View Full Version : Mirage
- 1990 Mirage No Spark
- Diagnostic Code Puzzle!
- 1998 DE lighter socket broken
- 97-Mirage, 1.5 L Timing issues
- Help - 1.5 L Coolant problem
- 95 Mitsubishi Mirage Questions... please help!
- ridiculous downshift on atuo transmission
- 2000 Mirage knocking bad under foot at 50-65
- Need some major help :(
- Where does the vacuum line go?
- My Mirage Engine run but dies when put in gear.
- rough idle plz help
- help please !! motor build question!!
- 2000 Mirage 1.8 Timing Belt changeout
- need some help with coiloversd
- 95 mitsubishi mirage 1.5 clutch $80 obo
- Need Help With 98 Mirage 2dr Headlights!!!
- Need shift/selector cable for 92 Mirage
- 02 mirage 4g63 swap
- 95 mirage 4g15
- 93 ca2a mirage idle rough a/c on
- broken timing belt on 96 mirage 1.5
- help?
- shifting?.?.?
- Oil capacity
- Takeoff power loss, need help bad!
- 99' mirage de 2 door ENGINE DROP
- 1999 mirage
- transmission won't engage and no milage display
- Aftermarket clutch and pressure plate
- Engine whine when accelerator is pressed (2000)
- 1997 Mirage LS parts MUST GO ASAP
- Need Help Asap!!!!
- need an exhaust
- '98 Mirage turn signal probs.
- 1993 Mirage/Summit Failure
- 2001 1.8 spark plugs
- 99 Mirage - dented oil pan
- 99 Mirage - how to adjust headlights
- 4g64 problems
- 1999 Mitsubishi????
- 4g63 swap in my colt/mirage
- Instruments Not Work
- 1994 mirage car bra and distributor for sale
- EGR Valve - Carbon Build-up
- *** valve help ***
- 1.5 is a crappy engine
- Wanted this center cap (pic) from 13inch steel wheel
- Mirage 2000 RADIO CODE needed...
- '01 Mirage. Need help/advice/suggestions!?!
- Po 705 need help
- 1996 Mirage S- Stalls outs/ Poor Performance
- 1995 Mirage question.....
- '89 Mirage 1.5l hatchback: Fuel Sender/Holster
- 95 clutch slave cylinder
- 1994 Mitsubishi Mirage Died While Running and Now Won't Start!
- Mirage Idler Pulley
- 95 mirage starter repl?
- clutch oil
- motor
- 89-92 mirage gauge cluster
- splash shield / pan
- Shifting issues
- timing chain
- check engine light just came on
- how do i put a tach on
- help
- 2002 Mitsubishi Mirage Coupe FOR SALE
- 2000 mirage wont start
- Steering Wheel Help
- 01 Mirage ES 4 dr. mods (4g93)
- Please help
- Please Help!
- SRS & Engine Check Soon lights are on
- computer reading
- computer
- 1992 Mirage 119k miles
- Any one has any evo V Headlights for sale?
- 1.5 or 1.8
- 92 Mirage
- 97 Mirage - Startup problems... Please help...
- Mirage swap
- Stuck Horn.
- mirage s 96 engine upgrade/swap
- 1990 Mirage
- Recharging air conditon
- 02 mirage with A/C problems
- 2000 miriage overheating
- fuel pump
- po446 error code
- Mirage EGR Code P0401
- UpGrades for a 2001 Mirage
- 96 mivec mirage splutters
- 98 mirage gauges
- Talon Tsi (4g63) turbo swap into my Mirage
- 96 coupe
- 95 Mirage using 1 qt oil a week
- 96 mirage turns over but wont start
- 2003 Mirage oil type
- P0705 Transmission Range Sensor Circuit malfunction(PRNDL Input)
- mirage airbag question
- 98 Mirage keyless entry programming??
- Crankshaft Pully
- 2001 Mits Mirage Gauges Wont Work
- 95 swap options
- 4G69 in a '91 Mirage?
- How on earth do you remove front rotors.
- O2 Sensor
- 2003 Mirage all wheel drive conversion
- Hey got a problem w/ radio, hopefully you can help
- air intake mass air flow computer
- 2001 mirage gauges won't work?
- 97 Mirage coup 1.5 Engine Help
- 91 Mirage body kit?
- Wont start!!!
- 96 Mirage Overheating... I think?
- Whats the redline on my 2000 mirage 1.8 16-valve
- Over filled battery, 97 mirage 1.5l
- 4G15 to 4G63T?
- 1995 Mitsubishi Mirage. i need help??????
- 1995 Mitsubishi Mirage iCU fuse location???
