View Full Version : Alero
Pages :
1 2 3 4 [ 5]
6 7 8 9 10
- 99 Alero misfire/rough idle
- Cold air intake/ Short Ram intake for Alero???
- Stalling..3 time tow
- 01 alero shifting hard and clunking
- 01 alero 3.4l +LIMG + heater core
- Keyless Remote Entry stopped working
- Blinkers/flashers not working-Alero
- moving on
- Broken Window Regulators
- All out of idea's!!!!!!
- New member
- 01 Alero, Identify Stereo wiring
- New Member - Heat/AC & TCS/ABS/SES issues
- 01 Alero , radio locked
- 1999 alero stalling
- Remote Keyless Entry
- 2000 alero cam sensor
- Different hub problems
- Heater blower switch only works on high-Alero
- Engine Hicups when idling...
- 01 alero won't start
- Exhaust mods
- 02 alero blower resistor
- 2000 Alero V6 with code P0122
- 99 Alero Leaking Anti-Freeze
- 03 running bad when hot
- 99 alero tranny question.
- Airbag Cover Removal
- stalls when put into park
- Oldsmobile Alero Fast Idle
- Rear seat fold-down
- fuel gauge shows empty when in park
- Re-programming keyless entry remotes
- Install rocker panel
- 01 Alero 2.4 SES Trac Off Lights
- diagnostic kit for detecting issues
- 3.4 alero LIM gasket replace
- Blower Motor problem
- 2003 Alero Oil Change Light
- Service Engine Soon Light
- All sensors lights ON while driving!!!!
- horn goes off bad swicth??
- Engine Knock when Alero first starts up...
- Broken Coil Spring
- 2000 Olds Alero Anti-lock Light, No DTC
- 2001 Alero - Trac, ABS, and Service Vehicle Soon
- Front Licence Plate Bracket
- touch up spray paint source
- step by step lower intake procedure
- orginal rear speakers
- 2002 alero rough shifting
- Help with Alero
- acceleration problems
- Brakes
- Front Strut Mounts on 03 Alero
- Alero Intake manifold replacement
- Looking to buy Alero Parts off of your alero!
- Whining in front wheel, feel it in gas pedal
- Oldsmobile alero 2000 won't start
- LIM - My Turn
- 2003 alero gl idle problem
- Fan stopped blowing this morning.....:(
- Reverse lights not working...
- 99 Alero window problems
- my alero(s) both love to eat........?
- Keyless Entry?? Yes or No??
- 2000 Olds. Alero Transmission Problems!
- clunk/knock when starting
- 2004 Alero
- P0300-Random/Multiple Cylinder Misfire questions-Please help!
- Honk when locking?
- 2000 Alero - SVS, ABS & Trac off lights on
- 2002 Alero Strange Noise
- Catalytic Converter
- warped disk?
- Hiss from Radiator and A/C Compressor Noise
- The lights, radio, and air work but won’t start.
- 99 alero will not start
- alero heater blower 1999
- Ignition key won't turn, can't remove gear shift knob
- OBD II (2) Drive cycle
- Small Gas Tank??
- 2000 Driver Side Mirror
- Can a bad tie-rod cause shaking?
- Not locking
- Dash Replacement and Now Air Bag Wrinkle
- Coolant has brown Sludge 2003 Alero
- 1999 Low Coolant Warning Light On
- 2003 Alero Check Engine Light
- Another Trac Off, ABS light question
- Aaaah, I've had it!
- Still no Blower...
- trac off light and rough shifting
- fuel, brake problem?
- tranny shifts hard (sometimes)- 2001 olds alero
- Not starting....At a Loss...
- here is obd scan of my 2001 alero 3.4l v6
- Time to Trade? 2002 Alero
- Help Passlock Issue?
- Getting rid of door chime?
- 2001 Alero Purchase
- Fuel smell around car
- Front End Noise
- Exhaust/Cold Air Intake
- Trouble starting after sitting....?
- 1999 Alero, RKE module?
- TSBs - were they addressed or not?
- Fuel Filter Location?
- auto shifter knob broken
- 99 alero very slugish!
- new bearing started failing after 3 weeks
- Car Seat tethering for 99 Aleros
- Fuelpump repacement help....?
- remove front sway bar
- what type of oil
- Interior switch, will it work
- Low Trac, ABS...etc.
- Headlight chime comes on upon acceleration
- 01 Alero Instrument Problems
- Car Started to smell and now won't start.
- Whats wrong with my 2003 alero? ingition switch?
- Erratic Problems
- Getting to the gauges
- oil sensor
- broken seat...04 Alero
- very basic question about speakers
- 2000 alero 2.4 trac off light on tranny shifts hard
- abs sensor
- Surging Problem
- sub amp hook up
- 1999 Alero Parking Brake Shoes
- Something wrong with window
- 2000 Alero 2.4 Trac Off Light On tranny shifts hard
- service vehicle/anti-lock/trac off lights on Alero
- 03 Alero shaking in "drive" when stopped
- Bad Wheel Sensor=No cruise control?
