Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Oldsmobile
> Aurora |
View Full Version :
Aurora
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
starter
Dash lights - display lights wacky!
whistling noise
cigarette lighter
Programming a second Keyless Remote
power seat stuck 1997 Seville
windshield washer fluid doesn't work right
power seats memory???
95 Aurora acceleration troubles
Tranmission Replacement
4.6 Northstar into a Aurora
Are calipers and pads interchangable between?
Denied Silverstars at Pep Boys
Engine speed swinging during Idling
Tachometer/Speedometer...and a few other things
99' Aurora question
95 Aurora - compatable parts?
Water Pump Replacement
dumb question
radiator
Water Pump Cam Pulley
steering shudder low speed
New here, need exhaust opinions
Built-in diagnostic service mode?
Waterpump Idler Pulley
Service engine soon light?
Question For Speedyguy
95 Aurora - Oh Boy!
Oil Leak
Keyless
New Wheels and Tires
Wheels and/or Tires For Sale
Still Noisy
Valve Cover removal / Spark plug and wires???
central shaft in the transmission snapped in half
RR Defroster
Climate Contol Blower has a mind of it's own
Keyless question
That Chirp is DRIVING ME INSANE
95' aurora keyless entry
smokes from under hood
a few questions
Can you tell Indy8 has the day off?
electrical problem
Battery Problems
Rattling sound coming from A/C?
passenger climate control knob
new member here - quick question on ebay intake
Anyone who needs a radiator, read this!
Diagnotic codes through climate control center
Power steering steers hard to the left
INDY RULES - Another Question
Message For Conundrum
rear bumper skin 2001 aurora
Why should I buy American Again?
Eibach Springs?
power antenna
GM TSB for using Time-Sert aluminum bolts?
o2 front sensor
battery trbl or worse ?
Engine control module......
Random "Security" Light
CHECK OIL LEVEL on DIC wont go away
Aurora running hot
missing and bad gas mileage
How difficult is it to replace waterpump
Whistle when cold and low RPM
New Member...'95 Questions...
delay windshield wiper '96 aurora
Are my rear shocks gone?
Fuel Rail (smell of gas)
Starting my Aurora
Strange electircal behavior, is it just the starter?
quiet flashers?
Traction Control Light---Low Tranny fluid???
clicking from controler under seat
hard to start when very cold out
Noise at back of car
Clean Key, Wait 3 Minutes.... getting me mad
radiator leaks bad need info
ABS System Questions 95' Aurora
Theft System Fault
wiper arm trim piece
Blower control location?
95 Aurora stalls out at 70mph
Headlights
Water pump socket
Lights are flickering????
Aurora Service Manual
Dash lights out
1997 aurora seat heater
cruise control
Heater Problem
Starter Installation
Another New Member
Need advice on computer / transmission.
Some questions
how do I adjust high idle?
Bose Stereo System
Front passenger seat door controls don't all work.
Will a '99 radiator fit into a '97?
A few Problems - Please HELP!!!!
Long List of problems. Should I fix or sell???
Smoke from underneath car!!!!
How do I test for codes? (95 Aurora)
power mod ebay
Belt Removal ?? Replacing Alternator
new oil leak...need parts
Heat Blocker Air Filter
vibration
Sticky Shifter
02 Aurora reliability
coolant flush 1998 aurora
ooh! sexy photos of cylinder heads!
interior light problems
Steering Wheel Controls
hp ideas
plug gap
Running rough at idle and while driving???
Traction, Traction who's got the Traction?
Clicking from under the dash
My passenger seat doesn't work?!
Have a Great New Year everyone!
okay dumb question
Transmission only works in second
Twilight Sentinel 97 Aurora
My Exhaust Plans
shudder at low speed turns
Aurora power windows/locks
Fuel gauge wackey
rims and tires
Extended Warranty
speaker problem
copying a transponder key
Followup on alignment and popping noise
what is this part?
dirt accumulation under the hood
95 Aurora left parking lights don't work
Total power loss and stall
Headlight Replacement???
Problem with Left Side Mirror
Fuel Pump amd MAFS
Transmission problem?
transmission relay?
Followup on Alignment and snapping noise when turning
1997 Stock Chrome Alloys
Need help rough idle
Hi Everybody!
Noisey Serpintine belt
95 parking brake cable broken.
'96 Aurora radiator
subs and amp
Tps
Please Help INDY!!!
'96 Headlight weirdness
Crazy Tint
rpm at speed check
Transmission nightmare
front end vibration
2001 headlight problem
cupholder stuck in
1st generation, 2nd generation
Electrical Problems
yay!
Strange Idle
TSB On Headgasket
Performance numbers
All Gms, Not Just Pontiac Have This Problem
go figure
when will it ever end?
Power seat drivers side not moving down...
Attachments!
What Happend To Domesticperformance.com?
Silverstar HeadLamp Capsules on sale.
Dealer Issue...not my aurora..need advice
98 front suspension??
Tires for the Aurora
wheel offset
electrical problem i think
code 1660?
Changing my battery just made me feel like a dumb@##
Sentinel Not Working
Sythetic tranny fluid
Oil pressure
Steering Wheel Bit Loose
New member!
Transmission switch
Dic
service manual diagnostic flow
Can't Stop the Squeak!
Noise on turns
electrical and shifting problems
Traction Conrol light On
White smoke
Intermittent trouble with driver's power window
Aurora door lock troubleshoot
Front end allignment and other stuff
95 Aurora Electrical Probs
Soap Dish
I am going to shoot my car with a bazooka
Factory Auto Manual
Hard to start
Radiator R&R
Wheel weight?
this place has really picked up
Clifford remote starter in 95 aurora??? anyone?
Used parts?
Reman. Alternator
Autobahn package
Hard shift (intermittant) '01 V6 Aurora
Is an alternator a DIY job?
DEAD Transmission!
exhaust
Happy Thanksgiving To All Members!
New owner of 97 Aurora
Squeak when Turning Right!!!
radio antenna
how to time
Transmission fluid leak
Cooling System Pressure
roof rack
coolant heater
RPO Codes
performance chip?
What do the stars under our usernames mean?
guess what
Cleaning Stuff
door lock actuator
What are those things?
refills for OEM wiper blades
Fog Lights
Aurora Backfire at 1500 RPM light load
Lights flickering/pulsating....
custom parts
cooling fans
starting problems, just turning over
Climate Conrol - Airflow Direction
Aurora Radiator Cap
special tools for the northstar 4.0L
4.0 Engine Oil Capacity ?
Auto level suspension
Aurora engine operating temp
Fuel for the Aurora
1995 Aurora Inst. light dimmer
Keyless Entry
Valuable Northstar/Aurora engine info
daytime running lights
Does anyone have this feature/option?
I went to the dealership
Web
AF
