View Full Version : Aurora
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13
  1. backseat replacement
  2. Getting your 95 scanned for free...
  3. Recall notice?
  4. replaced head gaskets
  5. 97 Transmission...jolts when shifting
  6. alternator problem?
  7. rattle,churn, kaplunk???
  8. STALLING... and ideas?
  9. 1998 Aurora - Hesitation
  10. not taking much coolant after flush.
  11. intermittent seized pulley on 97 Aurora...loud!
  12. Battery....stone dead
  13. Wiper ghosts and reverse lamp plexiglass
  14. L47 Headers - Available?
  15. Rear Shocks Compressor - R&R
  16. Oil leaks...what' s the best solution
  17. 97 Aurora A/C failure...electrical?
  18. (How To) Replace Front Struts ('96) ???
  19. VATS ignit. key resistance??
  20. Ran out of gas, now the problems begin...Help!
  21. serpentine belt problem?
  22. When I accelerate lightly it runs rough...
  23. Chrome rims and brake temperature
  24. Airbox mod -- service engine soon light.
  25. recharging air conditioning
  26. Brake lights
  27. check engine light
  28. remote start not working
  29. 1998 Aurora cooling problem
  30. have power won't even turnover
  31. MNicolas
  32. Wonky Traction Control
  33. Electrical Mirrors
  34. police problems
  35. Dex-cool or not?
  36. Fuel Injectors
  37. No Gas on the 19th
  38. recall ...earlier this year
  39. Tranny filter and fluid change
  40. What to do with Dealer
  41. Red Aurora
  42. Bad MPG and Surging
  43. Shifter
  44. How do I diagnose power window problem??
  45. acna
  46. Automatic Level Control
  47. Autobahn package???
  48. 1996 aurora Keyless entry prog HELP
  49. Aurora Replacement
  50. egr
  51. Introducing the new ACNA Aurora Club webpage
  52. Cylinder numbers on 95
  53. keep factory head unit
  54. What is the best REPAIR MANUAL to get?
  55. more oil leak questions
  56. 2001 Aurora Has Loud Whine at 60+ MPH
  57. How do I disengage the check engine light?
  58. what is this part?
  59. backfire, then die..still
  60. idea on how to save $ on gas.. any ideas on how to make it work???
  61. Aight, just got back from the dealer
  62. Open Injector Circuit P0203
  63. Got Aurora parts- all great shape
  64. Trying to find trans stick
  65. Looking for Aurora
  66. Interior Anything??
  67. how do i get to back 4 spark plugs???
  68. let's pimp MY ride...
  69. Problems with Shifting
  70. Clean Key wait 3 minutes....
  71. Fuel Gauge
  72. gas prices
  73. Basic/ Preventative maintenance
  74. spark plugs......which ones are better
  75. Just Purchased 95 Aurora/HELP with repairs
  76. exhaust tips
  77. Ita
  78. Aurora Club - I'm actually pulling it off :oř
  79. tires
  80. Add on Cd Changer
  81. '95 SES / "Limp Home" problem
  82. How do you remove air filter box ('96)?
  83. Parking Brake Set
  84. Change Transmission Fluid
  85. Egr Gasket ?
  86. Alarm noise level
  87. 1964 Aurora ?
  88. Back Window
  89. Lumbar and seat memory
  90. service manual cd
  91. replacing wheel bearings
  92. reprogrammed my remote
  93. Is there a common fuse??
  94. keyless remote
  95. Finally bought fogs! Now more questions...
  96. New oil leak
  97. A/C Questions
  98. Ignition help needed
  99. Vibrating Drivers Side Mirror
  100. may be selling
  101. and the saga continues
  102. Engine
  103. difference between radiators???
  104. how do the rear brakes adjust?
  105. Lighted switch of power mirrors.....
  106. Rear brake pad replacement
  107. low oil pressure?????
  108. paint color code????
  109. how to find a keyless entry remote
  110. classic/new style..anyone owned both?
  111. Sticky Windows- no literally sticky!
  112. Aurora Club...UPDATE
  113. Power Door Lock Bumper Kit...
  114. drl
  115. Loss of power after coil pack replace
  116. whats the difference in these tire sizes
  117. shift selenoids
  118. DIC fuel economy accuracy
  119. Hey
  120. advice please:Power windows won't work from any panel..need help!!
  121. Gas scent in car
  122. End of the Line for a Great Brand!
  123. Aurora Club...
  124. Traction Light Question - yes another one!
  125. Driver's Side door unlock repair procedure
  126. Oil pressure sending unit broken? 01 Aurora
  127. Replacing Instrument Bulb 2001 Aurora
  128. fuel pressure regulator
  129. SilverStar 893ST fog bulb warning
  130. 1998 Aurora Shop Manual
  131. Fuel injectors or timing belt
  132. 1997 aurora lots of problems
  133. oil pan gasket ??
