View Full Version : Aurora
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13
  1. Change Transmission Fluid
  2. Egr Gasket ?
  3. Alarm noise level
  4. 1964 Aurora ?
  5. Back Window
  6. Lumbar and seat memory
  7. service manual cd
  8. replacing wheel bearings
  9. reprogrammed my remote
  10. Is there a common fuse??
  11. keyless remote
  12. Finally bought fogs! Now more questions...
  13. New oil leak
  14. A/C Questions
  15. Ignition help needed
  16. Vibrating Drivers Side Mirror
  17. may be selling
  18. and the saga continues
  19. Engine
  20. difference between radiators???
  21. how do the rear brakes adjust?
  22. Lighted switch of power mirrors.....
  23. Rear brake pad replacement
  24. low oil pressure?????
  25. paint color code????
  26. how to find a keyless entry remote
  27. classic/new style..anyone owned both?
  28. Sticky Windows- no literally sticky!
  29. Aurora Club...UPDATE
  30. Power Door Lock Bumper Kit...
  31. drl
  32. Loss of power after coil pack replace
  33. whats the difference in these tire sizes
  34. shift selenoids
  35. DIC fuel economy accuracy
  36. Hey
  37. advice please:Power windows won't work from any panel..need help!!
  38. Gas scent in car
  39. End of the Line for a Great Brand!
  40. Aurora Club...
  41. Traction Light Question - yes another one!
  42. Driver's Side door unlock repair procedure
  43. Oil pressure sending unit broken? 01 Aurora
  44. Replacing Instrument Bulb 2001 Aurora
  45. fuel pressure regulator
  46. SilverStar 893ST fog bulb warning
  47. 1998 Aurora Shop Manual
  48. Fuel injectors or timing belt
  49. 1997 aurora lots of problems
  50. oil pan gasket ??
  51. Power Steering/whistling/bearing Noise???
  52. Interesting thought
  53. 2 questions....
  54. Bad Engine Possibly
  55. Part # for door lock bumper repair kit.
  56. I`m New..I have a question
  57. Aurora grease fittings
  58. Change Oil Soon??????
  59. garage door opener
  60. buying new radiator - but how to tell which one i need?
  61. Trouble with Cruise Control...can anyone help?
  62. Surging and bad gas mileage
  63. Gas pedal moves and makes clicking noise
  64. 98 Aurora Foglight Bulb Replacement
  65. Gear Shift Indicator Light
  66. Replacement light in dashboard
  67. Radio codes
  68. Rim Suggestions
  69. even the tow truck driver was amazed...
  70. cooling fan wiring
  71. Door panel removal
  72. Fuse keeps blowin
  73. stalling problem
  74. clean key wait 3 minutes
  75. 95 Aurora Electrical Problems
  76. door latch/interior light
  77. '98 Aurora repair manual??
  78. Car Domain Page
  79. Will These Wheels Fit
  80. No heat on drivers side
  81. Drivers side door won't unlock with power locks
  82. Battery/vent doesnt fit
  83. Aurora turn signal problem
  84. Cleaning Exhaust tips/New steering controls
  85. Adding an alarm
  86. Testing Fuel Injectors?
  87. Aurora tips..found in another Olds forum.
  88. OMG: Major car misfiring
  89. new tires
  90. air box mods
  91. Coolant leak
  92. Good Aurora mechanics in SoCal???
  93. wanted: anyone interested in participating in a study of contemporary racism
  94. 2001 - Secondary Air Injection code
  95. 2001 Aurora transmission "kick"
  96. Has anyone ever ran out of gas?
  97. Fuel Tank Removal- cleaning
  98. Got myself a 98' Aurora
  99. Northstar Engines
  100. Oil Recommendations
  101. 95 Engine Mis-Firing Detection
  102. Change Oil Msg won't reset or go away?
  103. Foglight ? (among others)
  104. battery and smoking steering wheel
  105. Headlight Question
  106. fuel pressure regulator
  107. EGR R&R
  108. AUrora Performance Parts
  109. Finally Brough my Aurora Home!!!!
  110. Front Wheel Bearing is loose
  111. Headrest
  112. blue smoke seen coming out exhaust
  113. e30 focus error
  114. heated seat
  115. Shaking????
  116. Aurora battery life
  117. Olds Recalling the Aurora
  118. Aftermarket sunroof???
  119. Bad April Fools Joke?
  120. My mom's car leaks oil!!!!
  121. traction control ????
  122. Split Fire Spark Plugs
  123. noob Aurora questions
  124. 2001 Aurora Wheel Cap Rattle
  125. Non Working Recliner/Lumbar Support
  126. voltage
  127. 1/4 mile
  128. auto tranny on 2002 3.5
  129. 95Aurora scan tool ?
