View Full Version : Galant
- Air Conditioning PLEASE HELP
- Spark plugs
- how hard is it to change spark plugs on a 99 galant?
- Eclipse Exhaust on a Galant?
- Air conditioning
- 6a13
- Cleaning the MAF
- 1994 galant with 97 trans having problem!!
- help, JVC CD troubleshooting
- Throttle restrictor?
- o2 sensor help
- metra turbo kit bracket for 7th Gen
- do you guys suggest buying a galant ?
- my left turn signal wont turn off
- Power Loss
- Error codes 11 and 59
- 99 AC condensation drain tube?
- knock 2001 2.4 es galant
- oil change frequency
- Starter replacement
- 1999 Won't start. @.@
- galant tail lights
- 99 Galant sterter replacement
- Car won't start....alternator?
- '92 Eagle gtx 2000 won't start-problem solved
- Crank Pully '95 Galant
- Error 25 - Barometric pressure sensor
- 1999 Galant Factory stereo wiring
- 1994 Mitsu Gallant Running to rich?
- transmission filter
- is it just me
- programming keyless remote for galant
- mitsubishi galant es check engine light??
- Anti-freeze reservoir and AC (semi-long)
- Accessing Rear and Door Speakers
- whats your idling? and other concern
- Mass Air Flow Sensor Help!!!!!
- Timing Belt Cover
- 99-03 front speakers
- FOR SALE --- 97 misubishi galant --- FOR SALE
- 1995 Gallant needs new rack and pinion steering
- help 02 galant cant find my spark plugs
- body shop replaced oem tire with mismatched tire
- Car starter or battrey?
- 2001 Galant Radio reset
- american-european designs
- 98 radio harness
- WTB: Used 96 Auto Tranny for Galant ES. Help!
- Quick ???
- Power failure
- Engine Noise like loose rocker
- 2005 Fog Lights
- 2001 Galant/radio Code?
- Raido
- galant engine swap
- 1990 GSX engine swap?
- Infinity Success Story
- Please Help with 03 CD Player Problem
- Car sitting about a year
- Headlight Bulbs
- odd noise (seemingly) from front wheels
- 94 Galant GS troubles
- radio code for 2003 galant..please help...
- FS: 1990 Galant AWD parts
- FS: 96 Mitsu Galant S
- lost keys on 2000 galant
- 99 Galant-Does bad tie rod mean new rack and pinion
- Crazy iddle on Galant GSR 91
- timing belt install 98. galant 1997cc doch
- Stereo reset...HELP!
- Opinions on 2001 Galant Es 2.4L
- 98 galant gls 2.0 auto throwing off pss belt
- Help
- Rear Disc brake job who can help?99 galant
- oil on boots and on plugs
- Parting out whole car!!!! 02 galant charcoal
- trans flush service
- ignition
- Soch inj 2.0ltr 4963(SB6P41G Series)
- Blinking A/C LED, compressor shut off ('99 Galant)
- FS: Galant stock spoiler + Galant door emblems
- 99 Galant dies when ac is on
- need tps for 89
- Checking timing belt
- galant gearbox fitting????
- Electrical problems
- Wiring for cd deck install needed for amp bypass!
- GVR4 for sale???
- hood pin installation??
- GT vr-4 jdm
- No drive forward or reverse
- 1997 Galant PS belt
- 98 computer to a 96, will it work?
- Removing wheel/speed sensor from Hub Assy
- WTB: 94-98 Silver door mold/trim
- Time to start building
- Front & Rear Fog light switch
- 2001 Mitsubishi Galant ES Won't Fire
- wheels for sale
- 92 Galant Check Engine Light On Wont Keep Running
- WANTED: 98 Galant car...wrecked or blown engine OK
- Help with 01 Galant, Lights dont work after Cd player Install
- Galant 2000 Timing belt
- 2001 Galant CD player troubles
- 1998 galant help please
- vented fender
- What transmission fluid for a 1997 galant in owner's manual...
- "97 galant" every 97 galant radio code is not 3844! here is what I did to get my code
- 97 Galant Lifters Need Help
- 1998 Galant Woes. . . . .
- need help with skunk 2 coilovers for galant 01
- 97 galants do they have two keys???
- help!
- 1999 Galant Viento GDI
- Am i putting to much weight in my trunk?
- I finally got pics of my galant up, here they are!
- removing the wheel cover/ hubcap of a 2001 galant
- help : wind screens
- help! PLEASE "97 galant" tran problem not working look for help:(?
- 92 Galant Acceleration problems
- Angel/demon headlights
- SRS Light wont turn off!!!!
