  53. EVAP problem
  54. heated seat
  55. New Radio, engine code reader issues
  56. 98 Aurora Stuck in Park When Cold
  57. E break locked up HELP?
  58. 99 Aurora AC/Heater not blowing
  59. Sunroof Issue
  60. do 97 auorars ahve fuel shut off switches if so where?
  61. Pain the Side Repair Job
  62. Codes, p0171 and p0174
  63. 96 Aurora Brakes Help!
  64. 01 Oil Leak... Somewhere
  65. Car kicks between gear changes
  66. Air injection pump
  67. '99 - Running lights wont turn off
  68. Need help with heated seat switch
  69. 97 Aurora Lumbar problem
  70. 97 olds aurora wiring diagram
  71. 1996 aurora motor conversion
  72. Engine noise problem
  73. Engine noise problem
  74. Maintanence Tip
  75. Crankshaft/Camshaft Sensors on 98 Aurora
  76. 96 aurora possible oil leak
  77. P0154, P0300, P0550, P1133, P1153
  78. Brake light causing tranny problems???
  79. EGR Valve
  80. 1995 Aurora shifting
  81. 97 Aurora backfiring/surging/loss of power
  82. RIP (Christine) My Aurora
  83. 01 A/C problem HELP!!!
  84. Anyone replace long P/S Pressure Hose?
  85. 1996 Olds Aurora w 4.0L Engine
  86. 98 security light on and car won't start
  87. Norstar engine Swap?
  88. Diagnostics tool
  89. Please Help Me!!!
  90. Crankshaft Position Sensors
  91. Air Level Control
  92. Power Steering Fluid Leak?
  93. Check Engine Light
  94. 03 Aurora - oil pressure specs & catalytic converter question
  95. 98 Aurora dying at stops
  96. 2001 Aurora Steering Problem
  97. 02 Aurora blowing cruise control fuse
  98. shifter button
  99. sevice engine light
  100. transmission and horn
  101. olds overheating only when pulling
  102. Who has the most miles Part 2
  103. Service Vehicle Soon / DIC voltage 17+
  104. still stuck in second gear
  105. 1995 fan, lights, and fuel problems
  106. 01 aurora belt routing change
  107. 2001 Aurora whirring noise?
  108. 96 Aurora fog light troubleshooting
  109. 95 Olds Aurora Fails California Smog Test
  110. 01-02 Aurora 3.5 vs. 95-99 Aurora
  111. Water Pump Pulley
  112. Olds Aurora
  113. 1995 Fuel Pump Problem??
  114. 03 Aurora - air bag problem - EXP 1
  115. Water pump help plz
  116. need a surge tank for 97 aurora
  117. 03 Aurora 4.0 - whistling noise when revving
  118. mother of all problems
  119. Fuel pump won't shut off
  120. engine swap
  121. where 2 order gm seal tabs
  122. radiator
  123. Aurora helpul tips link
  124. Aurora helpful stereo removal link
  125. Engine dies everytime I stop. Help please !!!!
  126. 1995 4.0 fuel problem
  127. lose of fuel pressure
  128. Brake Problems
  129. 2001 Oldsmobile Aurora 4.0
  130. Check Charge System
  131. Thermostat location??
  132. Aurora (GM) Door Remotes - Operate Mult Vehicles?
  133. 2 minor problems
  134. 2001 Aurora input turbine speed sensor
  135. 96 Aurora Hard to start when hot
  136. rack and pinion
  137. Only half of the vents blow cold air
  138. gauges dead... ???
  139. security
  140. CD player error code
  141. Instrument cluster
  142. Transmission Fault Code
  143. 96 Rora, I think I killed it, Need expert advice - Alternator
  144. Serp Belt
  145. Water damage to Aurora (1997)
  146. subframe insulators
  147. 98 popping-backfire having to work accelerator
  148. Aurora 1998 headlights flicker, car is off
  149. FREE Parts Manual!
  150. Please Help!?
  151. fuel problems
  152. ac
  153. Overheating
  154. 2001 v8 aurora problems! check these out!
  155. 1995 Oldsmobile Aurora fuel pump removal
  156. Wheel Bearing CV joint separation
  157. 2001 Aurora trans story
  158. hesitation during acceleration
  159. 98 aurora ac just blows hot air
  160. 96 Aurora-Thought it was a Rod Knock
  161. 96 Ses
  162. 95 aurora smoke, steering column
  163. weird sound...
  164. Check engine light
  165. help! squeel from 96 aurora
  166. ac,compessor location
  167. 96 aurora ssqueeking sound from trans area
  168. 98 Aurora AC Charging
  169. 1996 olds aurora possiblt tran
  170. axle help
  171. Rear Brakes.
  172. Blinking Security light After Clean Key, wait 3 minutes
  173. 95 Aurora Ignition "Buzz"
  174. Door panel
  175. 99' wiper blade problems
  176. Rear air shocks?
  177. 96 Cooling Fan
  178. Parting out olds Aurora.....
  179. transmission
  180. My car is messed up
  181. coolant loss all at once
  182. help hard start
  183. 96 Aurora Driver's Door Lock
  184. 96 Aurora Seat Controls
  185. excessive engine overheating
  186. power windows
  187. drivetrain problem
  188. Same problems
  189. engine temp. problems to
  190. 97 aurora no spark
  191. 95 aurora won't start
  192. Engine Temp
  193. 2001 Aurora trans problem?
  194. ABS traction control
  195. Changed FPR now having white smoke out of exhaust???
  196. bad vibration when accelerating
  197. master cylinder
  198. Right turn signal not blinking - just solid
  199. Aurora dash swap help (mystery module)
  200. instrument cluster????? PLEASE HELP!
  201. '97 Aurora refused to start after 30mins of driving
  202. need cold air again
  203. '01 Aurora A/C won't turn on!
  204. Engine Stops
  205. Blown Head Gasket
  206. unknown problem
  207. Timing chains
  208. 96 Aurora AC Compressor Removal
  209. Radiator Fan Broken?
  210. manuels
  211. front brake pads
  212. What color coolent should I be using for my 95 Aurora
  213. Are Aurora's OBII Compliant
  214. 1995 Radiator Fan operation
  215. Steering wheel button bulb replacements...
  216. aurora maf sensor
  217. Radio turns on automatically at start up
  218. back seat 98 aurora
  219. 2001 Aurora wipers, cruise, ABS
  220. 95 Aurora engine suddenly rough on startup, no power now
  221. Passenger Power Windows do not work on 97 Aurora
  222. traction control problem
  223. oil leak
  224. 95 Aurora - Belt Routing
  225. shift solenoids...
  226. moon roof failing to open
  227. 95 aurora dashlights
  228. Weird Residue on Trans fluid pan, Slipping at 2.5k
  229. tail lights on a '97 Aurora
  230. To buy or not to buy
  231. 2001 Aurora axle shafts
  232. Looking for Shortstar Info & Pics
  233. Need Help!!! Somebody
  234. 2001 Aurora
  235. 95 Aurora Tranny acting really wierd or is it the ECM?
  236. wheel bearing hub replacement
  237. radiator replacement???
  238. 2001 Oldsmobile Aurora rear door panel removal
  239. black layer in intake manifold and TB
  240. heating problem
  241. 2001 Aurora 4.0 with P741 code, 80K miles
  242. AC - TEMP controller dead
  243. 2001 Aurora
  244. ems problems
  245. Intermittent Air Conditioning
  246. 2001 water leak on drivers side floor
  247. 2001 Aurora
  248. 95 Aurora - Dead Stall in Reverse
  249. Need Help..
  250. Passenger side turn signals don't flash
