View Full Version : Aurora
Pages :
1 2 3 4 5 6 7 8 9 [ 10]
11 12 13
- 2001 Tsb
- What can it be?1995 Aurora
- OBD code reader
- Desactivating the auto door lock system..
- Starting delay
- 97' Service Manual For Sale
- Where is coolant temp sensor 95?
- power antenna
- Goodbye Aurora Fans!
- ODB Help please.
- check engine light wont go away!
- steering wheel lamps in '96 aurora
- 1996 Aurora with new GM Northstar engine
- Lumbar support haunted
- Air-intake Mod. Question
- 20-22" RIMS ON 95 AURORA
- driver's rear side window doesn't work
- Happy Fourth
- Exhaust?
- Replacing a PCV Valve?
- outside temp going crazy.....
- Rough Idle
- power antenna doesn't go up (sometimes)
- For Sale: 95 Aurora $1000 -Pittsburgh, PA-
- under hood light???
- Tranmission Issues
- Adding CD changer
- Mouse In Steering Wheel...
- parts
- why mix coolant 50/50?
- 96 aurora manual
- Pressure wash
- Knocking under acceleration
- Dash AC Blower Knob
- Front Struts
- car redone
- Automatic Headlights 2001 Aurora
- Passenger Side Cornering Turn Signal Lamp/ How to replace?
- Water in the Foglight
- Fuel Pump Noise?
- Highway Shaking
- Power/reverse?
- Turn Signal Noise
- 1995 Waterpump
- book time - changing control arm bushings
- Inserted CD always sticks when it is hot outside
- '95 Drivers Side View Mirror Needed
- Is my rear caliper broken?
- Performance Computer Chip (PCM)
- need 95 parts, I have them!!!!
- Fuel Pump!!
- Towing Ability ?
- Necessary to clear / reset ABS after repairs?
- seen an aurora with hydrolics
- ACNA Aurora Meet
- Lamp Control Module
- Still Hestitating after all this work!?
- STB and Aurora/STS similarities
- Loose Door Trim
- Rear shocks IF I don't want air...
- bars leak
- Window Tint
- Instrument panel lights
- 95 Aurora - A/C Compressor
- Laboring engine
- Tail lights don't work
- Fuel rail recal and fuel pump preasure regulator
- seat belt won't retract
- Removing Rear Bearing Hub = STUCK!
- How to determinw hich abs/ trac control sensor
- Have to crank engine for a long time to start
- Where to get/best freon to use
- 1995 Aurora Spark plugs & Wireset advice
- pics of a 95 that didnt get recalled in time, trying to fix, anyone have a map?
- runaway idle
- Water Leak Right Front Passenger side
- Many Problems
- 1st Aurora God do I love this car but have some questions!!
- ANyone had the recall done yet? Any difference?
- Air Bag
- ABS Codes #35 & #36
- radiator flush
- front urethane bushing question
- Tranny Fluid Change
- AutoSound High Flow Cat installed
- NOx failure
- 95 fuel system question
- changing shifter nob
- Cabin Air filter
- 1998 Remote Programing
- Winter Driving
- Blower wont start?? ne help!
- engine code P 1350 and P 1375
- any advice for strut replacement?
- 80mm TB
- Water pump removal tools
- home link system for 1995 aurora
- wet rear drivers side floor
- Rack and Pinion
- help! w/console trim
- Cruise Control and Torque Converter connection
- cigerette lighter doesn't work
- What is a good price
- Engine swap
- Diagnostic Trouble Codes
- 1995 Aurora for Sale- 1st $1,000. Takes It
- What do you use to clean the inside of your car?
- A/C compressor r/r price???
- People with cooling problems - Read This
- a/c problems
- sideview mirror control's lights don't work
- A/C Condensor Replacement
- Physical location of RCDLR
- 98 Turn Light Switch
- A/C compressor replacement
- HELP!! popping noises on right turns
- Transmission Oil Life Display On DIC
- Torque Converter Drain Plug?
