View Full Version : Alero
Pages : 1 2 3 [4] 5 6 7 8 9
  1. 1999 Alero, RKE module?
  2. TSBs - were they addressed or not?
  3. Fuel Filter Location?
  4. auto shifter knob broken
  5. 99 alero very slugish!
  6. new bearing started failing after 3 weeks
  7. Car Seat tethering for 99 Aleros
  8. Fuelpump repacement help....?
  9. remove front sway bar
  10. what type of oil
  11. Interior switch, will it work
  12. Low Trac, ABS...etc.
  13. Headlight chime comes on upon acceleration
  14. 01 Alero Instrument Problems
  15. Car Started to smell and now won't start.
  16. Whats wrong with my 2003 alero? ingition switch?
  17. Erratic Problems
  18. Getting to the gauges
  19. oil sensor
  20. broken seat...04 Alero
  21. very basic question about speakers
  22. 2000 alero 2.4 trac off light on tranny shifts hard
  23. abs sensor
  24. Surging Problem
  25. sub amp hook up
  26. 1999 Alero Parking Brake Shoes
  27. Something wrong with window
  28. 2000 Alero 2.4 Trac Off Light On tranny shifts hard
  29. service vehicle/anti-lock/trac off lights on Alero
  30. 03 Alero shaking in "drive" when stopped
  31. Bad Wheel Sensor=No cruise control?
  32. Hub/Bearing Replacement?
  33. Fixing Dash that is pulling up?
  34. help removing steering wheel 2001 alero
  35. Serpentine Belt Alero 2000
  36. My Poor Baby
  37. Selling 2002 Alero Need Info
  38. what are the normal rpms in a 3.4
  39. 99 Alero:Overheating/Eatting Coolant
  40. Automatic Transmission, typical setting for in town?
  41. Original engine or not?
  42. engine swap from 2.4l to 3.8 supercharged buick
  43. Lifter Tick
  44. how would you rate your alero's handling
  45. 2000 alero engine problems
  46. Goodbye, A.F.
  47. think i found verdict in my v6 01 alero running hot
  48. Speed Sensor Wiring
  49. alero stalls when warm ???
  50. Will this radio fit??
  51. Key doesn't turn all the way back.
  52. CD Player thinks it has CD in it...but it doesn't
  53. Hud
  54. timing chain
  55. "clunk" when brakeing in reverse
  56. Gas Door not closing all the way on 2000 Alero
  57. Dash Panel Vent Removal
  58. picture of 3400 engine with intake plenum off and intake
  59. 2004 Alero Creaking noise from front end. Weird
  60. rotten Bleeder Valve on ABS Compressor/Proporsioning valve
  61. 3400 V6 SFI LIM Gasket Procedure
  62. Engine Diagnosis
  63. Stutter When Braking-Alero
  64. wierd noise .........
  65. just got a 2nd alero 99 4cyl what's major problem with them?
  66. Stalling When Warm
  67. 2000 alero 2 lights on
  68. Another starting issue, however, no security light!!
  69. Possible Dash pad repair
  70. Really poor mileage.
  71. Alero no fuel pressure
  72. Not starting, no fog lights, no windows, no dash lights
  73. Is it just me or are there alot of problems with alero's from 98-03?
  74. Replacing Head Gasket
  75. New wheel bearing assembly, 2 days later ,"Service engine/trac-off/abs" lights appear
  76. Just a friendly heads up
  77. Anti-lock brake light
  78. Front Hub torque values
  79. 99 Alero constantly broken, especially wheels!
  80. computer relearn procedure
  81. Milky Dipstick
  82. Gas Smell Under Hood
  83. Determining which hub/sensor is bad?
  84. 2001 Alero Stereo wiring problem
  85. Alero will not start . . ? Passlock
  86. 1999 Alero will not take gas
  87. Best way to get to ABS module/motor in Alero's
  88. Alero High Idle...HELP!
  89. Alero HEater and A/C wont Blow...
  90. Body kits and tails
  91. Lit Up Dash.....Help!!! pls-2001 Olds Alero
  92. Short Ram Air Intakes for '03 Alero
  93. ABS, Low Trac, Service Light coming on. Need to get state inspection done. Pleas help
  94. 1999 Alero power steering issue?
  95. 3400 engine + m62 supercharger?
  96. Alero Manual Referance
  97. Break Pad Replacement Help Needed
  98. No AIRBAG LIGHT...Will not Pass inspection!!
  99. Who Knows??
  100. Serious Passlock Problems
  101. O2 Sensor
  102. Are Brake Rotors hard to change on Alero?
  103. High pitched noise in engine
  104. cruise control button
  105. Extreme vibration when turning
  106. passlock low battery
  107. Replaced lock cylinder Alero 1999 V6
  108. 2003 GLS - P0128 - and gas mileage lower than usual
  109. This will seperate the men from the boys!
  110. 2000 alero transmission
  111. 2002 Alero problems
  112. PCM Questions and Problems
  113. change oil light
  114. Trunk lock....Please Help!!!!
  115. The end is coming
  116. 2000 Alero 2.4L cuts out at 4k rpm
  117. Tire & Wheel Size
  118. Alero 2000 2.4l problems, 2000$ in reparations, still problem
  119. Head Gasket(s) .... again
  120. Anyone replace an AXLE SEAL? HELP
  121. Brake Sensor?
  122. Driver window doesn't work
  123. where to get Audio decals/stickers?
