View Full Version : Galant
- 2003 Galant relays
- 2000 Galant Transmission
- need help distiguishing galants
- 2003 Galant Engine Diagram
- help needed
- Temperature gauge goes wacky?
- KYB GR-2 Shocks with Skunk2 Coilovers FS, CHEAP!!
- Hi my name is eric, and i bought a lemon. Help!
- Mitsubishi Galant 2006 Rims
- Need a trany
- mitsubishi galant stuck in 3rd gear help!!!
- disabling keyless entry horn
- 1999 Powered Mirror Wiring Diagram
- 200 Galant - Failed Emissions Test VA
- My '00 Galant has big problems HELP!!!
- What other engines will replace a 4G37?
- galant 1989 engine??????
- Engine Vibration (4G93)
- Bad Vibrations
- 1994 mitsubishi galant - no brake lights
- 2.4 Galant Viento Lifters
- 02 Galant completely DEAD! HELP!!!
- '91 galant
- valve adjust
- Inquiry
- antenna problem
- 95 Galant S Tranny problems
- mitsubishi galant vr-g 4 sale..URGENT!!!!
- P1400 SES code
- '95 Galant FOR SALE!!!
- GALANT GLSI 1996 2.0l STEERING PROBS
- Mutliple problems with 2001 Mitusbishi Gallant.....
- Is it worth it?
- Automatic transmission fluid change
- 94-98 Auto to Manual Transmission Conversion Instructions
- Removing 99 Galant Center Console
- 2.0 to a 2.4 cold air intake
- 94 Galant Tranny problem
- 2003 Clunking Noise
- Looking for a 6A13TT motor.........
- Carfax for Mitsubishi Galant
- Valve advice needed
- ecm wiring diagram needed for an 01 galant
- PLEASE HELP! Galant is struggeling when accelerating
- Need Help Plz!!!!
- 1991 Eagle 2000 GTX
- Moderator, plz delete Checking Galant ATF level
- Galant Tranny Questions
- Checking Galant ATF level
- The part where the manifold and turbo part turns bright red
- 1990 Galant ABS light on
- Water leaking in 2002 Galant LS
- Galant GSX project
- 2004 Galant alternater
- 02 Galant Drop Kit
- info on the 98 galant 2.4
- galant heat
- 2004 galant help ??
- Install problems with TYC tail lights (2002 Galant)
- A/c
- Help in Replacing Lifters in 97 Galant
- 95 Galant Es Tranmission Probs!! Help!!!!
- Airbag
- Problem on bolt up turbo engine 4g63
- airbag
- front right hub... WTF
- RPM @ 60mph ??????????
- 95 Galant Tranny Problems
- need help
- how the F**k do you take the 6*9 speaker out!
- 2002 Galant Aftermarket Stereo
- timing belt
- chrome gas door????
- 1990 Galant GSX ... wanting turbo, help?
- Spark plug change?
- Help!!!! Not sure if the Mechanics Diagnosis is Legit
- blue light????
- 03 A/C compressor relief valve
- paint code
- bought a 2000 Galant 2.4L
- 2001 Galant overheats on idle
- I need help plzzz....shift solenoid code...???
- No AC
- 2001 Gallant Fuel Filter
- Power windows don't work
- 94 Mits Galant trouble
- can i put a 4g63-t in my non-turbo galant?
- 99 galant DE
- 99 galant engine swap
- 04 Galant Keyless Remote
- 91 Galant Shakes real bad
- 93 Galants Starts but won't go!!
- BRAND NEW 99-02 OEM Radiator for 2.4L
- Evo suspension
- 1974 Galant 1600 'Sport' -carbs
- vibrating dirverside(floor-board)
- My 2002 Galant DE Makes wierd clicking noise from A/C
- 4G67 head on 4G63 N/T motor
- 98 galant headlights
- Check Engine
- 95 Galant starting problems
- Brake Question
- car problems
- hoW do you get....
- Engine noise and vibrations.
- 97 galant start up
- Dead Car
- Galant Suspension
- Its cold and I have no heat
- Galant gone dead
- Galant gone dead
- 1994 6a 12 Galant
- Evo 3 swap?
- 1997 galant anti-theft stock system
- 91 Galant ignition timing adjustment connector????
- mitsubishi galant glsi 2.0 steering probs
- Intrax Springs 94-98
- Programming Keyless Entry 2000 Galant ES
- Reprogram ECU for more Horsepower
- 99 Galant engine kickback
- Wheel Covers
- HELP!! 92 2.0 Liter......Broken Timing Belt?
