View Full Version : Aurora
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13
  1. 1996 Olds Aurora w 4.0L Engine
  2. 98 security light on and car won't start
  3. Norstar engine Swap?
  4. Diagnostics tool
  5. Please Help Me!!!
  6. Crankshaft Position Sensors
  7. Air Level Control
  8. Power Steering Fluid Leak?
  9. Check Engine Light
  10. 03 Aurora - oil pressure specs & catalytic converter question
  11. 98 Aurora dying at stops
  12. 2001 Aurora Steering Problem
  13. 02 Aurora blowing cruise control fuse
  14. shifter button
  15. sevice engine light
  16. transmission and horn
  17. olds overheating only when pulling
  18. Who has the most miles Part 2
  19. Service Vehicle Soon / DIC voltage 17+
  20. still stuck in second gear
  21. 1995 fan, lights, and fuel problems
  22. 01 aurora belt routing change
  23. 2001 Aurora whirring noise?
  24. 96 Aurora fog light troubleshooting
  25. 95 Olds Aurora Fails California Smog Test
  26. 01-02 Aurora 3.5 vs. 95-99 Aurora
  27. Water Pump Pulley
  28. Olds Aurora
  29. 1995 Fuel Pump Problem??
  30. 03 Aurora - air bag problem - EXP 1
  31. Water pump help plz
  32. need a surge tank for 97 aurora
  33. 03 Aurora 4.0 - whistling noise when revving
  34. mother of all problems
  35. Fuel pump won't shut off
  36. engine swap
  37. where 2 order gm seal tabs
  38. radiator
  39. Aurora helpul tips link
  40. Aurora helpful stereo removal link
  41. Engine dies everytime I stop. Help please !!!!
  42. 1995 4.0 fuel problem
  43. lose of fuel pressure
  44. Brake Problems
  45. 2001 Oldsmobile Aurora 4.0
  46. Check Charge System
  47. Thermostat location??
  48. Aurora (GM) Door Remotes - Operate Mult Vehicles?
  49. 2 minor problems
  50. 2001 Aurora input turbine speed sensor
  51. 96 Aurora Hard to start when hot
  52. rack and pinion
  53. Only half of the vents blow cold air
  54. gauges dead... ???
  55. security
  56. CD player error code
  57. Instrument cluster
  58. Transmission Fault Code
  59. 96 Rora, I think I killed it, Need expert advice - Alternator
  60. Serp Belt
  61. Water damage to Aurora (1997)
  62. subframe insulators
  63. 98 popping-backfire having to work accelerator
  64. Aurora 1998 headlights flicker, car is off
  65. FREE Parts Manual!
  66. Please Help!?
  67. fuel problems
  68. ac
  69. Overheating
  70. 2001 v8 aurora problems! check these out!
  71. 1995 Oldsmobile Aurora fuel pump removal
  72. Wheel Bearing CV joint separation
  73. 2001 Aurora trans story
  74. hesitation during acceleration
  75. 98 aurora ac just blows hot air
  76. 96 Aurora-Thought it was a Rod Knock
  77. 96 Ses
  78. 95 aurora smoke, steering column
  79. weird sound...
  80. Check engine light
  81. help! squeel from 96 aurora
  82. ac,compessor location
  83. 96 aurora ssqueeking sound from trans area
  84. 98 Aurora AC Charging
  85. 1996 olds aurora possiblt tran
  86. axle help
  87. Rear Brakes.
  88. Blinking Security light After Clean Key, wait 3 minutes
  89. 95 Aurora Ignition "Buzz"
  90. Door panel
  91. 99' wiper blade problems
  92. Rear air shocks?
  93. 96 Cooling Fan
  94. Parting out olds Aurora.....
  95. transmission
  96. My car is messed up
  97. coolant loss all at once
  98. help hard start
  99. 96 Aurora Driver's Door Lock
  100. 96 Aurora Seat Controls
  101. excessive engine overheating
  102. power windows
  103. drivetrain problem
  104. Same problems
  105. engine temp. problems to
  106. 97 aurora no spark
  107. 95 aurora won't start
  108. Engine Temp
  109. 2001 Aurora trans problem?
  110. ABS traction control
  111. Changed FPR now having white smoke out of exhaust???
  112. bad vibration when accelerating
  113. master cylinder
  114. Right turn signal not blinking - just solid
  115. Aurora dash swap help (mystery module)
  116. instrument cluster????? PLEASE HELP!
  117. '97 Aurora refused to start after 30mins of driving
  118. need cold air again
  119. '01 Aurora A/C won't turn on!