  134. Power Steering/whistling/bearing Noise???
  135. Interesting thought
  136. 2 questions....
  137. Bad Engine Possibly
  138. Part # for door lock bumper repair kit.
  139. I`m New..I have a question
  140. Aurora grease fittings
  141. Change Oil Soon??????
  142. garage door opener
  143. buying new radiator - but how to tell which one i need?
  144. Trouble with Cruise Control...can anyone help?
  145. Surging and bad gas mileage
  146. Gas pedal moves and makes clicking noise
  147. 98 Aurora Foglight Bulb Replacement
  148. Gear Shift Indicator Light
  149. Replacement light in dashboard
  150. Radio codes
  151. Rim Suggestions
  152. even the tow truck driver was amazed...
  153. cooling fan wiring
  154. Door panel removal
  155. Fuse keeps blowin
  156. stalling problem
  157. clean key wait 3 minutes
  158. 95 Aurora Electrical Problems
  159. door latch/interior light
  160. '98 Aurora repair manual??
  161. Car Domain Page
  162. Will These Wheels Fit
  163. No heat on drivers side
  164. Drivers side door won't unlock with power locks
  165. Battery/vent doesnt fit
  166. Aurora turn signal problem
  167. Cleaning Exhaust tips/New steering controls
  168. Adding an alarm
  169. Testing Fuel Injectors?
  170. Aurora tips..found in another Olds forum.
  171. OMG: Major car misfiring
  172. new tires
  173. air box mods
  174. Coolant leak
  175. Good Aurora mechanics in SoCal???
  176. wanted: anyone interested in participating in a study of contemporary racism
  177. 2001 - Secondary Air Injection code
  178. 2001 Aurora transmission "kick"
  179. Has anyone ever ran out of gas?
  180. Fuel Tank Removal- cleaning
  181. Got myself a 98' Aurora
  182. Northstar Engines
  183. Oil Recommendations
  184. 95 Engine Mis-Firing Detection
  185. Change Oil Msg won't reset or go away?
  186. Foglight ? (among others)
  187. battery and smoking steering wheel
  188. Headlight Question
  189. fuel pressure regulator
  190. EGR R&R
  191. AUrora Performance Parts
  192. Finally Brough my Aurora Home!!!!
  193. Front Wheel Bearing is loose
  194. Headrest
  195. blue smoke seen coming out exhaust
  196. e30 focus error
  197. heated seat
  198. Shaking????
  199. Aurora battery life
  200. Olds Recalling the Aurora
  201. Aftermarket sunroof???
  202. Bad April Fools Joke?
  203. My mom's car leaks oil!!!!
  204. traction control ????
  205. Split Fire Spark Plugs
  206. noob Aurora questions
  207. 2001 Aurora Wheel Cap Rattle
  208. Non Working Recliner/Lumbar Support
  209. voltage
  210. 1/4 mile
  211. auto tranny on 2002 3.5
  212. 95Aurora scan tool ?
  213. My Car Gets Hot When Is Idling
  214. Centre Console
  215. Good Price For '95 Aurora W/105,000m?
  216. '96 Aurora - Optional Tire Size
  217. Changing Rear Air Shocks
  218. Correct Installation of Brake Pads? (Orientation)?
  219. Fuel rail recall
  220. Gear shifter knob
  221. The good 'ol oil leak
  222. 97 sunroof clicks
  223. Memory Seats retrofit
  224. rims and tires upgrade
  225. ECM vs. autobahn
  226. 1995 aurora brakes
  227. Stalls
  228. God I am starting to hate this car
  229. hard shift into reverse
  230. lack of power
  231. Air Intake Kits
  232. '96 Aurora A/C Diagnostics Mode?
  233. New Member Introduction
  234. Airbags and other questions.
  235. Wood grain on Driver window lock control
  236. 99 Aurora worth it
  237. Do I Really Need The Water Pump Socket?
  238. Steering wheel controls
  239. 12 Disc cartridge
  240. Date
  241. Where is the Oil Pressure Sending Unit 01 Aurora v6
  242. blinker
  243. Where Exactly Is The Water Pump Located
  244. 95 Aurora w/ Issues Missing, Check Oil Message
  245. 95Aurora TrackCont./Antilock lights both on
  246. Accelerator padle sticks!!
  247. new aurora owner
  248. Need Tourque Info.
  249. head lights dim occassionally 2001 Aurora
  250. Aurora fuel rail recall
