View Full Version : Galant
- 2002 Galant radiator problem???
- door buzzer
- 99 galant
- 1996 Galant Horn Woes
- shocks on 92 Galant
- How To Set Basic Timing Galant 2003
- 1997 galant 2.4 fan inop
- 97 galant with overheating prob and oil light on
- Engine Skipping
- Another 2001 Mitsubishi Galant Leak
- Weird Radio Problem '01 Galant HELP!
- temperature gauge needle 03 galant
- 94 Galant - Tranny?
- 95 Galant Oil Question
- 1997 Galant engine replacement
- e54 tuning advice
- 94 Galant wont start AT ALL
- misfire 1st gear, '03 Galant
- Shaking issues
- 1990 mitsubishi galant ECU wiring
- 2003 Galant - Service Engine Light On
- 1995 galant won't start.
- help with aftermarket remote
- 2000 just died in the middle of the road?
- Pros & Cons of Galant Diesel
- Description of Galant Diesel
- Mitsubishi Galant 2000 water in rug
- Whats The Largest Rim Size I Can Put On A 1997 Galant?
- 2002 Galant Stereo
- Problem with 2002 A/C
- Transmission?
- how do you install optix neon into fuse so that it turns on with the headlights?
- 00' Galant 4G63T
- 2002 stereo wiring diagram
- 2.4 GDI Idle problem
- Time To Upgrade
- WTB Nose Panel/Header Panel for 1994
- squeaking noise
- Looking for an 89 galant
- Rear Hub Assembly
- 4g63 sohc to dohc
- 2001 Radio Code
- Part Number
- Can't Stop Brake Noice...Help
- '03; Galant, a/c pulley not aligned..squealing
- 98 galant small/big problem
- Help!!! Code P0302 01 Galant
- '98 stereo input question
- just purchased 02' Galant DE
- 92 galant overheating/no fans/burping sound in radiator
- 1992 Galant blowing A/T fuse
- Need Help on 01 Galant Headlight Replacement
- Turbo 7g galant
- Need Help @002 Galant Starting Issues
- Idle Air Control
- Alternator??
- Galant Dash & Tails Lights
- 1990 Galant VR4 white smoke from exhaust
- A/C Switch 1997 ES
- 6 sets of 2 beeps, and ses light.
- '97 Galant Sparkplugs, how to change?
- Where can one get a lens for the headlight?
- Tails Lights & Dash Lights Off & On???
- 1991 galant will not start
- Synthetic Oil....
- Cabin Air Purifier Filter R&R '03 Galant
- 94-98 galant parts for sale
- how much for o2 sensor?
- 92' Rear Right Speaker Works About Half the Time
- Shimmy in front end when accelerating...Help!
- Galant transmission
- Mitsubishi Galant 2003 transmission fluid
- Galant Problem
- need HELP! 2000 MITS GALANT RADIO "OFF" & wrong code.
- Ford guy buying 1st foreign car, what should I know?
- General Maintenance/repair Question, suspension
- Galant 1997 Engine cranks slowly, but it wouldn't start!
- 90 Galant issues
- transmission
- 2005 Timing
- 06 galant GTS gas mileage problems
- 2001 Galant oil light problem
- Money Saving Question?
- check engine light codes
- 99 Galant problem
- Fuel gauge problems.
- My 2001 Galant ES V6
- Door trim assistance '92 galant
- 91' Galant VR-4 for SALE!
- Galant Keyless Entry
- 2000 Galant Horn/keyless entry
- interior:fake wood, need help!
- 1998 galant radio help please..
- 2006 Galant RPM.
- Need help with changing the ATF.
- Problem shifting into 1st
- New 1995 Galant Owner
- Communication CD
- Fuel Pump Problem?
- galant 2.5 v6 auto gear box
- removing dash?
- 98 moon roof?
- 98 front end?
- 2003 Galant LOUD CLICKING!!!
- 1999 galant vrg
- 2003 Galant relays
- 2000 Galant Transmission
- need help distiguishing galants
- 2003 Galant Engine Diagram
- help needed
- Temperature gauge goes wacky?
- KYB GR-2 Shocks with Skunk2 Coilovers FS, CHEAP!!
- Hi my name is eric, and i bought a lemon. Help!
- Mitsubishi Galant 2006 Rims
- Need a trany
- mitsubishi galant stuck in 3rd gear help!!!
- disabling keyless entry horn
- 1999 Powered Mirror Wiring Diagram
- 200 Galant - Failed Emissions Test VA
- My '00 Galant has big problems HELP!!!