  130. My Car Gets Hot When Is Idling
  131. Centre Console
  132. Good Price For '95 Aurora W/105,000m?
  133. '96 Aurora - Optional Tire Size
  134. Changing Rear Air Shocks
  135. Correct Installation of Brake Pads? (Orientation)?
  136. Fuel rail recall
  137. Gear shifter knob
  138. The good 'ol oil leak
  139. 97 sunroof clicks
  140. Memory Seats retrofit
  141. rims and tires upgrade
  142. ECM vs. autobahn
  143. 1995 aurora brakes
  144. Stalls
  145. God I am starting to hate this car
  146. hard shift into reverse
  147. lack of power
  148. Air Intake Kits
  149. '96 Aurora A/C Diagnostics Mode?
  150. New Member Introduction
  151. Airbags and other questions.
  152. Wood grain on Driver window lock control
  153. 99 Aurora worth it
  154. Do I Really Need The Water Pump Socket?
  155. Steering wheel controls
  156. 12 Disc cartridge
  157. Date
  158. Where is the Oil Pressure Sending Unit 01 Aurora v6
  159. blinker
  160. Where Exactly Is The Water Pump Located
  161. 95 Aurora w/ Issues Missing, Check Oil Message
  162. 95Aurora TrackCont./Antilock lights both on
  163. Accelerator padle sticks!!
  164. new aurora owner
  165. Need Tourque Info.
  166. head lights dim occassionally 2001 Aurora
  167. Aurora fuel rail recall
  168. Any indicator on the dash that indicates "Park" "Reverse""Drive"
  169. Piston Slap?
  170. '96 Aurora engine miss
  171. replacing lights in steering wheel controls???
  172. Shifter light replacement..
  173. crazy control panel
  174. Front Door Speaker Removal??
  175. daytime running lights are bullshit
  176. crazy climate control
  177. DTC P0171, Need Help.
  178. Oil Change intervals using synthetics
  179. Heater/AC Fan Won't Stop Running
  180. 1996 Aurora Strange Problem
  181. Power Steering Pump/Hoses Procedure(s)
  182. creaking in steering column 2001 Aurora
  183. battery?
  184. 2004/2005 Aurora?
  185. New Member
  186. Loud wind noise (2001 Aurora)
  187. finding knob for radio
  188. OBD II Scan Tools, where to buy....
  189. Where is the flasher relay located ??
  190. Aurora Meets?
  191. Oil Pressure Drop
  192. Carfax
  193. RPM drop-off when coasting (30-40 mph)
  194. Trim on body chipping paint?
  195. OBDII Trouble Code Meaning?
  196. Engine "shaking" at idle.. running poorly
  197. Oil Pressure Question
  198. Changing front pads & cutting rotors
  199. Replaced Fuel Rail, Now Car Won't Start!!! Any Advice
  200. A few questions
  201. 2001 fog lamp replacement
  202. replacing strut bearing???
  203. fog lights constantly burning out!!!
  204. Front Pads & Rotors
  205. Two Questions - hopefully simple
  206. Coil Packs
  207. shift solenoids
  208. I was bad lol
  209. Bought 1995 Aurora
  210. A couple problems with the Aurora!
  211. Stupid Vent on Door
  212. Multiple Problems 95 aurora ANY HELP WOULD BE GREATLY APPRECIATED
  213. went to get 6x9's for trunk and...
  214. Where are the spark plugs in 98 aurora?
  215. 98 Aurora stalling out
  216. Why are the ABS and TRACTION CONTROL lights!!!!
  217. Where is fuel filter?
  218. Cassette Stuck Question
  219. huge fuel leak under the hood
  220. Confused newbie
  221. Interchangable Coil packs?
  222. Shudder when breaking at high speeds / pulsating breaking
  223. Waterpump
  224. best spark plugs
  225. does a 95 rim fit 97 aurora???
  226. Compression Help!
  227. Eibach drop springs
  228. ABS Diagnostic Error Codes (how to flash codes)
  229. I need help!!!
  230. door speakers
  231. wtf is wrong with my car
  232. Aurora audio, whose got something nice?
  233. Hot Engine Message Withpower Loss
  234. Aurora Engine External Dimensions?
  235. Autobahn Package In The Aurora
  236. water pump housing and heater core
  237. 95 Aurora Trans Mount (or Other Problem)
  238. how do you get the idler pulley off?
  239. Idler pully
  240. Ding, ding, ding
  241. rear window won't go down.
  242. '96 Low Oil Light
  243. Heater question
  244. 95 aurora electrical power will not shut off with key off
  245. Rain-x
  246. Electrical diagrams
  247. governer on 1995 Olds Aurora
  248. Keyless entry remotes and drop-in K&N for sale
  249. Steering column
  250. The fastest
