View Full Version : Galant
- 99-03 Galant Custom Grille Or Universal Billet?
- 2004 galant radio question
- Front ECU?
- headlight wiring
- Where to get parts?
- (almost)went down flooded road
- worried about car
- 01 galant dies
- what should i do?
- Radio Code Galant 2000
- 1997 Galant Horn Woes
- '95 Galant - Problem symptoms
- '00 Galant for sale!
- 92 Mitsubishi Galant Auto trans problem
- Passenger Mirror
- galant idle
- Infinity Center Channel
- 92 galant tranny problem
- Transmission Problems?
- Very Wierd Problem????
- widebody
- 94 galant please help can someone please answer back
- Fan Belt Squealing
- Window getting help in middle, need advice :(
- overdrive relay
- How do i install an new system in my 97 galant???
- Noise from front wheel well
- 03 galant LS intake and catback? HELP ME
- A/C pollen filter for 03 Galant?
- Buy a previously leased 2003 Galant-V6 ?
- but what's the difference ?
- Best fit intercooler for a 91' VR-4
- thinking about buying
- question about o2 sensors
- Importing VR-4 to the States?
- Help GDI
- WTB: 94 galant Headlight
- 2000 galant swap details
- 2001 Galant radio swap
- 91 Galant GSX automatic transmission stuck in limp mode (stuck in 3rd) FIXED!
- Factory head unit input adapter?
- Euro headlights
- 98 misubishi Galant ES...NEED HELP
- duplicate keys ?
- Passenger mirror (manual)
- 94 2.4 DOHC low idle
- 91 Galant Tranny prblms 3rdgearstick
- roof leak
- 01 Galant 8G Manual transmission swap
- Remote entry problemm, 2001 ES
- Galant 97 ES problem-thudding noise
- Motorized Antenna
- Gauge Neddles probem Help
- head lights
- galant body kits
- Please help! 1990 galant surges at idle and will not stablize!
- 1990 galant
- 99' Galant V-6
- 2001 Galant remote programming
- Thinking about getting a 2001 es...
- Mitsubishi Galant keyless remote programming
- 2003 needs help
- 2001 Galant ES Fast Bags
- 01 v6 Galant worth putting money into?
- EGR valve
- Replacing Brake Lights on Galant 2002
- 92 Galant dies on highway
- Got any suggestions?
- Making a VR4?
- 2.4 headers
- 99 GTZ...traction control light, or what?
- engine or tranny swap
- 03 keyless entry programing?
- radio code
- 2003 mild accelleration surging
- Galant body kits
- 97 misbitchi galant es v4 HELP!
- Galant VR-4 info
- Car Bogging At 5000 Rpm
- Radio problems Help!!
- Please Help!
- VR4 ECU vs VR4 CYCLONE ECU
- want 2 buy
- Just got galant 2k1 with 130k miles from dad, any suggestions on engine swap?
- After Market Lights Anyone?
- 94 Gs
- Whats wrong with my speedometer? please help
- RPM 3100 at 70mph
- electrical gremlins!!..help please
- speedometer cable
- 96 galant type s for sale or help fix
- 99 Black Galant Paint Problem
- galant 78 wiring diagram
- rims
- Dead battery, or just a short in system?
- Installing aftermarket Stereo....electrical problems
- Trouble with new brake pads on 91 Galant!
- 90 Galant won't 1. start, 2. keep running, or 3. runs fine????
- 2001 Galant ES Braking concerns
- VR-4 4G63 (from nz) in 82 Starion
- '91 Galant VR-4 Body kits?
- Galant repair manual
- engine
- Rocker Arm noise on 97 2.4L
- 97 galant overheating help!!!
- cold start & idle problem
- 2001 Galant ES Interior Accessories
- 1995 Galant problem(s)
- rear wheel bearings
- Wanted: 1990 Mitsubishi Galant GSX with busted engine
- Changing starter in Galant GTi 1990 4WD
- When to change the timing belt.
- Yeah, But....
- 1998 Galant
- left brakelight
- Alternator Exchange
- Reputable Galant ECU purchase site?
- 1990 Galant Overheating
- Cut short of 200K, need new beast
- Speed Chips
- Need master key cut
- Limp Mode and ECU question
- Mitsubishi 1800 GDI
- help?
- parting out 94 galant
- turbo a 99 galant
- 99 galant
- chrome rims
- help again...