  120. Engine Stops
  121. Blown Head Gasket
  122. unknown problem
  123. Timing chains
  124. 96 Aurora AC Compressor Removal
  125. Radiator Fan Broken?
  126. manuels
  127. front brake pads
  128. What color coolent should I be using for my 95 Aurora
  129. Are Aurora's OBII Compliant
  130. 1995 Radiator Fan operation
  131. Steering wheel button bulb replacements...
  132. aurora maf sensor
  133. Radio turns on automatically at start up
  134. back seat 98 aurora
  135. 2001 Aurora wipers, cruise, ABS
  136. 95 Aurora engine suddenly rough on startup, no power now
  137. Passenger Power Windows do not work on 97 Aurora
  138. traction control problem
  139. oil leak
  140. 95 Aurora - Belt Routing
  141. shift solenoids...
  142. moon roof failing to open
  143. 95 aurora dashlights
  144. Weird Residue on Trans fluid pan, Slipping at 2.5k
  145. tail lights on a '97 Aurora
  146. To buy or not to buy
  147. 2001 Aurora axle shafts
  148. Looking for Shortstar Info & Pics
  149. Need Help!!! Somebody
  150. 2001 Aurora
  151. 95 Aurora Tranny acting really wierd or is it the ECM?
  152. wheel bearing hub replacement
  153. radiator replacement???
  154. 2001 Oldsmobile Aurora rear door panel removal
  155. black layer in intake manifold and TB
  156. heating problem
  157. 2001 Aurora 4.0 with P741 code, 80K miles
  158. AC - TEMP controller dead
  159. 2001 Aurora
  160. ems problems
  161. Intermittent Air Conditioning
  162. 2001 water leak on drivers side floor
  163. 2001 Aurora
  164. 95 Aurora - Dead Stall in Reverse
  165. Need Help..
  166. Passenger side turn signals don't flash
  167. harder start when hot
  168. Thermostat gasket
  169. Is a 1995 Aurora A good Buy??
  170. Need Help..
  171. Charging System Problem (02' Aurora)
  172. Help!!!!!!
  173. 97 aurora fogging windows problem
  174. God, I scr**ed that up. Hole in my PS pulley
  175. 98 aurora missfire
  176. Idler pulley gone bad
  177. Power Steering Pump Removal and Installation
  178. 2001 oldsmobile aurora crankshaft sensor
  179. Still Having Heating Issues
  180. Need Help finding Parts
  181. i whant a custome body kit
  182. Reverse lights inoperable
  183. Help! no heat in my new car
  184. Aurora lettering emblem on taillight
  185. new ecm....new problems
  186. PO741 Torque Converter Clutch Stuck Off HELP
  187. computer problem
  188. Engine spins, but won't start
  189. '95 Aurora "Blue" smoke out of exhaust..help
  190. no heat
  191. Need help
  192. '96 heavy transmission leak
  193. 2001 Power Steering Problem
  194. '96 Aurora - washer fluid loss
  195. '95 Aurora stays in only in 2nd gear
  196. battery voltage
  197. Repair rear shock air lines
  198. 2001 3.5 Aurora - Rear Valve Cover Leak
  199. 1998 aurora drivers seat
  200. Questions from a new aurora owner
  201. ecm or tranny???
  202. HELP!!! 95 aurora guages not working
  203. '99-headlight flicker & fuel gage erratic
  204. Autobahn Tranny Problem?
  205. 1998 Aurora - Fuel Rail Leak
  206. 95 Aurora
  207. No Heat
  208. Problems help please
  209. Headlights?? '97 Aurora
  210. Progamming a 2001 Aurora Key FOB
  211. Water Leak
  212. Oil Pressure problem
  213. 95 Aurora won't start or crank
  214. Tapping noise after turning off the car
  215. grunt on start up
  216. Replacing Side Bulbs
  217. testing fuel pressure regulator and crankshaft position sensor
  218. Still not working
  219. 2001 v6 surging, stalling, and tach issues
  220. Warranty for Emissions
  221. aurora mpg
  222. Coil Pack Screws-Change Plugs
  223. My car - im lost =(
  224. 2002 Aurora key fob programming
  225. Are these lights good or no good
  226. Fuel Door, Trunk Release Not Working
  227. leather seats
  228. rear shocks air kit
  229. Ball Joint Rubber Boot
  230. Front struts
  231. Parking lights wont turn off?
  232. '95 Aurora-Transmission Leak
  233. head gasket blown wondering the best stuff to keep the car going befor i get a new on
  234. 2001 Aurora Speedo
  235. Rear Air Shock Hissing
  236. heater not blowing
  237. driver seat locked in position please help me
  238. Temp display Heat/AC controls quit working
  239. nead help with pully on cam shaft
  240. 99 aurora rough idle
  241. Aurora Vented Battery - Where to Find?
  242. High Oil Pressure
  243. belt routing diagram
  244. 1995 Fans wont turn off
  245. 97 aurora delayed start when turning key
  246. 98 Aurora Neutral Start
  247. Steering Rack
  248. boiling trans fluid
  249. code readers (scanners)
  250. high RPM's, Trans wont shift out of 1st, help please
