View Full Version : Mirage
Pages : 1 [2] 3
  1. need some help
  2. 96 Mirage--Idle Air Control Motor
  3. 04-06 ralliart lancer mivec parts into mirage
  4. haha almost done.
  5. 3000gt engine in mirage?
  6. mirage 97
  7. Gauges Go Out on 2000 Mitsubishi Mirage
  8. Turn Signal Stuck
  9. 90 mirage engine swap w/ eclipse turbo
  10. 89 Mirage cooling problems
  11. how to install keyless?
  12. 2001 Mirage ATF information?
  13. Is 4G93 interference engine?
  14. help please
  15. Question
  16. FS: 94 Mirage/Colt SHOW CAR!!
  17. looking for a wiring diagram 93 mirage
  18. 1987 mirage
  19. 1.8 ls engine swap?
  20. Noisy
  21. 2001 mitsubishi mirage timing belt
  22. Help: Friends car gas smell and runs rough
  23. How do I replace my EGR valve?
  24. 4g63 mounting and headlights
  25. EGR valve
  26. check engine light
  27. '90 Mirage Sedan Manual Window Regulators
  28. Hey Guyz
  29. I Need A Turbo!!!!!
  30. evo turbo onto a 1.8 LS engine
  31. new Head
  32. cluster
  33. looking to buy a rage
  34. For Sale....
  35. need help tach
  36. mirage LS project
  37. Beat teh crap out of a mirage tonight
  38. lancer doors onto a mirage
  39. Mirage Turbo Kit
  40. water in trunk
  41. Fuse box diagram 95 Mirage?
  42. 94 rage for sale w/4g63 swap!!!!!!!!
  43. Mirage Buying
  44. 93-96 mirage Jdm Tail Lights
  45. 98 Mirage Oil light
  46. undercarrage neon lights
  47. EvO 5 Conversion
  48. 95 Mirage timing belt
  49. Eclipse motor in a mirage
  50. evo II headlights
  51. Stuck Tranny
  52. Engine Swap questions
  53. Questions about 4g63 motor
  54. 5g Mirage Engine Swap QUestion:
  55. 94 mitsubishi mirage f/s and a question
  56. Free Mirage*!!!
  57. Questions
  58. Emergency Help!
  59. i'd like to check out your cars
  60. 85 colt engine swap?
  61. body kit
  62. Fuel filter
  63. 1998 Mirage Tach
  64. EL REv. Gauge Prob.
  65. 99 Mirage A/C Compressor not starting
  66. 97 mirage ignition coil wiring
  67. Summit/Mirage
  68. performance upgrades
  69. New mirage
  70. a question i should know the answer too....
  71. Lowering springs
  72. need some help
  73. how to turn the sound on my alarm
  74. Which order do you intall plug wires? HELP!
  75. rough idol
  76. ecm, iac
  77. cluster
  78. Questions about Mirage
  79. Engine Swap
  80. Rubber around out side of windows
  81. Help~ 94 Mirage ls coupe question
  82. widebody 4G63 coupe
  83. What motor comes in what car.
  84. 94 1.8L mirage: how to install an aftermarket tachometer
  85. Mirage 98 problems
  86. 1995 1.8 L Mitsubishi Mirage transmission
  87. Ideas on how to pimp my ride?
  88. 97 Mirage Ls Coupe Problems Please Help
  89. 02 Mirage Technica
  90. 4g63t swap
  91. if i had 4 grant to spare....
  92. side markers replacement
  93. evo conversion?
  94. Evo 5/6 conversion
  95. lancer evolution injectors or fuel managment
  96. engine code readout
  97. Tech/Repair Manuals?
  98. 4g63t in 1995 mirage
  99. added turbo, stock ecu ?
  100. I Need Help
  101. Mirage 92 1.5
  102. Altezza light, anyone knows PLEASE!!!!!!
  103. need to find EVO5 widebody kit and TRUNK DECK!
  104. 91 mitsubishi mirage engine 1.5L
  105. 94 1.5 idle problems
  106. 4 door body kits for a 2 door
  107. 97 mirage front speakers???
  108. 92 Mirage Cracked Exhaust Manifold
  109. 91 mirage part out
  110. 1993 Mirage Horn Relay and Fuse Diagram Request
  111. Mirage Engine conversion to EVO 2!
  112. Turbo
  113. 93 mirage transmission problems :(
  114. audio system for sale
  115. 1997 1.8 liter mirage parts for sale
  116. mpg cut in half 4G15 HELP
  117. WTB: 95 1.8L a/c compressor
  118. fs: selling my 94' mirage s coupe....
  119. 93 Mitsubishi Mirage axle problems?
  120. Idle Air Control(IAC)
  121. headlights
  122. which mitsubishi FWD axles fit a 97 mirage
  123. 1990 Mirage ECU location?
  124. Stalling
  125. smoking probs
  126. BRAND NEW in original package short shift for Mirage Colt/Lancer CE $100aud shipped
  127. 94 mirage es
  128. 91 mirage starter wont turn over (help)
  129. don't reply if you're not going to reply
  130. Car idle and start problem....
  131. Cooling Fan turns on and off quickly
  132. 4g63 mitsu eclipse engine for swap...