- HELP i need info on 02 galant rotors...
- help regarding instrument gauge light
- galant timing belt
- 2003 Galant remote profram procedure?
- What Transmission Fluid?
- newbie here with some concerns!
- WTB: I Need This ASAP!!
- Im new but not that new??
- Concerns about my new '88 Galant
- Ignition Key Sticking
- Brake Job Questions
- Program Ignition Key '03 Galant
- WTB: AC Clutch or whole assembly 95-99 Galant
- I need a Galant Ecu Part Number MD167737
- Alternator Belt Repeatedly Slipping
- Engine Swap
- Engine in 1998 Galant ES? Durability?
- 2001 battery replacement & programming
- 1997 Galant VR-G info please
- ECS problem
- bogging out
- Throttle stuck wide open
- TPS replaced, still acting weird
- kick ass body kit for 99-03 galants
- Why?????
- Transmission Problems(No reverse)
- Questions.....HELP.......
- Need Manual Bad
- Good place to find everything you need for a Galant???
- Tranny kick when driving any clue?
- 95 Galant dies out???
- Transmission/Overdrive problem, Please help!
- turbo parts list
- Help
- rpm's possessed by the devil \m/
- rpm's possessed by devil
- Galant Engine Swaps
- where can buy the carbon dash board?
- car is making a squeking noise....
- Check engine light is on...etc
- Problem with lights in the car
- '91 Galant won't start
- Central Lock doesen't Work- Electric problem ?
- 2000 GTZ Stalls after wreck
- somebody help!!!
- My 97 Galant Is making a clonking noise on its rear axile..
- Galant es 97 bodykit?
- Galant 2001 driverside Halo headlight removal
- 95 Galant automatic transmission fluid
- 97 Galant ES
- Galant engine swap with FTO's 6A12 mivec
- Need Help...
- how to instal the gauge on my car?
- where can buy the asian style body kits of galant 99-2001
- going turbo
- how do you remove rear drums 2000 galant
- Electrical Problem
- Timing Belt Put On wrong
- Galant head light assembly
- remote for car
- New Engine needed for 2000 Galant
- 92 Galant won't start!!
- swap 1999 Mitsu Galant 57,000m mint condition for Roadtrek or custom van w/sleeper.
- garage opener programming steps?
- 95 galant torque convertor not disengaging
- gdi
- 92, blew enging, need quick info on swap
- I want one!
- Looking for a Galant to be used in a Photoshoot
- 1990 Galant GSX
- Oil
- Rear End Knock
- 1992 engine knocking
- Firewall in 2002 Galant
- 2001 Galant radio code
- 98 Galant - Japanese model
- Many Questions Needing Answers
- Water leaking into passenger compartment
- radio code for 2000 galant?
- How long do 1989 Galants last (motor)????
- Parting out 92 Galant LS
- engine & tranny swap
- Unpredictable occurance of high idle. ECU problem?
- Galant GSX, Can it be a VR4,should I buy a gsx?
- 97 Galant 4 cyl : Cold air intake?
- Electrical Problem - Need Help
- 1990 Mitsi Galant - Why I hate it!!!
- 1995 Galant This squeaking is driving me crazy
- HELP! Inconsistent starting problem!
- Best engine swap for 89 galant
- Stereo Unlock Codes
- NO POWER IN CLOCK, STEREO and LIGHT
- car wont start
- Aftermarkrt Coil packs for 4g93 GDI
- '01 Galant ES won't start -- freezing temp's
- need pic. of fusebox- Mitsubichi 91 sr4??
- Blower motor stop working!
- transmission trouble
- 1992 galant gti gear ratio????
- Galant Clutch Problem
- clicking noise in passenger dash
- galant intake
- Performance Parts For A 95 Galant
- Radio Code for 2000 Mitsubishi Galant??
- ECM location on 97 Galant !!
- Spark plug gap !!
- VR4's
- Transmission Override Problem
- ? on power antenna not going down
- Engine Idle Too High
- transmission in {limpin} mode have you seen this problem
- Help, start problem
- Reprogramming a transmitter (remote)
- What are the keyless entry model numbers for 2001 Galant?
- no power to sunroof and...
- 2000 Galant radio "off"
- Timing belt change...
- Galant Transmission Help
- Cold Weather Starting Problem
- computer REFLASH fixed
- 97 galant radio code