- Preferred Transmission Fluid Change Method?
- Cleaning Injectors? Beneficial or not?
- Bose Stereo
- Major power loss and spit and sputter at takeoff
- Plug Wires - here is part #
- Annoying shake
- Rear Brake replacement
- Hard Shifting into Park
- oil on spark plugs????
- Computer
- O2 sensors
- owners manual
- Just bought an Aurora
- clicking noise when turning right
- Anyone know of a good extended service contract?
- Are front bearings a maintenance item? Weird sound...
- Erratic RPM on start-up
- Trunk switch
- Recall notice
- Aurora Redesigned fuel rail
- release buttons
- Rear Sway Brace/Tie Rod
- Aurora struts replacement...which brand?
- rebuilt alternator
- battery replacement
- Silverstars
- replace engine or gaskets
- Slow to start
- Indy8 still around?
- A/C compressor removal?
- Stabilus trunk supports
- Aurora coolant leak
- Aurora Forums??
- acna
- accident
- over heating
- blower fan
- MPG and spark plug wires
- 1996 olds aurora O2 problem
- NAPA auto parts
- Noise from road/tires
- Broken headlight switch
- obd II
- Radiator cooling fans
- A/C compressor....burning rubber and bearings.
- Low Oil Pressure?
- Recall Update
- Differences between 95-99 service manuals?
- backseat replacement
- Getting your 95 scanned for free...
- Recall notice?
- replaced head gaskets
- 97 Transmission...jolts when shifting
- alternator problem?
- rattle,churn, kaplunk???
- STALLING... and ideas?
- 1998 Aurora - Hesitation
- not taking much coolant after flush.
- intermittent seized pulley on 97 Aurora...loud!
- Battery....stone dead
- Wiper ghosts and reverse lamp plexiglass
- L47 Headers - Available?
- Rear Shocks Compressor - R&R
- Oil leaks...what' s the best solution
- 97 Aurora A/C failure...electrical?
- (How To) Replace Front Struts ('96) ???
- VATS ignit. key resistance??
- Ran out of gas, now the problems begin...Help!
- serpentine belt problem?
- When I accelerate lightly it runs rough...
- Chrome rims and brake temperature
- Airbox mod -- service engine soon light.
- recharging air conditioning
- Brake lights
- remote start not working
- 1998 Aurora cooling problem
- have power won't even turnover
- MNicolas
- Wonky Traction Control
- Electrical Mirrors
- police problems
- Dex-cool or not?
- Fuel Injectors
- No Gas on the 19th
- recall ...earlier this year
- Tranny filter and fluid change
- What to do with Dealer
- Red Aurora
- Bad MPG and Surging
- Shifter
- How do I diagnose power window problem??
- acna
- Automatic Level Control
- Autobahn package???
- 1996 aurora Keyless entry prog HELP
- Aurora Replacement
- egr
- Introducing the new ACNA Aurora Club webpage
- Cylinder numbers on 95
- keep factory head unit
- What is the best REPAIR MANUAL to get?
- more oil leak questions
- 2001 Aurora Has Loud Whine at 60+ MPH
- How do I disengage the check engine light?
- what is this part?
- backfire, then die..still
- idea on how to save $ on gas.. any ideas on how to make it work???
- Aight, just got back from the dealer
- Open Injector Circuit P0203
- Got Aurora parts- all great shape
- Trying to find trans stick
- Looking for Aurora
- Interior Anything??
- how do i get to back 4 spark plugs???
- let's pimp MY ride...
- Problems with Shifting
- Clean Key wait 3 minutes....
- Fuel Gauge
- gas prices
- Basic/ Preventative maintenance
- spark plugs......which ones are better
- Just Purchased 95 Aurora/HELP with repairs
- exhaust tips
- Ita
- Aurora Club - I'm actually pulling it off :oÞ
- tires
- Add on Cd Changer
- '95 SES / "Limp Home" problem
- How do you remove air filter box ('96)?
- Parking Brake Set