  133. front corner turning light
  134. Which engine to choose
  135. this is off any topic some what
  136. questions on tech
  137. 2002 Mirage?
  138. must sell 92 1.5l mirage $500 OBO
  139. confuesed
  140. headlights dimming, loud humming noise.....
  141. Strange cold starts
  142. Short Circuit
  143. 97 Mirage LS - Any kits available??
  144. air intake
  145. High Idle
  146. Mirage gearbox oil change, need help!!
  147. Removing a tail light
  148. Pioneer Cd Player In 92 Mirage Help
  149. Highway driving issues with a '95 manual trans
  150. need 1.5l distributor 89-92
  151. 2.0 ????
  152. 93 es
  153. HELP Please
  154. eclipse suspention on 5th gen mirage
  155. 97 mirage de acceleration problem
  156. 92 mirage 4 spd 1.5 problem....
  157. Questions on 1997 Mitsubishi mirage
  158. where are the spark plugs in 2000 mirage?
  159. 1990 Mirage 1.5 clutch
  160. please help with body kits
  161. 92 Mirage
  162. 91 Colt/Mirage 4 speed manual NO FORWARD GEARS
  163. bad computer?
  164. eclipse turbo complete engine 4 sale (swap)
  165. 400hp 4g63 eclipse gst mt comp eng 4 sale
  166. im new here and wondering what can be converted in evo
  167. Rims
  168. bigger throtel body
  169. 4g15 Ported Intake Manifold For Sale
  170. Check Engine Light!!!???
  171. Headlight Yellowing/Moisture
  172. Code P0340 Cammshaft Position sensor circuit malfunction
  173. Exhaust smoke
  174. Accessories for Mirage
  175. question about o2 sensors
  176. Juke Problems
  177. Camshaft Pos. Sensor ++
  178. Burnt oil smell
  179. My Carbon Trunk Lid Pix/Teasers! (SNEAK PEAk)
  180. NIce Pix Of My Car... DeskTop Background Pix!
  181. Question on bodykits for my 93 2dr plymouth colt gl
  182. Some More Pix Of My Miravolution GT!!
  183. 1998 Mirage DE Coupe acceleration problems
  184. 4G91 transmission help!!!
  185. The Mirage Is Back! Now Evo 5 Super GT Extreme Widebody! 350z Orange
  186. Speakers - Front Door
  187. Timing Setting
  188. Timing Belt replacement on 2002
  189. Fog light removal
  190. Mirage vs. Transmission Problems
  191. 1991 Mirage to Part out
  192. Mirage vs. Conquest?
  193. 93 mirage coupe body kits HELP!!!!!!!!!
  194. Why Is This Mirage Forum Sooo Dead??
  195. thinking about buying a 94 Eagle Summit ES coupe
  196. 1992 Mirage/eagle 1.5 manual..Redline?
  197. Parting a 1994 Mits Mirage 1.8L, Man.Tranny
  198. Spark Plugs
  199. 1997 Mirage Wiring Diagram
  200. 1992 eagle/mitsubishi mirage intake air temp sensor?
  201. Another Question
  202. Need Help PLZ!!!
  203. EVO 5 kit offers
  204. Miravolution.com: A Website For Evolized Mirages, Helping You Tune Ur Mirage EVOLized
  205. Pix Of My Kandy Blue/Purple TURBO Mirage Evo 4 Conversion!!
  206. door panel removal
  207. Another Swap Question (yes I searched)
  208. Questions about 94 Mirage Coupe S 2 Door
  209. coldair
  210. hooking up a mirage?
  211. trouble with keyless entry
  212. Engine Swap
  213. yeah
  214. Freaking Dumb Jealous People
  215. Door hinge problem on '01 Mirage
  216. mirage 1994--->EVO 3 conversion
  217. 94 mirage S Coupe
  218. Parting out '91 MIrage 1.5l
  219. Stereo Code
  220. Looking for ECU list of errors
  221. 98 Mirage Swap For A 4g63
  222. molded 97 front clip
  223. to cyclone or not too cyclone
  224. Mirage transformation... need some help.
  225. bodykits
  226. wtb: a manual gear box for 96 and up
  227. turbo kit
  228. engineswap from a 1.5 to a 1.6 mivec...
  229. Radio Wiring Diagram Needed.....
  230. New Rims
  231. Trans swap.
  232. Headlight Headache
  233. Map Sensor
  234. diagnostic codes
  235. Automatic Shifter
  236. can any one help me
  237. my mirage will not go passed 85??????help??
  238. What trans mount to use.
  239. mivec wiring diagram
  240. JDM Headlights
  241. Mirage Problems please help!!
  242. 1991 Mirage ECU
  243. 1996 Mirage Tachometer hookup
  244. 95 mirage parts
  245. 4g63t
  246. Ecu
  247. Performance Upgrades
  248. most
  249. whats considered a decent system?
  250. Performace thermostat