- TPS problem
- I would like some Info on a 96 mirage
- 1997 Evo Mirage for sale with 1.8 engine swap many mods
- Project 90 Mirage Getting Close!
- Stumbling on acceleration.... help!!
- Need a 97 automatic 1.8L transmission
- Power Locks Problem - Keep blowing fuses
- 1993 Mitsubishi Mirage Water Pump
- Help w/ 02 Mirage: Noisy Idle, Varies w/ Eng Speed
- vacume line
- Timing belt/ crankshaft sensor
- 02 sensor
- Blower motor and automatic windows
- 97 1.5l Mirage Battery wont charge.
- Fishy Smell
- want to buy 1.8l mirage intake manifold
- 95 mirage rough idle
- Misfire in Cylinder 1
- 2000 Mirage door
- difference in '95 and '97 alternators???
- Should I fix or junk my car
- 2000 Mirage looking for Engine upgrade
- mirage main caps
- What can i do to my 9 7 mirage de coupe to make it go faster for very little money?
- Got another engine swap idea.
- Hot air come out from A/C, help.
- clutch problem
- Stereo install
- Speaker cover for drivers side 97-01
- Mirage Auto wrekers
- Low Idle speed
- fuel pressure
- How to take apart my AC Controls
- '93 Colt
- how to change belts on mirage 2000?
- need help on headlights
- 93 mirage with 4g63 swap
- surging idle speed
- It's me again
- Please someone can helpme
- Need electric fuel pump '91 Mirage 1.5 l
- avg miles for 1998 and 2000 mistubhisi mirage
- EVO 5 Conversion kit for 97-2001 mirage FOR SALE!!!!
- Best Engine
- Front Speakers?
- Know a good writeup on replacing clutch??
- 4g63 swap
- Stuck Key
- Stereo info.
- 97 mirage wire colors
- 97 Mirage Ignition coils and system
- car does not start when it rains
- Got 5G..Evo 4-6 Swap Q's
- throttle position sensor
- You want MIVEC??
- carbonfiber doors
- 1999 mirage
- 92 Mirage: Random stalling
- Is $55 shipped to much to pay for a strut bar
- New here...
- 1994 Mirage parts
- Hi guys hope someone can help.
- 98 mirage needs new engine need about 300horses
- headlight change
- My horn does not work
- Battery Change 97 Mitsubishi Mirage LS
- Cigarette lighter does not work
- 2001 LS low idle
- 2002 Mirage removal of door panels
- 91 Mirage 1.5l won't start
- Finally The Eclipse Is Given A 4g63 Again!
- 1994 mirage cold air intake
- 1994 mirage high idle
- 1994 Mirage Manual Tranny Fluid Check and Fill
- 1997 1.5l Mirage Engine & Parts for sale
- 4g64 swap into 97 coupe
- Engine swap for a 2000 Mirage 4Dr
- 1989 Mirage front brake rotor removal
- super turbocharger
- headlight swap from 97 to 93?
- Engine Swap 4g93 Please Help !
- Projector headlights for 1993-1995 mirage
- Wireing Harness
- Worth the time, effort and $$?
- wiper motor location
- new to the mirage scene
- 1998 mirage turn signal problems
- Custom built cold air intake?
- 2000 Mirage fuel door
- 90 mitsubishi miarage, oil light flicker
- swap problem
- Know one can tell me what is worng!
- 2002 Mitsubishi Mirage Radio Lock
- cooling fans on, rough idle?plz help!
- Hard starting due to battery change?
- Does anyone know what kind of "rims" this Mirage is using??
- can a 1.5 liter go into a 3rd gen eclipse
- 90 mitsubishi mirage 1.5
- Any potential in the 1.5?
- Grinding noise when engine running?
- AC Compressor
- 2000 Mirage tire size
- 1989 Mirage won't start help plz....
- Mirage LS help
- IAC location?
- Buzzing from heater fan?
- tie rod/lower A-arm ball joint removal
- 1994 Mirage service/shop manual needed
- When to change the timing belt?
- 98 Mirage DE engine size
- 98 Mirage DE Fuel Filter
- need wiring diagram/ workshop manuel for '93 Mirage Cyborg R
- Exhaust manifold
- cant figure out whats wrong! pls help!
- mirage 1994,cooling question
- 96 Mirage SRS and Horn stopped working
- mirage
- 97 mirage tranny swap !
- No Bumper Supports! they protruded further than bumpers
- bad oil leek
- need some help
- 96 Mirage--Idle Air Control Motor
- 04-06 ralliart lancer mivec parts into mirage
- haha almost done.
- 3000gt engine in mirage?
- mirage 97
- Gauges Go Out on 2000 Mitsubishi Mirage
Automotive Network, Inc., Copyright ©2012