- My Friend Ethans Galant
- ECU in a 1990 Galant
- different tranny fluid
- 97 galant check engine light
- Exhaust Cost
- pwr steering flush
- 2001 Galant Banging Sound on the Right Side
- Instruction for removing galant 2000 stereo
- electrical windows wont go down
- idle problem???
- how to fit wheels and supention on 2001
- Radio codes for my 97 Galant
- The little red light
- Headlights Cleared Corners
- simulated wood dash kit
- 2000 gallant brake & timing questions
- ECU Question
- Dyin While Drivin, Help!!
- 96 Gallant S/ horn installation
- Help! Car wont start.
- how to replace radiator support
- 95 galant electrical problems
- 01 galant stereo wiring question
- 2000 Galant Keyless Entry Reprogramming Problem!
- Reverse Glow Gauges For 02 Galant
- 2002 Transponder Key
- 94-98 parts
- Eagle / Mitsubishi Trouble PLEASE HELP |
- 91 cylinder ignition lock
- 95 Galant Auto Tranny Problem
- 95 galant intake
- 97 Galant Died, new battery, no start????
- HUGE ELECTRICAL PROBLEM WITH MY 01 Galant! PLEASE HELP!
- 2001 Galant Starting Problems
- Exploded diagrams of front end? (about the radiator support)
- door locks
- Jerk while starting to Move
- 1993 Galant
- 99 Galant hesitates
- Hi, New Galant Supporter wanted to say hello
- 4wd 4ws Gti non starter
- 2001 Galant Fog Light Replacement
- Is my galant having tranny problems?
- What do you think about the 1990 Galant
- Need help with fuel filter
- Coolant drainage valve on Galant 2000
- Turbine Body/Housing YELLOW/WHITE/BURNT with pics
- Buying a VR-4
- 2004 2005 Galant comments
- Weird noise when starts in cold
- '94 Galant SEI ?
- 90 Auto trans
- HELP! Antifreeze in my ISC Motor cavity ?
- HELP! 92 Galant using/losing oil maniacally!
- 95 galant transmission trouble
- 2004 Galant Radio Question
- Side Mirrors with L.E.D.s
- engine swapin
- 1989 Gallant problem(s)
- galant antenna problems.help please.
- this is a bunch of hooey
- Keyless Remote
- 1998 Mitsubishi Galant???
- Both fans not working in mountains
- Failed Emissions Inspection
- '95 Galant Illumination Problem
- Mitsubishi Galant 1994 silver 96k miles - $2500
- 1996 Galant Idle Problem
- greetiings
- Old 1972 Galant
- manufacturers warranty
- speed sensor wire
- Tranny or rebuild kit.
- locking problem
- transmission problems 2000 galant
- 2001 Galant ES "knock sound"
- Wiring diagram for 1990 Galant needed. HELP.
- Leaky sunroof
- Airbag questions
- Brake Problem
- Angel eye/ Projector lights
- any luck shoving different motor in?
- 94 galant transmission
- Bearing Noise?
- 2000 Galant cold start idle issue
- Electrical Problems
- 89 galant timing belt swap need help!
- engine swap info..need help fast
- Mits. Galant & anti-theft alarm & door locking problem
- changing plugs?
- programming a 1996 galant keyless entry remote
- My instrument panel is dead
- 98 Galant, need doghouse, airbags
- Radio/starting car trouble
- Warm-up catalyst error code
- 1990 Galant problems...again
- reving idle, throttle while driving
- NEWB WITH 99 Galant questions
- 1992 Mitsubishi Galant heat not working well in cold weather
- Infinity Audio pieces from 99 GTZ for sale- see ad
- Galant 91 GSR suspension
- Galant A/T late-shifting
- help with drive axle
- 97 gallant parts car $250.
- help
- Body Kit For 97 Galant???
- Galant VR4 Rally Car...
- ECU WIRING DIAGRAM 4G63t
- lights dim-HELP!
- 2002 Galant performance
- clan
- '01 Galant Audio Wiring Colors=?
- Where can I find the GTZ letters from the back of the car?
- moon roof problem
- balance shaft installation
- Dash noise like small marbles
- 99 Galant No lights on the instrument cluster
- 89 Galant starter prices
- Need help...Infinity center channel
- Brake drums too small or shoes too big?
- O/D don't work
- Interference Engine or Not, That is the ?
- Price of Swap for VR4
- Lowering
- anyone know of any galant performance forums?
- got new 00 galant v6, how to speed it up?
- CD Player question
- Suicide Doors?