  124. Power steering pump
  125. 2003 Alero guages & radio won't work
  126. 99 Alero sounds.. possible problem with brakes or CV what do you think?
  127. 2000 Alero Ignition Key Won't Turn
  128. Alero Ignition
  129. REPLACE WHEEL HUB or CV JOINT? NEED HELP
  130. Replacing ignition...
  131. cannot get airbag connector off
  132. How to remove the heater blower? Something in the way
  133. starting problem.....please help!!!-99 alero
  134. Driver's window died!!!
  135. Starts, runs great and then starts to die?!?!?
  136. Stalls, cranks, no restart
  137. Alero ABS, Low Trac, Service Light and Brake Light coming on...
  138. replacing cruise control button assy'
  139. Please Help!
  140. Help Identifying Bracket
  141. Getting rid of Alero
  142. Heating Issues
  143. How and where do i check the transmission fliud on a 99 3.4 alero
  144. Temperature Gauge
  145. Help! Timing Chain Tensioner 2.4 Help!
  146. 99 Alero overheated and now won't start
  147. Overheating and now, engine knocks bad
  148. Brakes and Rotors
  149. Couple of electrical problems
  150. service vehicle soon light only and dash lights going haywire
  151. 2000 Alero V6, Start-up trouble
  152. 99 Alero with starting problems
  153. 1999 Alero with starting difficulty
  154. 99 Alero Losing coolant, running hot
  155. Intake Manifold Gasket Replacment
  156. Need code descriptions for an alero...
  157. 2000 Alero not charging, new battery and alternator
  158. 2000 4cyl. Olds Alero ABS/low trac/ no trac light problems/ brake problems
  159. Brand of Oil Filter
  160. replacing stock speakers in '99 Alero door panel
  161. Idle Hick-Up at A/C Comp. Cycle.
  162. A/C Switch Question...
  163. Window Problems
  164. power steering pump
  165. is my car overheating??-Alero
  166. Overheating.. LIM and ? on head gasket
  167. radiator drain plug
  168. Perhaps Typical But New to Me Noises
  169. Adjust Emergency Break 04 Alero
  170. tire loading information label
  171. Alero Not Starting - But not the usual
  172. Head lights won't work - Help!
  173. Can not find where piece of paneling goes
  174. 02 Deck
  175. 01 v6 alero temperature problems
  176. Alero Transmission
  177. How Do you program A 2002 ALERO!!!
  178. Removing Control Arm (99 alero)
  179. Best Tires for 2002 Alero
  180. 02 alero..sensor or hub??
  181. rear disc conversion??
  182. Fuel gauge stuck
  183. ambient light sensor
  184. Coolant Leak-Alero
  185. Maintenance on 2003 Alero GL
  186. 99 Alero coolant issue, dipstick oil milky. Head gasket or LIM?
  187. wheel hub
  188. Rad Flush
  189. Car Won't Start...Fuel Pump
  190. whining sound, radio time reset and flickering mileage display
  191. 99 Alero Transmission Acting Funny
  192. supercharger??
  193. over heat
  194. P0300 Random Misfire 2.4L Quad 4 SOLVED!
  195. 3.4 thermostat impossible
  196. Lug Studs
  197. mushy brakes
  198. Power steering problems
  199. How can I strip Rocker Arm bolts?
  200. 02 Alero Power Locks
  201. Calipers Slides or ?
  202. Radiator drain plug
  203. PCV Valve & Tire Pressure ?'s
  204. CV Boot Replacement?
  205. 2002 Alero is constantly up & downshifting
  206. Alero Overheating
  207. Need new side mirror!
  208. Fuel Pump Repair Kit
  209. Fuel:air mix problem?
  210. Alero Dash
  211. Does anyone make a shift kit for a 3.4L Alero with stock tranny?
  212. Alero Problems...Passlock?
  213. Hickups at idle?
  214. Alero 3.4L Auto transmission?
  215. Alero Book
  216. new car!
  217. Lock Horn Beep
  218. Engine Light on and Car won't start!
  219. service engine soon
  220. will these rims fit?
  221. Alero won't start
  222. 2000 Alero Security Light On, Car Won't Start
  223. '99 Alero Rear Axle Problem?
  224. 2000 Alero Rear Window Defroster
  225. 2000 Alero burning oil???
  226. heat problem
  227. '00 Alero---ABS/Brake Lights on
  228. 2001 Alero dash lights dont work, please help!!!
  229. no start
  230. its cold need heat.
  231. 2000 Alero Replacement Blower Motor Revisited
  232. 2000 2.4 (Q-4) Crank/No Start
  233. horn design
  234. Squeaky Steering Wheel
  235. darn blower motor resistor screw, HELP
  236. Aftermarket Exhaust
  237. wheel hub assembly removal
  238. Car starts then dies after about 2 seconds.
  239. horn problem 2003 alero
  240. FAQ Checking ATF Fluid Level on 4T40E/4T45E Autotransaxle
  241. Which hub/bearing is better
  242. I want these!!
  243. Good news, baby!
  244. Alero 3.4 ECT Revisted
  245. is the alero problematic??
  246. Defroster
  247. My Car Wouldn't Start and then it Did
  248. Few questions??
  249. Oil problems
  250. 2002 Alero front end noise