- FS: 99-03 Galant Rear KYB GR-2 shock
- 94 Galant
- Just a suggestion
- Change your brakes yourself
- Idle, engine shake, rough?
- 01 galant manual trans. conversion
- Galant 94-98 Parts For Sale
- looking at a galant gtz...
- ho ho ho
- Quite interesting car - ´97 VR4
- 2002 Galant Noise?
- Galant GSR 91 electrical Problems
- ALDL Computer Diagnostic Port
- '94 Galant Fuel Mileage ?
- Driver side window
- Transmission problem
- galant VR4 - evo 6.5 conversion
- 99 galant 2.4 es
- 2003 galant body kit. help please.
- Dimming Lights
- cabin air filter
- Horrible knocking/bumping noise
- I4 vs V6
- headlight and foglight replacement
- 01 Galant Key Transponder Programming
- Changing inner tie rod end, HELP!!
- 97 eclipse electrical problem
- Wanted-4g63 Any Condition
- KRAP!.....No spark with 92 Galant!...Any ideas?
- 2000 Rough idle and tapping sound
- Front Driver and Passenger doors rattle... 01 Galant
- 2001 crash
- Window
- Galant vs Audi A4
- How many miles does ur Galant has?
- Timing`Belt/ Transmission
- 99 galant no heat
- 2002 Galant Timing Belt
- 03 Galant vibrating in floorboard
- 97 Galant Transmission Problem???
- Freeze Plug Problem!! Anyone Please Help..?!
- Engine Ran out of oil too fast!
- GTZ not firing one cilinder
- fuel filter replacement
- radio code
- 98 Galant-Somethings about to die
- 2002 Galant Brake problem
- head gasket help
- Need help interpreting codes
- 95 Galant automatic transmission problems!
- Need help with g/f 95 galant
- 2002 galant keyless entry problem
- Draining Engine Oil on 2003 Galant
- Here's a good one on a '01 Galant
- Fuel Gauge has a mind of it's own
- 1991 Car Stereo wiring
- How do i remove the dash
- 99 Nitrous Equiped Galant 4 Sale.. Heavily Modified Must See!
- 60K tuneup
- 94 galant won't shift into 4th gear/ over drive automatic
- OBD II Scanner Port
- Aluminium or Stainless Piping kit
- More Intake Issues
- help need window
- 05' Aftermarket Radios ??
- Corresct A/c recharge pressure.
- 2003 Galant radio help
- 91 Eagle/Mitsubishi starting problems...
- Main Ecu On A 94 Galant??????
- Check Engine Light sometimes comes on
- Discount OEM parts for Galant?
- overheating
- I need code for my cd player Mitsubishi Galant 2001
- Code
- Intake Install
- New 1996 Galant ES owner. Problems.
- speakers in a 1998
- need Navigator Unit
- Galant's, Any chronic problems? especially the 2002
- my gearbox is noisey
- Help!!! Galant will not start...
- Very Loud Engine noise..what going on!??
- seatbelt
- Galant Horn
- where is tranny ecu on a 94 galant
- rear shocks wanted !
- Squeeking problem
- 1999 Galant + Radio Help
- Service Issues
- Dedication to my 98' Galant
- Water pump for 6A1x family engines
- Speaker Installation
- Left Turn Signal
- Trans. slipping at 109k
- wet passenger carpet
- Window
- WTB vr4 rear cradel and control arms for rear left
- air condition vent knocking
- exhaust leak?
- I wanna hook my galant up!!pleez help
- 1990 Galant power windows... down, but not up..
- The overview of 2005 Mitsubishi Galant
- Help me fix my Galant!
- Advice on buying a 1999 Galant estate please
- car shaking at 65 mph
- vr4 ecu WIRING
- When Brakes pressed - parking lights, brake lights and dash lights come on.
- recharging a/c
- parting out 1997 galant 4 door silver w/ gray interier
- horsepower gain
- For Sale: 98 Mitsubishi Galant ES (Needs some work)
- air conditioning overservice
- Speedometer Fix?
- Galant VR4 #1279 For Sale
- 1999 Galant ES Trans. Out
- motor mounts
- 94 Galant ES
- 4g94 Gdi
- Windscreen Washer - Wiring
- Low revs - poor performance
- wheel bearings
- no dash or tail lights
- Replace serpentine belt 97 Galant
- 2001 V6 Galant timing belt R & R
- Galant Turbo Kits