- What other engines will replace a 4G37?
- galant 1989 engine??????
- Engine Vibration (4G93)
- Bad Vibrations
- 1994 mitsubishi galant - no brake lights
- 2.4 Galant Viento Lifters
- 02 Galant completely DEAD! HELP!!!
- '91 galant
- valve adjust
- Inquiry
- antenna problem
- 95 Galant S Tranny problems
- mitsubishi galant vr-g 4 sale..URGENT!!!!
- P1400 SES code
- '95 Galant FOR SALE!!!
- GALANT GLSI 1996 2.0l STEERING PROBS
- Mutliple problems with 2001 Mitusbishi Gallant.....
- Is it worth it?
- Automatic transmission fluid change
- 94-98 Auto to Manual Transmission Conversion Instructions
- Removing 99 Galant Center Console
- 2.0 to a 2.4 cold air intake
- 94 Galant Tranny problem
- 2003 Clunking Noise
- Looking for a 6A13TT motor.........
- Carfax for Mitsubishi Galant
- Valve advice needed
- ecm wiring diagram needed for an 01 galant
- PLEASE HELP! Galant is struggeling when accelerating
- Need Help Plz!!!!
- 1991 Eagle 2000 GTX
- Moderator, plz delete Checking Galant ATF level
- Galant Tranny Questions
- Checking Galant ATF level
- The part where the manifold and turbo part turns bright red
- 1990 Galant ABS light on
- Water leaking in 2002 Galant LS
- Galant GSX project
- 2004 Galant alternater
- 02 Galant Drop Kit
- info on the 98 galant 2.4
- galant heat
- 2004 galant help ??
- Install problems with TYC tail lights (2002 Galant)
- A/c
- Help in Replacing Lifters in 97 Galant
- 95 Galant Es Tranmission Probs!! Help!!!!
- Airbag
- Problem on bolt up turbo engine 4g63
- airbag
- front right hub... WTF
- RPM @ 60mph ??????????
- 95 Galant Tranny Problems
- need help
- how the F**k do you take the 6*9 speaker out!
- 2002 Galant Aftermarket Stereo
- timing belt
- chrome gas door????
- 1990 Galant GSX ... wanting turbo, help?
- Spark plug change?
- Help!!!! Not sure if the Mechanics Diagnosis is Legit
- blue light????
- 03 A/C compressor relief valve
- paint code
- bought a 2000 Galant 2.4L
- 2001 Galant overheats on idle
- I need help plzzz....shift solenoid code...???
- No AC
- 2001 Gallant Fuel Filter
- Power windows don't work
- 94 Mits Galant trouble
- can i put a 4g63-t in my non-turbo galant?
- 99 galant DE
- 99 galant engine swap
- 04 Galant Keyless Remote
- 91 Galant Shakes real bad
- 93 Galants Starts but won't go!!
- BRAND NEW 99-02 OEM Radiator for 2.4L
- Evo suspension
- 1974 Galant 1600 'Sport' -carbs
- vibrating dirverside(floor-board)
- My 2002 Galant DE Makes wierd clicking noise from A/C
- 4G67 head on 4G63 N/T motor
- 98 galant headlights
- Check Engine
- 95 Galant starting problems
- Brake Question
- car problems
- hoW do you get....
- Engine noise and vibrations.
- 97 galant start up
- Dead Car
- Galant Suspension
- Its cold and I have no heat
- Galant gone dead
- Galant gone dead
- 1994 6a 12 Galant
- Evo 3 swap?
- 1997 galant anti-theft stock system
- 91 Galant ignition timing adjustment connector????
- mitsubishi galant glsi 2.0 steering probs
- Intrax Springs 94-98
- Programming Keyless Entry 2000 Galant ES
- Reprogram ECU for more Horsepower
- 99 Galant engine kickback
- Wheel Covers
- HELP!! 92 2.0 Liter......Broken Timing Belt?
- FS: 99-03 Galant Rear KYB GR-2 shock
- 94 Galant
- Just a suggestion
- Change your brakes yourself
- Idle, engine shake, rough?
- 01 galant manual trans. conversion
- Galant 94-98 Parts For Sale
- looking at a galant gtz...
- ho ho ho
- Quite interesting car - ´97 VR4
- 2002 Galant Noise?
- Galant GSR 91 electrical Problems
- ALDL Computer Diagnostic Port
- '94 Galant Fuel Mileage ?
- Driver side window
- Transmission problem
- galant VR4 - evo 6.5 conversion
- 99 galant 2.4 es
- 2003 galant body kit. help please.
- Dimming Lights