- Hub/Bearing Replacement?
- Fixing Dash that is pulling up?
- help removing steering wheel 2001 alero
- Serpentine Belt Alero 2000
- My Poor Baby
- Selling 2002 Alero Need Info
- what are the normal rpms in a 3.4
- 99 Alero:Overheating/Eatting Coolant
- Automatic Transmission, typical setting for in town?
- Original engine or not?
- engine swap from 2.4l to 3.8 supercharged buick
- Lifter Tick
- how would you rate your alero's handling
- 2000 alero engine problems
- Goodbye, A.F.
- think i found verdict in my v6 01 alero running hot
- Speed Sensor Wiring
- alero stalls when warm ???
- Will this radio fit??
- Key doesn't turn all the way back.
- CD Player thinks it has CD in it...but it doesn't
- Hud
- timing chain
- "clunk" when brakeing in reverse
- Gas Door not closing all the way on 2000 Alero
- Dash Panel Vent Removal
- picture of 3400 engine with intake plenum off and intake
- 2004 Alero Creaking noise from front end. Weird
- rotten Bleeder Valve on ABS Compressor/Proporsioning valve
- 3400 V6 SFI LIM Gasket Procedure
- Engine Diagnosis
- Stutter When Braking-Alero
- wierd noise .........
- just got a 2nd alero 99 4cyl what's major problem with them?
- Stalling When Warm
- 2000 alero 2 lights on
- Another starting issue, however, no security light!!
- Possible Dash pad repair
- Really poor mileage.
- Alero no fuel pressure
- Not starting, no fog lights, no windows, no dash lights
- Is it just me or are there alot of problems with alero's from 98-03?
- Replacing Head Gasket
- New wheel bearing assembly, 2 days later ,"Service engine/trac-off/abs" lights appear
- Just a friendly heads up
- Anti-lock brake light
- Front Hub torque values
- 99 Alero constantly broken, especially wheels!
- computer relearn procedure
- Milky Dipstick
- Gas Smell Under Hood
- Determining which hub/sensor is bad?
- 2001 Alero Stereo wiring problem
- Alero will not start . . ? Passlock
- 1999 Alero will not take gas
- Best way to get to ABS module/motor in Alero's
- Alero High Idle...HELP!
- Alero HEater and A/C wont Blow...
- Body kits and tails
- Lit Up Dash.....Help!!! pls-2001 Olds Alero
- Short Ram Air Intakes for '03 Alero
- ABS, Low Trac, Service Light coming on. Need to get state inspection done. Pleas help
- 1999 Alero power steering issue?
- 3400 engine + m62 supercharger?
- Alero Manual Referance
- Break Pad Replacement Help Needed
- No AIRBAG LIGHT...Will not Pass inspection!!
- Who Knows??
- Serious Passlock Problems
- O2 Sensor
- Are Brake Rotors hard to change on Alero?
- High pitched noise in engine
- cruise control button
- Extreme vibration when turning
- passlock low battery
- Replaced lock cylinder Alero 1999 V6
- 2003 GLS - P0128 - and gas mileage lower than usual
- This will seperate the men from the boys!
- 2000 alero transmission
- 2002 Alero problems
- PCM Questions and Problems
- change oil light
- Trunk lock....Please Help!!!!
- The end is coming
- 2000 Alero 2.4L cuts out at 4k rpm
- Tire & Wheel Size
- Alero 2000 2.4l problems, 2000$ in reparations, still problem
- Head Gasket(s) .... again
- Anyone replace an AXLE SEAL? HELP
- Brake Sensor?
- Driver window doesn't work
- where to get Audio decals/stickers?
- Power steering pump
- 2003 Alero guages & radio won't work
- 99 Alero sounds.. possible problem with brakes or CV what do you think?
- 2000 Alero Ignition Key Won't Turn
- Alero Ignition
- REPLACE WHEEL HUB or CV JOINT? NEED HELP
- Replacing ignition...
- cannot get airbag connector off
- How to remove the heater blower? Something in the way
- starting problem.....please help!!!-99 alero
- Driver's window died!!!
- Starts, runs great and then starts to die?!?!?
- Stalls, cranks, no restart
- Alero ABS, Low Trac, Service Light and Brake Light coming on...
- replacing cruise control button assy'
- Please Help!
- Help Identifying Bracket
- Getting rid of Alero
- Heating Issues
- How and where do i check the transmission fliud on a 99 3.4 alero
- Temperature Gauge
- Help! Timing Chain Tensioner 2.4 Help!
